HF pagers
Revision as of 16:39, 3 July 2020 by R4002 (Talk | contribs)
See also the Remote Control FCC Part 95 Class C Page - Remote Control Radio Service (RCRS), FCC Rules Part 95, Personal Radio Services, Subpart C—Radio Control Radio Service 95.701-95.899, previously 95.201-95.225
Frequency List
Frequency Remarks
26.100 MHz Hospital pagers (Holland) FM mode
26.145 MHz Marine Instruments Radio Buoys
26.150 MHz Marine Instruments Radio Buoys
26.150 MHz Hospital pagers (Holland) FM mode - confirmed active June 2020
26.155 MHz Marine Instruments Radio Buoys
26.160 MHz Marine Instruments Radio Buoys
26.165 MHz Marine Instruments Radio Buoys
26.170 MHz Marine Instruments Radio Buoys
26.175 MHz Marine Instruments Radio Buoys
26.250 MHz Hospital pagers (Holland) FM mode - confirmed active July 2020
26.300 MHz Hospital pagers (Holland) FM mode - confirmed active July 2020
26.350 MHz Hospital pagers (Holland) FM mode - confirmed active July 2020
26.400 MHz Hospital pagers (Holland) FM mode - confirmed active July 2020
26.450 MHz Hospital pagers (Holland) FM mode - confirmed active July 2020
26.500 MHz Paging, heard in Europe, noted use in Holland - FM mode - confirmed active July 2020
26.545 MHz Channel 3A 26.995 MHz "down one band"
26.595 MHz Channel 7A 27.045 MHz "down one band"
26.645 MHz Channel 11A 27.095 MHz "down one band"
26.695 MHz Channel 15A 27.145 MHz "down one band"
26.745 MHz Channel 19A 27.195 MHz "down one band"
26.805 MHz Channel 23 27.255 MHz "down one band"
26.850 MHz Hospital pagers (Holland) FM mode
26.950 MHz Local pager, heard in mainland Europe, transmits "idle" signal even when no pages are being sent - off the air?
26.995 MHz Remote Control Technology Long Range Wireless Switch System LRWSS model # 01217 4-watt FSK (FM) 27MHz transmitter
27.095 MHz European standardized Eurobalise train telemetry system (27.090 MHz - 27.100 MHz)
27.255 MHz RadioShack 7-watt FSK paging transmitter on-site system frequency (legal under Part 95 of FCC rules)
27.255 MHz Linear Controls XT-1 "Xtended Range Wireless" telemetry/control system, 10 watts FSK mode
27.445 MHz Channel 3A 26.995 MHz "up one band"
27.495 MHz Channel 7A 27.045 MHz "up one band"
27.545 MHz Channel 11A 27.095 MHz "up one band"
27.595 MHz Channel 15A 27.145 MHz "up one band"
27.645 MHz Channel 19A 27.195 MHz "up one band"
27.650 MHz Data link/Carrier signal, FM/FSK, possible military, Norfolk, VA - confirmed active again March 2019
27.705 MHz Channel 23 27.255 MHz "up one band"
Keywords:
