Cordless telephone
Cordless phone
Contents[hide] |
Frequencies
- Base Frequency 46.610 MHz - Handset Frequency 49.670 MHz
- Base Frequency 46.630 MHz - Handset Frequency 49.845 MHz
- Base Frequency 46.670 MHz - Handset Frequency 49.860 MHz
- Base Frequency 46.710 MHz - Handset Frequency 49.770 MHz
- Base Frequency 46.730 MHz - Handset Frequency 49.875 MHz
- Base Frequency 46.770 MHz - Handset Frequency 49.830 MHz
- Base Frequency 46.830 MHz - Handset Frequency 49.890 MHz
- Base Frequency 46.870 MHz - Handset Frequency 49.930 MHz
- Base Frequency 46.930 MHz - Handset Frequency 49.990 MHz
- Base Frequency 46.970 MHz - Handset Frequency 49.970 MHz
The so-called "49 MHz" cordless phones were rapidly adopted by consumers, resulting in heavy frequency congestion. The 49.830-49.890 MHz frequencies were and still are heavily used by other devices including baby monitors in continuous transmit mode. 15 frequencies were added bringing the total number of channels to 25.
900 MHz Cordless Phones
The FCC quickly moved to authorize additional frequency space for cordless phones. With the 900 MHz ISM band 902-928 MHz becoming available next. 900 MHz cordless phones are still used today. Multiple duplex pair analog narrow FM, digital voice and various frequency hopping spread-spectrum or FHSS cordless phones became available for the 900MHz band. If FHSS technology is used, base stations may transmit up to 1 watt ERP. This increase in transmitter power combined with the interference rejection capabilities of spread spectrum gave the higher-end 900 MHz cordless phones significant range. Unlike the older-generation models, 900 MHz cordless telephones never had a standardized channel plan or base and handset frequency pair or channel plan. This meant that manufacturers simply created their own, with widely differing channel steps, number of channels and other options. Even cheap analog FM 900 MHz cordless phones usually featured automatic channel selection. In other words, if the first channel pair was busy the system simply switched to the next clear channel. This same technology was (and is) included in digital voice cordless telephones operating in the 900 MHz band, the 2.4 GHz band and the 5.8 GHz band as well as those using modern DECT technology.
2.4 GHz Cordless Phones and 5.8 GHz Cordless Phones
The 2.4 GHz band (2400 MHz - 2483.5 MHz) became available shortly after 900 MHz and originally provided excellent results. However, the proliferation of devices operating in the 2.4 GHz band now means that 2.4GHz cordless phones often suffer from (or cause) interference and/or have reduced range compared to the other bands. The 5.8 GHz allocation (5725 MHz - 5875 MHz or 5.725 GHz - 5.875 GHz) was opened up to alleviate the congestion on 2.4 GHz. Many 5.8 GHz band cordless phones are sold today. Some "5.8 GHz" phones are actually cross-band and use 5.8 GHz for handset to base but use 900 MHz or 2.4 GHz for base-to-handset.
DECT 6.0 - DECT Cordless Phones
- Base Frequency: 1642 kHz 1.642 MHz - Handset Frequency: 47.45625 MHz - Channel 1
- Base Frequency: 1662 kHz 1.662 MHz - Handset Frequency: 47.46875 MHz - Channel 2
- Base Frequency: 1682 kHz 1.682 MHz - Handset Frequency: 47.48125 MHz - Channel 3
- Base Frequency: 1702 kHz 1.702 MHz - Handset Frequency: 47.49375 MHz - Channel 4
- Base Frequency: 1722 kHz 1.722 MHz - Handset Frequency: 47.50625 MHz - Channel 5
- Base Frequency: 1742 kHz 1.742 MHz - Handset Frequency: 47.51875 MHz - Channel 6
- Base Frequency: 1762 kHz 1.762 MHz - Handset Frequency: 47.53125 MHz or 47.44375 MHz - Channel 7
- Base Frequency: 1782 kHz 1.782 MHz - Handset Frequency: 47.54375 MHz - Channel 8
- Base Frequency: 47.43125 MHz - Handset Frequency: 77.5125 MHz
- Base Frequency: 47.41875 MHz - Handset Frequency: 77.5000 MHz
CT0 - UK Specification CT0 - Current Allocation - 10mW power output, FM mode. 31 MHz cordless phone UK. 31.025 MHz - 31.225 MHz and 39.925 MHz - 40.125 MHz. 8.9 MHz duplex offset (handset transmit frequency +8.9 MHz above base transmit frequency). 25 kHz channel spacing, 12.5 kHz offset frequencies.
- Base Frequency: 31.0375 MHz - Handset Frequency: 39.9375 MHz - Channel 1
- Base Frequency: 31.0625 MHz - Handset Frequency: 39.9625 MHz - Channel 2
- Base Frequency: 31.0875 MHz - Handset Frequency: 39.9875 MHz - Channel 3
- Base Frequency: 31.1125 MHz - Handset Frequency: 40.0125 MHz - Channel 4
- Base Frequency: 31.1375 MHz - Handset Frequency: 40.0375 MHz - Channel 5
- Base Frequency: 31.1625 MHz - Handset Frequency: 40.0625 MHz - Channel 6
- Base Frequency: 31.1875 MHz - Handset Frequency: 40.0875 MHz - Channel 7
- Base Frequency: 31.2125 MHz - Handset Frequency: 40.1125 MHz - Channel 8
DECT 1.8 GHz/1.9 GHz 1880-1900 MHz - <250mW handset and base stations 1880-1900 MHz on the standard GMSK modulation type using TDMA. CEPT DECT standard.
Spain
Variants of this channel plan are or were used in many other European countries.
The EU is currently in the process of reorganizing the 31.025 MHz - 31.325 MHz band.
Authorization to use cordless phones in the 31 MHz and 39 MHz/40 MHz band will expire and be withdrawn effective December 31st, 2023.
- Base: 31.025 MHz - Handset: 39.925 MHz - Channel 1
- Base: 31.050 MHz - Handset: 39.950 MHz - Channel 2
- Base: 31.075 MHz - Handset: 39.975 MHz - Channel 3
- Base: 31.100 MHz - Handset: 40.000 MHz - Channel 4
- Base: 31.125 MHz - Handset: 40.025 MHz - Channel 5
- Base: 31.150 MHz - Handset: 40.050 MHz - Channel 6
- Base: 31.175 MHz - Handset: 40.075 MHz - Channel 7
- Base: 31.200 MHz - Handset: 40.100 MHz - Channel 8
- Base: 31.300 MHz - Handset: 40.200 MHz - Channel 11
- Base: 31.325 MHz - Handset: 40.225 MHz - Channel 12
France CT0
- Base: 26.3125 MHz - Handset: 41.3125 MHz - Channel 1
- Base: 26.3250 MHz - Handset: 41.3250 MHz - Channel 2
- Base: 26.3375 MHz - Handset: 41.3375 MHz - Channel 3
- Base: 26.3500 MHz - Handset: 41.3500 MHz - Channel 4
- Base: 26.3625 MHz - Handset: 41.3625 MHz - Channel 5
- Base: 26.3750 MHz - Handset: 41.3750 MHz - Channel 6
- Base: 26.3875 MHz - Handset: 41.3875 MHz - Channel 7
- Base: 26.4000 MHz - Handset: 41.4000 MHz - Channel 8
- Base: 26.4125 MHz - Handset: 41.4125 MHz - Channel 9
- Base: 26.4250 MHz - Handset: 41.4250 MHz - Channel 10
- Base: 26.4375 MHz - Handset: 41.4375 MHz - Channel 11
- Base: 26.4500 MHz - Handset: 41.4500 MHz - Channel 12
- Bade: 26.4625 MHz - Handset: 41.4625 MHz - Channel 13
- Base: 26.4750 MHz - Handset: 41.4750 MHz - Channel 14
- Base: 26.4875 MHz - Handset: 41.4875 MHz - Channel 15
Republic of Vanuatu CT1 CT2 DECT
DECT is approved for the frequency band 1880 MHz - 1900 MHz or 1.88 GHz - 1.9 GHz. The Personal Handy Phone System (PHS) is approved for operating in the overlapping frequency band 1895 MHz - 1920 MHz or 1.895 GHz - 1.920 GHz.
- CT1 Cordless Telephones
Multiple frequency bands.
1.7 MHz band and 30 MHz pairs / 39 MHz 40 MHz power limit is 160mw EIRP.
30.075 MHz - 30.775 MHz 39.775 MHz - 40.475 MHz
30 MHz band 72 MHz bands frequency pairs (channels) are limited to 1 watt power 0dBW (base station) and 0.5 watt or 500mw power -3dBW (handset).
30 MHz base / 39-40 MHz handset channel plan:
- Base: 30.075 MHz - Handset: 39.775 MHz - Channel 1
- Base: 30.100 MHz - Handset: 39.800 MHz - Channel 2
- Base: 30.125 MHz - Handset: 39.825 MHz - Channel 3
- Base: 30.150 MHz - Handset: 39.850 MHz - Channel 4
- Base: 30.175 MHz - Handset: 39.875 MHz - Channel 5
- Base: 30.200 MHz - Handset: 39.900 MHz - Channel 6
- Base: 30.225 MHz - Handset: 39.925 MHz - Channel 7
- Base: 30.250 MHz - Handset: 39.950 MHz - Channel 8
- Base: 30.275 MHz - Handset: 39.975 MHz - Channel 9
- Base: 30.300 MHz - Handset: 40.000 MHz - Channel 10
- Base: 30.325 MHz - Handset: 40.025 MHz - Channel 11
- Base: 30.350 MHz - Handset: 40.050 MHz - Channel 12
- Base: 30.375 MHz - Handset: 40.075 MHz - Channel 13
- Base: 30.400 MHz - Handset: 40.100 MHz - Channel 14
- Base: 30.425 MHz - Handset: 40.125 MHz - Channel 15
- Base: 30.450 MHz - Handset: 40.150 MHz - Channel 16
- Base: 30.475 MHz - Handset: 40.175 MHz - Channel 17
- Base: 30.500 MHz - Handset: 40.200 MHz - Channel 18
- Base: 30.525 MHz - Handset: 40.225 MHz - Channel 19
- Base: 30.550 MHz - Handset: 40.250 MHz - Channel 20
- Base: 30.575 MHz - Handset: 40.275 MHz - Channel 21
- Base: 30.600 MHz - Handset: 40.300 MHz - Channel 22
- Base: 30.625 MHz - Handset: 40.325 MHz - Channel 23
- Base: 30.650 MHz - Handset: 40.350 MHz - Channel 24
- Base: 30.675 MHz - Handset: 40.375 MHz - Channel 25
- Base: 30.700 MHz - Handset: 40.400 MHz - Channel 26
- Base: 30.725 MHz - Handset: 40.425 MHz - Channel 27
- Base: 30.750 MHz - Handset: 40.450 MHz - Channel 28
- Base: 30.775 MHz - Handset: 40.475 MHz - Channel 29
- Base: 1.725 MHz - Handset: 40.025 MHz - Channel 1
- Base: 1.740 MHz - Handset: 40.075 MHz - Channel 2
- Base: 1.755 MHz - Handset: 40.125 MHz - Channel 3
- Base: 1.770 MHz - Handset: 40.175 MHz - Channel 4
- Base: 1.785 MHz - Handset: 40.225 MHz - Channel 5
- Base: 30.600 MHz - Handset: 72.800 MHz - Channel 22
- Base: 30.625 MHz - Handset: 72.825 MHz - Channel 23
- Base: 30.650 MHz - Handset: 72.850 MHz - Channel 24
- Base: 30.675 MHz - Handset: 72.875 MHz - Channel 25
- Base: 30.700 MHz - Handset: 72.900 MHz - Channel 26
- Base: 30.725 MHz - Handset: 72.925 MHz - Channel 27
- Base: 30.750 MHz - Handset: 72.950 MHz - Channel 28
- Base: 30.775 MHz - Handset: 72.975 MHz - Channel 29
CT2 - similar to the 900 MHz band and the SRD860 band 864 MHz - 869 MHz band.
- 864.150 MHz
- 864.250 MHz
- 864.350 MHz
- 864.450 MHz
- 864.550 MHz
- 864.650 MHz
- 864.750 MHz
- 864.850 MHz
- 864.950 MHz
- 865.050 MHz
- 865.150 MHz
- 865.250 MHz
- 865.350 MHz
- 865.450 MHz
- 865.550 MHz
- 865.650 MHz
- 865.750 MHz
- 865.850 MHz
- 865.950 MHz
- 866.050 MHz
- 866.150 MHz
- 866.250 MHz
- 866.350 MHz
- 866.450 MHz
- 866.550 MHz
- 866.650 MHz
- 866.750 MHz
- 866.850 MHz
- 866.950 MHz
- 867.050 MHz
- 867.150 MHz
- 867.250 MHz
- 867.350 MHz
- 867.450 MHz
- 867.550 MHz
- 867.650 MHz
- 867.750 MHz
- 867.850 MHz
- 867.950 MHz
- 868.050 MHz
