Part 15 Beacons
Contents[hide] |
Overview
- 160 - 190 kHz
- 13.553 - 13.567 kHz (often referred to as 13560 kHz)
- 26960 - 27280 kHz
160-190 kHz Part 15 Beacons
167.180 LC Sacramento CA 180.580 6R El Dorado Hills CA 181.818 JH Florence SC 182.448 R Keeler CA 183.500 WD2XFJ Burbank CA 185.100 22A Baraga MI 185.185 SIW Oswego IL 185.290 KT Oswego KS 185.295 MBD Westminster CO 185.297 TAG Raymond ME 185.298 CV South Coffeyville OK 185.299 SIW Oswego IL 185.303 SJ East Haven CT 185.650 WE2XEB Penn Yan NY 186.008 WG2XNI Denver CO 186.204 MLS Massilon OH 187.015 J La Crescenta CA 187.507 WI Aiken SC 188.830 EAR Saltford, ON
13560 kHz Part 15 Beacons
- 13555.60 MTI
- 13562.08 NDB
- 13562.80 GNK Madison WI
- 13564.00 K6FRC
FCC Regulations
160 - 190 kHz
13560 kHz
26960 - 27280 kHz
