VHF UHF logs
THIS IS A PLACEHOLDER
		CSQ is carrier squelch (no tone or code).  Most radios default to CSQ or 67.0 Hz,
		Some radios, in particular pre-programmed FRS handhelds, have specific CTCSS or DCS tones/codes associated with a specific channel/frequency
		"Most ""job site"" handheld radios default to 67.0 Hz, 88.5 Hz or 023 DCS but there are numerous exceptions "
		"FRS units are most likely to use CSQ, although a significant number default to ""code 1"" (67.0 Hz)"											SIGNAL STRENGTH/QUALITY
													Signal QUALITY:
Date	Frequency 	Tone/Code	Channel ID	Remarks - User(s) - presumed or confirmed, signal strength, time of day, association with other logs, etc. 									LOUD
													GOOD
													FAIR - signal strength still strong enough to copy message
													POOR - parts of message unreadable
													UNREADABLE
2/25/2021	151.5125	136.5 Hz		Tower crane control (very busy)
	151.8050	71.9 Hz		Dominion Energy drone pilot - inspecting power lines
	462.7625	88.5 Hz		Night shift tower crane control 									Signal READABILITY
	462.7875	88.5 Hz		Night shift tower crane control 									CLEAR (or CRYSTAL)
	462.8125	88.5 Hz		Night shift tower crane control 									READABLE
	462.8375	88.5 Hz		Night shift tower crane control 									DISTORTED or GARBLED
	467.6375	CSQ	FRS 11	Local school, active during weekdays only 									"FADING - also called ""picket fencing"" - signal strength rapidly changing - generally occurs when two mobile stations are "
	462.7250	432 DCS	FRS 22	Spanish, lots of music and alert/alarm tones on channel
	462.7250	136.5 Hz 	FRS 22	Construction crew, weaker than the 432 DCS guys
	462.6750	606 DCS	FRS 20	Hardware store in-store communications
	462.6125	127.3 Hz	FRS 03	School
	151.9400	74.4 Hz	MURS 3	Truckers, truck to truck CB-like chatter (radios appear to be on wideband mode, receivable on 151.9450 MHz as well)
	462.7125	159.8 Hz	FRS 07	Downtown parking garage or security force
	462.5875	118.8 Hz	FRS 02	Local COVID testing or vaccine testing site
	462.6625	79.7 Hz	FRS 05	UNID users
2/26/2021	467.5625	CSQ	FRS 08	UNID users
	464.5000	88.5 Hz	Brown Dot	IT networking crew checking network and WiFi coverage at VCU Children's Hospital
	464.5000	179.9 Hz	Brown Dot	Hotel staff
	467.9250	218.1 Hz	Blue Star	Tower crane crew
	467.6625	67.0 Hz	FRS 12	Service elevator requests - construction site downtown
	154.4900	67.0 Hz		Highway sign/infrastructure maintenance crews
	151.6260	167.9 Hz	Red Dot	Crane Master - truck to truck
	151.8200	131.8 Hz	MURS 1	Water/sewer pipe inspection/repair crew
	151.8800	131.8 Hz	MURS 2	Water/sewer pipe inspection/repair crew
	461.1125	162 DCS		Construction
	462.9125	192.8 Hz		Construction
	462.8125	136.5 Hz		Construction
	462.8375	136.5 Hz		Construction
	461.1125	67.0 Hz		Hotel
	154.5700	371 DCS	MURS 4	Utility crews, portables
	154.6000	371 DCS	MURS 5	Utility crews, portables
	469.5000	114.8 Hz		Tower crane control (also active on 469.550 [114.8 Hz])
	469.5500	114.8 Hz		Tower crane control
	461.1625	67.0 Hz		Hotel
	451.8000	712 DCS		Tower crane control
	151.8200	67.0 Hz	MURS 1	Hotel/hospitality
	462.7250	136.5 Hz	FRS 22	Catering company - active downtown
3/2/2021	466.3375	156.7 Hz		Spanish language
	464.5000	67.0 Hz	Brown Dot	"""Large amount of trash here"""
	151.5950	85.4 Hz		Construction or maybe heavy materials hauling or other similar activity (simplex, portables?) - no local other licensed users
	464.5000	712 DCS	Brown Dot	Tower crane control
	467.8750	229.1 Hz	Gold Star	Tower crane control
	152.4425	445 DCS		Henrico County Public Schools - Repeater (confirmed user)
	152.3000	023 DCS		Yellow Cab Dispatch only (taxis transmit on 157.5600 MHz)
	461.3625	97.4 Hz		Construction
	464.8250	026 DCS		Tower crane control, mixing with repeater using 179.9 Hz on same frequency
	467.7125	226 DCS	FRS 14	FRS call tones heard, weak
	464.8250	179.9 Hz		Philip Morris - Chesterfield area (repeater - confirmed user)
	462.5625	CSQ	FRS 01	UNID - possibly children playing with radios
	467.9000	82.5 Hz	Red Star	Construction crew, weak
	467.6375	CSQ	FRS 11	School
	457.5250	315 DCS		School - confirmed user
	462.5875	100.0 Hz	FRS 02	Sporadic activity, possible school or similar organization
	464.5500	67.0 Hz	Yellow Dot	Window installation crew?
	152.3000	445 DCS		Henrico County Public Schools - Repeater (confirmed user)
	469.5625	464 DCS		Spanish
	451.8125	703 DCS		Construction crew
	462.6250	127.3 Hz	FRS 18	School, weak
	467.7125	131 DCS	FRS 14	Security
	466.1625	506 DCS		Construction
	466.2625	506 DCS		Construction
	466.0875	506 DCS		Crane control/construction
	466.3125	156.7 Hz		"""check to make sure the kids aren't over by the..."" ""10-4"" "
	462.5875	118.8 Hz	FRS 02	"""we need another wheelchair"""
	464.5500	131.8 Hz	Yellow Dot	"""The DEC guys want..."" "
	464.5500	114 DCS	Yellow Dot	UNID
	466.3625	506 DCS		Crane control
	462.7250	431 DCS	FRS 22	Spanish
	469.5000	506 DCS		Spanish
	469.5500	506 DCS		Spanish
	464.4875	82.5 Hz		Weak
	151.7000	67.0 Hz		Portables, poor signal
	464.5000	67.0 Hz	Brown Dot	Crane control
	154.5050	072 DCS		Henrico County Public Schools - Repeater (confirmed user)
	462.9125	192.8 Hz		Strong, possibly crane control
	462.8125	627 DCS		"""Want to request one now"" ""pull up to the corner"" "
	462.7625	026 DCS		"""Jacket"" "
	467.7125	107.2 Hz	FRS 14	Weak signal,
	464.4875	136.5 Hz		"""814"" ""T K U"" ""copy that"" "
	464.5500	67.0 Hz	Yellow Dot	Crane control
	462.6875	CSQ	FRS 06	"""Just call me if you need me"" ""they're playing tennis and they are really bad"" ""okay buddy"" "
	464.5500	627 DCS	Yellow Dot	"""3/4 bolt needs to be snapped"" ""the bolt is missing"" ""somebody didn't tell them that the bolts need to be snapped"" ""cable walk"" "
	469.5625	123.0 Hz		"""okay 10-4"" ""level gauge"" ""yes sir"""
	464.5125	115 DCS		"""stop there"" (weak) "
	154.4825	152 DCS		Henrico County Public Schools - Repeater (confirmed user)
	469.5500	114.8 Hz		Related to 462.9125 [192.8 Hz] Crane operator chatter, English/Spanish
	469.5125	136.5 Hz		"""came back to get you guys motivated"" "
	462.6250	127.3 Hz	FRS 18	School, possibly multiple users on same frequency/tone
	462.7125	146.2 Hz	FRS 07	Weak, maybe retail or security?
	462.7125	159.8 Hz	FRS 07	Downtown security or parking garage
	451.8000	023 DCS		Construction or concrete contractor
3/5/2021	462.7125	023 DCS	FRS 07	"""polarization"" ""coming your way"""
	154.5700	371 DCS	MURS 4	Utility or road repair crew (portables)
	462.6750	606 DCS	FRS 20	"""brown couch at the front display, he's gonna pick it up tomorrow"""
3/10/2021	462.7250	146.2 Hz	FRS 22	"two mobile units having a long casual conversation, mention of ""Hanover County"""
	154.5700	162.2 Hz	MURS 4	Weak, Spanish language chatter
	154.5700	371 DCS	MURS 4	Construction/utility work
	462.7125	159.8 Hz	FRS 07	"""bring it up to 12"" - downtown parking garage or security "
	462.8625	88.5 Hz		Tower crane control chatter
	464.5000	612 DCS	Brown Dot	Construction
	464.5500	271 DCS	Yellow Dot	Construction
	462.5875	118.8 Hz	FRS 02	"""classroom"" ""wheelchair"" "
	464.5500	627 DCS		Construction, likely same group logged on 3/2/2021
	151.5125	136.5 Hz		Crane control
	151.6250	97.4 Hz	Red Dot	Possibly cemetery or funeral home? portables or mobiles
	467.6625	67.0 Hz	FRS 12	Elevator floor requests, similar to traffic heard on FRS 12 and FRS 7 previously
	457.5250	315 DCS		Local school
	469.5000	047 DCS		Tower crane control
	462.6875	023 DCS	FRS 06	Telecom installation team secondary
	462.7125	023 DCS	FRS 07	Telecom installation team (also heard on FRS 06 and FRS 03)
	462.6125	023 DCS	FRS 03	Telecom installation team secondary
	467.6125	CSQ	FRS 10	"""it already dropped"" ""the end of it"""
	462.5625	023 DCS	FRS 01	"Telecom installation team - ""get that other side of the antenna"" (strong) "
	462.6000	023 DCS	FRS 17	Local school, switched from 467.6375 to this freq
	462.5875	025 DCS	FRS 02	Window installation or repair crew?
	462.6125	67.0 Hz	FRS 03	Weak chatter
	154.4900	67.0 Hz		Highway maintenance or lighting/sign repair crew (numerous previous logging on this frequency/tone)
3/11/2021	462.6625	136.5 Hz	FRS 05	COVID testing or vaccination coordination? possibly
	462.6750	606 DCS	FRS 20	Local hardware or furniture store
	462.6875	141.3 Hz	FRS 06	"Weak, mention of ""waiting room"" "
	462.6750	136.5 Hz	FRS 20	Local school, previously was on  [023 DCS], some minor interference from 462.6750 [606 DCS]
	464.5500	627 DCS	Yellow Dot	Construction, strong signals
	467.6625	67.0 Hz	FRS 12	Service elevator requests (floors being called out)
	464.5000	67.0 Hz	Brown Dot	Spanish language
	462.6875	85.4 Hz	FRS 06	Construction, heard lengths (of something) being read (with Roger beeps)
3/12/2021	467.5625	67.0 Hz	FRS 08	"""my cousin gave me something to wash my car with"" ""okay cool"" "
	464.5000	627 DCS	Brown Dot	Spanish/English - likely construction
	464.5500	627 DCS	Yellow Dot	Spanish/English - likely construction
	469.5500	506 DCS		Spanish chatter
	154.5700	371 DCS	MURS 4	Construction crew, talking about supplies being delivered today
	462.6250	136.5 Hz	FRS 20	Local school, with Roger beeps
	462.6125	77.0 Hz	FRS 03	weak
	467.5625	243 DCS	FRS 08	"""his answers in the form responses are all green so I guess he's in the clear?"" "
	457.5250	315 DCS		Local school, strong signals
	462.8125	88.5 Hz		Crane control or construction
	462.7125	023 DCS	FRS 07	Telecom install/antenna installation
	151.6250	065 DCS	Red Dot	AIRCARE EAGLE Medevac Dispatch
	462.6625	136.5 Hz	FRS 05	UNID user, only caught tail end of transmission
	467.8750	218.1 Hz	Gold Star	Construction
	151.5125	136.5 Hz		Crane control, strong signals as usual
	151.7000	141.3 Hz		Utility or sewer repair crew?
	462.7250	67.0 Hz	FRS 22	"""come in, testing..."" ""okay"" "
	466.2625	445 DCS		construction chatter
	464.8250	026 DCS		Crane control
	464.8250	179.9 Hz		Philip Morris repeater
	462.7125	94.8 Hz	FRS 07	"""Did you get that, Marjorie?"" ""that class up here"" ""so what are you saying, you don't want to take the day off?"""
	462.6000	023 DCS	FRS 17	Local school, possibly primary (see also 462.6750 [136.5 Hz])
	462.6625	136.5 Hz	FRS 05	Construction, possibly a different group from the earlier log on same frequency/tone
	462.7125	146.2 Hz	FRS 07	UNID user, weaker than group using 94.8 Hz
	469.5000	114.8 Hz		Crane control
	469.5625	043 DCS		Weak signal, presumably construction related
	151.8800	114 DCS	MURS 2	"Heard mention of ""classroom"" "
	467.8125	97.4 Hz	"""K"" Dot"	Talking about trash cans?
	462.7125	159.8 Hz	FRS 07	Same group as previously logged on this frequency/tone
	151.8200	67.0 Hz	MURS 1	Hotel or hospitality operations
	154.5150	67.0 Hz		"Mention of ""Mayo Bridge"" (weak) "
	462.6125	127.3 Hz	FRS 03	"""three"" ""okay three more"" "
	467.8500	627 DCS	Silver Star	Spanish language chatter
3/14/2021	462.5750	654 DCS	FRS 16	Construction? weak/sporadic
	462.6000	118.8 Hz 	FRS 17	Unknown language chatter
	151.6250	67.0 Hz	Red Dot	Portables, possibly flagmen directing traffic
	462.6625	79.7 Hz	FRS 05	Talking about exit numbers, likely people caravanning on I-95 or I-64
	467.5875	97.4 Hz	FRS 09	Spanish
	154.5700	123.0 Hz	MURS 4	UNID user
	462.6000	455 DCS	FRS 17	Construction chatter
3/15/2021	462.7625	026 DCS		Talking about camera setups (portables)
	462.7250	136.5 Hz	FRS 22	"""that's it"" ""okay, 32, thanks"" "
	469.5500	114.8 Hz		Tower crane coordination (very active at times)
	154.5700	127.3 Hz	MURS 4	Radio checks, likely local radio op, possibly militia or paramilitary user
	462.7125	159.8 Hz	FRS 07	"""pickup on 9"" ""when you get to 10 can you...."" "
3/16/2021	462.7250	431 DCS	FRS 22	Spanish language, very active at times
	462.6250	127.3 Hz	FRS 18	"""Mrs. Williams"" ""chair"" "
	462.6500	351 DCS	FRS 19	Local school
	462.6875	85.4 Hz	FRS 06	Talking about cars? weak chatter
	461.1625	67.0 Hz		Hotel/hospitality
	467.9250	67.0 Hz 	Blue Star	Catering company?
	451.8125	466 DCS		Construction, background noises heard
	464.5000	179.9 Hz	Brown Dot	Engineering/maintenance coordination
	464.5500	346 DCS	Yellow Dot	Crane control or other construction activity, strong signals
	462.7250	136.5 Hz	FRS 22	Weak, mixing with other users using [431 DCS]
	464.5500	627 DCS	Yellow Dot	"""Is that pipe down there?"" ""Can we take that apart?"" ""The thing is gonna hook...up here..."" "
	464.5500	179.9 Hz	Yellow Dot	Weak, may be related to 464.5000 [179.9 Hz]
	467.8750	79.7 Hz	Gold Star 	Unknown user
	154.5700	371 DCS	MURS 4	Construction or road repair crew (portable radios)
	467.9000	074 DCS	Red Star	"""so that's gonna be...."" ""Roger"" (weak)  "
	467.7125	131 DCS	FRS 14	Weak, was able to decode DCS but UNID traffic
	462.5875	025 DCS	FRS 02	talking about ductwork
	456.8125	85.4 Hz		Construction
	462.6625	136.5 Hz	FRS 05	Parking lot coordination?
	151.9550	94.8 Hz	Purple Dot	Coordinating vehicles
	151.6250	67.0 Hz	Red Dot 	Talking about lighting? possibly film or camera crew (portables)
	462.5625	67.0 Hz	FRS 01	Sounds like kids playing with radios
	462.5625	250.3 Hz	FRS 01	Heard right after the group using 67.0 Hz, different end of transmission tone (Roger Beep) - likely different groups
	462.6250	127.3 Hz	FRS 18	"""Yolanda Barr - what's her number?"" ""get her a radio?"" ""incoming 1040"" "
	462.6125	127.3 Hz	FRS 03	"""Scott Lee, please call 227"" ""I need a sharps container at table 19"" "
	462.5250	114.8 Hz		"""towels"" ""bring them back around"""
	462.5875	71.9 Hz	FRS 02	"""nurse station"" ""number 2"" "
	469.5000	205 DCS		"""how's that looking now?"""
	469.5000	192.8 Hz		"""the panel"" "
	462.7125	159.8 Hz	FRS 07	Same group heard on this frequency/tone almost daily
	466.0875	506 DCS		Very active crane control/construction chatter
	464.5000	179.9 Hz	Brown Dot	Active with very strong signals, testing smoke or heat detectors
	154.4900	67.0 Hz		Highway maintenance or similar work crew contractor
	151.6250	77.0 Hz	Red Dot	Radio checks, very weak
3/17/2021	462.6375	210.7 Hz	FRS 04	"""hello?"" - Roger beeps heard, weak signals around 8:00 AM"
	462.8625	88.5 Hz		Construction, good signals
	464.5500	627 DCS	Yellow Dot	Construction, very active
	462.8375	88.5 Hz		Spanish
	467.5625	77.0 Hz	FRS 08	"""he's pulling up now"" ""okay thank you"" "
	467.7625	131.8 Hz	"""J"" Dot"	"""adjust the..."" ""5 feet"" "
	462.6750	136.5 Hz	FRS 20	School
	151.8200	103.5 Hz	MURS 1	Coordinating delivery of materials (weak)
	467.5625	CSQ	FRS 08	"""back about one-third..."" ""okay"" (weak)"
	464.5500	243 DCS	Yellow Dot	Weak
	464.5000	179.9 Hz	Brown Dot	Engineering? mixing with another user on frequency
	151.6250	167.9 Hz	Red Dot	Crane Master Truck to Truck - confirmed licensed user
	158.4000	167.9 Hz		Crane Master Alternate - confirmed licensed user
	467.5625	CSQ	FRS 08	There appear to be 2 or 3 different groups using same frequency
	464.8250	026 DCS		Crane control - same group as previously monitored
	469.5625	712 DCS		IT or systems engineers, weak
	457.5250	315 DCS		School - portables
	462.7000	131.8 Hz	FRS 21	Spanish
	462.7250	431 DCS	FRS 22	Spanish, same group that was previously monitored
	151.5125	136.5 Hz		The usual crane control traffic
	462.5875	CSQ	FRS 02	Stuck mic (dead air) for 20-30 seconds around 8:30 AM, no CTCSS or DCS
	464.5000	172 DCS	Brown Dot	Crane control mixing with IT or HVAC testing crew or engineering crew using 179.9 Hz
	462.7250	252 DCS	FRS 22	"""Michael Wilson will be coming down also"" "
	467.8750	206.5 Hz	Gold Star	Likely tower crane control or construction traffic
	456.8125	023 DCS		Concrete construction contractor - portable radios
	464.5500	88.5 Hz	Yellow Dot	Window installation crew?
	462.7250	136.5 Hz	FRS 22	"""at 2:00"" ""Ellie has a 1:30 appointment so she's coming on in"""
	462.6000	77.0 Hz 	FRS 17	"""that's Susan, right?"" ""yes ma'am"" "
	154.5150	67.0 Hz		"""another trailer"" ""okay Johnny"" "
	462.6625	79.7 Hz	FRS 05	"""right there at 1636..."" "
	462.6250	127.3 Hz	FRS 18	Requesting assistance at table 3
3/18/2021	467.7625	065 DCS	"""J"" Dot"	"""attention associates: new order"" (automated voice)"
	464.5500	165 DCS	Yellow Dot	Spanish language
	467.8375	263 DCS		Retail
	467.7500	115 DCS		Target Store operations (active)
	154.6000	CSQ 	MURS 5	Retail store, possibly WalMart - note complete lack of CTCSS tone or DCS code usage on a very popular (and license free!) channel / frequency
	154.5700	CSQ	MURS 4	Retail store, possibly WalMart - note complete lack of CTCSS tone or DCS code usage on a very popular (and license free!) channel / frequency
	461.2625	023 DCS		RMC Events
	462.6125	103.5 Hz	FRS 03	Possible retail store user
	467.8750	85.4 Hz	Gold Star	"""associate"" "
	467.7625	97.4 Hz	"""J"" Dot"	possible retail user as well
	462.6625	203.5 Hz	FRS 05	"""Channel 25"" ""copy that"" "
	461.3625	023 DCS		RMC Events (simplex - portable radios)
	467.8750	413 DCS	Gold Star	"""attention associated...curbside pickup...attention assocaties...curbside pickup.."""
	467.8500	331 DCS	Silver Star	Retail
	467.9250	67.0 Hz	Blue Star	"""ring back"" ""price check"" "
	467.8750	411 DCS	Gold Star	Retail, weaker than group using 413DCS
	467.9000	88.5 Hz	Red Star	weak
	467.6375	CSQ	FRS 11	Local school (switched frequencies again)
	464.3250	546 DCS		RMC Events (simplex - portable radios)
3/19/2021	462.6250	127.3 Hz	FRS 18	"""17"" ""can you get them?"" ""she might have an appointment at another time"" ""no, 1980"" - active "
	464.5000	179.9 Hz	Brown Dot	Network or IT engineers testing smoke or heat sensors
	151.5125	136.5 Hz		Crane control, usual users of this frequency/tone
	462.6750	606 DCS	FRS 20	Retail store (portables)
	462.5875	CSQ	FRS 02	Weak, FRS call tones heard
	467.6125	073 DCS	FRS 10	"FRS ""Roger Beeps"" heard"
	469.5000	205 DCS		"""come in, Travis"""
	469.5000	151.4 Hz		Weak, construction (Spanish/English)
	154.5700	88.5 Hz		"""got you on the top"" (??) "
	464.5500	67.0 Hz	Yellow Dot	"""306"" ""alright"" "
	462.6625	88.5 Hz	FRS 05	Tail end of a transmission
	462.7250	67.0 Hz	FRS 22	"""what's up pal?"" ""my stomach...can't...fill....up...."" "
3/22/2021	464.5000	025 DCS	Brown Dot	Spanish
	462.5625	67.0 Hz	FRS 01	"Weak, heard YL talking w/""roger beeps"""
	154.5700	371 DCS	MURS 4	Same group previously monitored on this frequency/tone
	462.7125	159.8 Hz	FRS 07	"""position good"" ""okay you got it on lock"" - presumed same previous user of frequency/tone "
	464.5500	627 DCS	Yellow Dot	"""1010 to base"" ""yeah I got crane time"" ""that's gotta go on level 7"" - very active "
	467.7875	132 DCS		Voice inversion scrambling with FSK/ANI burst at the end of transmissions
	469.5500	114.8 Hz		"""just so you know I'm working right next to your counterweight on your right side"" "
	469.5000	205 DCS		"""hey Lizzie have you seen them pallets?"" "
	151.5125	136.5 Hz		Same group previously monitored on this frequency/tone
	466.0875	506 DCS		Crane control, possibly related to 469.5500 [506 DCS]
	469.5500	205 DCS		Weak, possible construction
	462.6250	127.3 Hz	FRS 18	"""told her that her brother can't be here if he's symptomatic...she's going to call their mom"" (strong signal) "
	159.5625	074 DCS		Henrico County Public Schools - Repeater (confirmed user)
	462.7250	136.5 Hz	FRS 22	"""right, Portland"" (very strong/local signal) "
	466.1875	506 DCS		"""Bring it back up"""
	462.6750	136.5 Hz	FRS 20	Local school or daycare
	464.8250	026 DCS		Crane control (simplex, very active)
	467.9250	100.0 Hz	Blue Star	"""Mikey are you on here or are you on 2?"""
	464.8250	179.9 Hz		Philip Morris (confirmed user with 179.9 Hz tone - wide area repeater)
	462.7625	365 DCS		"""11th Street"" ""direction"" (weak, likely portable radios) "
	457.5250	315 DCS		"""I'm outside of Virginia Hall"" ""okay I'll let Julia know"" ""okay thanks"" "
	462.6375	131.8 Hz	FRS 04	"""220"" ""okay Mrs. Nelson"" ""another appointment"" "
	467.8500	179.9 Hz	Silver Star	Hotel/hospitality
	467.8500	67.0 Hz	Silver Star	Weak, probably construction related
	154.4900	67.0 Hz		Highway maintenance or repair crew
	464.5000	173.8 Hz	Brown Dot	Spanish, heard several two-digit numbers being read
	464.5500	94.8 Hz	Yellow Dot	"""level 13"" ""check"" ""pick up"" (weak) "
	462.6875	141.3 Hz	FRS 06	Weak chatter, UNID users
	462.8125	612 DCS		"""copy"" "
	464.5000	205 DCS	Brown Dot	Construction, possibly alternate channel
	154.5400	023 DCS		Portables, presumed construction comms
	462.9125	192.8 Hz		"""coming in"" ""okay stop"" "
	467.8750	229.1 Hz	Gold Star	"""Roberto you got me on here?"" ""yeah"" ""is it okay if I come up?"" ""yep you're good"""
	462.5625	77.0 Hz	FRS 01	"""swing it to the left...to the left..."""
	462.6125	127.3 Hz	FRS 03	"""Juanita?"" ""okay"""
	467.5625	85.4 Hz	FRS 08	"""number 3...two of them"" ""okay I think they're number 3s"" ""the reducers fit no. 3"
3/23/2021	464.5500	627 DCS	Yellow Dot	Crane operations - primary channel very active
	154.6000	67.0 Hz	MURS 5	"Driver training control - ""next driver please"" ""30 percent brake"" ""no ABS this time"" ""remember this is a..."" ""okay nice easy stop"" etc. (portables, very active around 9:00-9:15am) "
	469.5000	205 DCS		Same group/users monitored using frequency/code previously
3/24/2021	461.0875	179.9 Hz		"""6 more inches...okay tie it off"" ""Beth has joined the party I'm gonna hand you off to her"" "
	457.5750	315 DCS		"""let her know that somebody is stopping for a temperature check"" "
	469.5125	165 DCS		"""1004"" ""another beam"" ""okay that's good"" ""truck"" "
	467.7875	132 DCS		Scrambled transmissions (similar to previously logged activity on this frequency and tone)
	462.5250	114.8 Hz		"""bring the....students..."" (weak, simplex)"
	462.5500	123.0 Hz	FRS 15	"""total..."" "
	151.8050	136.5 Hz		Henrico County Public Schools - Repeater (confirmed user)
	462.6875	146.2 Hz	FRS 06	"""Mr. Baskerville"" "
	467.7625	94.8 Hz	"""J"" Dot"	Weak, heard construction noises in background
	151.7450	74.4 Hz		Henrico County Public Schools - Repeater (confirmed user)
	151.7825	162 DCS		Henrico County Public Schools - Repeater (confirmed user)
	462.6750	606 DCS	FRS 20	Retail store, variable signal strength
	464.5000	67.0 Hz	Brown Dot	"""ten and five...ten and five"" ""okay right...more to the right..."""
	456.8125	732 DCS		"""back down to the second girder"" "
	467.7125	131 DCS	FRS 14	Security or similar group
	151.9100	565 DCS		Henrico County Public Schools - Repeater (confirmed user)
	450.2250	023 DCS		Hotel or hospitality use, portables/simplex
	462.6125	97.4 Hz	FRS 03	Heard FRS call tones
	467.8125	103.5 Hz	"""K"" Dot"	Hotel operations, possibly valet parking operations
	464.5375	85.4 Hz		Hotel/hospitality (weak)
	159.6450	162.2 Hz		Trucking company yard operations/security
	464.5500	103.5 Hz	Yellow Dot	"""Room 611"" ""main trunk"" "
	461.2125	67.0 Hz		"Mention of ""service elevator"" "
	451.8125	023 DCS		Concrete construction contractor - portable radios
	462.7250	67.0 Hz	FRS 22	"Kids playing around on the radio - ""hello!!!"" ""heyyy hello!!!!"" etc. (heard around 4:10-4:15pm)"
	467.6375	CSQ	FRS 11	Local school, same user previously monitored using FRS 11 without any CTCSS or DCS
	467.8750	79.7 Hz	Gold Star	Weak, Spanish language chatter
	469.5500	023 DCS		Concrete construction contractor - portable radios
3/25/2021	467.6625	67.0 Hz	FRS 12	"""Pick up level 12....pick up on 12 please"""
	151.5125	136.5 Hz		Crane control (busy)
	151.5125	411 DCS 		Another user mixing in (weaker than the strong 136.5 Hz signals)
	462.7250	218.1 Hz	FRS 22	Weak, bits and pieces heard breaking squelch
	151.8200	186.2 Hz	MURS 1	"Building maintenance or engineering, heard mention of ""panel 3"" "
	462.6875	146.2 Hz	FRS 06	Likely same user logged yesterday using same frequency/tone
	462.9375	703 DCS		Retail?
	467.7625	065 DCS	"""J"" Dot"	Retail operations
	466.3375	743 DCS		"Talking about tubing, ""when will the delivery truck be here?"""
	464.5500	627 DCS	Yellow Dot	"English/Spanish ""open the gate...Northside"" ""yeah give me a second "
	467.5625	85.4 Hz	FRS 08	"""no, hold the thing like 2 inches from your mouth"" ""okay can you hear me now!?"" ""yes that's like...perfect.."" ""yeah the damn thing is like 6 inches from my mouth now"" ""okay you're good right there then"" ""I guess my tutor isn't going to be able to...I have like no wifi at all, even the mobile hotspot isn't working"""
	467.5625	67.0 Hz	FRS 08	"""what about Jamar?"" ""I guess he's not coming in today"" "
	462.6250	127.3 Hz	FRS 18	School? more than likely two or three different groups on same frequency/tone
	152.9000	205 DCS		Maggie Walker Governor's School (Repeater - confirmed user - note that Richmond Schools use 152.9075 and Henrico Public Schools use 152.8850)
	462.5875	71.9 Hz	FRS 02	"""113"" ""okay you're good 112...."" ""got it"" "
	462.7125	159.8 Hz	FRS 07	"""pick up on 14!"" ""can you hear that?"" ""14 okay"" ""the valves are shut"" ""did you confirm that all our stuff is gone"" ""he's on the other side of the building"" "
	466.3625	156.7 Hz		"""bring that crane back up..."" "
	467.8500	100.0 Hz	Silver Star	Weak signal
	151.7000	141.3 Hz		Utility contractor or similar? Sounds like truck to truck comms
	461.3625	025 DCS		Construction or crane control )
	462.5625	77.0 Hz	FRS 01	Crane control, possibly mixing with another group/user on same channel
	466.0875	205 DCS		Construction
	462.6000	455 DCS	FRS 17	"""Madison is inside"" ""I can't go all the way down to the teacher's lounge"" ""she'll be alright"" ""facilities"""
	154.4900	162.2 Hz		Luck Stone Statewide (confirmed user - also on 151.550, 154.625 and 160.125...also use CB radios extensively)
	464.5500	67.0 Hz	Yellow Dot	"Possibly retail user - ""Did he get that last one...?"" "
	469.5500	114.8 Hz		"""Did Roberto show you that shit?"" ""man, you gotta send it to me"" "
	462.6875	85.4 Hz	FRS 06	"""Kayla Wilson, right?"" ""okay thank you"" ""confused, don't really know what to do"""
	151.8200	103.5 Hz	MURS 1	"""Aurturo"" ""dole"""
	462.5500	123.0 Hz	FRS 15	"""Lynette"" ""she's back up"""
	464.5500	506 DCS	Yellow Dot	"""OK"" (English/Spanish) ""15"" ""okay, good"" "
	462.6375	77.0 Hz	FRS 04	"""thank you Tony"" ""copy that, two more cars"""
	467.9250	206.5 Hz	Blue Star	Spanish language, probably construction based on traffic and signal strength
	154.5700	371 DCS	MURS 4	Previously logged users using same code/frequency
	152.8850	85.4 Hz		Crushed stone or quarry operations
	151.5800	026 DCS		AdvanSix Resins and Chemicals (repeater - also use 150.8300 [131.8 Hz], 150.8600 [023 DCS], 150.9650 [025 DCS], 152.3075 [074 DCS], 152.9225 [74.4 Hz], 153.2300 [071 DCS] and numerous others
	467.8125	88.5 Hz	"""K"" Dot"	Construction or materials delivery coordination
	469.5500	023 DCS		Miguel and another UNID station, probably construction-related
	154.5700	88.5 Hz	MURS 4	"""okay I got you on channel 15"" "
	467.5625	065 DCS	FRS 08	Weak, presumed construction use
	466.3125	156.7 Hz		"""B-2!"" ""B-2!"" "
3/26/2021	467.8500	627 DCS	Silver Star	Spanish language, strong signals at 8:20am
	467.6625	67.0 Hz	FRS 12	Elevator requests, as previously logged
	466.1625	156.7 Hz		"""Should be here any second..."""
	151.8800	103.5 Hz	MURS 2	Caught tail end of transmission, UNID user but same CTCSS as previously logged on other MURS channels
	462.6625	79.7 Hz	FRS 05	"""they have one scheduled for 9:00 I think"""
	466.3125	156.7 Hz		Likely same users monitored on this frequency/tone before
	462.5250	114.8 Hz		"""Ms. Lee"" "
	469.5500	506 DCS		"""did you copy that?"" (Spanish language)"
	469.5500	205 DCS		Crane control/construction
	464.5000	103.5 Hz	Brown Dot	Portables
	462.5625	67.0 Hz	FRS 01	"""yes, number 2"" ""at the right time"" ""okay"" (Spanish language)"
	154.5700	371 DCS	MURS 4	Active, Spanish and English
	462.5625	67.0 Hz	FRS 01	"""I have Kirby Wilson...they have an 8:30...in the parking lot"" (different user)"
	462.5750	165.5 Hz	FRS 16	"""okay go ahead"" (strong signal)"
	469.5000	205 DCS		"""going down"" ""I got 'em Troy"""
	462.7125	159.8 Hz	FRS 07	"""back down...back down"" (likely same user previously logged on frequency/tone)"
	464.5500	627 DCS	Yellow Dot	"""do we have the plans? I need a copy of those files"" "
	151.6250	67.0 Hz	Red Dot	"""back down towards..."""
	462.6750	136.5 Hz	FRS 20	"School, FRS ""Roger Beeps"" heard, sporadic signal "
	151.8200	103.5 Hz	MURS 1	"""full up"" ""day or night...obviously day or night"" ""that one over there"" "
	462.6875	141.3 Hz	FRS 06	"""back by the other cones"""
	467.5625	85.4 Hz	FRS 08	"Weak, FRS ""Roger Beeps"" heard, previously monitored frequency/tone"
	466.0625	032 DCS		Construction
	462.7875	162 DCS		Weak chatter, with interference from paging/data on 462.8000
	462.6125	77.0 Hz	FRS 04	"Spanish language chatter (with FRS ""Roger Beeps"")"
3/27/2021	466.0625	023 DCS		Construction
	466.2875	606 DCS		Construction
	466.3125	156.7 Hz		Same group previously monitored using the 466.xxxx freqs with 156.7 Hz
	461.2875	192.8 Hz		Construction/crane control
	462.6125	127.3 Hz	FRS 03	"""Can you hear me on the walkie talkie?"" - kids playing with radios? "
	151.7600	136.5 Hz		Construction or crane control, alternate channel?
	450.2250	023 DCS		"""that's at 10:30"" ""right, table 14"" "
	462.5875	CSQ	FRS 02	"""he got his money can do anything he want with it!"" "
	469.5500	205 DCS		"""Wake up, man!"""
	154.4900	67.0 Hz		"Talking about signs, heard mention of ""exit 78"" "
	151.8200	103.5 Hz	MURS 1	Weak, likely same users as previously logged on MURS using 103.5 Hz CTCSS
	466.0875	506 DCS		Crane control, strong signals
	461.1625	506 DCS		Construction
	462.6500	143 DCS	FRS 19	"""right there"" ""okay"" (FRS ""Roger Beeps"" heard) "
	464.5500	627 DCS	Yellow Dot	Construction/crane control
	462.6250	127.3 Hz	FRS 18	Construction noises heard in background
	151.6250	77.0 Hz	Red Dot	"""Back it down"" "
	469.5500	114.8 Hz		Heard other radio chatter in background, appears to be coordination for multiple cranes
	462.7875	025 DCS		"Mention of ""fixture"" "
	464.8250	026 DCS		Crane control, very busy
	154.5700	131.8 Hz	MURS 4	Utility or sewer contractor?
	154.5150	82.5 Hz		Portables
	469.5000	205 DCS		Construction
	462.5625	CSQ	FRS 01	Spanish chatter, possibly tower crane related (no tone/code in use)
	467.8750	229.1 Hz	Gold Star	Crane control and related chatter
	464.5000	627 DCS	Brown Dot	Appears to be secondary to 464.5500 [627 DCS]
	461.1625	67.0 Hz		"""service request"" (strong signal) "
	151.6250	065 DCS	Red Dot	AIRCARE EAGLE working FLIGHTCOM
	462.5625	67.0 Hz	FRS 01	"""Brock"" ""okay"" "
	467.6625	67.0 Hz	FRS 12	"""Pickup on 14, pickup on 14 please"" - elevator requests "
	462.7250	67.0 Hz	FRS 22	Kids playing on radios, call/alert tones heard at 1:45pm
	154.5275	136.5 Hz		Crane control, probably alternate frequency
	461.2125	67.0 Hz		"""down...the brake!"" "
	464.5500	179.9 Hz	Yellow Dot	Engineers, testing alarm or sensors
	467.8750	69.3 Hz	Gold Star	Tail end of transmission
	464.5500	047 DCS	Yellow Dot	"""number 3 crane"" ""try channel 4"""
	462.6875	141.3 Hz	FRS 06	Talking about appointment times - rapidly fading in and out
	151.9550	82.5 Hz	Purple Dot	Weak signal, likely portables
	462.6250	127.3 Hz	FRS 18	Spanish language, sporadic signals
3/28/2021	464.5500	67.0 Hz	Yellow Dot	Tail-end of transmission, UNID user
	462.7000	118.8 Hz	FRS 21	"""Did you want some hot sauce?"" ""We're making some uh...chips sauce"" ""okay"" "
	462.6750	172 DCS	FRS 20	"FRS ""Roger Beep"" heard, weak but readable "
	151.5125	136.5 Hz		Same users previously monitored - crane control
	462.6125	127.3 Hz	FRS 03	"""Mikey"" (unsure if this is same group as previously monitored - this is a very popular frequency/tone combination) "
	467.9250	67.0 Hz	Blue Star	Security or facilities maintenance?
	151.8200	67.0 Hz	MURS 1	"""We have some...up here"" possibly hotel/hospitality users"
	467.6875	67.0 Hz	FRS 13	"""she isn't ready yet"""
	462.5625	183.5 Hz	FRS 01	"""Patrick...for his second shot...get him ready to come over"""
	464.5500	162.2 Hz	Yellow Dot	"""in the next couple hours"""
	462.6125	97.4 Hz	FRS 03	radio checks
	467.7500	115 DCS		Retail (Target store frequency/code combination)
	467.7625	67.0 Hz	"""J"" Dot"	Retail, unknown user
	451.8000	506 DCS		Gas station?
	462.5625	71.9 Hz	FRS 01	"""Juan, did you copy that?"" "
	467.8750	100.0 Hz	Gold Star	Retail - Kroger (confirmed user of frequency/tone)
	467.9250	100.0 Hz	Blue Star	Retail - Kroger (confirmed user of frequency/tone)
3/29/2021	466.0875	506 DCS		Construction
	466.3125	156.7 Hz		Construction, English/Spanish
	467.5875	032 DCS	FRS 09	Spanish language
	462.6625	67.0 Hz	FRS 05	"""He back over there!"" ""I see you!"" (kids on FRS radios)"
	451.8125	162.2 Hz		"""Base to Rover 2"" "
	151.5125	136.5 Hz		Crane control (usual users on this frequency/tone)
	464.8250	026 DCS		Crane control, mixing with 179.9 Hz users
	467.6625	67.0 Hz	FRS 12	"Elevator requests ""pick up 13 please? going down"" etc."
	464.5500	627 DCS	Yellow Dot	Busy - construction/crane operator
	151.6250	67.0 Hz	Red Dot	"""Excellent, thank you"""
	467.5625	CSQ	FRS 08	"""two more cars coming in"" ""okay"" (no CTCSS or DCS decoded)"
	466.1375	156.7 Hz		Construction?
	469.5500	114.8 Hz		Crane coordination, busy
	462.6875	85.4 Hz	FRS 06	"""Mike 8"" ""one eight"" (several different stations heard, poor to unreadable signal) "
	466.3125	023 DCS		Extreme interference from 156.7 Hz group on same frequency
	462.5500	123.0 Hz	FRS 15	"""Johnson"" "
	462.4250	103.5 Hz		"""I'm right here..."" (weak, YL voices)"
	462.8125	627 DCS		"""bring the cones"" ""no, second cone..."""
	462.5625	67.0 Hz	FRS 01	"Strong signal, no ""Roger Beep"""
	462.6750	136.5 Hz	FRS 20	Local(ish) school
	154.5700	371 DCS	MURS 4	Likely same user previously logged using frequency/code combo
	467.8500	94.8 Hz	Silver Star 	Construction or maybe building maintenance crew
	467.9000	131 DCS	Red Star	"""Parking lot is getting full....we have COVID cars lining in...."""
	462.5875	118.8 Hz	FRS 02	"""anyone working with..."" ""need to notify..."""
	469.2625	186.2 Hz		Retail store
	462.8625	88.5 Hz		Spanish language, construction noises in background
	151.9400	77.0 Hz	MURS 3	Retail, weak signal (portables)
	462.7125	159.8 Hz	FRS 07	Previously heard user of this frequency/tone
	154.4900	67.0 Hz		Highway maintenance crew (sign work)
	462.6250	127.3 Hz	FRS 18	"""Hey Maria"" and ""Hey Linda"" heard around 9:45 AM"
	467.6125	100.0 Hz	FRS 10	Radio checks, no response heard
	462.6375	131.8 Hz	FRS 04	"""Ms. Jenkins can you hear me?"" "
	467.8500	131 DCS		"""attention associates"" "
	462.9125	192.8 Hz		"""drink Red Bull and then they did it!"" - general chatter (construction workers, very similar to traffic heard on 469.5500 [114.8 Hz])"
	154.6000	023 DCS	MURS 5	"""156 is 6-D"" ""and 155 is at 10-D"" ""twenty more feet"" (fair-weak but readable) - active around 12:00 noon/12:15pm"
	151.6250	025 DCS	Red Dot	"""I don't know if we just wanna wait on those"""
	464.5500	67.0 Hz	Yellow Dot	"""push it a little more...a little more Mike"""
	456.8125	712 DCS		Construction or crane operations
	469.9500	203.5 Hz		Retail ops (simplex)
	464.5625	165.5 Hz		"""back...200"" ""10-4"" "
	461.1125	67.0 Hz		"""room 502"" ""request order"" "
	462.6125	97.4 Hz	FRS 03	"Spanish, sporadic signal w/ FRS ""Roger Beeps"""
	466.0625	506 DCS		Construction
	462.8125	123.0 Hz		"""101 to base"" "
	462.7250	136.5 Hz	FRS 22	School, or day care? coordinating lunch schedules
	462.7125	146.2 Hz	FRS 07	Presumed construction comms, mixing in with 159.8 Hz CTCSS user on frequency
	461.1625	67.0 Hz		Security or facilities maintenance
	462.5625	250.3 Hz	FRS 01	"Mic key ups, FRS ""Roger Beep"" heard"
	464.5000	103.5 Hz	Brown Dot	Hotel/hospitality
	462.6500	131.8 Hz	FRS 19	Sounds like kids talking to parents on FRS units
	462.8250	162.2 Hz		Security or engineering
	151.9550	94.8 Hz	Purple Dot	Film crew?
	461.0875	023 DCS		Cement contractor?
	462.1250	69.3 Hz		Spanish language, probably construction related
	457.5250	315 DCS		Local school (simplex/legit 457.xxxx Business Radio Service frequency)
	462.6875	141.3 Hz	FRS 06	"""We have an extra long line"" ""okay"" "
	467.6625	CSQ 	FRS 11	"Local school - coordinating students being picked up, etc. - ""checking in Channel 11"""
	469.5500	77.0 Hz		Weak
	151.8200	103.5 Hz	MURS 1	Utility contractor or similar
	461.0375	91.5 Hz		Hotel or hospitality
	461.3625	243 DCS		"""stop for a minute"""
	464.5000	627 DCS	Brown Dot	"""Miguel"" - possibly alternate channel for 464.5500 and others "
	467.5875	127.3 Hz	FRS 09	"Mention of ""circuit 3"" "
	462.8875	88.5 Hz		Tower crane control or coordination
	467.9000	047 DCS	Red Star	Dan and Miles, UNID
	462.7875	025 DCS		Seems to be same group as previously monitored
3/30/2021	464.5000	179.9 Hz	Brown Dot	"""my man...bring the boom back there...back there..."""
	466.0875	506 DCS		Crane control/construction (very active at times)
	462.7250	431 DCS	FRS 22	"Spanish language chatter with ""Roger Beeps"", call tones, etc. "
	464.8250	026 DCS		Crane control, also very active at points
	462.6625	136.5 Hz	FRS 05	"""Hello?"" ""the line is...."" "
	464.5500	79.7 Hz	Yellow Dot	Weak/poor readability
	151.8200	103.5 Hz	MURS 1	Likely same users previously monitored using MURS with 103.5 Hz
	457.5250	315 DCS		"""Yellow cone"" "
	462.7125	159.8 Hz	FRS 07	Building security, parking deck security or similer
	469.5500	179.9 Hz		Construction, sporadic signal
	467.9250	67.0 Hz	Blue Star	Spanish language, fair/weak signal
	462.7250	146.2 Hz	FRS 22	"""The only time you would use TAC 3 is when you want to avoid interruption of transfer of the encryption key"" - likely GMRS repeater (heard at 7:48 AM)"
	464.5500	627 DCS	Yellow Dot	Likely same users previously monitored using same tone
	462.5875	67.0 Hz	FRS 02	"""ahhhh!"""
	461.0875	67.0 Hz		Building maintenance or facilities management - fair signal
	464.5000	146.2 Hz	Brown Dot	Spanish language chatter
	462.5625	167.9 Hz	FRS 01	Caught tail end of transmission
	151.6250	223 DCS	Red Dot 	Heard what sounded like alarms going off in background, weak/poor readability signal
	462.7125	023 DCS	FRS 07	RF engineering crew?
	151.5125	136.5 Hz		Crane control, usual users of frequency/tone
	467.5625	CSQ	FRS 08	"""Copy you on 8"" ""okay channel 8"" "
	462.6750	606 DCS	FRS 20	Retail store, poor signal
	462.6125	127.3 Hz	FRS 03	"""next car, blue car..."""
	461.0625	179.9 Hz		Weak, poor to unreadable (voice traffic)
	467.8875	025 DCS		"""lighting"" ""checks"" ""404"" "
	469.5500	114.8 Hz		Usual users (see previous logs for this frequency/tone)
	467.6625	67.0 Hz	FRS 12	Elevator floor/pickup requests - same as logged numerous times on this frequency/tone
	462.7625	192.8 Hz		Construction or similar chatter
	462.6750	136.5 Hz	FRS 20	Local (sort of) school - sometimes suffering from interference from the retail users using 462.6750 [606 DCS]
	159.5025	156 DCS 		Richmond City Public Schools (confirmed user)
	462.5625	CSQ	FRS 01	"""Mom?"" ""yes I can hear you"" (kids playing on the radio, including singing, etc)"
	462.6875	141.3 Hz	FRS 06	"""311, 233"" "
	464.5000	346 DCS	Brown Dot	"""can you pull forward?"" ""okay keep pulling"""
	462.5875	77.0 Hz	FRS 02	Different group, mixing with group using 97.4 Hz CTCSS
	462.6125	023 DCS	FRS 03	"""okay, back 3"" ""they're just like tap-welded right on the inside of the leg of the apex.....yeah they get in the way and shit"""
	462.5875	97.4 Hz	FRS 02	Crane control (monitored around 4:15/4:20pm)
	462.5250	114.8 Hz		"""have them come to the back door now"""
	462.5625	67.0 Hz	FRS 01	Different group (not kids playing on the radio)
3/31/2021	467.9000	131 DCS	Red Star	"""there's a gentleman in...."" ""can you help him?"""
	467.8500	331 DCS	Silver Star	"""new order"" ""attention associates"""
	467.9000	205 DCS	Red Star	"""Loss prevention"" ""manager"""
	467.7625	107.2 Hz	"""J"" Dot"	"""meet the manager..."" ""number 8122"" "
	467.7500	115 DCS		"""back of house"""
	467.9250	67.0 Hz	Blue Star	"""leave away"" (in English), then Spanish language "
	467.9250	155 DCS	Blue Star	Retail? heavy interference from other users on frequency
	462.5875	118.8 Hz	FRS 02	"""Tom, did you copy that?"" "
	467.7750	072 DCS		Retail, Target confirmed use of frequency/tone combination
	469.5500	114.8 Hz		Same group previously monitored on this frequency/tone
	467.5625	026 DCS	FRS 08	"""1310"" ""how did you measure that?"" "
	467.5875	91.5 Hz	FRS 09	"""did you get that?"" ""thank you!"" ( ""can somebody bring Aiden's tablet outside please?"" - sounds like a school (fair signal, with FRS ""Roger Beeps"")"
	462.6375	131.8 Hz	FRS 04	tail-end of a transmission heard, just enough to decode CTCSS/PL tone 131.8 Hz
	464.5500	627 DCS	Yellow Dot	"""Mark it...based off our base grid line..."""
	152.9075	743 DCS		Richmond City Public Schools (confirmed user)
	462.6875	141.3 Hz	FRS 06	"""ticket for Moreno..."" "
	466.3125	156.7 Hz		"""back to..."""
	462.6750	606 DCS	FRS 20	"""Roger Roger!"" ""oh yeah, it is"" (unknown if same group usually heard on this frequency/code)"
	151.5125	136.5 Hz		Crane control - busy (usual users heard here)
	467.8500	627 DCS	Silver Star	Alternate channel for guys usually using 464.550 / 464.500 with 627 DCS
	462.7125	159.8 Hz	FRS 07	"""I'm working on the one down in the basement!"" - same group usually heard using 159.8 Hz CTCSS on FRS 7/462.7125 MHz "
	469.5500	205 DCS		Crane control or other construction
	462.6125	127.3 Hz	FRS 03	"""hold it...hold it....you got it"""
	153.0125	743 DCS		Richmond City Public Schools (confirmed user)
	469.5000	205 DCS		"""I'm on my way down to the platform, coming from 17..."" (loud signal at 11:40 AM)"
	151.6250	67.0 Hz	Red Dot	"""Channel 2"" ""baking"" "
	467.6625	67.0 Hz	FRS 12	Elevator requests - same as previously monitored, very active at points
	466.3375	023 DCS		"""walking on this..."""
	461.2875	131.8 Hz		Spanish, poor/weak signal
	159.8700	127.3 Hz		Trucking company, yard control/dispatch (heard CB chatter in background)
	462.5625	114.8 Hz	FRS 01	School or day care facility
	154.4900	67.0 Hz		"""I think the rain is gonna start soon..."""
	466.2625	205 DCS		Tail end of signal heard just after 12:00 noon
	151.8200	103.5 Hz	MURS 1	Likely same group previously monitored using 103.5 Hz on MURS
	467.5625	243 DCS	FRS 08	Talking about questionnaires
	152.9075	074 DCS		Richmond City Public Schools (confirmed user)
	450.2250	023 DCS		UNID users heard
	158.4000	123.0 Hz		"""124 South..."" (sounded like an address) - heard around 7:30pm"
	467.6625	CSQ	FRS 12	"""maybe it's something happening over at campus or something I'm not sure what though"" (NOT the usual elevator request traffic, no CTCSS or DCS tone/code)"
	467.8875	110.9 Hz		"Mention of ""Brook Road"" - portables (likely)"
	456.8125	423 DCS		Possibly retail?
4/1/2021	151.6250	065 DCS	Red Dot	AIRCARE EAGLE doing radio checks at 8:04 AM with FLIGHTCOM (again at 8:14 AM for a dispatched call)
	467.5625	91.5 Hz	FRS 08	"""...truck..."" (FRS ""Roger Beeps"") heard - poor copy at 8:06 AM"
	462.7250	146.2 Hz	FRS 22	Repeater (GMRS operators)
	151.6250	167.9 Hz	Red Dot	Crane Master Truck-to-Truck primary coordination (confirmed user frequency/tone)
	464.5500	627 DCS	Yellow Dot	Crane control/construction
	462.6375	67.0 Hz	FRS 04	"""car..."" ""sedan coming your way"" "
	464.5000	103.5 Hz	Brown Dot	Weak signal, presumed hotel/hospitality user based on previous logs
	451.8000	023 DCS		Construction work site coordination - concrete contractor
	467.6625	67.0 Hz	FRS 12	Usual daytime user of frequency/tone (elevator call/floor requests)
	466.2625	023 DCS		"""Chookie...just FYI...we're starting our last one..."""
	462.5500	123.0 Hz	FRS 15	"Poor copy, presumed portables (no ""Roger Beeps"" heard)"
	154.5275	136.5 Hz		Crane control - possibly alternate to 151.5125 [136.5 Hz]
	462.6875	141.3 Hz	FRS 06	"COVID vaccination site coordination """"""9:30"""" """"370172"""" """"Smith, 9:20"""" - active ""here for his second shot""  "
	462.6875	85.4 Hz	FRS 06	"""he's coming back in now"" (similar signal strength to group using 141.3 Hz - frequency very active this morning with both groups)"
	158.4075	065 DCS		FLIGHTCOM working AIRCARE EAGLE radio checks, test alert tones and other tests - alternate channel?
	462.6625	136.5 Hz	FRS 05	"""Juan"" and another UNID station "
	462.4250	103.5 Hz		School? (weak, portables)
	462.7125	159.8 Hz	FRS 07	Usual user of this frequency/tone
	151.8200	103.5 Hz	MURS 1	Active around 9:20AM-9:25AM (presumed same users as before)
	464.5000	627 DCS	Brown Dot	Same users monitored using 627 DCS on this and other frequencies
	462.6500	632 DCS	FRS 19	"""How do you copy me?"" (at 9:31AM with FRS Roger Beep) "
	154.5700	151.4 Hz	MURS 4	Weak to fair signals - crane control communications
	464.8250	026 DCS		Usual activity, sometimes with interference from Philip Morris repeater (using 179.9 Hz CTCSS)
	464.5000	179.9 Hz	Brown Dot	"""I gotta bring it back up here"" "
	469.2625	67.0 Hz		UNID users, presumed simplex
	451.8125	423 DCS		Weak signal, was able to decode DCS
	158.4000	167.9 Hz		Likely Crane Master (alternate channel, primary is 151.625 [167.9 Hz])
	466.3625	156.7 Hz		"""main..."" and some Spanish language heard (around 10:45AM)"
	462.6125	97.4 Hz	FRS 03	Presumed school or day care, fair/weak
	466.3125	156.7 Hz		Construction chatter
	461.0375	023 DCS		Spanish, poor signal, poor copy
	462.9125	192.8 Hz		Crane control, active at/around 12:10-12:12PM
	462.6625	67.0 Hz	FRS 05	"""9 foot"" ""okay"" "
	461.1875	67.0 Hz		Spanish language, fair to poor signals
	462.5625	67.0 Hz	FRS 01	"Chatter regarding cars, talking about schedules (no ""Roger Beeps"")"
	462.7875	88.5 Hz		Tail end of a signal, no voice heard...but CTCSS tone decodes
	464.5000	67.0 Hz	Brown Dot	"""get close to the..."" ""it's not coming up there so good"""
	462.8875	612 DCS		Voice inversion scrambling
	152.3975	503 DCS		Repeater, distant...presumably school system
	469.9500	203.5 Hz		Hotel or hospitality (portables/simplex)
	462.7250	136.5 Hz	FRS 22	Local school, fair to poor signal
	462.6250	156 DCS	FRS 18	"""channel..."" ""no, go all the way to the bottom"" "
	466.0875	506 DCS		Construction, likely tower crane control
	464.5500	67.0 Hz	Yellow Dot	Crane control or similar construction comms
	462.8125	192.8 Hz		Spanish language, weak signal
	466.3125	023 DCS 		Mixing with users using 156.7 Hz
	462.7625	025 DCS		"""It's starting to rain!"" "
	467.8500	627 DCS	Silver Star	Construction, alternate channel (previously logged)
	462.6625	136.5 Hz	FRS 05	Weak signal heard at 2:52PM
	467.8875	110.9 Hz		Weak voice activity mid-afternoon
	469.5000	205 DCS		"""come back up here"" "
	462.7000	155 DCS	FRS 21	Tail end of a fair-to-strong signal
	469.5500	114.8 Hz		General informal chatter about cranes, other companies, very active at points
	467.6375	CSQ 	FRS 11	Local school with FRS Roger Beeps...no CTCSS/DCS tone, previously monitored same user on this frequency
	462.5625	67.0 Hz	FRS 01	"Different group than previously monitored this morning on same frequency/tone (using FRS ""Roger Beeps"")"
	467.6375	073 DCS	FRS 10	"""Wait...uh...hold on a second"""
	462.6125	023 DCS	FRS 03	RF installation crew, previously heard on other FRS channels with 023 DCS
	464.5500	179.9 Hz	Yellow Dot	Active early evening with what sounded like engineering or maintenance workers
	451.8125	023 DCS		Construction work site coordination - concrete contractor
	469.5625	225.7 Hz		"""James, do you copy?"""
	151.6250	047 DCS	Red Dot	"""slow down, you're talking way too fast"""
	462.6250	127.3 Hz	FRS 18	"""Shannon"" and another YL, weak signal "
	467.8625	612 DCS		"""back it up a bit"" (poor copy)"
4/2/2021	466.3375	023 DCS		Spanish language - construction comms (monitored around 6:45-7:30AM)
	464.5000	179.9 Hz	Brown Dot 	"""4:30, okay?"" ""yes sir"" (in Spanish, heard at 7:02AM) - active early morning "
	462.9125	192.8 Hz		"""Jesus Christ..."" ""we're about the same spot as yesterday, a little bit closer to the west on level 6"" -  chatter/construction comms "
	462.7125	159.8 Hz	FRS 07	Usual users of this frequency/tone combination - first heard around 7:15AM
	464.8250	026 DCS		Crane control - usual users of this frequency/code
	466.3125	156.7 Hz		Spanish language - construction comms (monitored around 6:45-7:30AM)
	462.6000	146.2 Hz	FRS 17	Crane control, presumed
	464.5500	627 DCS		"""He just came back up here"" - usual users "
	462.4250	103.5 Hz		"""I said how the hell did you measure it like that?!!"" (portables, sounds like typical construction site chatter)"
	462.8625	88.5 Hz		Spanish language, presumed construction users - very active this morning
	462.5250	114.8 Hz		School or daycare user
	462.6750	67.0 Hz	FRS 20	"FRS ""Roger Beeps"" heard, children talking in background - presumed school or daycare "
	469.5000	205 DCS		"""what floor are you on?"" ""11"" ""alright we're coming down now"" "
	151.8200	103.5 Hz	MURS 1	"""behind the uh...behind the generators"" (8:27 AM)"
	464.5500	627 DCS	Yellow Dot	"""we're gonna do everything and then we're gonna shit up"" "
	469.5500	114.8 Hz		Usual users as heard on this frequency/tone
	462.6750	77.0 Hz	FRS 20	"""that's inappropriate!"" - different style ""Roger Beep"" heard (compared to the one heard on 462.6750 users using 67.0 Hz CTCSS)"
	462.6875	141.3 Hz	FRS 06	COVID vaccination center coordination - fair to good signal strength
	462.6375	114.8 Hz	FRS 04	Spanish language chatter, presumed construction-related
	462.5750	165.5 Hz	FRS 16	"""I'm down here on the ground...behind you"" (heard at 1:25/1:26PM)"
	464.5500	67.0 Hz	Yellow Dot	Weak signal, caught a second (enough to decode CTCSS and that's about it)
	154.5700	88.5 Hz	MURS 4	Spanish language, poor copy
	462.6125	127.3 Hz	FRS 03	"""this is logistics, does somebody need something at table 16?"" ""yes, can I get some large gloves please?"" "
	462.9250	025 DCS		Hotel or hospitality - possibly catering company
	462.5875	025 DCS 	FRS 02	"""suggestion"" ""section 3"" ""call back"" (poor/fair signal) "
	151.6250	065 DCS	Red Dot	AIRCARE EAGLE being dispatched by FLIGHTCOM at 3:35 (flight number 222)
	462.6875	073 DCS	FRS 06	"""hello you..."" ""hello Judy??!!"" (kids playing on radios - 5-10 seconds of dead air, heard at 4:41/4:42PM)"
	469.5375	196.6 Hz		"""4.6"" ""tank 2"" "
	151.8200	186.2 Hz	MURS 1	" ""Operations to floor wardens"" (weak/fair signal) "
	462.6750	606 DCS	FRS 20	"""manager"" ""floor manager"" (presumed retail users, previously monitored)"
	154.5700	043 DCS	MURS 4	Crane control
	462.5625	94.8 Hz	FRS 01	"""I've been working a lot harder than that"" (no ""Roger Beeps"") "
4/3/2021	462.6875	67.0 Hz	FRS 06	"""I'm bringing it back up now"" ""thank you"" (with FRS ""Roger Beeps"")"
	466.2625	023 DCS		"""pull on 3!"" ""pull on 3"" "
	154.4900	67.0 Hz		Sign or road maintenance crew
	151.9550	127.3 Hz	Purple Dot	Very weak signal, presumed portables
	462.6125	CSQ	FRS 03	Crane control (weak signal - no CTCSS or DCS decoded)
	462.6250	127.3 Hz	FRS 18	"""going..."" ""man..."" (very poor copy)"
	462.6750	606 DCS	FRS 20	Retail (likely same user previously monitored using 606 DCS on 462.6750 MHz)
	154.5700	67.0 Hz	MURS 4	"""with several"" ""dollars"" "
4/4/2021	154.6000	88.5 Hz	MURS 5	"""TAC13"" - ambulance service using MURS as a chat / ""back channel"" - informal CB-like banter about various topics - heard reference to ""Battalion 403"" and another 3-digit unit ID"
	464.5500	627 DCS	Yellow Dot	Same users normally heard with 627 DCS
4/5/2021	151.6250	065 DCS	Red Dot	FLIGHTCOM working AIRCARE EAGLE with radio checks, alternating tone alarm tests at 7:48 AM
	464.5500	627 DCS	Yellow Dot	Usual users of this frequency/code combination
	467.7125	67.0 Hz	FRS 14	"Spanish language chatter with FRS ""Roger Beeps"""
	462.9125	192.8 Hz		Crane control and informal chatter
	462.6000	241.8 Hz	FRS 17	"Tail-end of FRS transmission heard with FRS-style ""Roger Beep"""
	151.5125	136.5 Hz		Crane operators saying good morning and checking in at 7:51 AM
	467.5625	88.5 Hz	FRS 08	"Weak/poor signal, heard FRS ""Roger Beeps"" "
	469.5500	114.8 Hz		"Crane control and general chatter, heard reference to ""El Guapo"""
	151.8200	103.5 Hz	MURS 1	"""well...I ain't worried about all that!"" (at 10:43AM) good copy, presumed same users as previously logged using 103.5 Hz on MURS "
	462.7000	155 DCS 	FRS 21	COVID vaccination or similar site coordination (previously monitored on numerous other FRS frequencies)
	462.7125	159.8 Hz	FRS 07	Same users as previously monitored (downtown)
	467.6625	67.0 Hz	FRS 12	Elevator requests, previously logged on 467.6625 67.0 Hz like nearly daily use
	466.0875	506 DCS		Poor copy, presumed construction users based on previous logs
	464.5000	82.5 Hz	Brown Dot 	Local school? Weak/poor copy
	457.5250	315 DCS		Local school (confirmed user via numerous leggings)
	467.8750	229.1 Hz	Gold Star	Construction - Spanish and English heard, good copy at 10:57 AM - mix of informal chat, similar to 469.5500 [114.8 Hz], 462.9125 [192.8 Hz], etc.
	151.6250	167.9 Hz	Red Dot	Crane Master truck to truck (confirmed user) - coordinating trucks, directions, loud signal at 11:00 AM with CB-like truck-to-truck comms
	462.6750	606 DCS	FRS 20	Retail use - see other logs for 462.6750 [606 DCS]
	462.5625	CSQ	FRS 01	"""hey Mike?"" ""yeah, go ahead"" (distinctive FRS Roger Beeps heard, no CTCSS or DCS tone/code) "
	466.3125	156.7 Hz		"""whoa!"" ""okay back..."" ""back..."""
	151.8800	026 DCS	MURS 2	Very weak, unreadable voice but was able to decode DCS at 11:36 AM
	466.2375	506 DCS		Construction chatter, heard construction noises in background
	467.5875	CSQ	FRS 09	"Informal chatter, kids playing on radios (with FRS ""Roger Beep"", no CTCSS or DCS decoded) "
	158.4075	065 DCS		LIFE EVAC 1 working AIRCARE EAGLE and FLIGHTCOM (control station) at 11:41AM
	462.6250	127.3 Hz	FRS 18	Local school or day care - poor/fair signal
4/6/2021	467.8500	627 DCS 	Silver Star	Secondary channel for users normally using 464.550 [627 DCS] or 464.500 [627 DCS]
	464.8250	026 DCS		Crane control (simplex)
	462.5250	114.8 Hz		Local school, poor copy
	464.5500	627 DCS	Yellow Dot	Construction/crane control (appears to be primary)
	154.4900	67.0 Hz		Road repair/maintenance
	462.6250	127.3 Hz	FRS 18	Local school or daycare
	151.8200	103.5 Hz	MURS 1	Contractors - active during morning and throughout the day (sporadically)
	467.6375	CSQ	FRS 11	Local school - same user previously monitored using this and other FRS channels
	462.7250	136.5 Hz	FRS 22	"""bring back"" sounded like ""catheter"" - poor copy"
	464.5000	263 DCS	Brown Dot	Spanish language, presumed construction
	462.6875	071 DCS	FRS 06	"""Baltimore is about five and a half hours away"" ""okay so we're gonna stop..."" (group caravanning up I-95)"
	151.5125	136.5 Hz		Usual users heard on this frequency/tone
	462.5625	CSQ	FRS 01	Kids playing on walkie-talkies
	466.0625	79.7 Hz		Tower crane control
	154.5700	371 DCS	MURS 4	Road construction - usual users previously heard using this DCS code
	151.6250	065 DCS 	Red Dot	AIRCARE EAGLE working FLIGHTCOM COMMUNICATIONS
	462.9125	192.8 Hz		Crane control, usual users heard on this frequency/tone
	154.5700	67.0 Hz	MURS 4	Poor copy, unable to ID users
	158.4075	065 DCS		FLIGHTCOM working AIRCARE EAGLE on alternate channel (primary is 151.6250 [065 DCS])
	451.8125	632 DCS		"""Lane 3"" ""the second car"" ""check that ticket"" "
4/7/2021	466.3125	156.7 Hz		Tower crane control/construction
	462.1250	69.3 Hz		Hospitality or catering, heavy interference from Jefferson Hotel DMR system on same frequency
	464.8250	032 DCS		Tower crane control/construction
	467.6625	67.0 Hz	FRS 12	Usual users - service elevator floor requests
	154.5700	88.5 Hz	MURS 4	Tail-end of a strong transmission, no voice traffic heard....UNID user at 7:47AM
	462.9125	192.8 Hz		Tower crane control/construction
	462.5750	654 DCS	FRS 16	"""Operations to Command"" ""table 6"" - possibly COVID vaccination site operations"
	467.8500	627 DCS	Silver Star	Spanish language - active early morning starting around 7:50AM
	464.5500	627 DCS	Yellow Dot	"""We got 3..."" ""base to unit 3"" ""okay level 15"" - likely previously monitored users"
	151.5125	136.5 Hz		Tower crane control/construction - the usual users of 151.5125 [136.5 Hz] and 154.5275 [136.5 Hz]
	462.6750	243 DCS	FRS 20	"""channel 3"" ""bring Johnny back up"" ""basket to the right"" "
	469.5500	114.8 Hz		Crane coordination mixed with informal CB-like chatter...can hear other channels active in the background
	462.7125	159.8 Hz	FRS 07	"""go slower a little bit"" (at 7:55AM) - same users monitored basically daily on this frequency/tone "
	151.6250	065 DCS	Red Dot	FLIGHTCOM doing test tones/radio check at 8:02AM - working AIRCARE EAGLE
	467.5875	91.5 Hz	FRS 09	"""...Broad Street..."" (poor signal) "
	462.8375	88.5 Hz		Tower crane/construction chatter (English/Spanish)
	464.5000	627 DCS	Brown Dot	Construction users
	466.0875	506 DCS		"""ahh, yes"" (in Spanish)"
	462.5500	123.0 Hz	FRS 15	"""Mrs. Johnson"" ""main room"" - presumed school or similar facility "
	461.0875	023 DCS		Construction
	451.8125	506 DCS		Retail operations? - portables
	456.8125	205 DCS		Construction
	154.5275	136.5 Hz		Tower crane control/construction - the usual users of 151.5125 [136.5 Hz] and 154.5275 [136.5 Hz]
	467.8125	103.5 Hz	"""K"" Dot"	Hotel/hospitality
	469.5500	506 DCS		Spanish - talking about measurements, interference from other users on frequency
	158.4000	167.9 Hz		Crane Master alternate/tactical channel (primary is 151.6250 [167.9 Hz])
	467.6375	CSQ	FRS 11	"Local school, FRS portables (with ""Roger Beeps"") - confirmed use of carrier squelch / CSQ [no tone or code] - heard ""Channel 11"" ID over the air clearly "
	461.1625	67.0 Hz		Hotel or hospitality user
	462.8250	162.2 Hz		Security or building maintenance? Poor signal
	151.9550	127.3 Hz	Purple Dot	Weak/poor signal, presumed portables
	469.5500	712 DCS		Spanish language, heavy interference from 114.8 Hz and 506 DCS activity on same frequency
	469.5000	506 DCS		Tower crane control/construction
	151.8200	131.8 Hz	MURS 1	Utility contractor?
	464.5625	85.4 Hz		Hotel/hospitality
	154.5700	371 DCS	MURS 4	Road repair or similar? varying signal strengths at 8:30-8:35 AM
	456.8125	506 DCS		"""order 44"" ""pump 5"" - portables (weak signal)"
	450.2250	023 DCS		School or day care - sporadic signals
	464.5500	82.5 Hz	Yellow Dot	"""...opinion..."" ""186.22"" ""tank"" - very sporadic signals with heavy interference from group using 627 DCS"
	466.3625	192.8 Hz		"""level 9"" ""cage"" ""drop...down 10 feet"" - sounds like crane control "
	462.5625	114.8 Hz	FRS 01	"""Logistics"" ""okay that's doable"" "
	158.4000	123.0 Hz		"""Regional"""
	462.6750	606 DCS	FRS 20	Retail store or similar user - presumed to be same users previously monitored using this frequency/DCS code combination
	464.5000	103.5 Hz	Brown Dot	"Heard mention of ""bread"" at 12:42PM, could be related to 467.8125 [103.5 Hz]"
	464.5000	192.8 Hz	Brown Dot	"""get your counts right!"" ""right there!"" (poor copy) "
	467.8750	229.1 Hz	Gold Star	Tower crane control/construction
	467.8500	192.8 Hz	Silver Star	Tower crane control/construction
	462.8625	88.5 Hz		Crane control
4/8/2021	151.5125	136.5 Hz		Crane control - usual users heard on this frequency/tone
	462.8625	88.5 Hz		Tower crane coordination - very active at points, same group heard on other active crane control frequencies
	154.4900	67.0 Hz		Early morning chatter - coordinating where to get breakfast, etc.
	462.7125	159.8 Hz	FRS 07	Usual group heard on this frequency/tone combination
	469.5500	343 DCS		Weak/poor signal heard around 7:50AM/7:51AM
	464.5000	432 DCS	Brown Dot	Coordination deliveries, truck arrival times, general construction chatter
	469.5000	315 DCS		"""87"" other two-digit numbers (in Spanish)"
	469.5000	506 DCS		Spanish language, much stronger than group using 343 DCS
	467.6625	67.0 Hz	FRS 12	"Elevator floor requests - ""pickup on 7, going down"" ""pickup on 12, going down..."" etc "
	464.5500	67.0 Hz	Yellow Dot	Caught last few seconds of a transmission
	464.5500	432 DCS	Yellow Dot	Tower crane control/construction
	461.2125	67.0 Hz		Hotel room cleaning or maintenance
	467.9000	229.1 Hz	Red Star	Construction, fair signal
	469.5500	114.8 Hz		Tower crane coordination - very active at points, same group heard on other active crane control frequencies
	462.5875	118.8 Hz	FRS 02	Weak, active just after 8:00AM
	464.5500	627 DCS	Yellow Dot	Tower crane control/construction - very active at points
	469.5000	205 DCS		Tower crane control/construction
	461.0375	023 DCS		Weak, likely construction comms
	462.7125	179.9 Hz	FRS 07	"Construction chatter, with FRS ""Roger Beeps"""
	462.9125	192.8 Hz		Tower crane coordination - very active at points, same group heard on other active crane control frequencies
	467.6625	115 DCS	FRS 12	Security or maintenance? poor copy
	158.4000	123.0 Hz		"""didn't get that, repeat"" "
	466.0875	506 DCS		Tower crane control/construction
	462.6625	79.7 Hz	FRS 05	Weak, possibly group caravanning up/down I-95
	152.3000	023 DCS		Yellow Cab - Dispatcher (taxis transmit on 157.5600 [023 DCS])
	462.5625	CSQ	FRS 01	"""right..."" ""back it up...back...okay you're good"" ""hang onto the...""  (with FRS ""Roger Beeps"") "
	456.8125	445 DCS		Construction
	464.8250	026 DCS		Tower crane control/construction
	467.6375	CSQ	FRS 11	Local school, same as previously logged
	464.5500	205 DCS	Yellow Dot	Construction, sporadic signal
	158.4075	065 DCS		LIFE EVAC 4 working FLIGHTCOM at 11:45AM
	462.6875	141.3 Hz	FRS 06	"""copy"" - ""second dose"" - COVID vaccination site operations  "
	467.7625	229.1 Hz	"""J"" Dot"	Informal chatter, sounded like same guys from 467.8750 [229.1 Hz]
	467.7125	131 DCS	FRS 14	Weak/poor signal - possibly security
	462.5625	67.0 Hz	FRS 01	Spanish language at 11:50AM
	462.6125	127.3 Hz	FRS 03	"""this is Mary, how can I help you?"""
	456.5125	632 DCS		"""cycle set"" ""copy that"" (portables, simplex)"
	467.8500	94.8 Hz	Silver Star	Spanish, heard construction noises in background
	462.7250	136.5 Hz	FRS 22	Spanish language chatter, fair/poor signal
	462.6375	032 DCS	FRS 04	"Heard a couple FRS-style ""Roger Beeps"" "
	462.6125	67.0 Hz	FRS 03	"""the line..."" ""they're all tangled up in the peg"""
	462.6625	79.7 Hz	FRS 05	"""yellow"""
	464.5625	85.4 Hz		Weak signal, presumed related to 464.5375 [85.4 Hz]
	462.7125	146.2 Hz	FRS 07	Possibly also related to COVID vaccination site
	154.5700	371 DCS	MURS 4	Repair crew, likely same users previously monitored on MURS with 371 DCS code
	462.6750	606 DCS	FRS 20	Local store, presumed same group previously monitored using this frequency/DCS code combination
4/9/2021	464.8250	026 DCS		Tower crane control/construction
	154.5700	371 DCS	MURS 4	"""man, the fucking HVAC pipe is right there..."" ""this is the only one that has it..."" at 8:08 AM"
	469.5500	315 DCS		Tower crane control/construction
	151.5125	136.5 Hz		Crane control (usual users heard on 151.5125 and 154.5275 with 136.5 Hz CTCSS)
	467.8750	67.0 Hz	Gold Star	"""on.."" (weak signal, poor copy) "
	469.5000	315 DCS		"""pipe...right there"" ""okay you're good...yeah I think you're all clear"" (construction noises heard in background "
	469.5500	506 DCS		"""okay it's good"" ""to the right"" (in Spanish) "
	462.7250	136.5 Hz	FRS 22	Poor signal, possible school or daycare type group/user
	462.5625	77.0 Hz	FRS 01	"""okay come on!"" (in Spanish) with unique ""Roger Beeps"" "
	469.5500	114.8 Hz		Tower crane coordination and informal chatter, very active at points
	464.5000	506 DCS	Brown Dot	English/Spanish, presumed construction use
	464.5000	432 DCS	Brown Dot	"""we're only...we're only going to the 3rd floor so I don't think it will be a problem"" "
	154.5150	67.0 Hz		"""900 pounds"" ""aluminum"" ""712.5"" - portables"
	462.5875	025 DCS	FRS 02	"Construction users, FRS ""Roger Beeps"""
	461.0375	67.0 Hz		Weak, suffering extreme interference from GRTC DMR system on 461.0250 MHz
	462.6875	85.4 Hz	FRS 06	"""we already went there"" ""before"" (FRS ""Roger Beeps"") - first heard around 8:30AM"
	457.7625	136.5 Hz		"""it's supposed to be on the ticket"" ""oh okay"" "
	466.3375	025 DCS		Construction
	467.6625	67.0 Hz	FRS 12	Elevator requests, usual traffic heard on 467.6625 with 67.0 Hz CTCSS (FRS channel 12)
	462.6875	141.3 Hz	FRS 06	COVID-19 vaccination site operations
	464.5500	67.0 Hz	Yellow Dot	"Radio checks at 8:35 AM - ""can anybody hear me?"" ""hello?"" "
	466.1875	156.7 Hz		Tower crane control/construction
	462.5750	243 DCS	FRS 16	"""okay that's gonna be exit 76..."" - discussion about driving, presumed to be a group driving up or down 95"
	151.8200	103.5 Hz	MURS 1	Presumed same users as previously monitored (general construction or contractor chatter)
	464.5500	77.0 Hz	Yellow Dot	"""I don't want to fire them...I just want them to know to get off the fucking phone"""
	462.6750	606 DCS	FRS 20	Local store/retail (portables, same user previously monitored)
	464.5500	743 DCS	Yellow Dot	"""lunch truck"" "
	151.9550	67.0 Hz	Purple Dot	"""level 6"""
	462.6625	136.5 Hz	FRS 05	"""check table 2"" (sporadic signals)"
	158.4075	065 DCS		LIFE EVAC 4 working FLIGHTCOM at 12:11PM
	462.5875	97.4 Hz	FRS 02	"""can we take a lunch break now?"" ""yeah, yeah I'm good with that"" "
	464.5000	131.8 Hz	Brown Dot	Weak signal around noon/12:15PM
	151.6250	065 DCS	Red Dot	AIRCARE EAGLE dispatched by FLIGHTCOM
	461.1875	023 DCS		Concrete construction contractor - portable radios
	462.7250	67.0 Hz	FRS 22	Sounds like kids playing on the radio, fair to poor signal strength
	466.0625	023 DCS		Weak signal, likely construction chatter
	464.5000	179.9 Hz	Brown Dot	Maintenance or engineering
	456.8125	141.3 Hz		Road repair or utility company? portables
	462.6625	67.0 Hz	FRS 05	"""back up...keep going..."" (construction sounds heard in background)"
	154.5275	136.5 Hz		Crane control (usual users heard on 151.5125 and 154.5275 with 136.5 Hz CTCSS)
	154.6000	67.0 Hz	MURS 5	"""rebar"" ""piping"" (fair to weak signal) "
	461.0875	023 DCS		Talking about cement trucks and delivery times
	151.8200	114 DCS	MURS 1	"""Ms. Jones, do you have your walkie talkie on?"" "
	464.5000	88.5 Hz	Brown Dot	"""once you get to that point...go ahead and bag it"""
	462.7125	159.8 Hz	FRS 07	Same users usually heard on this frequency/tons
	151.8200	67.0 Hz	MURS 1	"""32"" ""U2"" ""okay 32"" (YL speaker, heard at 4:48PM)"
	462.5500	123.0 Hz	FRS 15	"""four o'clock!"" ""come up here early you know what I mean?"" "
	151.6250	167.9 Hz	Red Dot	"""you said it does shift better or it doesn't?"" ""well, it's had a rough life"" ""let's try it again"" - Crane Master confirmed user "
4/10/2021	154.5700	88.5 Hz	MURS 4	"""channel 15"" ""copy you loud and clear"" "
	466.3125	156.7 Hz		"""yeah we're up here"" ""the only chargers we have for the radios are on B-3, there ain't nothing on B-4 is there?"" "
	154.4900	67.0 Hz		"""yeah we're gonna get coffee first"" ""no at Wawa"" "
	151.6250	065 DCS	Red Dot	FLIGHTCOM doing radio checks and test tones at 7:15AM
	462.7250	141.3 Hz	FRS 22	"""do you copy?"" ""yeah I got you"" - not the usual 136.5 Hz tone, strong signal with 141.3 Hz"
	464.5500	627 DCS	Yellow Dot	"""hey Justin!"" - usual users on this frequency/tone"
	462.6750	606 DCS	FRS 20	Retail store, very active at points
	154.5700	151.4 Hz	MURS 4	Tail end of a transmission caught, nothing else heard
	151.5050	167.9 Hz		Crane Master secondary or backup use
	462.5875	97.4 Hz	FRS 02	"""cable up...cable up..."" - crane control/tower crane control "
	467.6625	67.0 Hz	FRS 12	Elevator floor requests, typical users heard basically daily
	462.8625	88.5 Hz		Tower crane control/construction
	462.6250	127.3 Hz	FRS 18	Daycare? Poor signal
	467.5625	186.2 Hz	FRS 08	Very weak signal, unable to make out any voice
4/11/2021	469.5000	205 DCS		Tower crane control/construction
	462.5875	97.4 Hz	FRS 02	Tower crane control/construction - active mid-morning
	464.8250	026 DCS		Crane control - same users usually heard...interference from Philip Morris repeater using 179.9 Hz CTCSS tone on same frequency noted
	462.6625	225 DCS	FRS 05	"Unmodulated carrier (""dead air"") for 2-3 seconds "
	469.5125	464 DCS		"""Shuttle"" (weak to fair signal)"
	467.6125	97.4 Hz	FRS 10	Tower crane control, possibly same group monitored using 97.4 Hz on 462.5875 MHz/FRS 02
	158.4075	065 DCS		LIFE EVAC 4 working FLIGHTCOM Medevac dispatch at 2:04PM
4/16/2021	464.5500	94.8 Hz	Yellow Dot	Spanish language chatter, presumed construction
	462.5875	118.8 Hz	FRS 02	Familiar traffic with this frequency and CTCSS tone combination, sporadic signals
	462.6250	127.3 Hz	FRS 18	Dead air for 3-4 seconds
	464.5500	627 DCS	Yellow Dot	Same group normally heard on this frequency/code combination
	467.5625	306 DCS	FRS 08	"Poor signal, FRS call tones or ""alert tones"" heard "
	467.9000	612 DCS	Red Star	Construction
	151.6250	167.9 Hz	Red Dot	Crane Master truck to truck (primary channel - confirmed user)
	469.5500	205 DCS		Tower crane control/construction
	467.6125	CSQ	FRS 10	Truck to truck chatter, sounds like a chase car talking to a truck or similar type traffic
	466.3125	156.7 Hz		"Construction, Spanish with some English words, including ""playbook"" and ""cradle"" "
	464.5000	88.5 Hz	Brown Dot	"""Contact"" ""close 14"" ""copy that""  "
	462.7000	100.0 Hz	FRS 21	Construction or similar, fair signal
	462.8125	627 DCS		"""236"" ""238"" - presumed construction, same signal strength as the group heard using 627 DCS on 464.550 and other frequencies "
	467.5875	67.0 Hz	FRS 09	Kids playing with FRS radios, FRS-style Roger Beeps heard...fair to weak signals
	462.5750	632 DCS	FRS 16	"""not available right now...."" (female speaker)"
	462.5875	97.4 Hz	FRS 02	Crane control, same users previously heard using 97.4 Hz CTCSS tone on FRS Ch.2 462.5875
	467.8875	110.9 Hz		"""rebar""""truckload"" "
	464.4875	79.7 Hz		"""Basket"" ""B-1"" ""main floor"""
	467.6375	CSQ	FRS 11	Local school - strong signals
	462.7250	223 DCS	FRS 22	Weak UNID chatter, likely kids playing with FRS walkie talkies
	154.5700	67.0 Hz	MURS 4	Luis and Juanito, presumed construction or utility contractor
	151.5050	167.9 Hz		Crane control - presumed Crane Master based on CTCSS tone
	462.6500	351 DCS	FRS 19	"""okay I got you on channel 13, can you hear me?"" ""10-4"" "
	158.4075	065 DCS		LIFE EVAC 3 and LIFE EVAC 4 (Medevac helicopters) heard
	462.5750	654 DCS	FRS 16	"""brake!"" ""okay next exit is gonna be..."""
	461.3625	74.4 Hz		Hotel or hospitality
4/17/2021	151.8200	103.5 Hz	MURS 1	Construction or utility contractor
	467.8500	100.0 Hz	Silver Star	Retail of some sort, portables (weak)
	462.5625	CSQ	FRS 01	"""it's not in the refrigerator"" - no CTCSS or DCS tone/code used "
	469.5625	712 DCS		Poor copy, unable to ID voice
	464.5500	243 DCS 	Yellow Dot	Construction or possible tower crane control use
	462.7250	141.3 Hz	FRS 22	"""yeah I got you"" "
	456.8125	074 DCS		"""pump 2"" ""customer request"" "
	464.5500	346 DCS	Yellow Dot	Parking or security - Temporary Repeater - very strong
	462.7125	97.4 Hz	FRS 07	"""back"" ""three"" ""check the tray"" "
	464.5000	67.0 Hz	Brown Dot	Very active
	467.6375	CSQ	FRS 11	"""look at his dumbass struggling"" ""right there"" - very informal chatter "
	462.6375	114.8 Hz	FRS 04	"""I'm sorry bro"" ""sector 2"" ""copy that"" "
	462.8250	162.2 Hz		Parking lot attendants or traffic control
	464.5500	67.0 Hz	Yellow Dot	Weak, simplex
	154.5700	162.2 Hz	MURS 4	Coordination parking, directing traffic, similar to chatter heard on FRS 11 - 467.6375 CSQ
	467.6625	115 DCS	FRS 12	Parking coordination
	469.5125	411 DCS 		"""On Location Van 2 to Base"" ""two more pickups"" "
	462.7125	77.0 Hz	FRS 07	Kids playing on radios, FRS call tones and Roger beeps heard
	467.5625	243 DCS	FRS 08	"""over here....we dry...."" (strong signal at 6:34PM, no ""Roger Beeps"" heard)  "
	462.5875	025 DCS	FRS 02	"""that red truck"" ""blue car"" - presumed parking coordination chatter "
	158.4075	065 DCS		FLIGHTCOM working LIFE EVAC 3
	462.6375	74.4 Hz	FRS 04	Traffic control / flaggers or flag men
	462.5875	67.0 Hz	FRS 02	"""do not get going until I tell you to - please confirm!"" "
	462.7250	250.3 Hz	FRS 22	"Tail end of a transmission heard with FRS style ""Roger Beep"" "
	467.8750	229.1 Hz	Gold Star	Tower crane coordination
	462.6375	127.3 Hz	FRS 03	"""good job today thank you"" "
	467.9250	131.8 Hz	Blue Star	Poor copy, unable to ID voice
	467.8875	162 DCS		"""lot B"" ""number of spots left after the trailers"" "
	462.6500	241.8 Hz	FRS 19	Similar to FRS traffic monitored earlier today - parking lot attendants
	450.2250	023 DCS		Parking lot attendants or traffic control
4/18/2021	467.6875	CSQ	FRS 13	Parking lot comms, likely associated with RIR NASCAR race (see logs from 04/17/21 as well)
	466.2625	205 DCS		Construction
	466.3125	156.7 Hz		Crane control/construction
	467.8125	107.2 Hz	"""K"" Dot"	"""check"" ""unit 2, radio check..."" (at 8:13AM)"
	462.5500	123.0 Hz	FRS 15	"""back in a second!"" ""do you have your radio on?"" ""okay second vehicle"" "
	464.4875	026 DCS		"""level 2"" "
	462.6625	67.0 Hz 	FRS 05	General informal chatter, sporadic weak to fair signal w/FRS call tones
	462.5500	67.0 Hz	FRS 15	"""okay you're good...go to the next one"" "
	158.4075	065 DCS		FLIGHTCOM dispatch (bleeding over onto 158.4000)
	462.6250	127.3 Hz	FRS 18	"""cart"" ""take it to the back section"" ""Linda"""
	450.2250	023 DCS		Security? portables, weak
	467.7625	464 DCS	"""J"" Dot"	Construction
	467.9250	67.0 Hz	Blue Star	Weak, only able to decode CTCSS tone
	469.5125	114 DCS		"""shuttle van"" ""back by the cones"" (portables, fair to poor signal)"
	154.5700	67.0 Hz	MURS 4	"""okay I have you loud and clear"" "
	461.1875	67.0 Hz		"""okay"" (fair signal)"
	462.6000	118.8 Hz	FRS 17	"""car 3 to car 1"" ""okay we're looking  for 78"" - presumed car to car comms on I-95 "
	461.2125	67.0 Hz		"""I'll go check the [unreadable] right now"" - possibly related to traffic heard on 461.1875 MHz 67.0 Hz "
	462.5625	136.5 Hz	FRS 01	FRS call tones heard, verified correct CTCSS
	151.9550	179.9 Hz	Purple Dot	Construction-related chatter
	467.8375	346 DCS		"""gate 3"" ""Laburnum Ave"" "
	158.4000	023 DCS		"Radio checks, reference to ""Channel 16"" - sounds like portables "
	467.8750	67.0 Hz	Gold Star	Spanish language
	462.6125	74.4 Hz	FRS 03	Traffic control, parking lot attendants or flaggers?
	462.5750	023 DCS	FRS 16	"""section 2"" ""link 4"" - talking about ""dish angles"" and antenna mounting - likely RF engineers "
	451.8125	346 DCS		"""do you copy Echo 3 on direct?"" ""negative copy switching back to 1"" (presumed alternate channel for RIR event with the 464.550  [346 DCS] repeater being primary)"
	469.9500	203.5 Hz		Parking lot attendants - simplex
	462.5875	67.0 Hz	FRS 02	"""cars"" - sounds like more traffic control type chatter "
	154.5150	67.0 Hz		Spanish language chatter
	467.7750	072 DCS		Retail - portables - likely Target (Target channel 2, radio plan A)
	464.5500	162.2 Hz	Yellow Dot	Likely retail
	467.7500	115 DCS		Retail - portables - likely Target (Target channel 1, radio plan A)
	451.8125	203.5 Hz		Camera direction, TV production chatter
	467.9000	174 DCS	Red Star	Weak, portables
	461.3625	172 DCS		Retail, possibly a grocery store
	462.9125	065 DCS		"heard reference to ""loss prevention"""
	467.9000	94.8 Hz	Red Star	Likely also retail
	462.5875	118.8 Hz	FRS 02	"""they have a 1:45 appointment for an oil change I believe"""
	456.8125	023 DCS		Construction materials contractor or similar
	467.7625	107.2 Hz	"""J"" Dot"	Weak, suffering from strong interference from data/voice on 467.750 MHz and voice on 467.775 MHz
	467.8500	100.0 Hz	Silver Star	Retail/security
	467.9000	225.7 Hz	Red Star	"""50 pound bag"" ""customer"""
	464.8250	516 DCS		Presumed also related to NASCAR race (temporary repeater) - possibly RMC Events
	462.5750	251 DCS	FRS 16	UNID business user
	461.3625	546 DCS		Parking/traffic control
	467.9000	131 DCS	Red Star	Retail/security or loss prevention
	154.5700	CSQ	MURS 4	Retail/security - likely WalMart or Sam's Club going by the fact that they're using carrier squelch (CSQ) on MURS
	461.2625	023 DCS		Parking/traffic control - likely RMC Events
	452.1125	315 DCS		Parking or security operations (simplex)
	461.3125	023 DCS		Parking/traffic control - likely RMC Events
	462.7125	CSQ	FRS 07	"""yeah he's worried about being late for work"" ""yeah well...."" - informal CB-like chatter, faded in and then out very quickly "
	154.6000	CSQ	MURS 5	Retail/security - likely WalMart or Sam's Club going by the fact that they're using carrier squelch (CSQ) on MURS
	467.7625	065 DCS	"""J"" Dot"	Retail - weak/fair signal
	466.1875	023 DCS		Concrete construction contractor - portable radios
4/19/2021	158.4075	065 DCS		FLIGHTCOM dispatch at 9:48AM
	464.5625	85.4 Hz		Hotel or hospitality
	154.4900	67.0 Hz		Road repair crew or contractor
	467.7875	464 DCS		"""Level 10"" ""back it up 5 feet..."""
	464.5500	205 DCS	Yellow Dot	Tower crane control/construction
	151.5125	136.5 Hz		Crane control (usual users of this frequency/tone - have also been heard using 154.5275 with 136.5 Hz tone)
	462.8625	88.5 Hz		Tower crane control/construction - English/Spanish - likely related to activity on 469.5500 [114.8 Hz], 462.9125 [192.8 Hz] and others
	462.6750	606 DCS	FRS 20	Retail, same group previously monitored using 606 DCS code on this channel
	456.8000	074 DCS		Poor signal, presumably portables
	467.5625	CSQ	FRS 08	"""okay we don't need to have that conversation now"" ""alright you're good"" - YL and OM speakers, fair to poor signals at 10:00-10:02 AM"
	464.5000	179.9 Hz	Brown Dot	Poor signal, difficult to ID user
	462.6000	67.0 Hz	FRS 17	"""Mike..."" (female speaker) - very poor copy "
	462.6875	67.0 Hz	FRS 06	Weak
	469.5000	205 DCS		Tower crane coordination
	462.5625	CSQ	FRS 01	"""I don't think he even knows where we are"" (poor signal, FRS Roger Beeps heard)"
	462.7125	167.9 Hz	FRS 07	"""back..."" (also very weak) "
	464.5375	223 DCS		Construction
	462.7125	159.8 Hz	FRS 07	Same group usually heard using this CTCSS tone and channel combination
	464.5000	88.5 Hz	Brown Dot	Weak, interference from other user(s) on frequency
	467.6625	67.0 Hz	FRS 12	Elevator floor requests - same users as previously monitored, good signals
	154.4900	162.2 Hz		Luck Stone - base to truck (dispatch)
	451.8000	031 DCS		"Mention of ""field maintenance"" and discussion regarding weather / raining "
	467.6375	CSQ	FRS 11	"Local school - previously logged using this channel - no CTCSS or DCS tone/code used, carrier squelch with FRS ""Roger Beeps"" as usual"
	462.6625	88.5 Hz	FRS 05	Heard YL speaking, poor copy, UNID users
	462.5750	243 DCS	FRS 16 	Spanish language chatter - presumably construction or similar
	151.8200	131.8 Hz	MURS 1	Utility marking or inspection company (portable radios)
	464.5500	127.3 Hz	Yellow Dot	Crane control? presumed
	462.5625	67.0 Hz	FRS 01	"Group caravanning up 95, good signals at points, FRS style ""Roger Beeps"" heard "
	467.7125	107.2 Hz	FRS 14	FRS call tones heard...no audio (voice) heard...
4/20/2021	469.5500	114.8 Hz		Tower crane coordination
	462.6375	131.8 Hz	FRS 04	"""lot B"" ""okay let the dark blue truck go through"" "
	464.5500	627 DCS	Yellow Dot	"""level 9 has been inspected first, he wants to meet you on level 8"" ""okay he will call you back on the radio"" - very active around 8:40-8:45 AM"
	467.6625	053 DCS	FRS 12	"Coordinating planting, mention of greenhouse, ""Jamie"" - talking about eggplants...good strong signal "
	467.6625	67.0 Hz	FRS 12	Elevator floor requests, weaker than 053 DCS users on same frequency
	462.8875	88.5 Hz		Crane coordination (other radio chatter heard in background)
	151.8200	103.5 Hz	MURS 1	Contractor or utility repair crew....sporadic activity
	466.3125	156.7 Hz		Tower crane control or construction
	462.6875	85.4 Hz	FRS 06	Short transmission, presumed same group or user previously monitored using this tone on this channel
	461.1625	67.0 Hz		Hotel/hospitality - repair or maintenance crews
	462.5625	CSQ	FRS 01	Spanish language, very weak
	467.6125	CSQ	FRS 10	Kids playing with radios, FRS call tones heard
	151.6250	167.9 Hz	Red Dot	Crane Master truck to truck primary
	467.5875	67.0 Hz	FRS 09	FRS call tone, a radio check....nothing else heard?
	469.5500	506 DCS		Spanish language, heard several mentions of floor or level numbers
	467.6875	67.0 Hz	FRS 13	Local school or daycare? fair to poor copy
	151.8200	141.3 Hz	MURS 1	Weak, UNID users
	466.3625	156.7 Hz		Construction
	464.5000	179.9 Hz	Brown Dot	Facilities management
	462.6750	606 DCS	FRS 20	"""price check"" - likely the same retail group previously monitored "
	469.5500	732 DCS		Weak, UNID user...caught 1 second transmission
	462.6375	67.0 Hz	FRS 04	FRS call tones
	462.5625	67.0 Hz	FRS 01	Spanish language - different group (not the same guys running carrier squelch on frequency)
	464.5500	732 DCS	Yellow Dot	Construction - weaker than guys running 627 DCS
	154.5700	023 DCS	MURS 4	Two OMs chatting, poor copy
	462.6625	79.7 Hz	FRS 05	"""yeah we got it"" ""okay cool"""
	154.5700	371 DCS	MURS 4	Same group previously monitored using this DCS code
	467.6375	CSQ	FRS 11	Local school - **switched to channel 12 during afternoon due to interference**
	461.2125	67.0 Hz		Hotel/hospitality
	456.8125	732 DCS		Construction (simplex)
	464.5000	103.5 Hz	Brown Dot	Security or building maintenance / facilities management
	464.5500	67.0 Hz	Yellow Dot	Very weak signals, heard at 2:01pm
	467.8750	229.1 Hz	Gold Star	Crane control/coordination
	467.6375	97.4 Hz	FRS 11	UNID users, causing interference to local school users using carrier squelch
	467.6625	CSQ	FRS 12	Local school - switched from FRS Ch. 11 due to interference on channel
4/21/2021	457.5750	315 DCS		Local school, presumably alternate frequency to 457.525
	462.9125	192.8 Hz		Crane control/coordination
	457.5250	315 DCS		Local school - primary frequency
	464.5500	271 DCS	Yellow Dot	"""inspection on Friday"" ""clear 12"" "
	158.4075	065 DCS		LIFE EVAC 1 working FLIGHTCOM at 8:01AM
	467.9250	155 DCS	Blue Star	"""there's something wrong with the cable...on the trailer...it's broken and won't close"" "
	467.7500	115 DCS		Target Store operations (active)
	154.6000	77.0 Hz	MURS 5	Probably retail, portables
	462.6625	136.5 Hz	FRS 05	Likely a car repair shop or similar
	462.7875	131 DCS		Spanish language, fair signals
	462.5250	114.8 Hz		Daycare
	462.5875	118.8 Hz	FRS 02	"Retail or similar - heard mention of ""waiting area"" and ""customer service"""
	462.5750	CSQ 	FRS 16	"""okay thank you"" (weak) "
	464.5000	162.2 Hz	Brown Dot	Retail store, portables
	469.5500	703 DCS		HVAC engineers? talking about ductwork
	464.5500	162.2 Hz 	Yellow Dot	Retail store, portables
	467.9000	225.7 Hz	Red Star	Retail, good signals near Willow Lawn
	462.5500	123.0 Hz	FRS 15	Spanish language chatter, poor to fair signals
	467.8500	67.0 Hz	Silver Star	"""Floor 3"" ""inspector 1"" ""copy that base"" "
	462.8125	627 DCS		Several transmissions heard around 7:33pm...no voice traffic heard but likely construction related
	151.6250	654 DCS	Red Dot	Lane 3, order numbers....portables, weak signals
	462.5875	67.0 Hz	FRS 02	Vehicles caravanning up or down I-95
	462.8625	88.5 Hz		Crane control/construction
	469.5500	114.8 Hz		Crane coordination, very active at points
	464.5500	156 DCS	Yellow Dot	Construction sounds heard in background, weak signal
	451.8000	612 DCS		"""Base calling Mike...do you copy me on level D?"""
4/22/2021	464.5000	77.0 Hz 	Brown Dot	Spanish
	466.3125	156.7 Hz		"""no toilet paper on the 8th floor..."""
	467.6625	67.0 Hz	FRS 12	"Elevator floor requests, very active at points (with FRS ""Roger Beeps"")"
	467.7875	156 DCS		"""check out that request"" ""10-4"""
	466.1375	103.5 Hz		Directing supply delivery trucks, fair to good signal (portables)
	469.5500	226 DCS		"""level 2"" ""check the adjustment"" ""major"" "
	462.6250	67.0 Hz	FRS 18	Car to car chatter - likely a group caravanning
	464.5500	627 DCS	Yellow Dot	Usual users of this frequency and code combination - very active at points
	462.7125	159.8 Hz	FRS 07	Same users usually heard on this frequency/tone combination
	466.3625	205 DCS		Spanish and English mixed, likely crane control or construction
	467.7625	627 DCS	"""J"" Dot"	Construction/crane control chatter
	461.3375	023 DCS		"""inspection on the first levels on Friday"" ""okay"" ""ducting"" - possibly inspection crew or quality assurance crew "
	462.7250	136.5 Hz	FRS 22	parking lot attendants and traffic direction coordination (portables)
	158.4075	065 DCS		FLIGHTCOM dispatch loud and clear signals
	151.6250	97.4 Hz	Red Dot	"Car to car comms...heard mention of ""Lombardy Street"" "
	467.9125	032 DCS		"""Tower 2"" "
	462.6250	127.3 Hz	FRS 18	School or daycare, fair to poor signals
	462.5500	67.0 Hz	FRS 15	"""did you guys want to stop for lunch or wait another hour? - presumably vehicles caravanning "
	464.5000	192.8 Hz	Brown Dot	Microphone keyed down...hearing sirens in background at 11:58AM
	462.6625	67.0 Hz	FRS 05	Parking lot control
	467.5875	91.5 Hz	FRS 09	Spanish language, poor signal
	151.8200	103.5 Hz	MURS 1	Contractor/construction crew (portables)
	462.5875	023 DCS	FRS 02	RF engineering crew, testing radio or data / telemetry links
	469.5500	114.8 Hz		Crane coordination chatter - can hear other radios active in background
	462.5875	97.4 Hz	FRS 02	"Crane control, good signal with FRS ""Roger Beeps"" - first heard around 12:15PM"
	469.5000	205 DCS		Crane control/construction
	462.6625	023 DCS	FRS 05	"""Mick"" ""hold on one sec"" ""shine it now""  - possibly related to the guys monitored using this DCS code on other channels"
	467.6125	CSQ	FRS 10	"Kids playing on radios (FRS tones heard) - ""can you bring my phone so we can listen to music?"" ""okay also can we bring the together book so we can read it in the car?"""
	467.9250	67.0 Hz	Blue Star	Security?
	462.6125	127.3 Hz	FRS 03	"""Black Suzuki in the handicap spot"" ""10-4"" - very strong signals at 1:45PM"
	462.5250	114.8 Hz		Local school or daycare - fair signal (portables, simplex)
	462.5625	67.0 Hz	FRS 01	"""ease a little to the right you're almost right next to the building"" "
	464.5000	67.0 Hz	Brown Dot	Crane control
	461.1875	67.0 Hz		Crane control, fair signal
	467.6625	CSQ	FRS 12	Local school (have used other FRS channels previously, always with carrier squelch / CSQ) - switched from 12 to 13 at 4:40PM
	469.4875	110.9 Hz		Spanish, presumed construction
	467.6875	CSQ	FRS 13	Local school, switched from channel 12 to 13 at 4:40PM...continuing to use carrier squelch
	151.7000	141.3 Hz		Contractor - possibly utilities or water/sewer?
	467.6375	CSQ	FRS 11	"Heard mention of ""Casey"" ""oil"" and ""pump"" - likely the reason the school switched off channel 11 to channel 12 (which has construction chatter on it) and then to channel 13)"
	462.9125	192.8 Hz		Crane coordination
	462.7250	252 DCS	FRS 22	"""sandbox station"" "
4/23/2021	469.5500	114.8 Hz		"Crane coordination - informal chatter as well as ""official"" comms - can hear multiple radios in background "
	462.4250	103.5 Hz		Local school or daycare - fair signal with interference from digital signal on same frequency
	451.8125	205 DCS		Construction - talking about supply, heard discussion about beams and concrete
	464.5500	79.7 Hz	Yellow Dot	Weak/sporadic signal...was able to decode CTCSS tone but not much else
	154.4900	67.0 Hz		Highway maintenance or repair contractor
	467.6625	67.0 Hz	FRS 12	Elevator floor requests - same users usually heard
	466.3125	156.7 Hz		Spanish and English - construction chatter...very busy at points
	462.6625	88.5 Hz	FRS 05	"""get..."" ""right there"""
	154.5700	67.0 Hz	MURS 4	Open microphone, heard phone ringing in background
	158.4075	065 DCS		"FLIGHTCOM - ""that's affirmative - you were giving me your flight plan and they were on the other frequency canceling"" "
	467.6125	67.0 Hz	FRS 10	Crane control - first heard around 8:45AM
	151.5125	136.5 Hz		Crane control - the usual user of this frequency and tone combination
	159.5100	351 DCS		"""okay we'll have a look over there"" - possibly repeater "
	462.5875	97.4 Hz	FRS 02	"Crane control - good signal with FRS ""Roger Beep"" "
	464.5000	047 DCS	Brown Dot	Construction, poor to fair signal
	462.6375	131.8 Hz	FRS 04	"""back it up now"" ""next vehicle go"" "
	462.5250	114.8 Hz		"""yes, I can hear you fine on here now"" "
	462.7125	159.8 Hz	FRS 07	Same group usually heard on this frequency and tone combination (active somewhere downtown)
	464.8250	026 DCS		Crane control - as usual with sporadic interference from Philip Morris repeater on same frequency
	462.6250	127.3 Hz	FRS 18	"""okay you can bring it down now"" ""copy"" (all female voices)"
	457.5250	315 DCS		Local school - portables
	462.5875	74.4 Hz	FRS 02	"""she uh...she actually just went out""  - different ""Roger Beep"" than the other group on frequency - roughly same signal strength "
	462.6750	606 DCS	FRS 20	Retail user - monitored numerous times using this frequency and DCS code combination (portable radios)
	462.1250	69.3 Hz		Hotel or hospitality - portables/simplex - heavy interference from digital signal on frequency (note: the Jefferson Hotel is licensed to operate a digital voice repeater system on this frequency)
	462.5625	77.0 Hz	FRS 01	Spanish language
	151.6250	065 DCS	Red Dot	FLIGHTCOM dispatch
	462.5875	67.0 Hz	FRS 02	Crane control (third group monitored using this frequency so far today - each using a different CTCSS tone though)
	462.6500	CSQ	FRS 19	Sounds like car to car chatter - likely a group going up or down I-95 or I-64
	151.8200	103.5 Hz	MURS 1	Contractor or construction - presumably the same group previously monitored using this tone on MURS
	469.5500	732 DCS		Elevator floor requests - very similar to the traffic normally heard on FRS-12 with 67.0 Hz
	462.7250	67.0 Hz	FRS 22	Sounds like two kids talking on FRS walkie talkies (monitored around 12:43-12:44PM)
	467.5625	CSQ	FRS 08	"""I'm looking into the sun! I can't see fucking anything!"" "
	466.0625	732 DCS		Construction
	462.6125	127.3 Hz	FRS 03	"""Bring it back...towards me...."" (weak/poor signal)"
	464.5500	67.0 Hz	Yellow Dot	"""Check that level again"" (good signal)"
	462.6875	141.3 Hz	FRS 06	"""Cliff...I need you to dial 223...Cliff...dial 223"" "
	154.5275	136.5 Hz		Crane control - the usual user of this frequency and tone combination
	462.7250	136.5 Hz	FRS 22	Caught tail end of a weak signal
	456.8125	743 DCS		Construction - sporadic signal, portables/simplex
	467.8750	67.0 Hz	Gold Star	Talking about fences? installation crew?
	461.2625	67.0 Hz		Hotel or hospitality - customer service and room cleaning/repair crew and engineering
	462.6125	165.5 Hz	FRS 03	Open mic, weak signal but 100% copy on the CTCSS tone...
	151.5050	179.9 Hz		Crane control, unknown company (likely not Crane Master)
	467.6875	CSQ	FRS 13	Local school - see log from 04/22/21 regarding frequency/channel changes
	462.5875	118.8 Hz	FRS 02	Spanish language, weak/fair signal - sometimes 2-3 signals on frequency at once....
	467.6125	073 DCS	FRS 10	UNID net - suffering heavy interference from the other group (crane control) on frequency
	462.7250	218.1 Hz	FRS 22	"""Level 14"" ""copy that"" ""check that second load"" "
	461.3125	023 DCS		RMC Events - likely active at Richmond Flying Squirrels game at The Diamond
	461.2625	023 DCS		RMC Events - likely active at Richmond Flying Squirrels game at The Diamond
	467.8750	229.1 Hz	Gold Star	Crane coordination channel
	467.6125	94.8 Hz	FRS 10	"""blue sedan coming at you now"" "
4/24/2021	464.5500	627 DCS	Yellow Dot	Crane control and construction use - very active at points with strong signals
	158.4075	065 DCS		FLIGHTCOM working various medevac helicopters
	467.7625	205 DCS	"""J"" Dot"	Construction
	469.5000	114.8 Hz		"""yeah man and it's interfering with everyone else's radio"" "
	462.5500	67.0 Hz	FRS 15	"Weak, heard FRS ""Roger Beeps"" and call tones and alert tones "
	464.5000	023 DCS	Brown Dot	"""link 2 check signal strength"""
	467.7125	343 DCS	FRS 14	FRS call tones - fair to weak signal
	462.8250	162.2 Hz		Weak signals, Spanish language
	462.5875	97.4 Hz	FRS 02	Crane control, good signals mixed English and Spanish
	154.4900	67.0 Hz		Contractor or repair crew (portables)
	462.8625	88.5 Hz		Crane coordination
	464.5500	205 DCS	Brown Dot	Construction
	462.6125	67.0 Hz	FRS 03	Traffic control, flaggers or maybe parking lot coordination
	462.4250	103.5 Hz		Local daycare - portables with some interference from digital signals on same frequency
	462.6750	606 DCS	FRS 20	Retail store - various signal strengths, portables
4/25/2021	464.5000	432 DCS	Brown Dot	Construction
	462.5875	97.4 Hz	FRS 02	"Crane control - good signals with FRS ""Roger Beeps"" "
	456.8000	506 DCS		Construction (simplex, portables)
	469.5500	114.8 Hz		Crane control/coordination
	462.7125	67.0 Hz	FRS 07	"Sounds like kids playing with FRS walkie talkies...""Roger Beeps"" heard - no CTCSS or DCS tones/codes in use "
	462.5625	CSQ	FRS 01	two kids talking on the radio, very weak...no tone or code in use
4/26/2021	462.8125	627 DCS		Crane control and construction operations, active early in the morning on 26 April
	464.5500	67.0 Hz	Yellow Dot	"""call him back and let him know that the keys are not up here"" (fair signal at 7:07AM)"
	464.8250	026 DCS		Crane control, some interference from Philip Morris repeater on frequency
	158.4075	065 DCS		"FLIGHTCOM dispatch working medevac helicopter - ""what's your ETA to VCU?"" - loud and clear at 7:09AM"
	469.5500	114.8 Hz		Crane coordination, usual traffic for this frequency and tone
	151.6250	065 DCS	Red Dot	"AIRCARE EAGLE working FLIGHTCOM ""12 minutes en route to Hanover, risk is 1100"" - base station is loud and clear, aircraft is fair and readable at 7:15AM / 7:16AM"
	467.5875	91.5 Hz	FRS 09	"""I've got 3 more for you"" ""okay 3...I've got room for 3...."" ""that's quite the line..."" ""copy that"" "
	462.7875	021 DCS		"""why don't we..."" [faded out] weak at 9:31AM"
	462.5875	118.8 Hz	FRS 02	"""truck"" ""okay copy"" "
	462.8125	021 DCS		"""no, you can't go down that...it's a one-way"" (very heavy interference with other group using same frequency) "
	467.6625	77.0 Hz	FRS 12	"""Yes, yes, two...."" - weak signal "
	462.5750	654 DCS	FRS 16	"""Tammy Davis said the parking lot is empty"""
	469.5000	315 DCS		Crane control - fair signal - likely some distance away compared to most tower crane activity heard
	464.5500	627 DCS	Yellow Dot	Construction and crane control
	462.8375	021 DCS		Talking about directions - probably also related to the TV or film crews using the same non-standard DCS code
	462.5625	67.0 Hz	FRS 01	Crane control or construction (with interference from another group on channel using a different CTCSS tone)
	464.4875	021 DCS		"""back on the..."" - other fair to poor signals "
	151.8800	244 DCS	MURS 2	"""start to back...slow..."" - possibly construction "
	469.5500	165 DCS		"""hold onto your straps a little bit longer"" (weak, poor copy)"
	462.5625	77.0 Hz	FRS 01	Spanish language, heavy interference at points
	469.5500	506 DCS		Spanish language, presumed construction based on DCS code
	462.7125	159.8 Hz	FRS 07	Usual user of this frequency and tone
	462.8625	021 DCS		TV or film crew?
	151.6250	026 DCS	Red Dot	Weak, UNID users
	469.5125	315 DCS		Construction, weak signals
	461.2375	165 DCS		Construction, sporadic signals
	151.9550	127.3 Hz	Purple Dot	Weak, talking about trucks and deliveries
	467.5875	165.5 Hz	FRS 09	"""cage"" ""basket 2"" ""okay bring it back down..."""
	154.5700	371 DCS	MURS 4	Construction or contractor
	462.7250	136.5 Hz	FRS 22	Weak signal, presumed portables (low power considering the frequency and tone)
	469.4875	021 DCS		TV or film crew
	467.6125	67.0 Hz	FRS 10	Spanish language, very weak
	467.5625	CSQ	FRS 08	"Local school - dismissal - heard mention of ""6th grade"" ""7th grade"" and ""8th grade"" - no CTCSS tone or DCS code received "
	461.1875	136.5 Hz		Construction, sporadic signals
	464.5000	432 DCS	Brown Dot	"""Hey Jack...do you wanna turn around?"" "
	462.6750	136.5 Hz	FRS 20	"Local school with FRS ""Roger Beeps"" (some interference from retail store on same frequency) "
	466.0375	91.5 Hz		Facilities maintenance or engineering crew
	462.6250	127.3 Hz	FRS 18	Sounds like a catering company?
	464.5000	465 DCS	Brown Dot	"""cable run"" "
	467.8750	229.1 Hz	Gold Star	Crane control, active in the evening
	467.9125	021 DCS		TV or film crew
	469.5625	021 DCS		TV or film crew
	462.6125	74.4 Hz	FRS 03	Possible surveillance or radio training
	469.5125	021 DCS		TV or film crew...active, but weak
	467.8375	712 DCS		Construction or crane control
	464.5125	021 DCS 		TV or film crew
	464.5625	85.4 Hz		Hotel or hospitality - customer service and room cleaning/repair crew and engineering
	462.5500	123.0 Hz	FRS 15	Spanish language, fair to poor signals
	462.7625	021 DCS 		Coordinating shuttles or pick up and drop off vans/buses (poor signal)
	464.5625	021 DCS		TV or film crew...active, but weak
	467.7625	229.1 Hz	"""J"" Dot"	Crane control
	469.5375	021 DCS		TV or film crew...active, but weak
	451.8125	466 DCS		Construction crew
4/27/2021	462.5875	97.4 Hz	FRS 02	Crane control, very active at several points
	462.4250	103.5 Hz		Local school or daycare (simplex, portables)
	466.0875	506 DCS		"""okay well you can move it all up there and just pull the truck up..."""
	154.4900	67.0 Hz		Highway maintenance crew (portables) - same user previously monitored using this frequency and CTCSS tone combination
	462.5750	165.5 Hz	FRS 16	UNID user - solid CTCSS tone decode (tone noted in use on this channel previously)
	462.7125	159.8 Hz	FRS 07	Usual users of this tone and frequency
	154.5700	244 DCS	MURS 4	Contractor or construction user (portables)
	154.5700	371 DCS	MURS 4	Usual group on this channel - stronger than other group heard using different DCS code
	462.6875	85.4 Hz	FRS 06	"Unreadable voice, followed by FRS ""Roger Beep"" - this CTCSS tone previously monitored on this channel "
	467.9250	67.0 Hz	Blue Star	"""bring it back towards the left...no...yes...left...about 3 feet"" "
	158.4075	065 DCS		FLIGHTCOM dispatch - base station to aircraft (Medevac)
	151.6250	065 DCS	Red Dot	FLIGHTCOM dispatch - base station to aircraft (Medevac)
	469.5500	165 DCS		"""pickup on level 6 please"" ""okay so you want me to load it...?"" ""alright"""
	462.5625	77.0 Hz	FRS 01	Spanish language chatter - seems to be the same users previously monitored using this tone
	467.6125	743 DCS	FRS 10	Spanish language, very informal chatter (weak/fair signals)
	151.5125	136.5 Hz		Tower crane control, usual users of this frequency and tone
	462.6375	CSQ	FRS 04	Kids playing on FRS radios - weak to fair signals - no tones or codes in use
	469.5000	165 DCS		Construction chatter
	151.6250	167.9 Hz	Red Dot	Crane Master truck to truck - confirmed user - primary frequency
	462.6875	141.3 Hz	FRS 06	Filipe, are you all ready?  - discussion about appointment times, etc.  presumed COVID vaccination site or testing site
	462.6750	136.5 Hz	FRS 20	Local school - sporadic interference from retail store users on same frequency
	462.7625	021 DCS		TV or film crew
	467.6125	364 DCS	FRS 10	Background audio (weak)
	158.4000	167.9 Hz		Construction related chatter - possibly Crane Master based on CTCSS tone
	466.0875	97.4 Hz		Construction - fair to weak signals
	462.5875	118.8 Hz	FRS 02	"""following up on that appointment"" "
	462.5250	114.8 Hz		Talking about lunch buffet..
	469.5000	205 DCS		Construction and crane control
	462.6625	67.0 Hz	FRS 05	UNID user, caught tail end of transmission
	462.7625	205 DCS		Construction - Spanish and English
	464.5000	165 DCS	Brown Dot	Construction, sporadic signals
	462.6625	136.5 Hz	FRS 05	COVID-19 vaccination or testing site (active on other FRS frequencies as well)
	456.8125	205 DCS		Construction crew, talking about weather forecasts
	467.5625	371 DCS	FRS 08	FRS call tones heard
	464.5500	165 DCS	Yellow Dot	Construction, weak and strong signals, with interference from other stations on frequency
	466.1125	021 DCS		TV or film crew
	462.5625	023 DCS	FRS 01	Spanish language, weak poor signal
	462.6250	127.3 Hz	FRS 18	Local school or daycare (weak to fair signal, portables)
	462.9125	88.5 Hz		Crane coordination (can hear other radios in the background audio of some transmissions)
	154.5275	136.5 Hz		Tower crane control, usual users of this frequency and tone
	467.6875	CSQ	FRS 13	Local school - active in morning and mid-afternoon...
	451.8125	506 DCS		Construction crew, fair to weak signals
	462.6625	023 DCS	FRS 05	"""you are clear...you are visible on the monitor..you are clear keep it going..."" (FRS Roger Beeps heard) "
	462.8250	162.2 Hz		Local school or daycare? Poor copy
	462.7250	136.5 Hz	FRS 22	Catering company?
	464.4875	021 DCS		TV or film crew
	462.6125	97.4 Hz	FRS 03	Crane control and general informal chatter (poor to fair signals)
	467.9000	225.7 Hz	Red Star	Retail operations
	467.8750	94.8 Hz	Gold Star	Retail operations
	467.5875	032 DCS	FRS 09	"Heard female voice, weak to fair signal...no ""Roger Beep"" heard "
	467.7750	072 DCS		Retail operations - likely Target (known frequency and DCS code combination, heard near Willow Lawn)
	467.9250	225.7 Hz	Blue Star	Retail operations
	467.7500	115 DCS		Retail operations - likely Target (known frequency and DCS code combination, heard near Willow Lawn)
	464.5000	162.2 Hz	Brown Dot	"""50 pound bag"" ""check order"""
	456.8125	432 DCS		Weak signal, was able to copy DCS code and not much else
	462.6125	CSQ	FRS 03	"""no, that's not...."" ""copy"" (strong signals, received around 7:15PM) "
4/28/2021	469.5500	205 DCS		Construction
	469.5000	165 DCS 		Construction and general informal chatter
	469.5000	205 DCS		Construction, mixing with other signals on frequency
	466.0875	506 DCS		Crane control/construction (sporadic use)
	462.6750	606 DCS	FRS 20	Local retail store - previously logged using this frequency and code combination
	469.5500	165 DCS		Construction and general informal chatter
	467.8750	229.1 Hz	Gold Star	Active - crane control (busy during morning and evening hours)
	469.5500	506 DCS		Construction - English and Spanish
	467.5625	243 DCS	FRS 08	School or daycare operations? - portables...fair to poor signal strength
	467.6625	053 DCS	FRS 12	"Possibly local school - """"""I'm actually going to need your help taking the paper back down as well"" and similar traffic "
	462.6750	136.5 Hz	FRS 20	Local school - some interference from retail store on same frequency
	462.6250	127.3 Hz	FRS 18	Spanish and English, presumed construction crew
	462.5625	67.0 Hz	FRS 01	Very weak signals around 8:15AM - 8:30AM...was able to decode CTCSS and thats about it...heard some Spanish language chatter again at 8:45AM...
	462.7125	159.8 Hz	FRS 07	Usual users of this tone and frequency - very active at points with strong to fair signals (coming from the downtown area)
	467.9250	67.0 Hz	Blue Star	Crane control or construction
	462.8125	627 DCS		"Construction crew, appears to be alternate channel or general chat, tactical or ""talkaround"" "
	462.6625	023 DCS	FRS 05	Coordinating loading equipment, installing ??? unknown - active throughout the day (sporadic interference)
	151.7000	141.3 Hz		Utility or road contractor - possibly truck to truck comms
	462.7000	155 DCS 	FRS 21	"""bring that back up...."" ""okay 10 feet...."" "
	462.7875	021 DCS		TV or film crew
	462.6375	032 DCS	FRS 04	Sounds like traffic control
	464.4875	226 DCS		Supply or equipment delivery coordination? portables
	462.6375	131.8 Hz	FRS 04	School or daycare - weak and sporadic signals
	464.5375	85.4 Hz		Repair or engineering crew? weak to fair signals
	462.8375	021 DCS		Film crew, shuttles
	462.7125	146.2 Hz	FRS 07	"""they're ready for lunch now too so you can send the next group over"""
	464.5000	136.5 Hz	Brown Dot	"""hey we have another question for you..."" "
	462.5875	118.8 Hz	FRS 02	"""okay drop it down...drop it down.."" "
	154.4900	162.2 Hz		Luck Stone quarry and crushed stone - truck to truck and truck to base channel (dispatcher talking to mobile unit(s))
	464.5500	146.2 Hz	Yellow Dot	Security or inspection crew (portables)
	467.6875	CSQ 	FRS 13	"Local school - strong signals with FRS ""Roger Beeps"""
	462.8250	162.2 Hz		School or daycare
	462.6625	88.5 Hz	FRS 05	"""Justin"" and another, unidentified person - probably construction-related chatter "
	154.5700	043 DCS	MURS 4	Crane control, portables
4/29/2021	151.9550	127.3 Hz	Purple Dot	Security for warehouse or distribution center
	464.5500	156.7 Hz	Yellow Dot	"Base to ""unit 21"" ""can you open the roof access gate please?"" - base and mobiles with good signals "
	151.6250	065 DCS	Red Dot	AIRCARE EAGLE and FLIGHTCOM doing a radio check at 7:45AM
	451.8000	023 DCS		Talking about concrete
	469.5500	114.8 Hz		Crane coordination - very active at points
	151.5125	136.5 Hz		Crane control - usual users of this frequency and tone combination
	462.5625	97.4 Hz	FRS 01	"""gonna be checking your brakes"" ""okay"" "
	469.5000	205 DCS		"""another company is taking a delivery on the south side of the building....what do we got?!"" ""oh boy"" - general construction related comms "
	469.5500	165 DCS		Construction - interfering with other users on same frequency
	469.5500	732 DCS		"""well you've got that truck to your right...what do you think he'll do?"" (heavy interference from other users on frequency)"
	462.5625	67.0 Hz	FRS 01	"""Hey Amber...there are more than 5 flats but they all seem like they're the same"" ""okay yeah I would just dump all of those"" "
	464.5000	67.0 Hz	Brown Dot	Very weak signal - caught just enough to decode CTCSS - unable to ID user
	154.5700	371 DCS	MURS 4	Usual users on this frequency and DCS code combination - portable radios
	462.7250	252 DCS 	FRS 22	Spanish language, construction noises heard in background
	462.1250	69.3 Hz		Spanish language, sporadic signals - weak with heavy interference from DMR digital voice signals on frequency
	462.6750	606 DCS	FRS 20	Local retail user
	158.4075	065 DCS		FLIGHTCOM working LIFE EVAC 2
	467.6625	053 DCS	FRS 12	School - possibly same group monitored using this channel and DCS combination
	462.5875	023 DCS	FRS 02	Inspection crew or HVAC techs
	469.5500	506 DCS		Construction - general business related comms
	462.6750	136.5 Hz	FRS 20	Local school - some minor interference from retail users on same frequency
	462.6500	CSQ	FRS 19	Highway construction or repair crew, possibly active on other FRS channels as well
	462.6625	464 DCS	FRS 05	"""bring the diapers"" (low audio) "
	462.8875	021 DCS		TV or film crew
	462.6125	103.5 Hz	FRS 03	"""that group should be...[unreadable]"" - FRS ""Roger Beeps"" noted in use "
	462.7125	159.8 Hz	FRS 07	Usual users of this frequency and tone combination - downtown activity
	462.6125	023 DCS	FRS 03	Inspection crew or HVAC techs
	467.9250	67.0 Hz	Blue Star	Crane control or construction (fair to poor signal)
	461.1875	67.0 Hz		Construction
	462.6875	85.4 Hz	FRS 06	"previously monitored using this tone....heard  ""password is G O D 1"" "
	151.6250	67.0 Hz	Red Dot	Road or highway repair crew - sounds like portable radios
	462.6000	146.2 Hz	FRS 17	Car to car comms, likely a group traveling on the interstate
	469.5125	115 DCS		"heard ""West"" and nothing else - quick DCS decode though...unsure if related to other users logged on this frequency "
	469.9500	203.5 Hz		"""lane 2"" ""check for obstruction"" ""copy that"" (portables, simplex)"
	462.7000	CSQ	FRS 21 	"""Bobcat"" ""maybe we need to double check the voltage?"" ""okay standby"" ""it goes back down into one lane as it merges back into 64..."" - active, possibly highway construction crews? good signals, possibly running higher power mobile radios - ""turn around and take another route"" ""turn around, then we'll go north towards...195"" - very active at points "
	466.0875	97.4 Hz		"""we need two 6-footers or 8-footers would work...and a 7/8ths feed wrench"" (maybe ""speed wrench"") "
	467.6375	CSQ	FRS 11	Car to car chatter...fair to weak signals
	462.7875	023 DCS		"""just doing a radio check"" - at 12:52 PM - strong signal "
	462.6375	77.0 Hz	FRS 04	"""we need to get that footage"" ""yes, okay...going down...down...okay"" "
	462.5875	67.0 Hz	FRS 02	"School or day care - ""bring them to the activity room now"""
	469.5500	205 DCS		Construction chatter
	462.6625	136.5 Hz	FRS 05	COVID vaccination or testing site operations
	467.6875	CSQ	FRS 13	Local school - good signals with Roger Beeps - most active in mid-afternoon
	456.8125	165 DCS		Construction and delivery coordination chatter
	151.8200	67.0 Hz	MURS 1	"Female voices talking about ""elevator 2"""
	464.5375	85.4 Hz		Engineering or repair crew (portables, poor to fair signal)
	462.5625	77.0 Hz	FRS 01	Spanish language, weak with unique style Roger Beep
	462.6250	127.3 Hz	FRS 18	"""area 3"" ""check for Liam's mom she should be here to pick him up now"" "
	462.8125	627 DCS		Construction and general casual chatter
	461.2125	67.0 Hz		Hotel or hospitality service (portables, fair to weak signal)
	464.5000	179.9 Hz	Brown Dot	"""circuit 2 is showing open"" ""10-4"""
	461.1625	67.0 Hz		"""room 201"" ""clogged"""
	462.7250	67.0 Hz	FRS 22	Crane control, poor signal
	456.8000	023 DCS		Possibly construction - talking about rain and forecasted weather
	464.5500	114.8 Hz	Yellow Dot	Tail end of a transmission...heard construction noises in background
4/30/2021	467.8125	506 DCS	"""K"" Dot"	Materials delivery discussion - likely construction site related
	461.0875	244 DCS		"Construction - mention of ""outriggers"" "
	466.3125	156.7 Hz		Construction - very busy at points
	467.5875	371 DCS	FRS 09	Tail end of possible VOX or room audio transmission
	462.7125	79.7 Hz	FRS 07	"""point one"" ""yes...point one"" (in Spanish) with FRS Roger Beeps - fair to poor signals heard at 8:33AM"
	464.5500	244 DCS	Yellow Dot	Construction - fair signal strength
	466.2625	156.7 Hz		"""yeah I got you, hang on a second"" "
	467.6625	053 DCS	FRS 12	Local school - previously monitored using this DCS code on this frequency
	462.7125	159.8 Hz	FRS 07	Usual users of this frequency and tone combination - with some interference from the Spanish-speaking group using same channel (different CTCSS tone)
	464.5500	627 DCS	Yellow Dot	Construction - very active at points as usual
	462.6625	023 DCS	FRS 05	"""we should be able to reuse 2 per second..."" ""both sides of the..."" - likely same group heard previously "
	462.5875	97.4 Hz	FRS 02	Crane control/construction - busy at points
	469.5500	712 DCS		UNID user - caught this code for a moment on an active frequency
	467.8750	229.1 Hz	Gold Star	Crane coordination - often very active
	154.5700	043 DCS	MURS 4	Crane control (portables)
	462.6375	77.0 Hz	FRS 04	Spanish language, presumed construction
	158.4075	065 DCS 		FLIGHTCOM working medevac helicopters
	461.1875	79.7 Hz		"""get those lines up here!"" ""thank you"" "
	467.8500	100.0 Hz	Silver Star 	Retail operations - low power portables
	151.6250	065 DCS	Red Dot	FLIGHTCOM working medevac helicopters
	462.5250	114.8 Hz		School or day care - portables
	456.8125	654 DCS		"""Customer service"" ""back area"" (poor signal - likely low power portable radios) "
	467.8125	103.5 Hz	"""K"" Dot"	Hotel valet coordinationn
	462.5500	162.2 Hz	FRS 15	"""loaders are loading the second truck"" "
	462.6500	503 DCS	FRS 19	Car to car comms - likely a group on the interstates nearby - heard mention of exit numbers
	469.5500	732 DCS		Construction chatter - including service elevator requests
	462.6250	127.3 Hz	FRS 18	"""bring that class back up to the..."" - presumed school use "
	469.5500	165 DCS		"""give me five buckets...then we'll hit the horn and see what happens"" - additional chatter, crane operators or similar - this is a very busy frequency with multiple groups on during the day and often transmitting at the same time "
	462.6125	225.7 Hz	FRS 03	"""next group is good"" - with FRS style Roger Beeps "
	462.4250	103.5 Hz		Local school or day care? or...catering company - portables low power with heavy interference from DMR digital signals on frequency
	462.7000	CSQ	FRS 21	Highway repair or inspection crew - appears to be the same guys heard on this frequency (and also using carrier squelch) yesterday
	461.1875	67.0 Hz		"""is she leaving? she told me she's a late checkout"" - presumably hotel operator - fair to good signals"
	154.5700	371 DCS	MURS 4	Road repair crew or contractor
	462.6125	127.3 Hz	FRS 03	"""we'll come back that way"" - UNID users possibly school? "
	462.9125	192.8 Hz		Crane coordination - one of several frequencies logged on a daily or nearly-daily basis
	462.6750	136.5 Hz	FRS 20	"Local school - some interference from retail store using same frequency - heard mention of ""7th grade"" as well as numerous specific student's names "
	462.8625	88.5 Hz		Crane coordination - one of several active frequencies used by multiple cranes
	462.6000	CSQ	FRS 17	"""next time"" ""gray Toyota"" - poor signal "
	462.6875	85.4 Hz	FRS 06	Weak signal, activity noted on this channel and CTCSS tone previously - see older logs
	466.0625	244 DCS		Construction - fair signal strength
	462.6375	114.8 Hz 	FRS 04	Two stations talking about traffic conditions
	462.5875	118.8 Hz	FRS 02	"""3:45 appointment"" "
	151.8200	103.5 Hz	MURS 1	Construction or road repair crew, portables
	462.6625	203.5 Hz	FRS 05	"""oh yeah! she can..."" "
	469.5500	654 DCS		Construction - sometimes with severe interference
	462.5625	77.0 Hz	FRS 01	Very faint signal - sounded like Spanish language
	151.6250	023 DCS	Red Dot	Two or more mobiles - talking about traffic and signs, possible highway maintenance or traffic directors
	467.6875	CSQ	FRS 13	Local school - very good signals - previously monitored using this and other FRS channels without CTCSS tones or DCS codes
	151.8200	67.0 Hz	MURS 1	"""do you have me?"" ""yeah I'm on the elevator now sorry"" "
	462.5500	123.0 Hz	FRS 15	"""bring it back to the number 1 lane"" - portables "
	151.9550	023 DCS	Purple Dot	Traffic sign maintenance or highway repair crew
	154.6000	103.5 Hz	MURS 5	Repair crew or contractor
5/1/2021	464.5000	131.8 Hz	Brown Dot	Construction or maybe landscaping maintenance crew?
	154.4900	67.0 Hz		Repair crew or road maintenance crew (portable radios)
	462.6750	172 DCS	FRS 20	Construction - likely crane control as well
	158.4075	065 DCS		FLIGHTCOM working several aircraft
	469.5500	114.8 Hz		Crane coordination and (at times) informal chatter
	151.6250	023 DCS	Red Dot	Traffic sign maintenance or highway repair crew
	466.0875	97.4 Hz		Construction - poor to fair signal
	151.8200	67.0 Hz	MURS 1	Hospitality or similar - catering business?
	466.3125	156.7 Hz 		Construction/crane control
	461.2375	67.0 Hz		Construction
	462.6375	032 DCS	FRS 04	Traffic control - heard FRS Roger Beeps
	467.8750	114.8 Hz	Gold Star 	Second group mixing in with crane control activity running different CTCSS tone
	462.5875	67.0 Hz	FRS 02	"""also want a roll"" ""okay"" - kids playing on FRS walkie talkies "
	467.5625	371 DCS	FRS 08	Background audio, sounds like part of a wireless intercom system
	462.4250	103.5 Hz		"""next order, lemonade please"""
	462.7250	136.5 Hz	FRS 22	"""elevator 2"" - other traffic, weak signals and poor copy "
	151.6250	065 DCS	Red Dot	FLIGHTCOM dispatch - tone burst - scene request information to AIRCARE EAGLE aircraft, loud and clear signal
	154.5700	371 DCS	MURS 4	Repair crew or road maintenance crew (portable radios)
	154.5275	023 DCS		Traffic sign maintenance or highway repair crew
	464.5500	223 DCS	Yellow Dot	Construction crew, talking about drywall and prefabricated building materials
	462.9125	192.8 Hz		Crane coordination and general chatter - not as busy as the other coordination channels today
	462.5625	CSQ	FRS 01	"""Eddie needs to prepare..."" ""got it!"" - no CTCSS or DCS in use, typical FRS Roger Beeps...weak signals at 5:17PM"
	462.7625	165 DCS		"""123 remaining"" - unknown user "
5/2/2021	151.6250	065 DCS	Red Dot	FLIGHTCOM dispatch - loud and clear
	462.6250	127.3 Hz	FRS 18	Day care or similar operation? presumed daycare since it's Sunday
	462.5500	123.0 Hz	FRS 15	Spanish language - fair signal
	464.5500	627 DCS	Yellow Dot	Construction and crane control - appears to be primary channel
	158.4075	065 DCS		FLIGHTCOM dispatching LIFE EVAC 1 for an inter-facility transfer - South Hill Medical to VCU Main Hospital
	154.5700	88.5 Hz	MURS 4	Tail end of a voice transmission - heavy interference from FSK data bursts or telemetry on frequency (9:20-9:30AM)
	469.5500	114.8 Hz		Crane coordination - sometimes with very informal chatter mixed in
	462.7250	67.0 Hz	FRS 22	Weak signal, UNID users
	467.7875	110.9 Hz		Spanish language, poor copy
	466.1375	103.5 Hz		"""do you have me on 16?"" "
5/3/2021	466.3125	156.7 Hz		Construction and crane control
	462.8625	88.5 Hz		Construction - Spanish/English (appears to only be active in mornings and late evenings)
	469.5500	165 DCS		Construction and crane control
	462.6750	136.5 Hz	FRS 20	Local school, roughly the same signal strength as the retail users often heard on this same frequency
	466.0875	506 DCS		Construction - fair signal strength - one of two or three groups using this frequency
	151.6250	065 DCS	Red Dot	FLIGHTCOM dispatch - morning radio check and chatter at 8:00AM
	462.6250	67.0 Hz	FRS 18	Weak signals...possibly car to car comms
	462.5625	67.0 Hz	FRS 01	"""bed 1 is hooked to the other hydrant...so the hydrant that it comes from so...left to right"" ""copy that, I got it now"" - very good signals at 8:06AM"
	151.5125	136.5 Hz		Crane control - usual group of users heard on this frequency and tone
	464.5500	627 DCS	Yellow Dot	Usual groups heard on this frequency and DCS code - appears to be a primary job site (construction site) channel
	462.7125	159.8 Hz	FRS 07	Usual downtown building maintenance or security users heard on this frequency and CTCSS tone - note use of non-standard tone
	469.5500	114.8 Hz		Crane coordination - also informal CB-like chatter at times
	158.4075	065 DCS		FLIGHTCOM dispatch and radio comms with medevac aircraft
	464.3250	546 DCS		Event management
	466.0875	97.4 Hz		Construction or crane control - weak signals
	467.9250	67.0 Hz	Blue Star	Security or building management
	462.5500	123.0 Hz 	FRS 15	"Poor copy - heard ""Jean"" ""tomorrow"" and ""flip"" "
	461.2625	67.0 Hz		Hotel or hospitality - room maintenance or engineering
	151.6250	167.9 Hz	Red Dot	Crane Master (confirmed user) truck to truck chatter and informal comms...talking about impending thunderstorms
	462.5875	118.8 Hz	FRS 02	Auto repair shop or somilarV
	467.9250	100.0 Hz	Blue Star	"""wrap up"" - talking about a delivery truck, possibly Kroger (retail) based on frequency and CTCSS tone "
	467.8500	67.0 Hz	Silver Star	"""I want to see if we can manually check in a guest...last name is Nelson"" "
	158.4000	167.9 Hz		Truck to truck comms - presumed CRANE MASTER based on type of traffic heard and CTCSS tone
	467.6875	CSQ	FRS 13	Local school - FRS portables (no tone or code in use)
	464.5500	67.0 Hz	Yellow Dot	"""Customer service call on channel 1"" "
	464.5000	100.0 Hz	Brown Dot	"""we'll do a little turn"" ""okay right...turn right here"" ""Barry"" and another OM"
	462.6375	151.4 Hz 	FRS 04	Sounds like car to car comms - possibly a group going up or down 95 or 64
	467.7125	116 DCS	FRS 14	Weak signal, was able to decode DCS code in use (portables)
	152.3000	023 DCS		Yellow Cab - dispatcher (half duplex system, taxi mobile radios transmit on 157.5600 MHz so other drivers can only hear dispatcher and not other mobiles) - VERY high power transmitter with high-elevation antenna
	467.6375	051 DCS	FRS 11	Construction traffic control or similar
	462.6250	127.3 Hz	FRS 18	Weak signal - sounds like a school
	151.7600	67.0 Hz		Traffic control or flag men - portables, fair signal
	152.9075	074 DCS		Richmond Public Schools - confirmed user (repeater)
	152.9000	205 DCS		Maggie Walker Governor's School - confirmed user (repeater)
	467.5875	032 DCS	FRS 09	School or day care? portable radios
	464.5000	77.0 Hz	Brown Dot	"Security or facilities management - heard a reference to ""unit 3"" "
5/4/2021	158.4075	065 DCS		FLIGHTCOM dispatch doing morning radio checks, etc. loud and clear
	462.6125	74.4 Hz	FRS 03	"Weak - ""I can see you but..."" [faded out] heard around 8:50AM - heard additional transmissions, sound like kids on FRS handhelds "
	154.5700	043 DCS	MURS 4	Crane control - variable signal strengths
	151.5125	136.5 Hz		Crane control - usual user of this frequency and code combination
	467.6625	67.0 Hz	FRS 12	Elevator floor pickup requests - usual traffic for this frequency and tone
	467.7875	506 DCS		"Construction - appears to be secondary or ""talkaround"""
	467.5875	CSQ	FRS 09	Several guys talking about trucks coming, mud (??) - fair to poor copy, no CTCSS or DCS noted
	469.5500	712 DCS		Crane control
	457.5250	315 DCS		Local school, portables (usual user of this frequency and DCS code)
	462.7250	67.0 Hz	FRS 22	"""Sean"" and another first name heard, usual FRS Roger Beeps...plus call tones, possibly mixing with another user on same channel / frequency "
	154.4900	67.0 Hz		Contractor or highway repair - vehicle to vehicle comms
	462.7125	79.7 Hz	FRS 07	English and Spanish - sounds like construction site or similar chatter, good signals
	462.6625	023 DCS	FRS 05	"""don't forget to grab a couple waters out of the cooler"" ""Hospital"" - presumably same group heard using this DCS code on this and other FRS channels "
	462.5625	67.0 Hz	FRS 01	Coordinating tent or other temporary setup - discussion of stakes, adjusting the line, etc.
	464.8250	026 DCS		Crane control - usual user of this frequency and code combination
	469.5500	165 DCS		"""I didn't want to have to listen to that alarm go off for the rest of the day"" - active frequency with numerous groups / users "
	462.7125	159.8 Hz	FRS 07	Usual group using this tone on this channel - active with elevator floor or pick up requests and other facilities maintenance traffic
	464.5500	627 DCS	Yellow Dot	Construction - appears to be primary or command channel
	154.5275	136.5 Hz		Crane control, same users with this CTCSS tone, or at least same company
	462.6750	136.5 Hz	FRS 20	School, sporadic interference from the retail user on same frequency
	464.5500	346 DCS	Yellow Dot	"""man, I don't know where Scotty ran off to..."" - fair to poor copy, weaker than the other group active on this frequency this morning "
	464.5000	88.5 Hz	Brown Dot	Talking about fire alarms or smoke detectors / heat detectors
	469.5500	114.8 Hz		Crane control / coordination...mixing with other signals at point
	462.6125	210.7 Hz	FRS 03	"""next two cars are good to go"" - possibly flag men or traffic control "
	462.5875	97.4 Hz	FRS 02	Crane control - sporadic activity - Spanish/English
	461.1875	67.0 Hz		"""check the..."" ""thank you Manny"" "
	462.6500	CSQ	FRS 19	"""right, security is gonna come take a look at the camera in a second"" "
	469.5125	82.5 Hz		"""Bruto!"" - Spanish language chatter "
	462.5750	165.5 Hz	FRS 16	"""Guys I need the elevator back to 1...I got a couple roofers that need to make it back up to 14"" - strong signal at 1:39PM"
	462.6625	136.5 Hz	FRS 05	"""is that the one with the cone on it?"" ""I dunno"" "
	158.4000	67.0 Hz		Road repair or maintenance contractor - portable radios
	462.6000	455 DCS	FRS 17	Sounds like kids playing with walkie talkies - confirmed DCS code in use
	466.0875	506 DCS		Construction or crane control - very good signals at points
	467.8500	67.0 Hz	Silver Star	Security or similar
	462.5625	97.4 Hz	FRS 01	Spanish language, weak signals
	462.6750	606 DCS	FRS 20	Retail user - previously monitored using this frequency and DCS code
	461.0625	67.0 Hz		"""do you have me on channel 5?"" ""10-4"""
	467.5625	243 DCS	FRS 08	Spanish language, presumed construction site or job site comms
	464.5000	023 DCS	Brown Dot	UNID user - sounded like car to car comms - only caught a few seconds of chatter before signals faded out
	469.5000	165 DCS		"""is it going to rain this time too?"" ""better get some more gas"" "
	462.9125	192.8 Hz		Crane coordination - can hear other radio chatter in background at points
	467.6875	CSQ	FRS 13	Local school - strong signals...as usual, no CTCSS tone or DCS code in use
	466.2625	023 DCS		"Linda - radio checks ""just want to make sure you're on 2"" "
	467.5625	026 DCS	FRS 08	Catering service or events management? weak signal
5/5/2021	462.8125	627 DCS		Crane control and construction - appears to be alternate channel
	462.5625	77.0 Hz	FRS 01	"Spanish language, unique style ""Roger Beep"" "
	469.5000	165 DCS		Construction - fair to poor signals
	469.5500	114.8 Hz		Crane coordination and general informal chatter - mostly English language with some Spanish and Spanglish
	462.6250	127.3 Hz	FRS 18	Catering service or room service coordination
	464.5500	627 DCS	Yellow Dot	Crane control and construction - appears to be primary
	469.5500	165 DCS		Construction, fair signal..busy at times but also suffering interference due to other users on frequency
	466.0875	97.4 Hz		Construction or facilities management
	464.5500	67.0 Hz	Yellow Dot	"""what was going on there?"" ""450"" "
	464.3250	546 DCS		RMC Events - events management
	469.5500	343 DCS		Elevator floor requests
	462.6625	79.7 Hz 	FRS 05	FRS call tones heard
	457.5250	315 DCS		Local school - portable radios, strong to good signal strength
	462.7125	159.8 Hz	FRS 07	Building maintenance and facilities management - downtown - usual user of this frequency and tone combination..heard basically daily
	462.6500	632 DCS	FRS 19	Radio checks
	462.6625	023 DCS	FRS 05	"""wait for..."" ""to come through"" "
	462.5875	67.0 Hz	FRS 02	Coordinating takedown of tents or tables/chairs
	462.9125	192.8 Hz		Crane coordination channel - including some informal chatter
	466.2625	023 DCS		"""that group is with Tracey, right"" ""yes ma'am"" ""go ahead"" ""walk up towards the big parking lot"" "
	158.4075	065 DCS		FLIGHTCOM working LIFE EVAC 4
5/6/2021	469.5500	165 DCS		"""Go-man's on 64"" - other similar traffic "
	462.7875	023 DCS		"""go next"" ""one guy is almost done with the first row and halfway done with the second"" - weak signal, heavy fading "
	464.5000	432 DCS	Brown Dot	Weak signal, unable to ID
	464.8250	026 DCS		Crane control - usual users of this frequency and tone with sporadic interference from high-powered repeater on same frequency
	467.6625	67.0 Hz	FRS 12	Elevator floor requests - the usual traffic heard on this frequency and tone
	466.3125	156.7 Hz		Construction and similar chatter - same users heard basically daily
	466.2625	023 DCS		Events management, possibly RMC Events
	469.5500	732 DCS		"""I need a ride from Massey first floor...up to 6"" - heard names ""Travis"" and ""Lindsey"" or similar "
	461.1875	67.0 Hz		"""contact"" ""check"" - poor signal "
	151.6250	167.9 Hz	Red Dot	Crane Master truck to truck and primary operations channel - loud and clear signals
	466.0875	97.4 Hz		"""back up on..."" weak signals "
	467.8375	432 DCS		"""yeah....it says...4 9 9 4....again that's forty-nine ninety four...4994, copy?"" "
	154.5700	043 DCS	MURS 4	Crane control - portable radios
	462.6625	023 DCS	FRS 05	Building maintenance, facilities management or similar - heard one station referred to as BIG DOG - FRS-style Roger Beeps noted in use
	154.4900	67.0 Hz		Road repair or maintenance contractor - portable radios
	151.6250	065 DCS	Red Dot	FLIGHTCOM medevac dispatch
	469.5500	506 DCS		"""car"" ""level"" ""basket"" - very poor copy "
	461.3625	023 DCS		Events management, possibly RMC Events
	461.3125	023 DCS		Events management, possibly RMC Events
	462.5500	123.0 Hz	FRS 15	Somebody keyed a mic for a few seconds - very strong signal...no audio - heard around 8:33PM
5/7/2021	466.0875	97.4 Hz		Facilities management or similar
	469.5500	114.8 Hz		"Crane coordination and informal chatter - ""I already have 5 radios up here man I don't want another one"" - talking about installing a CB radio and listening to the various other companies (heard reference to Miller and Long) talk shit to each other on the CB. also mentioned how a CB was required for a previous job site "
	151.6250	167.9 Hz	Red Dot	Crane Master - confirmed
	466.3125	156.7 Hz		Construction and similar - very active at points
	467.8750	229.1 Hz	Gold Star	Crane coordination net
	158.4075	065 DCS		FLIGHTCOM dispatcher
	469.5500	732 DCS		"Elevator floor requests - ""pickup on 4 please"""
	469.5500	165 DCS		Crane control and coordination
	464.5500	627 DCS	Yellow Dot	"Construction - primary coordination channel, heard ""Justin"" and other stations "
	464.5000	88.5 Hz	Brown Dot	"""303"" - other measurements (??) "
	467.6625	67.0 Hz	FRS 12	"Elevator floor requests - usual group/users with FRS ""Roger Beeps"" on most, but not all transmissions "
	469.5000	205 DCS		"""don't forget me on level 4"" - sounds like elevator floor requests or service elevator pick up requests - later, heard ""do they want us to get all the Port-o-Johns out the building now?"" ""yes that's right"" "
	462.5625	77.0 Hz	FRS 01	Spanish language - appears to be the same guys previously heard using this tone but impossible to be 100% sure
	461.1875	225 DCS		"""I want to start on the end of West Franklin Street and work my way up..."" ""check it on that point...hold me on that point and see if I can see you from there"" ""alright we're gonna have to cut that tree"" - possibly survey crew "
	469.5000	732 DCS		UNID user, weak signal
	464.5500	165 DCS	Yellow Dot	Construction chatter, sporadic signal
	462.5750	165.5 Hz	FRS 16	"""ask him how many TVs he has! [laughter]"" - non-standard CTCSS tone noted in use "
	466.2625	023 DCS		Event management company - portable radios
	469.5500	506 DCS		"""that might be a problem"" - talking about weather forecast "
	462.5625	67.0 Hz	FRS 01	"Talking about ""breaking it down"" - presumed similar traffic re: taking temporary tents, tables, etc. down "
5/8/2021	466.2625	023 DCS		Events management - probably RMC Events - simplex / portable radios at Richmond Flying Squirrels game
	151.5125	136.5 Hz		Crane control - usual users of this frequency and CTCSS tone
	466.3625	023 DCS		Events management - probably RMC Events - simplex / portable radios at Richmond Flying Squirrels game
	158.4075	065 DCS		FLIGHTCOM dispatching medevac aircraft
	461.3125	023 DCS		Events management - probably RMC Events - simplex / portable radios at Richmond Flying Squirrels game
	462.6125	225.7 Hz	FRS 03	Talking about parking
	461.2625	023 DCS		Events management - probably RMC Events - simplex / portable radios at Richmond Flying Squirrels game
	469.5500	114.8 Hz		Crane coordination and informal CB-like chatter
	462.6375	CSQ	FRS 04	"""how close is he?"" ""he's hot"" ""okay keep your eye on the next guy"" ""10-4"" - could be radio operations training or surveillance or??? - FRS ""Roger Beeps"" noted "
5/9/2021	469.5000	732 DCS		Construction - fair signal
	462.5500	123.0 Hz	FRS 15	"""copy"" and ""10-4"" heard - short transmissions, strong signals"
	158.4075	065 DCS		FLIGHTCOM dispatch - loud and clear as usual
	461.1875	67.0 Hz		Hotel or hospitality comms - also some friendly banter and informal chatter
	464.8250	026 DCS		Crane control - usual users of this frequency and DCS code - simplex
	466.2625	023 DCS		Talking about setting up cones and other similar chatter - presumably event management?
5/10/2021	462.8625	88.5 Hz		Crane control and construction - strong signals loud and clear
	469.5500	506 DCS		Construction and similar comms - Spanish and English
	462.6250	127.3 Hz	FRS 18	"""move 2 feet to the right...I mean your left...your left!"" - fair to poor signal "
	467.5875	CSQ	FRS 09	"""radio check"" ""hello radio check?"" - FRS style Roger Beeps heard, strong signal - ""we got plenty of length in the cargo line"" ""Roger that"" "
	158.4075	065 DCS		FLIGHTCOM working several medevac helicopters - strong signal as usual
	467.6625	67.0 Hz	FRS 12	Elevator floor pick up requests
	469.5500	165 DCS		Construction - similar to previously heard signals using this DCS code
	462.5625	67.0 Hz	FRS 01	Crane control - very active after 10:30 or 11:00 in the morning - fair to good signals with FRS Roger Beeps
	457.5250	743 DCS		"""group 2"" - weak signals, NOT the local users of this frequency "
	469.5500	073 DCS		Security or building management? portables - simplex
	151.6250	065 DCS	Red Dot	AIRCARE EAGLE working FLIGHTCOM at 1:05pm - both the aircraft and the base station were loud and clear with strong signals
	462.5500	71.9 Hz	FRS 15	Traffic control or flag men - fair signals, some interference
	457.5250	315 DCS		Local school - good to strong signals, much stronger than other users heard on same frequency earlier
	461.1875	67.0 Hz		Building management or maybe hotel/hospitality maintenance
	464.5375	85.4 Hz		Hotel or hospitality - engineering?
	462.7125	159.8 Hz	FRS 07	Same building maintenance or facilities management traffic heard on this frequency and CTCSS tone combination almost daily
	467.7875	110.9 Hz		Spanish language, heard construction noises in background
	467.8750	229.1 Hz	Gold Star	Crane coordination - other similar comms
	462.7250	136.5 Hz	FRS 22	Weak signal - hearing what sounds like Spanish
	469.5500	114.8 Hz		Crane coordination (multiple cranes) - can often hear other radios in the background
	462.5500	123.0 Hz	FRS 15	Heard two people talking, one male and one female...unknown use at this time due to poor signal strength
	469.5500	205 DCS		"""I don't even know if he's taking the machine"" - other similar chatter - as usual, this frequency is very busy "
	466.3125	156.7 Hz		Construction coordination and control
	462.5750	023 DCS	FRS 16	"""4th grade lunch"" ""okay"" "
	469.5000	165 DCS		Construction - possibly alternate frequency
	462.4250	103.5 Hz		School or day care operations - not as local as other similar transmissions heard on other frequencies - including the Baofeng and Retevis default factory freqs
	462.7250	67.0 Hz	FRS 22	"""can you hear me?!"" ""I'm not back there!"" - possibly kids playing with walkie talkies - FRS Roger Beeps noted in use"
	469.5000	205 DCS		"""level 10"" ""okay 10-4"" - some interference due to other groups on frequency at the same time...sounds like high-rise construction comms, service elevator pickup requests, etc. "
	154.5700	151.4 Hz	MURS 4	Construction and crane control; portable radios
	464.5000	67.0 Hz	Brown Dot	Talking about Port-a-Johns
	467.6875	CSQ	FRS 13	Local school - usually most active in mornings and early to mid afternoon
	462.9125	192.8 Hz		Crane control/crane coordination (active most in the late afternoon
	467.5625	306 DCS	FRS 08	"""the next exit"" ""yeah I have you good"" ""yeah yeah 10-4"" - likely vehicle to vehicle comms on the interstate "
	462.5250	114.8 Hz		School or day care - [child's name] mom is here to pick them up, etc.
	464.5500	627 DCS	Yellow Dot	Construction - primary channel...
	462.5875	118.8 Hz	FRS 02	"""Waiting area"" ""okay another 15 minutes"" "
	466.1375	103.5 Hz		Building management or maintenance - portable radios
	462.6125	127.3 Hz	FRS 03	Local school - very good signals
	466.0875	97.4 Hz		Construction or similar - poor signal
	464.5500	94.8 Hz	Yellow Dot	Parking garage attendants or security - fair to poor signals
5/11/2021	466.3125	156.7 Hz		Construction - Spanish language heard with some English - very busy at points
	158.4075	065 DCS		FLIGHTCOM working LIFE EVAC 2 and LIFE EVAC 4
	462.5625	043 DCS	FRS 01	"""Ms. Jones' group is now in room..."" "
	151.6250	167.9 Hz	Red Dot	Crane Master truck to truck comms - very good to good signals
	154.5700	67.0 Hz	MURS 4	Spanish language, fair signal with some interference from data bursts (telemetry) on frequency
	462.8625	88.5 Hz		Crane control and coordination
	461.1125	67.0 Hz		Hotel operations - portable radios
	462.6125	114.8 Hz	FRS 03	Catering service or room service - probably hotel related? portable radios
	467.6625	67.0 Hz	FRS 12	Elevator floor pickup requests - the usual traffic heard on this frequency and CTCSS tone combination - with FRS Roger Beeps
	469.5500	165 DCS		"""elevator pick up on 16"" ""pull those two pieces of steel out like that...that makes me a little nervous...."" "
	462.7250	223 DCS	FRS 22	Crane control or similar traffic - talking about lines and baskets
	462.8875	88.5 Hz		Crane control and general informal chatter, possibly alternate frequency or talkaround channel
	467.6625	053 DCS	FRS 12	School - fair signal - portable radios without Roger Beeps or end of transmission beeps or data bursts
	469.5000	205 DCS		Crane control - good signal strength
	464.5000	023 DCS	Brown Dot	Talking about supply delivery times, casual and informal chatter, heavy fading
	467.6125	047 DCS	FRS 10	"""got power to the roof"" ""bucket"" "
	151.5125	136.5 Hz		Crane control - sometimes very busy
	464.5500	165 DCS	Yellow Dot	"""realize you can't do it"" - sometimes suffering severe interference due to other groups / users on this frequency "
	462.5875	97.4 Hz	FRS 02	Spanish language
	154.5700	043 DCS	MURS 4	Crane control, portable radios
	466.0875	506 DCS		Weak signals - presumed construction based on previous logs and the DCS code used
	462.5750	654 DCS	FRS 16	Construction site or work crew
	464.5000	179.9 Hz	Brown Dot	"One side of a conversation...one station is extremely strong, heard ""comeback, I didn't copy that last part"" "
	466.1875	506 DCS		Construction / crane control
	462.6750	606 DCS	FRS 20	Retail user - portable radios
	154.4900	67.0 Hz		Highway maintenance or repair crew
	462.7125	159.8 Hz	FRS 07	Same group usually heard on this frequency and channel (downtown)
	466.0875	97.4 Hz		Weak construction or similar traffic
	469.5500	743 DCS 		Construction
	151.6250	065 DCS	Red Dot	AIRCARE EAGLE working FLIGHTCOM - both the aircraft and the base station (dispatcher) coming in loud and clear
	462.6000	455 DCS	FRS 17	Road construction or highway sign installation crew
	464.5500	179.9 Hz	Yellow Dot	"""close up the machine room...I'll go ahead and put the card on the elevator and we'll head down"" "
	457.5250	315 DCS		Local school - heard teachers talking to each other as well as maintenance staff and facilities management staff using same frequency and DCS code
	151.6250	67.0 Hz	Red Dot	"""right there"" ""okay leave it there don't fuck with it"""
	462.6875	141.3 Hz	FRS 06	Steel girder lengths being read, good to fair signals
	462.6250	67.0 Hz	FRS 18	"""back room"" ""second shelf"" - portables, no Roger Beeps heard "
	462.7875	021 DCS		Film or TV crew
	462.7000	192.8 Hz	FRS 21	"Heard mention of ""my DeWalt level"" "
	466.2125	97.4 Hz		"""do you want me to connect the tag line cable to the block and then connect the cable to that?"""
	151.5050	145 DCS		Crane control or maybe concrete pouring...general construction comms
	462.5625	250.3 Hz	FRS 01	Crane control or similar
	464.5500	156.7 Hz	Yellow Dot	"""base"" ""unit 4"" and other callsigns heard - very good signals....more than likely security company"
	467.8500	054 DCS	Silver Star	"""when you bring that to Vanessa up front"" ""meet me in my office"" ""okay, copy"" "
	462.6125	100.0 Hz	FRS 03	Unmodulated carrier (dead air) for 2-3 seconds...then a FRS call tone / alert tone
	151.5125	67.0 Hz		"""one foot to your right"" ""158.5"" ""138.2"" ""148.2"" - several other values heard, portables...poor to fair signals "
	467.9000	118.8 Hz	Red Star	"""303, thank you"" "
	154.5700	371 DCS	MURS 4	Spanish language, variable signal strength
	464.5500	732 DCS	Yellow Dot	Construction, sporadic signals
	461.1125	205 DCS		Crane control, fair to weak signals
	467.8500	179.9 Hz	Silver Star	Hotel or hospitality - portable radios
	151.6250	145 DCS	Red Dot	"""lower...lower....stay low...stay low...."""
	462.6125	127.3 Hz	FRS 03	"Local school - heard mention of ""1st graders"" - good signal "
	462.5750	143 DCS	FRS 16	FRS call tones heard...no voice traffic copied
	464.5500	754 DCS	Yellow Dot	Talking about hand sanitizer
	151.8200	103.5 Hz	MURS 1	"""two Maseratis, man!"" ""3"" ""no, 5!"" "
	466.0625	82.5 Hz		Facilities maintenance or engineering
	151.9550	67.0 Hz	Purple Dot	"Caught tail-end of a transmission - strong signal...mention of ""3 feet"" - likely tower crane control or similar type comms "
	467.6625	100.0 Hz	FRS 12	Road repair crew, flag men or traffic direction
	467.8500	627 DCS	Silver Star	Spanish language
	154.5700	145 DCS	MURS 4	Crane control, possibly alternate frequency - poor to fair signals...portable radios
	469.5500	114.8 Hz		Crane coordination and informal chatter
	462.5875	71.9 Hz	FRS 02	Parking lot attendants or traffic control
	467.9125	021 DCS		Coordinating lighting - possibly film crew
	464.4875	143 DCS		Spanish language, poor signals
	462.5625	67.0 Hz	FRS 01	Spanish language chatter
	464.5375	85.4 Hz		Hotel or hospitality - customer service and room cleaning/repair crew and engineering
	462.8375	021 DCS		TV or film crew
	462.5875	118.8 Hz	FRS 02	School or day care - sporadic signals
	469.5000	506 DCS		Construction
	462.6750	136.5 Hz	FRS 20	School - not as local as the other logs...confirmed this is the correct tone
	467.7625	627 DCS	"""J"" Dot"	Construction-related comms, mostly Spanish language with some English
	462.5875	023 DCS	FRS 02	IT or RF engineering or installation team
	464.5000	103.5 Hz		Security or building maintenance / facilities management
	462.6875	85.4 Hz	FRS 06	Possible counter-surveillance - reading off license plates and vehicle descriptions...noted use of military phonetic alphabet - NATO phonetic alphabet
	461.0625	047 DCS		Construction or similar traffic
	154.6000	371 DCS	MURS 5	"Spanish language chatter - appears to be a secondary channel or ""talkaround"""
	462.5500	123.0 Hz	FRS 15	Local or semi-local school
	462.8125	627 DCS		Construction chatter - informal CB-like conversation - likely a secondary or general chat channel
	462.6250	127.3 Hz	FRS 18	Spanish language, poor signal
	462.9125	192.8 Hz		Crane coordination and informal chatter
	462.7875	754 DCS		"""delivery zone 3"" ""that should be ready after 4:30"" "
	462.7250	67.0 Hz	FRS 22	UNID signal, tail end of transmission with FRS Roger Beep heard...strong signal but nothing else heard on frequency (or CTCSS tone)
	456.8125	023 DCS		Concrete construction contractor - portable radios
	466.3375	110.9 Hz		Talking about steel beams - likely construction materials delivery
	467.6375	051 DCS	FRS 11	Local school - possibly secondary channel
	467.8375	021 DCS		TV or film crew
	462.7125	79.7 Hz	FRS 07	"Spanish language chatter - noted two different types of ""Roger Beeps"" as well as at least one transmitter without a Roger Beep at all"
	462.7875	732 DCS		Construction or maybe facilities management
	467.9250	100.0 Hz	Blue Star	"""loading dock"" ""truck bay 2"" "
	451.8125	023 DCS		Concrete construction contractor - portable radios
	462.5625	97.4 Hz	FRS 01	"""okay 10 is clear, need to check the equipment room gallery for power"" "
	466.3625	023 DCS		Caught tail end of transmission, possibly RMC events based on frequency and DCS code used
5/12/2021	469.5000	205 DCS		Elevator floor pickup requests, supply delivery requests for fright or service elevator - heard mention of level 17, level 12
	464.5500	88.5 Hz	Yellow Dot	"""bring it up"" ""copy that thank you"" "
	462.5250	114.8 Hz		"Local school or day care - talking about students ""coming upstairs"", going to rooms, etc.  portables/simplex "
	464.5500	627 DCS	Yellow Dot	Construction - primary work site channel - very active at points
	467.5875	91.5 Hz	FRS 09	"""in the house?"""
	461.0625	67.0 Hz		"""okay I'll give you a call on 105 in a minute"" "
	469.5500	165 DCS		Construction or similar, including some informal chatter
	469.5000	732 DCS		Elevator pickup or delivery requests
	462.5750	165.5 Hz	FRS 16	"Weak, heard ""okay"" ""16"" and a couple other short transmissions "
	464.5500	67.0 Hz	Yellow Dot	talking about delivery times...heavy interference from other signals on freq
	464.8250	026 DCS		Crane control - simplex (portable radios)
	462.6125	74.4 Hz	FRS 03	Spanish language, weak signals poor copy
	462.7125	77.0 Hz	FRS 07	"""you got me?"" ""okay...let's go..let's go...12"" ""copy that, I'll let you know"" "
	464.5000	103.5 Hz	Brown Dot	Security or facilities management
	461.1875	67.0 Hz		Hotel or hospitality - sporadic activity
	151.6250	065 DCS	Red Dot	FLIGHTCOM working AIRCARE EAGLE
	151.5050	145 DCS		Construction or crane control
	469.5500	506 DCS		Construction or crane control
	462.6000	455 DCS	FRS 17	"""anything?"" ""nothing yet"" ""ugh okay"" "
	154.5275	065 DCS		"LIFE EVAC 4 calling FLIGHTCOM dispatch ""we're about 4 minutes out from landing"" "
	462.5875	118.8 Hz	FRS 02	"""Miss Sam, come in..."" - probably a local school "
	464.5000	67.0 Hz	Brown Dot	"""14 is clear..."" ""okay 18...18..."" ""basement...west corridor"" "
	154.5700	77.0 Hz	MURS 4	"""that area is already done"" ""okay copy"" "
	467.5625	67.0 Hz	FRS 08	Sounds like kids playing with walkie talkies
	467.8500	67.0 Hz	Silver Star	"""...customer..."" ""okay sounds good"""
	469.5500	732 DCS		"""level 12, going down"" ""pickup on 6, pickup on 6 please"" - elevator floor requests "
	462.6125	210.7 Hz	FRS 03	FRS call tones (alert tones) heard
	151.6250	67.0 Hz	Red Dot	"""no, that's the shit that you do"" "
	462.7125	159.8 Hz	FRS 07	Same users usually heard on this frequency and CTCSS combination
	467.8750	229.1 Hz	Gold Star	Crane coordination and crane control
	462.7250	136.5 Hz	FRS 22	"""section 2"" ""tables"" ""appointment for 1:45"" "
	158.4075	065 DCS		"LIFE EVAC 3 and FLIGHTCOM - FLIGHTCOM advising LIFE EVAC 3 that they are still on ""HANOVER FREQUENCY"" and they need to switch to the STATEWIDE EMS channel "
	462.5625	261 DCS	FRS 01	"Spanish language, heard construction sounds in the background....no ""Roger Beeps"" "
	462.6750	606 DCS	FRS 20	Retail users, fair to good signals with some very poor signals (obviously portable radios inside a building given the variations in signal strength)
	462.7125	146.2 Hz	FRS 07	School or day care facility
	151.8200	103.5 Hz	MURS 1	"""did you get that level?"" ""we might have to move that dumpster on Roseneath"" - construction/contractor (portable radios)"
	464.5500	506 DCS	Brown Dot	Crane control or job site command channel
	462.7625	023 DCS		Construction - Spanish and English heard
	467.6625	053 DCS	FRS 12	Local school - fair to good signal strength
	461.2625	67.0 Hz		Hotel/hospitality (portable radios)
	462.8625	88.5 Hz		Construction and crane control - mixture of English and Spanish
	467.5625	77.0 Hz	FRS 08	Local school
	154.4900	67.0 Hz		Construction - highway maintenance or similar crew - portable radios
	462.6625	136.5 Hz	FRS 05	Weak signal, no FRS call tones noted
	462.6125	127.3 Hz	FRS 03	Local school - appears to be primary frequency at this time
	464.5000	732 DCS	Brown Dot	Crane control or construction
	467.7125	116 DCS	FRS 14	Spanish language
	466.1125	79.7 Hz		Construction
	154.5700	371 DCS	MURS 4	Crane control - portable radios
	462.8125	627 DCS		Construction or job site coordination (secondary or backup channel)
	462.6375	131.8 Hz	FRS 04	Local school - appears to have switched to this channel
5/13/2021	469.5500	205 DCS 		Construction crew coordination - good to fair signals
	469.5000	506 DCS		Crane control, sporadic signals
	467.6625	67.0 Hz	FRS 12	"Elevator floor pickup requests - ""12 going down"" ""5 going up"", etc. "
	469.5500	732 DCS		Elevator floor pickup requests - also building materials delivery requests/orders for different floors/levels
	462.6375	97.4 Hz	FRS 04	"""stop for gas?"" ""okay 10-4"" "
	450.2250	023 DCS		discussion about classes going outside for recess, etc.  probably daycare or local school
	469.5500	165 DCS		"""grouting"" ""I don't care if it's going that way or not!"" - interfering with other signals on same frequency "
	154.5700	88.5 Hz	MURS 4	Talking about signs and closing lanes
	462.7125	97.4 Hz	FRS 07	Weak chatter heard, possibly construction site comms
	462.5750	203.5 Hz	FRS 16	Weak signal...sounded like car to car chatter or similar
	469.5000	205 DCS		Troy and Willie talking about hand wash stations and port-o-johns....probably a sanitary job site service company?
	467.5875	CSQ 	FRS 09	"""I can't hear anything but a jackhammer - say that again"" ""okay I got you now...give me a call when you're ready"" "
	154.5700	371 DCS	MURS 4	Crane control - good to strong signals
	467.6125	67.0 Hz	FRS 10	"""Dad we'll call you when we're coming back in"" ""okay sounds good"""
	462.5250	114.8 Hz		Local day care or school - strong signals from portable radios
	151.9550	179.9 Hz	Purple Dot	Building or facilities management - portable radios
	467.8500	627 DCS	Silver Star	Construction crew - work site control channel, with some informal chatter
	467.6625	053 DCS	FRS 12	School - good signals, usually stronger than the downtown (presumed) construction users on this same channel
	151.6250	167.9 Hz	Red Dot	Crane Master truck to truck comms - also on-site (portable radios)
	467.5625	67.0 Hz	FRS 08	FRS call tones heard
	158.4075	065 DCS		FLIGHTCOM dispatching Medevac helicopters
	462.6875	67.0 Hz	FRS 06	Two kids playing with walkie talkies - no CTCSS or DCS tones or codes in use
	464.5000	77.0 Hz	Brown Dot	Sounds like a survey crew
	151.5125	67.0 Hz		Construction - probably portable radios
	462.7125	159.8 Hz	FRS 07	Downtown building maintenance or facilities management - usual users of this frequency channel and CTCSS tone
	466.0875	506 DCS		Crane control and construction comms
	464.5000	165 DCS	Brown Dot	Construction comms
	462.5875	118.8 Hz	FRS 02	Local school - appears to be secondary or backup channel
	462.8875	88.5 Hz		Crane control, mostly Spanish language
	464.5375	85.4 Hz		Hotel/hospitality front desk dispatcher and room cleaning operations
	464.5000	179.9 Hz	Brown Dot	Room service or repair requests
	467.8125	047 DCS	"""K"" Dot"	"""tanks 2 and 3 are both empty"" ""copy that"" "
	462.5500	71.9 Hz	FRS 15	"""take a look around and get back to me"" "
	467.8875	205 DCS		"""I'm on 11 now, coming down"" "
	462.6750	606 DCS	FRS 20	Retail operations - including loading dock coordination, customer service etc.
	151.8200	103.5 Hz	MURS 1	Construction site coordination - concrete or general building contractor
	462.5875	67.0 Hz	FRS 02	Very weak signals, late morning...unable to ID
	464.5500	67.0 Hz	Yellow Dot	Construction equipment delivery or repair coordination
	466.0875	97.4 Hz		Construction and related comms
	462.6750	136.5 Hz	FRS 20	School - confirmed this is a separate group from the retail store using the same frequency
	462.8625	88.5 Hz		Crane control and coordination - mix of Spanish and English traffic
	462.8250	162.2 Hz		"""she wants ham and cheese for lunch"" ""okay got it"" "
	462.6125	CSQ	FRS 03	"""do you hear me on this channel?"" ""how about now?"" ""okay good - take that next one away"" "
	464.5500	79.7 Hz	Yellow Dot	"""alright I dropped off the 100A and 100B trolley"" ""okay 10-4"" "
	462.6250	127.3 Hz	FRS 18	"Heard mention of ""order number"" "
	467.9250	67.0 Hz	Blue Star	Security or facilities management (portable radios)
	462.6875	141.3 Hz	FRS 06	Local school - appears to be secondary or backup channel
	154.4900	67.0 Hz		Road repair or maintenance crew - portable radios
	469.5000	732 DCS		"""let me call you back in a moment"" "
	467.6375	67.0 Hz	FRS 11	"""bring that up to 13....drop off on 13...."" "
	467.8750	165 DCS	Gold Star	Construction site equipment and supply delivery coordination
	462.5625	77.0 Hz	FRS 01	Spanish language, poor signals
	151.6250	67.0 Hz	Red Dot	"""good radio check...I'm gonna try my handset, hang on"" - sounded like portable radios...possibly road repair or highway sign installation company - previously monitored using common default factory VHF radio channels - see Motorola RDV5100 and similar radios "
	467.7625	506 DCS	"""J"" Dot"	Informal chatter, likely construction site or work site comms
	462.6625	116 DCS	FRS 05	Sporadic signal - heard vehicle descriptions being read over the air - probably flaggers / flag men or similar
	464.5000	732 DCS	Brown Dot	Construction site comms - fair signals
	462.5875	97.4 Hz	FRS 02	"Crane control and general construction comms - fair signal with FRS ""Roger Beeps"" "
	462.6375	77.0 Hz	FRS 04	"""bring that back in"" ""okay but the only way to..."" [faded out]"
	461.2625	141.3 Hz		Coordinating safety inspection of some kind - good signals
	467.8125	131.8 Hz	"""K"" Dot"	Materials delivery times chatter
	462.6875	85.4 Hz	FRS 6	"Reading vehicle descriptions and license plate numbers - fair to poor signal...FRS ""Roger Beeps"" noted "
	461.3125	023 DCS		Event management - probably RMC Events
	151.8200	67.0 Hz	MURS 1	Catering or hospitality - talk about orders being taken on the elevator, etc...fair to poor signals
	462.6500	632 DCS	FRS 19	"""second one"" ""thank you"" ""okay, Roger that."" - good signals around 2:30-2:45PM with FRS ""Roger Beeps"" "
	467.6875	065 DCS	FRS 13	Heard background noise, sounded like a school playground
	467.8625	072 DCS		"Talking about materials lots, setting up ""lines"""
	469.5500	114.8 Hz		Crane coordination with informal chatter
	462.7000	67.0 Hz	FRS 21	Weak signal - possibly vehicle to vehicle comms on the interstate
	466.3625	023 DCS		Event management - probably RMC Events
	462.6375	131.8 Hz	FRS 04	Local school - primary operations
	461.2625	023 DCS		Event management - probably RMC Events
	462.5500	123.0 Hz	FRS 15	"""on 2! on 2!"" ""come on, on 2!"" ""okay copy that on 2"" "
5/14/2021	469.5000	712 DCS		Coordinating materials distribution or delivery
	467.6625	67.0 Hz	FRS 12	"Elevator floor pickup requests - usual traffic heard on this frequency and CTCSS tone (with FRS ""Roger Beeps"") "
	154.5275	065 DCS		FLIGHTCOM working other medevac aircraft
	464.5500	627 DCS	Yellow Dot	"""we need that torch on the roof"" ""that truck is gonna be here in about 20 minutes"" ""once you fill all those tanks up"" - Construction work site coordination and operations - likely primary channel "
	462.8625	88.5 Hz		Crane coordination and control - appears to be most active in mornings and evenings, possibly associated with a late-night shift crew
	154.5700	371 DCS	MURS 4	Crane control and construction comms
	151.6250	065 DCS	Red Star	FLIGHTCOM and AIRCARE EAGLE doing radio checks
	467.8500	179.9 Hz	Silver Star	Hotel or hospitality operations
	462.5625	77.0 Hz	FRS 01	Spanish language, fair/poor signals....this group has been logged previously using this CTCSS tone
	469.5000	205 DCS		Chatter about portable toilets and other job site sanitary equipment
	467.6625	053 DCS	FRS 12	Local school - sporadic activity...most active in morning, around mid day and in early to mid afternoon
	462.6750	606 DCS	FRS 20	Retail store - primary operations channel (previously monitored numerous times)
	461.2125	67.0 Hz		Hotel/hospitality operations - portable radios
	469.5500	114.8 Hz		Crane coordination and informal chatter...often extremely informal
	151.5050	167.9 Hz		Crane Master - secondary or backup operations channel
	464.5000	67.0 Hz	Brown Dot	"""basement corridor"" "
	462.5875	97.4 Hz	FRS 02	Crane control operations
	466.0875	506 DCS		Construction operations
	462.5625	250.3 Hz	FRS 01	"""elevator"" ""I'm bringing up order 3"" ""okay thank you"" (weak to fair signal)"
	462.5875	118.8 Hz	FRS 02	Catering company or hospitality
	451.8000	023 DCS		Concrete contractor or similar materials construction company
	158.4075	065 DCS		FLIGHTCOM doing radio checks
	462.6250	127.3 Hz	FRS 18	Local school or day care - one of many groups that use this very popular frequency channel and CTCSS tone combination
	464.5000	94.8 Hz	Brown Dot	Fire alarm or security alarm installation crew or facilities management guys
	151.6250	167.9 Hz	Red Dot	Crane Master - primary operations channel
	456.8125	703 DCS		Spanish language, sporadic signal
	154.5700	67.0 Hz	MURS 4	Two guys talking about the recent spike in fuel prices
	462.6000	455 DCS	FRS 17	Caught the tail end of a very strong signal
	464.5500	732 DCS	Yellow Dot	Spanish language - fair signal...but weaker than other transmissions usually heard on this frequency
	462.5500	123.0 Hz	FRS 15	"heard reference to ""level 3"" and ""basket"" - maybe construction site materials delivery or tower crane control comms "
	462.9125	192.8 Hz		Crane coordination and control
	462.6375	131.8 Hz	FRS 04	Local school - appears to be primary channel for this group
	469.5500	023 DCS		Spanish language chatter
	462.8125	627 DCS		Construction site or work site comms - appears to be secondary or backup channel
5/15/2021	466.3125	156.7 Hz		"""where supposed to report back that...that concrete is blue screen on it this morning...before we leave this floor"" ""yeah 10-4 we got guys that are taking care of that"" "
	469.5500	114.8 Hz		Crane coordination and informal chatter...often extremely informal - Spanish and English, switching rapidly back and forth between the two at points
	464.5500	627 DCS	Yellow Dot	Construction site coordination - primary channel
	462.5875	97.4 Hz	FRS 02	Crane control - mix of Spanish and English
	456.8125	023 DCS		Concrete or other building materials delivery and building contractor coordination
	469.5500	205 DCS		High rise construction - including supply requests for different floors, etc
	462.5750	654 DCS	FRS 16	Crane control - good strong signal at 9:05AM
	469.5000	506 DCS		Construction crew or similar
	462.6625	97.4 Hz	FRS 05	"""yeah I'm the next lane over...are we gonna take this exit?"" "
	151.6250	136.5 Hz	Red Dot	Crane control, heard several measurements being read over the air....likely portable radios going by signal strength
	154.5700	371 DCS	MURS 4	Crane control and construction - portable radios with some informal chatter
	466.0875	506 DCS		Construction crew or similar
	464.5000	127.3 Hz 	Brown Dot	Building inspectors or facilities management - fair signal but sporadic activity
	151.6250	065 DCS		FLIGHTCOM and AIRCARE EAGLE doing radio checks - FLIGHTCOM dispatching
	451.8125	023 DCS		Concrete or other building materials delivery and building contractor coordination
	462.7250	67.0 Hz	FRS 22	"Kids playing on radios - heard several FRS call tones or alarm / alert tones in a row...fair signals...followed by 8 or 10 alert tones or call tones in a row and ""HELLO!"" ""I can't hear you on the walkie talkie! hello!!! I can't hear you!"" etc etc  "
	462.9125	192.8 Hz		Crane coordination - can hear other radio chatter in the background at points...similar to the other coordination frequencies
	462.6375	CSQ	FRS 04	"""just watch my rear and make sure everything is okay...we're gonna take a right and then get on the downtown expressway"" - more car to car comms - good signals...no CTCSS or DCS in use (carrier squelch)....about 4-5 minutes after initially heard transmission...signal strengths have decreased significantly, which backs up the vehicle to vehicle or car to car type comms theory "
	158.4075	065 DCS		FLIGHTCOM working LIFE EVAC 3 - aircraft mission particulars, fuel status, etc. and next mission assignment - very strong signals for both the helicopter and the base station
5/16/2021	464.5000	77.0 Hz	Brown Dot	"""we'll call him back and find out what time those loads of PVC are coming"" "
	462.7250	136.5 Hz	FRS 22	"""okay next one"" - weak signal...able to decode CTCSS and not much else "
	469.5000	165 DCS		Construction site comms
	466.3125	156.7 Hz		"""where is he going!?"" - typical group heard on this frequency and CTCSS tone combination "
	467.8500	179.9 Hz	Silver Star	"Hotel or hospitality operations - portable low power radios...heard ""front desk"" "
	462.5750	023 DCS	FRS 16	"""can I get a radio check on channel 9?"" ""I have you on here"" ""copy that"" "
	462.6250	67.0 Hz	FRS 18	Parking lot operations or traffic direction / flaggers
	464.5375	85.4 Hz		"""red Kia, lot 2"" "
	461.1625	67.0 Hz		Room cleaning requests - fair to poor signal, likely downtown hotel operations
	467.8750	229.1 Hz	Gold Star	Crane control and coordination
	462.6875	141.3 Hz	FRS 06	"""can you zoom in?"" ""yeah just stay on...[unreadable]"" - sounds like security guards or maybe loss prevention? could also be film or TV production crew "
	464.5500	627 DCS	Yellow Dot	"The ""Usual Suspects"" found on this frequency and DCS code combination - sometimes very busy "
	462.6375	114.8 Hz	FRS 04	talking about parking cars and coordinating traffic
	464.5000	103.5 Hz	Brown Dot	Hotel or hospitality
	462.7250	67.0 Hz	FRS 22	"""did you copy that?"" ""okay 10-4"" - weak signals...does not appear to be the same group heard yesterday using this frequency and tone "
	158.4075	065 DCS		"LIFE EVAC 4 ""down and secure at Chippenham"" confirmation transmission by FLIGHTCOM dispatch center "
	467.6375	77.0 Hz	FRS 11	Faint signal...female speaker...but good CTCSS decode
	464.5500	67.0 Hz 	Yellow Dot	Spanish language
	467.5625	67.0 Hz	FRS 08	"""okay she's good"" - weak signal "
5/17/2021	466.0875	506 DCS		Construction / work site comms
	451.8125	732 DCS		Construction site/work site coordination comms - portable radios
	158.4075	065 DCS		LIFE EVAC 1 working FLIGHTCOM doing a training flight in the local area - strong signals from aircraft and dispatch radios
	467.6625	67.0 Hz 	FRS 12	Elevator floor pick up and drop off requests
	466.3125	156.7 Hz		Construction site operations, sporadic signals
	154.5700	043 DCS	MURS 4	Construction site or tower crane control operations....noisy channel with interference from data bursts telemetry systems on frequency
	469.5000	165 DCS		Construction operations...- portable radios
	467.5625	243 DCS	FRS 08	Local school or similar - fair to good signals
	151.6250	145 DCS	Red Dot	Heard tail end of strong transmission
	469.5500	205 DCS		Crane control
	466.0875	97.4 Hz		Construction site coordination comms
	151.5125	136.5 Hz		Crane control - usual user of this frequency and CTCSS tone
	467.6625	053 DCS	FRS 12	Local school - appears to be the same group previously monitored using this DCS code on this frequency
	467.7875	132 DCS		"Voice inversion SCRAMBLED transmission secure mode scrambler with ANI data bursts end of transmission EOT ""squawk"" - first heard at 10:42AM"
	469.5500	165 DCS		Weak signal heard on a very active frequency
	462.6375	131.8 Hz	FRS 04	Local school - appears to (now) be primary channel
	467.8125	103.5 Hz	"""K"" Dot"	Hotel or hospitality ops
	464.5000	67.0 Hz	Brown Dot	Heard mention of sanitary equipment, probably for a job site or similar - possibly a different group / company / contractor than previously monitored?
	462.5625	CSQ	FRS 01	"Spanish language chatter - with ""Roger Beeps"" "
	461.1375	506 DCS		Construction - weak to fair signals
	462.6125	74.4 Hz	FRS 03	"traffic control / flaggers / flag men - portable FRS radios with typical FRS-style ""Roger Beeps"" "
	462.6750	136.5 Hz	FRS 20	Local school - further away than the other several schools or similar facilities heard, slightly stronger signals than retail user on same channel
	462.8625	88.5 Hz		Crane control / coordination
	151.6250	065 DCS	Red Dot	FLIGHTCOM dispatch - base station communicating with airborne units
	469.5625	021 DCS		TV or film crew - possibly production assistants or transportation coordination
	462.7250	136.5 Hz	FRS 22	Local school - coordinating pick ups and drop offs
	464.5500	205 DCS	Yellow Dot	Construction site comms - talking about weather forecast
	467.5625	243 DCS	FRS 08	Local school or day care - portable radios
	462.5250	114.8 Hz		Sounds like a day care facility - can hear children in background - must be pretty local, strong signals...coordinating pick ups of children
	461.2375	612 DCS		"""...528"" ""wooo hoo!"" ""...drone"" - broken signals, only able to copy bits and pieces "
	462.5875	023 DCS	FRS 02	"""thank you"" - female speaker, strong signal "
	467.9125	021 DCS		"""we're gonna [unreadable] back up again tomorrow...gonna talk to the director"" ""copy that"" - probably film or TV production crew going by DCS code used "
	469.5500	114.8 Hz		Crane coordination and general informal chatter - other radios heard in background of some transmissions....this frequency is active with numerous different users at points and this user appears to be the strongest signal basically every time
	462.5500	123.0 Hz	FRS 15	"""I'm gonna get a message to her real quick"" - sounded like the same group from the local school, might have switched frequencies again "
	466.3625	612 DCS		"""Don't wanna wait too long..."" - portables "
5/18/2021	464.8250	026 DCS		Crane control - portable radios - simplex
	467.6625	67.0 Hz	FRS 12	"Elevator floor pick up and drop off requests - the usual traffic with FRS ""Roger Beeps"""
	457.5250	315 DCS		Local school - portable radios - simplex
	154.4900	67.0 Hz		Highway construction or contractor - possibly the same group previously heard using this frequency and CTCSS tone
	462.6875	85.4 Hz	FRS 06	Security or surveillance - similar to traffic heard on this channel frequency and CTCSS tone previously
	466.3125	156.7 Hz		Construction site comms - Spanish and English heard
	467.6625	053 DCS	FRS 12	"""before she leaves today...I want to talk to her about Floyd"" - local school, presumably the same one usually heard on this channel / frequency and DCS code combination "
	154.5700	371 DCS	MURS 4	"""well if he wants to go for a ride he needs to get off [unreadable]"" - sounds like the same group previously monitored using this DCS code on this frequency "
	462.5625	CSQ	FRS 01	Spanish language, weak to fair signal...no CTCSS or DCS tone or code in use - carrier squelch
	461.2625	631 DCS		"""that's my bad...I know it was my idea yesterday but...[unreadable]"""
	462.5250	114.8 Hz		Local school or day care - must be very local....very strong signal loud and clear - portable radios
	464.5000	82.5 Hz	Brown Dot	Spanish language chatter - strong signals, possibly portable radios being used for car to car comms
	158.4075	065 DCS		FLIGHTCOM dispatcher working LIFE EVAC 1 and LIFE EVAC 2 airborne units (medevacs)
	462.7125	159.8 Hz	FRS 07	Same usual group usually heard on this frequency channel and CTCSS tone - downtown building security or facilities management or similar operation
	462.8375	631 DCS		Possibly coordinating materials delivery
	466.0875	506 DCS		Construction site coordination - talking about truck supply delivery
	464.5000	67.0 Hz	Brown Dot	Electricians - testing breakers, reset requests, etc.
	469.5000	205 DCS		Construction site comms
	462.7125	79.7 Hz	FRS 07	Crane control
	462.6375	131.8 Hz	FRS 04	School or day care? weaker signal, not (usual) local users that appear to have changed channels frequencies anyway
	464.5500	114 DCS	Yellow Dot	"heard mention of ""traffic"" - no other useful traffic heard using this DCS code - other traffic active on frequency at times very busy with chatter "
	466.1875	261 DCS		"""okay bring it back up..."""
	467.5875	91.5 Hz	FRS 09	FRS call tones / alert tones heard
	462.6250	127.3 Hz	FRS 18	Local school - possibly alternate or backup channel - this user has changed channels / frequencies and tones several times
	462.8125	021 DCS		TV or film crew
	464.5000	77.0 Hz	Brown Dot	"""you're coming off the center...you're coming off the center"" (female voice....with interference from other activity on frequency / channel)"
	462.7250	136.5 Hz	FRS 22	Local school - appears to be new primary channel - this user continues to switch channels and tones
	467.7875	132 DCS		Voice inversion SCRAMBLED scrambling scrambled transmissions with ANI data burst - automatic transmitter ID bursts at the end of transmissions
	461.2625	023 DCS		RMC Events - event management - active at Richmond Flying Squirrels Stadium
	462.6750	606 DCS	FRS 20	Warehouse coordination - possibly related to the usual retail store users heard on this channel frequency DCS code combination
	466.3625	023 DCS		RMC Events - event management - active at Richmond Flying Squirrels Stadium
	467.8500	054 DCS	Silver Star	"""what is your location?"" ""the fountain"" ""you're in the powder room?"" ""no, I'm at the fountain"" ""okay copy"" "
	466.2625	023 DCS		RMC Events - event management - active at Richmond Flying Squirrels Stadium
	461.3625	023 DCS		RMC Events - event management - active at Richmond Flying Squirrels Stadium
	466.3125	023 DCS		RMC Events - event management - active at Richmond Flying Squirrels Stadium
	151.8200	103.5 Hz	MURS 1	Contractor - likely same user previously heard using this CTCSS tone - including general informal chatter
	461.2375	631 DCS		"""okay hold for a minute"" ""check back around"" "
	464.3250	546 DCS		RMC Events - event management - active at Richmond Flying Squirrels Stadium (simplex)
	461.2875	532 DCS		"""get the video of those....[unreadable]"" ""shorts..."""
	467.8625	021 DCS		TV or film crew - possibly production company comms
	461.2375	612 DCS		"Weak/broken up signals - similar to what was monitored yesterday on this frequency and DCS combination - heard ""well, we have a question for him"" "
	464.5500	023 DCS	Yellow Dot	Event management comms - possibly also RMC Events - same signal strength as the RMC Events channels...not 100% sure though
	467.9250	229.1 Hz	Blue Star	Crane control - appears to be alternate channel
	469.4875	021 DCS		TV or film crew
	462.6625	82.5 Hz	FRS 05	"""can you hear me now?"" ""I can't hear [unreadable] on channel 6"" - pretty standard style FRS ""Roger Beeps"" in use "
	461.3375	612 DCS		Possibly same group using this as an alternate - see logs for same date and DCS code
	154.4900	023 DCS		"""did you get that last vehicle?"""
	466.3625	532 DCS		Weak signals, maybe also related to TV or film production or related services?
	467.5625	CSQ	FRS 08	"Two guys talking about somebody ""being hot"", ""knowing when he's hot"" ""having the next one"" and ""he's in the game!"" - heavy use of ""10-4"" and all transmissions have FRS Roger Beeps...no CTCSS tone or DCS code in use - carrier squelch only "
5/19/2021	461.2375	631 DCS		Hearing weak transmissions similar to those heard yesterday on same frequency and DCS code
	151.6250	546 DCS	Red Dot	"Crane control - weak to fair signals...heard the tell-tale ""cable down...cable down..."" ""hold your cable"" etc. "
	466.3125	156.7 Hz		Construction site comms - mix of Spanish and English
	462.5875	71.9 Hz	FRS 02	"""Benny, what's that?"" ""you can't say that on the radio!"" - weak/fair signals with Roger Beeps "
	464.5000	67.0 Hz	Brown Dot	Electricians or engineers checking alarm system circuits
	462.6750	606 DCS	FRS 20	Store or retail use
	461.1625	67.0 Hz		Engineering or repair crew - probably a downtown hotel or high rise
	462.8125	627 DCS		Construction site operations - likely secondary or backup / talkaround channel
	462.5625	67.0 Hz	FRS 01	10-15 seconds of dead air - unmodulated carrier...no Roger Beeps heard
	469.5500	205 DCS		Construction site operations
	462.5500	162.2 Hz	FRS 15	"""okay copy"" - two different groups using two different CTCSS tones on at the same time"
	151.5125	136.5 Hz		Crane control - usual traffic heard on this CTCSS tone on this frequency
	151.8200	103.5 Hz	MURS 1	"""alright 10-4"" - usual users of this frequency and CTCSS tone heard "
	462.5500	123.0 Hz	FRS 15	"""insulator"" - other unreadable transmissions mixing in - later, stronger signals in Spanish and English, presumed construction site comms "
	466.2875	506 DCS		Construction site comms
	462.7125	159.8 Hz	FRS 07	Same group usually heard on this frequency channel and CTCSS tone...downtown building or facilities management or security, possibly also related to parking garage operations
	151.6250	023 DCS	Red Dot	"""level A"" heard loud and clear "
	462.6875	85.4 Hz	FRS 06	"""copy that"" - appears to be the same group or user previously monitored using this CTCSS on this channel "
	154.5700	371 DCS	MURS 4	Same group previously monitored on this frequency and DCS code combination
	158.4075	065 DCS		FLIGHTCOM calling LIFE EVAC 4 (only able to copy FLIGHTCOM dispatcher signals at this time...)
	462.5625	CSQ	FRS 01	"Spanish language comms, unique style FRS ""Roger Beep"" - at time transmissions were first heard, no other active users on same frequency "
	469.5500	205 DCS		Construction site or crane control comms
	151.6250	065 DCS	Red Dot	FLIGHTCOM dispatch calling LIFE EVAC 4 on alternate frequency - was having issues contacting on previous frequency
	462.6500	632 DCS	FRS 19	"""get a name on the..."" ""do you want me to check him in?"" ""...bulb out..."" ""okay"" - Roger Beeps noted in use "
	466.0875	023 DCS		Construction materials delivery coordination
	461.2125	67.0 Hz		Hotel or hospitality operations
	154.5700	047 DCS	MURS 4	"""bring it up now...right now!"" "
	462.5250	114.8 Hz		Local school or day care - very good signals...must be pretty local
	151.6250	67.0 Hz	Red Dot	"""come in, B..."" ""can you hear me man?"" - weak signal...likely portable radios "
	464.5000	103.5 Hz	Brown Dot	Hotel or hospitality operations
	466.2625	506 DCS		Construction site comms
	462.6125	127.3 Hz	FRS 03	Local school or day care - possibly secondary or backup channel
	464.5375	85.4 Hz		Hotel or hospitality operations
	151.9400	110.9 Hz	MURS 3	"Heard ""okay 3"" and ""take it down"" ""these trees over here where...[unreadable]"" ""there's plenty of shade there"" "
	462.6125	210.7 Hz	FRS 03	Caught tail end of a FRS transmission...with the usual FRS Roger Beep...
	154.5275	065 DCS		FLIGHTCOM working several aircraft
	469.5000	205 DCS		Construction site comms, crane control...sporadic activity
	462.6500	351 DCS	FRS 19	Spanish language - mixing in with other comms on same frequency
	467.5625	CSQ	FRS 08	"""he's on his way"" ""okay bring up...."""
	462.8875	88.5 Hz		Crane control - Spanish and English language heard...also some general informal chatter
	466.0875	97.4 Hz		Weak / fair signals - presumed to be the same users previously heard
	462.6250	127.3 Hz	FRS 18	School or day care - pretty local based on signal strength
	467.6375	051 DCS	FRS 11	Local school or similar - not as strong as others but decent considering this is a low-power channel (or it's supposed to be anyway)
	151.5125	67.0 Hz		Weak signals heard...either low volume levels or unmodulated carrier (dead air) - probably portable radios )
	464.5500	77.0 Hz	Yellow Dot	Weak signal - but confirmed CTCSS tone decode - frequency currently active with stronger signals
	466.0875	506 DCS		"""in the truck driver game they call that falling asleep!"" - construction site comms "
	464.5000	346 DCS	Brown Dot	"""put all your shit on there"" ""okay man"" ""....like Lane and all that shit..."" - informal chatter "
	467.6125	073 DCS	FRS 10	Radio checks - two different UNID unidentified stations, Roger Beeps heard
	462.7250	136.5 Hz	FRS 22	Local school - appears to be primary channel (at least for now)
	151.6250	371 DCS	Red Dot	"""8"" ""22"" and a couple other numbers heard (in Spanish) "
	464.5000	432 DCS	Brown Dot	Tail end of unmodulated carrier (dead air) - strong signal, good DCS code decode
	462.6750	136.5 Hz	FRS 20	"School - somewhat local...sometimes it's the same signal strength as the retail store on this same channel / frequency, other times one or the other is stronger...the school appears to be using FRS handheld walkie talkies with user-selectable CTCSS / DCS ""sub channels"" or ""privacy codes"""
	469.5500	114.8 Hz		Crane control / crane coordination and some informal chatter
	151.8200	67.0 Hz	MURS 1	"""maybe wait a second or so after I finish talking and *then* try to talk!"" - female speaker - strong signal "
	466.2625	023 DCS		RMC Events - heard evening radio checks at 5:21PM and 5:22PM
	466.3125	023 DCS		RMC Events - radio check heard on this frequency as well
	466.3625	023 DCS		RMC Events - parking coordination comms
	467.7625	546 DCS	"""J"" Dot"	"""sector 121"" ""okay copy that"" "
	461.3125	023 DCS		RMC Events - parking coordination comms
	462.7125	CSQ	FRS 07	"Group driving down (or up) 95 - ""I told her we'd be there in about 2 hours"" ""it's a block of rooms...including the corner handicap room"" ""okay I had to let that van in behind you"" - signals faded in rapidly and then faded out just as rapidly...pretty standard FRS Roger Beeps in use, no CTCSS or DCS in use - true carrier squelch "
	462.5500	CSQ	FRS 15	"""Dugout...dugout...come in..."" ""okay..Bishop is warming up...just wanted to confirm, thank you"" - baseball team comms...verified no CTCSS or DCS tone or code in use "
	462.7250	136.5 Hz	FRS 22	Different user/group than the daytime (school) user of this frequency and CTCSS tone...sounded like two male speakers whispering into their radios...very strong signals, but difficult copy
	462.5875	67.0 Hz	FRS 02	"""okay copy that, I see the white truck coming around the corner now"" "
	469.5500	165 DCS		Construction site equipment and supply delivery coordination
5/20/2021	466.1875	506 DCS		Construction
	466.0875	506 DCS		Construction comms
	464.5500	627 DCS	Yellow Dot	Usual construction site - high rise tower - comms heard on this channel and DCS code - very active
	467.6625	67.0 Hz	FRS 12	Elevator floor requests -'usual traffic for this frequency
	154.5700	371 DCS	MURS 4	Crane control / construction site comms - portable radios
	466.3125	156.7 Hz		Construction site comms - sporadic signals...sometimes active for short bursts at a time - Spanish and English heard
	154.4900	67.0 Hz		Highway construction or highway sign contractor - portable radios
	462.5875	71.9 Hz	FRS 02	Weak signals with Roger Beeps....sounds like the same chatter heard yesterday on this channel frequency and CTCSS tone combination
	462.6750	606 DCS	FRS 20	Retail store and warehouse operations...more or less the same signal strength as the school using the same channel
	451.8125	023 DCS		Concrete or cement contractor - portable radios
	467.6625	053 DCS	FRS 12	Local school - sporadic signals....most active in morning...middle of day and afternoons
	466.1875	261 DCS		Construction comms
	158.4075	065 DCS		FLIGHTCOM working LIFE EVAC 1 and other medevac aircraft
	462.5625	77.0 Hz	FRS 01	Very weak signals - sounded like Spanish language....was able to decode CTCSS and also heard short 3-tone Roger Beep end of transmission EOT burst
	462.6750	136.5 Hz	FRS 20	Heard female voices - sounded like a school or similar...fair to poor signals (mostly) with some stronger ones at points
	469.5000	506 DCS		Construction site comms - sometimes mixing with other group / user on same frequency
	469.5000	205 DCS		Talking about trucks arriving late..
