DDE
Revision as of 15:24, 13 June 2023 by R4002 (Talk | contribs)
  • 35.0750 MHz / 39.4750 MHz - Channel 13
  • 35.0875 MHz / 39.4875 MHz - Channel 14
  • 35.1000 MHz / 39.5000 MHz - Channel 15
  • 35.1125 MHz / 39.5125 MHz - Channel 16
  • 35.1250 MHz / 39.5250 MHz - Channel 17
  • 35.1375 MHz / 39.5375 MHz - Channel 18
  • 35.1500 MHz / 39.5500 MHz - Channel 19
  • 35.1625 MHz / 39.5625 MHz - Channel 20
  • 35.1750 MHz / 39.5750 MHz - Channel 21
  • 35.1875 MHz / 39.5875 MHz - Channel 22
  • 35.2000 MHz / 39.6000 MHz - Channel 23
  • 35.2125 MHz / 39.6125 MHz - Channel 24
  • 35.2250 MHz / 39.6250 MHz - Channel 25
  • 35.2375 MHz / 39.6375 MHz - Channel 26
  • 35.2500 MHz / 39.6500 MHz - Channel 27
  • 35.2625 MHz / 39.6625 MHz - Channel 28
  • Business_Radio#VHF_Low_Band_25-50_MHz35.8000 MHz / 40.2000 MHz - Channel 37
Additional French VHF low 30-50 MHz and VHF mid band 66-88 MHz PMR PLMR LMR spectrum allocations:
12.5 kHz spacing
  • 30.8750 MHz - 32.1250 MHz - Simplex
  • 32.6000 MHz - 33.0000 MHz - Simplex
  • 34.8500 MHz - 34.9000 MHz - Simplex
  • 34.9000 MHz - 36.2500 MHz - Repeater outputs (duplex) systems - including DDE PMR
  • 36.2500 MHz - 36.6000 MHz - Simplex
  • 36.8625 MHz - 39.1000 MHz - Simplex
  • 39.3000 MHz - 40.6500 MHz - Repeater inputs (paired with 34.9 MHz - 36.25 MHz) - DDE PMR
  • 68.4625 MHz - 69.2500 MHz - Repeater inputs (paired with 72.5125 MHz - 73.3 MHz) - EDF and GDF PMR
  • 70.2500 MHz - 70.5250 MHz - Simplex
  • 70.9750 MHz - 71.9500 MHz - Simplex
  • 72.5125 MHz - 73.3000 MHz - Repeater outputs (duplex) systems - including EDF and GDF
  • 75.2000 MHz - 75.3000 MHz - Simplex
  • 75.3000 MHz - 77.4750 MHz - Repeater outputs (duplex - paired with 80.3 MHz - 82.475 MHz)
  • 80.0000 MHz - 80.3000 MHz - Simplex
  • 80.3000 MHz - 82.4750 MHz - Repeater inputs (paired with 75.3 MHz - 77.475 MHz)
