DDE
Revision as of 13:32, 13 June 2023 by R4002 (Talk | contribs)
ePMR LMR PMR PLMR VHF low band land mobile radio system. The VHF low band spectrum is used by numerous other services, including SINCGARS#Commonly_used_VHF_low_VHF_mid_and_HF_high_bands_HF.2FVHF_bands military FM, paging networks, public safety and other services in France and elsewhere in Europe and other areas.