	462.6250	127.3 Hz	FRS 18	Catering company? poor to fair signals...not super local
	456.8125	023 DCS		Concrete or cement contractor - portable radios
	151.6250	546 DCS	Red Dot	Crane control and general construction comms
	462.5875	118.8 Hz	FRS 02	Heard faint Spanish language chatter - presumably low-power portable handheld walkie talkie radios - Retevis or Baofeng radios
	466.1875	023 DCS		Concrete or cement contractor - portable radios
	467.6875	466 DCS	FRS 13	Weak signal picked up - possibly car to car chatter...signals rapidly gained strength and then rapidly lost it
	462.8125	627 DCS		"Construction site / job site comms - probably a secondary or fallback ""talkaround"" channel "
	466.1375	103.5 Hz		"""15 more feet..."" ""rope"" ""line"" and similar heard..""bring that line back...okay there..."" "
	466.3125	023 DCS		RMC Events - Event Management related comms
	467.7125	67.0 Hz	FRS 14	Facilities management? unable to really ID due to weak signal and poor copy
	151.6250	77.0 Hz	Red Dot	"""6, number 6 please"" ""can you bring it back up?"" ""come over"" - a couple transmissions had what sounded like a ringing telephone or other alarm or alert going off in the background audio "
	469.5000	732 DCS		Construction or work site coordination...weak to fair signal
	154.5275	065 DCS		FLIGHTCOM dispatch working LIFE EVAC 3
	466.3625	023 DCS		RMC Events - parking/traffic control
	469.5500	732 DCS		Construction or work site coordination...weak to fair signal
	464.5000	546 DCS	Brown Dot	Spanish language - sounds like crane control to me
	462.6250	371 DCS	FRS 18	"""give me 30 more feet"" ""crossbeam"" ""hold your cable"" - possibly a new crane control net frequency and DCS code??"
	461.0875	023 DCS		Concrete or cement contractor - portable radios
	462.6875	141.3 Hz	FRS 06	Local school - possibly secondary channel
	461.2625	023 DCS		RMC Events - parking/traffic control
	462.7250	136.5 Hz	FRS 22	Local school - probably primary channel
	467.6125	CSQ	FRS 10	FRS call tones / alert tones heard...fair to weak signals
	462.5750	77.0 Hz	FRS 16	Caught tail end of a transmission, no Roger Beep or other end of transmission tones or beeps heard
	461.1625	67.0 Hz		Hotel or hospitality
	461.3125	023 DCS		RMC Events - parking/traffic control
	462.7250	252 DCS	FRS 22	"""Miss Hendricks"" or ""Miss Hendrix"" doing a radio check "
	466.2625	023 DCS		"RMC Events - talking about vehicles ""dropping off"" and and such...probably traffic control and/or parking...very active at points  - appears to be primary frequency...appears to be the most active of the known RMC Events event management frequencies at this time"
	462.5500	CSQ	FRS 15	"""Dugout"" heard - appears to be the same group heard yesterday evening...likely bullpen / pitching coach or baseball staff comms "
	151.6250	065 DCS	Red Dot	FLIGHTCOM dispatch radio for AIRCARE EAGLE
5/21/2021	464.8250	026 DCS		Crane control
	469.5000	205 DCS		Construction site / work site materials delivery coordination
	467.6125	CSQ	FRS 10	Sounds like a parent and a child or children talking on FRS walkie talkies - FRS style Roger Beeps noted
	469.5500	023 DCS		Concrete or cement contractor - portable radios
	154.4900	67.0 Hz		Contractor - highway maintenance or sign installation or repair crew - portable radios
	462.6750	606 DCS	FRS 20	Retail use - in-store comms and warehouse/inventory comms
	151.6250	67.0 Hz	Red Dot	Contractor - highway maintenance or sign installation or repair crew - portable radios
	462.5625	77.0 Hz	FRS 01	Spanish language chatter
	469.5000	165 DCS		"Talking about ""hand sanitizer stations"" "
	158.4075	065 DCS		FLIGHTCOM dispatch working LIFE EVAC 1 and other medevac aircraft
	467.6625	67.0 Hz	FRS 12	"Elevator floor pick up and drop off requests - ""pick up on 14"" ""pick up on 11 please"" etc. "
	466.0875	023 DCS		Concrete or cement contractor - portable radios
	464.5000	712 DCS	Brown Dot	Spanish language - probably construction site comms
	467.6625	053 DCS	FRS 12	Local school - previously monitored using this frequency channel and DCS code combination
	151.6250	065 DCS	Red Dot	FLIGHTCOM dispatcher talking to AIRCARE EAGLE
	469.5500	165 DCS		"""okay fine well then give him your name"" "
	151.5125	67.0 Hz 		Weak voice traffic...last second of transmission heard, solid CTCSS tone decode
	462.5250	114.8 Hz		Local day care - coordinating location of teachers, classes, etc. - must be very local due to strong signal strength
	469.5000	732 DCS 		"""pickup on 6"" - elevator floor requests "
	467.5625	CSQ	FRS 08	"""Michael..."" - female speaker, FRS Roger Beeps heard "
	462.9125	192.8 Hz		"""crane operator"" ""yeah Roberto came back yesterday"" "
	462.5625	67.0 Hz	FRS 01	"""hey pull in here I found a good spot"" ""okay got it"" ""yeah big pimpin' right?"" - followed by more business-like comms...(same guys) - crane control, sometimes with heavy interference since there's another active tower crane user group on this channel...just using a different CTCSS tone "
	462.8625	88.5 Hz		Crane control and construction comms
	462.5875	CSQ 	FRS 02	"two kids talking on FRS walkie talkies - ""these are some strange directions"" - signals came up rapidly and then rapidly faded out...possibly two mobile units or kids riding in cars or a car "
	466.0875	506 DCS		Construction comms - some interference from the other users / groups on this frequency
	469.5500	732 DCS		Service elevator coordination and floor pick up and drop off requests
	464.5000	546 DCS	Brown Dot	Spanish language - fair to good/strong signals at points
	462.7250	136.5 Hz	FRS 22 	Local school - appears to be primary channel (for now anyway)
	154.5275	065 DCS		FLIGHTCOM dispatcher - possibly alternate channel?
	462.8875	192.8 Hz		"""radio check, this is the East crane...how well do you copy me?"" ""okay switching back to my other radio"" "
	151.6250	77.0 Hz	Red Dot	"""hey can I get a pick up on level 8?"" "
	466.2625	023 DCS		RMC Events - parking/traffic control
	462.7250	67.0 Hz	FRS 22	Weak signals...sounded like kids talking on radios / FRS walkie talkies
	461.3625	023 DCS		RMC Events - parking/traffic control
	462.6125	67.0 Hz	FRS 03	"Construction site comms or similar - familiar FRS ""Roger Beep"" "
5/22/2021	469.5500	732 DCS		Construction site comms - including elevator floor requests
	151.6250	065 DCS	Red Dot	"AIRCARE EAGLE working FLIGHTCOM at 8:00AM for ""morning radio check"" - both stations full scale loud and clear excellent signals "
	467.6625	67.0 Hz	FRS 12	Elevator floor pickup and drop off requests - usual chatter on this frequency and CTCSS tone
	464.8250	026 DCS		Crane control - portable radios (simplex)
	467.8500	179.9 Hz	Silver Star	"Hotel or hospitality - heard ""front desk"" "
	461.1875	67.0 Hz		Facilities management or similar
	154.5275	065 DCS		FLIGHTCOM doing radio checks
	469.5500	114.8 Hz		Crane coordination - including lots of informal chatter, Spanish and English
	154.5700	371 DCS	MURS 4	Construction contractor and crane control....sometimes with very good signals....but usually not so good - variable signals as expected with VHF band - MURS handhelds
	151.5125	136.5 Hz		Crane control - portable radios - primary channel for this particular user / group / company / contractor
	467.8125	103.5 Hz	"""K"" Dot"	"""Front desk"" - likely hotel or hospitality - portable radios "
	151.8200	67.0 Hz	MURS 1	Hospitality or catering? portable radios...fair to poor signals, at least one, possibly two of the voices heard were female
	158.4075	065 DCS 		FLIGHTCOM working LIFE EVAC 1 and LIFE EVAC 3 medevac helicopters
	462.6875	85.4 Hz	FRS 06	Security or maybe surveillance? could also be parking or similar traffic control...heard vehicle descriptors...license plates
	151.6250	025 DCS	Red Dot	"Somebody asking for ""Rick"" or maybe ""Dick"" - poor copy"
	462.9125	192.8 Hz		Crane control and crane coordination
	461.1625	67.0 Hz		Facilities management or engineering crew - portable radios
	467.8750	229.1 Hz	Gold Star	Crane control and crane coordination
	464.5000	67.0 Hz	Brown Dot	Electricians or engineers testing alarm system or fire alarm / smoke or heat detector system network functionality circuit testing, etc.
	469.5000	205 DCS		Construction site comms - sporadic activity
	464.5000	546 DCS	Brown Dot	Spanish language chatter - likely construction site comms
	154.5275	136.5 Hz		Crane control - portable radios...probably secondary channel for this user group company contractor etc.
	462.6750	606 DCS	FRS 20	Retail use - talking about inventory, customer service, etc.  low-powered portable walkie talkies - likely Retevis brand
	466.2625	023 DCS		RMC Events - parking/traffic control - appears to be primary channel - or the most active one at the Richmond Flying Squirrels game / The Diamond
	466.1625	506 DCS		Construction site comms - portable radios
5/23/2021	464.8250	026 DCS		Crane control
	462.7250	136.5 Hz	FRS 22	Maybe parking garage or parking lot check? fair to good signal strength...but *not* the local school user that recently started using this (very popular) frequency and tone combination
	462.9125	192.8 Hz		Crane control / coordination comms
	462.6750	CSQ	FRS 20	"""If you wanna go 60 miles an hour you wanna tell me that you wanna go 60 miles an hour"" ""uhhh...can you repeat that?"" [laughing] ""uh, never mind"" - sounded like two vehicles driving up or down the Interstate - no CTCSS or DCS noted "
	462.6250	127.3 Hz	FRS 18	Parking lot attendants or traffic control - heard several transmissions - all of which appeared to be very local - strong signals...probably related to a local church or similar
	151.6250	065 DCS	Red Dot	AIRCARE EAGLE being dispatched to a crash call by FLIGHTCOM dispatch radio
	467.7500	115 DCS		Retail - Target Stores Channel 1 (main channel plan)
	464.5000	074 DCS	Brown Dot	Caught tail end of a transmission...unknown user
	467.7750	072 DCS		Retail - Target Stores Channel 2 (main channel plan)
	461.1875	172 DCS		Unknown user - probably also retail store going by the DCS code in use
	154.5700	74.4 Hz	MURS 4	Portables - possibly also retail related
	467.9000	205 DCS	Red Star	Retail - Target Stores Channel 4 (main channel plan)
	469.5500	114.8 Hz		Crane control and coordination
	461.1125	172 DCS		Retail store - probably security or loss prevention - portable radios
	461.0375	743 DCS		Facilities management or similar? some heavy interference from the high-power GRTC DMR digital system on 461.025 MHz
	461.3625	172 DCS		Security ops - portable radios
	467.8500	67.0 Hz	Silver Star	Retail - portables - possibly primary channel
	451.8000	664 DCS		"""customer has a question about..."" - weak to fair signal, almost certainly portable radios "
	462.5875	97.4 Hz	FRS 02	Crane control - mix of English and Spanish language...FRS Roger Beeps noted
	466.0875	506 DCS		Construction site comms
	469.5500	205 DCS		Construction site equipment delivery or repair contractor or subcontractor
	462.5500	CSQ	FRS 15	"Weak signal...heard ""side"" and a couple unreadable transmissions...no indication of any CTCSS tone or DCS code usage "
	466.0875	97.4 Hz		Weak signals...bits and pieces coming through but unable to positively ID
	151.8200	67.0 Hz	MURS 1	"""you've got room in the rail"" or ""you've got room on the rail"" "
5/24/2021	461.3625	74.4 Hz		Electricians or engineering crew - testing alarm panel or alarm circuit functionality, possibility on a new building project in-progress....portable radios but good signals
	151.5050	025 DCS		"""yeah he's falling behind, he's gonna call when he's caught up"" ""okay just let me know when you want me to load the tractor up"""
	462.5875	118.8 Hz	FRS 02	"""wheel alignment"" ""8:00 appointment"" "
	469.5500	114.8 Hz		Crane control and coordination also lots of informal chatter
	466.0875	023 DCS		Construction site materials delivery coordination - concrete and possibly other materials - portable radios
	462.7125	146.2 Hz	FRS 07	"""can you bring it...okay you're right...zero it...zero it..."" - weak to fair signal - portable radios ""once you get that one done...the paperwork is already on the table"" "
	462.5625	77.0 Hz 	FRS 01	Spanish language chatter - probably related to crane control based on previous loggings of this frequency and CTCSS tone combination
	466.3125	156.7 Hz		Construction site comms and crane control - mixture of Spanish and English
	462.7250	252 DCS	FRS 22	"""okay I see you"" ""I'll run a piece of wire up to the 4th level...and that wire will connect to...."" ""right, I'll get it from the electrician"" "
	467.6625	67.0 Hz	FRS 12	Elevator floor requests - usual traffic heard on this frequency and CTCSS tone combination
	457.5250	315 DCS		Local school - portable radios - used by teachers and also maintenance staff and facilities management staff
	469.5500	732 DCS		Talking about supply delivery
	467.7125	107.2 Hz	FRS 14	"Tail end of a FRS transmission with the usual Motorola ""Roger Beep"""
	462.6750	606 DCS	FRS 20	Retail comms - warehouse and inventory as well as customer service related chatter
	158.4075	065 DCS		FLIGHTCOM dispatch morning radio checks
	462.5750	114.8 Hz	FRS 16	Spanish language
	151.6250	025 DCS	Red Dot	"""warehouse 3, ready to go...warehouse 3..."" "
	466.0875	506 DCS		"Crane control - ""trolley out"" ""cable down..."" ""hold your cable"" - etc..."
	464.5500	627 DCS	Yellow Dot	Construction site / work site comms - primary channel
	469.5000	205 DCS		Construction site related comms - fair to good signal
	151.6250	065 DCS	Red Dot	FLIGHTCOM working AIRCARE EAGLE - dispatch to scenes and radio checks
	462.5875	71.9 Hz	FRS 02	Crane control - fair to weak signals...mixture of Spanish and English and Spanglish
	462.6125	141.3 Hz	FRS 03	Spanish language chatter - possibly also construction site or work site related...FRS radios - noted tell-tale FRS-style Roger Beeps in use
	464.5000	179.9 Hz	Brown Dot	Engineering or facilities maintenance - fair to weak signals, portable radios
	461.2625	67.0 Hz		Hotel or hospitality operations
	464.8250	026 DCS		Crane control - usual users of this frequency - simplex portable radios
	151.6250	167.9 Hz	Red Dot	Truck to truck comms - likely Crane Master - confirmed user of this frequency and CTCSS tone combination...good signals, likely from high-power mobile radios...crane service company figuring out how to get to job site
	461.1875	023 DCS		Construction site materials delivery coordination - concrete and possibly other materials - portable radios
	462.6875	141.3 Hz	FRS 06	Local school - possibly alternate or secondary frequency - very local, very strong signals
	464.5500	546 DCS	Yellow Dot	Spanish language - fair to good signal
	154.5700	371 DCS	MURS 4	Crane control and construction site coordination comms
	462.6750	136.5 Hz	FRS 20	"School - heard reference to ""8th grade"" - fair to good signal - sporadic interference from retail and warehouse comms on same frequency / channel "
	462.9125	192.8 Hz		Crane control and coordination
	151.6250	77.0 Hz	Red Dot	"""pick up on...."" [faded away] - sounds like it could be tower crane or service elevator floor requests - heard ""level 8"" a couple times later as well "
	461.1625	67.0 Hz		Hotel or hospitality operations
	462.7250	136.5 Hz	FRS 22	Local school - primary channel - very local school
	469.5500	165 DCS		Elevator floor requests - fair to poor signal strength
	466.3125	023 DCS		RMC Events - parking and traffic control
	462.5625	67.0 Hz	FRS 01	Sounds like another crane control or tower crane operations channel...some interference from other user or users on same frequency
	466.3625	023 DCS		RMC Events - parking and traffic control
	462.5875	023 DCS	FRS 02	"Engineering crew or RF engineers - talking about ""dishes"" - testing signal strength for different links, probably part of a fixed point-to-point data link or telemetry system...or a WLAN or WiFi system...could be SATCOM also, not 100% sure "
	467.6875	103.5 Hz	FRS 13	"""bring those lines back"" ""okay I'll call you on [unreadable]"""
	467.8500	67.0 Hz	Silver Star	"Retail operations - heard mention of ""bread"" ""customer had a question about wine"" "
	466.2625	023 DCS		RMC Events - parking and traffic control - appears to be primary channel
5/25/2021	464.5500	627 DCS	Yellow Dot	Construction site command channel - coordinating several different activities at a job site / construction site - often a very active channel
	466.0875	506 DCS		Crane control and construction site comms
	151.8200	103.5 Hz	MURS 1	"Same users previously heard on this channel / CTCSS tone - heard ""okay...okay keep it right there buddy"" - fair signals, as to be expected with VHF handheld radios / MURS handheld walkie talkies "
	467.6625	053 DCS	FRS 12	School - daily operations
	469.5500	165 DCS		Service elevator floor requests - pickup and drop off requests
	469.5000	205 DCS		"""13, that's correct"" - possibly also elevator pick up requests "
	466.3125	156.7 Hz		Construction operations - often very active but with long periods of inactivity between spurts of activity - English and Spanish heard
	462.6750	136.5 Hz	FRS 20	School - middle or high school (possibly) - coordinating lunch schedules, teacher to teacher chatter...
	467.6625	67.0 Hz	FRS 12	Elevator floor requests - pick up and drop off
	464.5000	77.0 Hz	Brown Dot	Security or facilities management - suffering very heavy interference from GPS RTK data bursts on same frequency
	461.3625	244 DCS		Spanish language - sporadic signals
	462.7250	77.0 Hz	FRS 22	UNID user - very faint signals, was able to decode CTCSS tone in use
	469.5500	205 DCS		Talking about checking connections on different floors / levels - some interference from other users on frequency
	462.6750	606 DCS	FRS 20	Retail use - some interference from the school on the same channel / frequency
	151.6250	167.9 Hz	Red Dot	Crane Master truck to truck and truck to handheld comms - good strong signals heard
	462.6125	141.3 Hz	FRS 03	"""we need to talk to the captain"" ""okay"" "
	462.5500	CSQ	FRS 15	"""it was supposed to be cut"" ""that is gonna show that it isn't going to work..."" ""I'll call down when I'm ready to send some stuff down"" - unique FRS Roger Beep heard - no CTCSS or DCS in use, appears to be 100% carrier squelch / CSQ "
	467.8750	229.1 Hz	Gold Dot	Crane control and coordination
	154.5275	065 DCS		FLIGHTCOM dispatcher working medevac helicopter aircraft
	462.5625	67.0 Hz	FRS 01	Crane control - fair, but readable, signals - possibly same group previously monitored
	462.7000	CSQ	FRS 21	"""three seven"" - other, unreadable transmissions heard...no CTCSS or DCS tone or code decoded...appears to be another carrier squelch FRS net "
	461.2625	244 DCS		"""Charlie side"" ""okay right there"" "
	462.8875	88.5 Hz		Crane control - portable radios - Spanish and English
	466.0875	97.4 Hz		Construction site / job site comms
	462.8625	88.5 Hz		Crane control - portable radios - Spanish and English
	461.3625	023 DCS		RMC Events - secondary - parking and traffic control
	466.2625	023 DCS		RMC Events - primary channel - parking and traffic control
5/26/2021	469.5500	165 DCS		"""alright 10-4...I'll get those out of here..."" ""even Richard said that's impossible"" ""once we're done with that we're gonna put pit dirt on top of it"" ""well, we can't say we didn't go far enough...we undercut what they asked us to undercut"""
	462.8625	88.5 Hz		Crane control, heard about 10 seconds of somebody keying their mic down...could hear Spanish chatter and banging / construction noises in the background during the key down
	467.6625	67.0 Hz	FRS 12	Elevator floor pickup requests
	464.5500	627 DCS	Yellow Dot	Coordinating outriggers, beam locations...usual traffic here
	462.9125	192.8 Hz		Crane control and coordination - including some informal chatter, sometimes *very* informal
	151.8200	103.5 Hz	MURS 1	"""do you know where the tow cutter is?"" "
	469.5000	732 DCS		Construction and crane control - weak/fair signals
	466.3125	156.7 Hz		Active, as usual, with Spanish and English construction site comms
	469.5000	205 DCS		Elevator floor pick up and drop off requests - or equipment / supply requests for different levels / floors
	151.6250	065 DCS	Red Dot	Tone burst followed by alternating tones - FLIGHTCOM calling AIRCARE EAGLE for morning radio check - both stations loud and clear good radio check at 8:25AM
	469.5500	114.8 Hz		Crane coordination - same voices heard here as on the other commonly heard (basically daily) crane coordination channels
	462.7000	CSQ	FRS 21	Caught a couple very weak transmissions
	462.5250	114.8 Hz		"Local day care or school - ""...shoes and Brady needs a mask..."""
	464.5000	346 DCS	Brown Dot 	"""in 0.3 miles you'll take a right"" ""copy that"" ""obviously, Hunter, you're gonna want to watch out for buses coming up behind you...."" ""okay you're clear homie"" "
	462.6125	141.3 Hz	FRS 03	Carrier - no modulation or voice heard, this CTCSS tone previously noted on this frequency, active users somewhere in this general area
	466.0875	506 DCS		Construction site comms - sporadic signals
	151.6250	77.0 Hz	Red Dot	"""level 2 please! level 2..."" "
	469.5500	732 DCS		"Elevator requests - heard ""12 going down"" - busy frequency "
	151.6250	145 DCS	Red Dot	Construction site comms - portable radios
	467.6875	445 DCS	FRS 13	"""bring it down nice and easy"" - probably also crane control "
	464.5000	506 DCS	Brown Dot	"Weak(er) signals - DCS tone noted in use ""under"" stronger signals on this frequency "
	462.5875	77.0 Hz	FRS 02	FRS call tone / alert tones heard...no voice transmissions though
	461.2625	244 DCS		Crane control
	464.5000	67.0 Hz	Brown Dot	Very weak signals - was able to decode CTCSS code tone in use
	464.5500	754 DCS	Yellow Dot	"""level 2"" "
	151.5050	145 DCS		Construction - possibly related to materials delivery
	462.6750	606 DCS	FRS 20	Retail and warehouse use
	462.5750	115 DCS	FRS 16	"""man, he can also come back up here...."" "
	154.6000	114 DCS	MURS 5	"""check section 2"" ""students"" - possibly a school or similar "
	467.9000	100.0 Hz	Red Star	Caught the tail end of a transmission
	462.5625	CSQ	FRS 01	Vehicles caravanning - car to car chatter with Motorola FRS Roger Beeps - no CTCSS or DCS in use
	467.5625	243 DCS	FRS 08	"""okay send it back up"" ""20 more feet...20 more feet"" ""good...looking good"""
	462.5500	073 DCS	FRS 15	"""check 15...check one five, over"" ""okay"""
	464.5500	156.7 Hz	Yellow Dot	"Security - heard ""unit 21"" ""unit 26"" and other two-digit mobile numbers - very good signals - possibly mobile radios "
	461.1875	073 DCS		Crane control or construction site control communications - weak to fair signals
	151.6250	167.9 Hz	Red Dot	Crane Master truck to truck - talking about exits on I-64 - very strong signals from high power mobile radios
	462.6250	127.3 Hz	FRS 18	"""Meg"" and another unidentified female speaker, heard reference to ""channel 6"" - indicating that they are likely using Baofeng or Retevis walkie talkie radios "
	467.8500	054 DCS	Silver Star	"Heard ""office"" clearly - maybe some sort of faculties management, security or other office building or maybe hotel or hospitality type business or organization "
	462.5875	CSQ	FRS 02	"""wanna get out...."" [faded away] - no CTCSS tone or DCS code noted in use "
	151.9550	77.0 Hz	Purple Dot	Elevator floor pick up requests - weak to fair signal
	158.4075	065 DCS		FLIGHTCOM working LIFE EVAC 1 medevac helicopter
	461.1875	023 DCS		Concrete delivery coordination
	462.5750	654 DCS	FRS 16	"Caught a couple short transmissions, sounded like Spanish language....no FRS ""Roger Beeps"" noted "
5/27/2021	469.5000	205 DCS		Construction site materials or equipment delivery and coordination
	462.5250	114.8 Hz		Local school or day care - portables, must be pretty local
	464.5000	162.2 Hz	Brown Dot	"""did [unreadable] and Willie ever make it back?"" ""hey Charlie, did you copy my last?"""
	469.5500	732 DCS		Supply drop off requests - elevator pick up floor requests and drop off requests
	151.6250	77.0 Hz	Red Dot 	Elevator floor requests - could hear telephone ringing or another type of alarm or alert tone in background at beginning of transmission
	469.5500	165 DCS		"""is he on this channel?"" ""okay take it back..."" ""take it back..."" ""get that bell"" ""looks like they might have...possibly broken the....uh....yeah, you see the cast iron piece? yeah the bottom of it"" "
	151.9400	110.9 Hz	MURS 3	"""okay standby guys...."" "
	464.5500	627 DCS	Yellow Dot	Construction site coordination - primary channel or command channel - talking about water bottles and other supplies
	466.3125	156.7 Hz		Construction comms - mixture of English and Spanish
	469.5500	506 DCS		Construction site comms
	462.8625	88.5 Hz		Crane control / crane coordination
	154.5700	371 DCS	MURS 4	Crane control and construction comms - some informal chatter as well
	462.5875	97.4 Hz	FRS 02	Spanish language, heard construction noises in background
	469.5000	165 DCS		Sporadic signal, presumed to also be construction related
	462.6250	118.8 Hz	FRS 18	"""...back here..."" ""okay"" "
	462.7250	67.0 Hz	FRS 22	Faint signal heard, Spanish language traffic
	464.5500	162.2 Hz	Yellow Dot	"Construction comms - heard mention of ""Charlie"" - probably the same guys monitored using the same CTCSS tone earlier today "
	462.7000	141.3 Hz	FRS 21	possibly car to car type comms? faded in rapidly and then faded out just as quickly, characteristic of high-speed mobile to mobile type comms, probably handheld walkie talkies inside vehicles
	451.8000	754 DCS		Crane control / construction site coordination type comms
	462.6750	606 DCS	FRS 20	Retail and warehouse comms
	158.4075	065 DCS		FLIGHTCOM dispatch working helicopters
	462.7250	252 DCS	FRS 22	"""coming down!"" - construction related comms, probably connected with tower crane control - heard ""6th floor"" and other level or floor designations "
	462.6750	136.5 Hz	FRS 20	"School - heard reference to ""6th grade"" and ""8th grade"" - very active during mid-afternoon "
	464.5000	165 DCS	Brown Dot	"""is he gonna come down and meet us or what's the deal?"""
	462.7125	CSQ	FRS 07	"""Tyler...Tossinglight?"" ""Tyler...."" ""okay got it"" - with FRS Roger Beeps, probably Midland or Cobra brand FRS handhelds "
	469.5500	205 DCS		Construction site materials or equipment delivery and coordination
	462.5625	77.0 Hz	FRS 01	Spanish language - probably construction site related communications, previously logged on same frequency channel and CTCSS tone
	469.5500	743 DCS		Spanish language chatter
	151.6250	065 DCS	Red Dot	AIRCARE EAGLE working FLIGHTCOM
	462.6250	127.3 Hz	FRS 18	Catering company or hospitality business comms? portable low power radios
	467.8750	229.1 Hz	Gold Star	Crane control / crane coordination
	461.1625	67.0 Hz		Hotel / hospitality comms
	462.5875	77.0 Hz	FRS 02	Crane control and construction site related comms
	466.0875	97.4 Hz		Weak to fair signal heard, no modulation (voice)
	462.9125	192.8 Hz		Crane control / crane coordination
	464.5500	754 DCS	Yellow Dot	"""come up...okay come up...."" ""I gotta set it on the landing, we can't have this rope rubbing on the pedestal"" "
	462.7250	136.5 Hz	FRS 22	Local school - very local, extremely strong signals...stronger than all other traffic on frequency....very active in the 3:00 to 5:00 or so range
