Revision as of 19:38, 9 May 2020 by R4002 (Talk | contribs)
[1]
[2]
Overview
Three "bands" in (legal) use, the regular CB band 26.965-27.405 MHz, the UK FM "27/81" band 27.60125-27.99125 MHz and the "UW band" 27.605-27.995 MHz. Church services have been heard outside these band limits, often in the 27.405 MHz to 27.600 MHz portion and below 26.965 MHz (CB channel 1). Some churches use modified "export radios" which, instead of observing the UK FM offset, transmit on the "zeros" instead (i.e., operating on 27.800 MHz instead of 27.80125 MHz). Since the difference between UK FM offset and the zero offset is only 1.25 kHz and FM is used, this usually makes very little to no difference to the (local) receivers the church transmission is meant for. Examples include 27.729 MHz or 27.730 MHz instead of the 27.73125 MHz center frequency. 27.980 MHz AM is included in logs, even though the UK FM band prohibits use of AM mode, this would indicate use of "export" specification radios or multi-country radios set for "RU" or "Russia" mode.
CADS operates on the 80 UK CB channels (standard CB channels 1-40 and UK FM CB channels 1-40) so 26965-27405 and 27601.25-27991.25 FM mode only. UK law defines the 27/81 UK FM CB band as 27.59625 MHz to 27.99625 MHz (5 kHz down from UK CB channel 1 and 5 kHz up from UK CB channel 40, effectively 27.600 MHz to 28.000 MHz). The mid band CEPT/EU band is defined as 26.960 MHz to 27.410 MHz. Ireland's WPAS service operates on two sets of 40 interleaved channels for a total of 80 channels. Although not technically authorized in Ireland, Churches often use the standard 40 "mid band CB" or "CEPT CB" channels as well. Ireland allows use of AM and FM on all 80 channels as part of the WPAS system, while FM is the only mode allowed in the UK. When added to the 40 mid band CB channels 26.965 to 27.405 a total of 120 channels becomes available.
In practice, several churches will share frequencies or use offset channels and/or channels in between the 26.965-27.405 MHz range and the 27.60125-27.99125 MHz / 27.605-27.995 MHz range. Narrow FM mode with 5 kHz deviation (wideband in land mobile two-way radio parlance) is the standard, with some variation in deviation depending on the manufacturer and model of the radio transmitter used and when the radio was manufactured. AM mode is the standard 8 kHz A3E emission 8K00A3E (AM-narrow), although the de facto CB bandwidth is 10 kHz for AM and FM modes.
Frequencies
CB Channel Frequency
Channel 01 26.965 MHz
Channel 02 26.975 MHz
Channel 03 26.985 MHz
Channel 04 27.005 MHz
Channel 05 27.015 MHz
Channel 06 27.025 MHz
Channel 07 27.035 MHz
Channel 08 27.055 MHz
Channel 09 27.065 MHz
Channel 10 27.075 MHz
Channel 11 27.085 MHz
Channel 12 27.105 MHz
Channel 13 27.115 MHz
Channel 14 27.125 MHz
Channel 15 27.135 MHz
Channel 16 27.155 MHz
Channel 17 27.165 MHz
Channel 18 27.185 MHz
Channel 19 27.185 MHz
Channel 20 27.205 MHz
Channel 21 27.215 MHz
Channel 22 27.225 MHz
Channel 23 27.255 MHz
Channel 24 27.235 MHz
Channel 25 27.245 MHz
Channel 26 27.265 MHz
Channel 27 27.275 MHz
Channel 28 27.285 MHz
Channel 29 27.295 MHz
Channel 30 27.305 MHz
Channel 31 27.315 MHz
Channel 32 27.325 MHz
Channel 33 27.335 MHz
Channel 34 27.345 MHz
Channel 35 27.355 MHz
Channel 36 27.365 MHz
Channel 37 27.375 MHz
Channel 38 27.385 MHz
Channel 39 27.395 MHz
Channel 40 27.405 MHz
NEW SECTION TO BE ADDED TO LATER
26.965 MHz to 27.405 MHz amplitude modulated, angle modulated voice sound broadcasting phase modulation or frequency modulation A3E and G3E or F3E26.96 MHz to 27.41 MHz band with the exception of 26.995 MHz 27.045 MHz 27.095 MHz, 27.145 MHz, 27.195 MHz. 27500 kHz 27.5 MHz to 27.6 MHz 27.6 MHz to 27.995 MHz 27.60125 MHz to 27.99125 MHz 27.59625 MHz 27.99625 MHz 27.605 MHz 27.995 MHz
