HF marine
Revision as of 17:35, 26 October 2018 by R4002 (Talk | contribs)
Fisheries, fishing boats, and other commercial marine users will often use frequencies in the fixed/mobile bands (including 43 meters - 6765-7000 kHz) clear frequencies in the shortwave broadcast bands or even amateur frequencies for "out of band" communications to reduce the chance of radio interception by their competition. Out of band frequencies are also used in other ITU regions for marine fax transmissions.
See also: VHF marine band
Band Frequency Range
405-525 kHz MF band, used in some areas for NAVTEX on 490 kHz and/or 518 kHz. 500 kHz (600 meters) was the original CW Morse code calling frequency
2000-2300 kHz MF 2 MHz marine band - USB voice calling 2182 kHz, DSC calling 2187.5 kHz
2450-2850 kHz MF 2 MHz marine band
4000-4063 kHz 4 MHz fixed/mobile band, shared with marine for simplex purposes
4063-4438 kHz HF 4 MHz marine band - USB voice calling 4125 kHz, DSC calling 4207.5 kHz
6200-6525 kHz HF 6 MHz marine band - USB voice calling 6215 kHz, DSC calling 6312 kHz
8000-8195 kHz 8 MHz fixed/mobile band, shared with marine for simplex purposes
8195-8815 kHz HF 8 MHz marine band - USB voice calling 8291 kHz, DSC calling 8414.5 kHz
12330-13200 kHz HF 12 MHz marine band - USB voice calling 12290 kHz, DSC calling 12577 kHz
16460-17360 kHz HF 16 MHz/17 MHz marine band - USB voice calling 16420 kHz, DSC calling 16804.5 kHz
25070-25121 kHz HF 25 MHz marine band
26145-26175 kHz HF 26 MHz marine band
26175-28000 kHz Various CB-like marine allocations found in this region
