The 26995-27255 frequencies may be used for data links, remote sensing and other niche purposes that the 72 MHz and 75 MHz frequencies may not be used for. See the HF pagers page for more information.
- 26.995 MHz - 26995 kHz - Brown or Channel 3A
- 27.045 MHz - 27045 kHz - Red or Channel 7A
- 27.095 MHz - 27095 kHz - Orange or Channel 11A
- 27.145 MHz - 27145 kHz - Yellow or Channel 15A
- 27.195 MHz - 27195 kHz - Green or Channel 19A
- 27.255 MHz - 27255 kHz - Blue (shared with channel 23)
Many wireless mice and keyboards use 27.145 MHz. Low power remote control devices may fall under Part 15 rules instead of Part 95. The 72MHz and 75MHz RC frequencies are shared with the mid-band VHF business radio band and the miltary's FM tactical SINCGARS system which operates in the 30-88 MHz range.
- 72.01 MHz
- 72.03 MHz
- 72.05 MHz
- 72.07 MHz
- 72.09 MHz
- 72.11 MHz
- 72.13 MHz
- 72.15 MHz
- 72.17 MHz
- 72.19 MHz
- 72.21 MHz
- 72.23 MHz
- 72.25 MHz
- 72.27 MHz
- 72.29 MHz
- 72.31 MHz
- 72.33 MHz
- 72.35 MHz
- 72.37 MHz
- 72.39 MHz
- 72.41 MHz
- 72.43 MHz
- 72.45 MHz
- 72.47 MHz
- 72.49 MHz
- 72.51 MHz
- 72.53 MHz
- 72.55 MHz
- 72.57 MHz
- 72.59 MHz
- 72.61 MHz
- 72.63 MHz
- 72.65 MHz
- 72.67 MHz
- 72.69 MHz
- 72.71 MHz
- 75.41 MHz
- 75.43 MHz
- 75.45 MHz
- 75.47 MHz
- 75.49 MHz
- 75.51 MHz
- 75.53 MHz
- 75.55 MHz
- 75.57 MHz
- 75.59 MHz
- 75.61 MHz
- 75.63 MHz
- 75.65 MHz
- 75.67 MHz
- 75.69 MHz
- 75.71 MHz
- 75.73 MHz
- 75.75 MHz
- 75.77 MHz
- 75.79 MHz
- 75.81 MHz
- 75.83 MHz
- 75.85 MHz
- 75.87 MHz
- 75.89 MHz
- 75.91 MHz
- 75.93 MHz
- 75.95 MHz
- 75.97 MHz
- 75.99 MHz
- 34.950 MHz - Channel 55
- 34.960 MHz - Channel 56
- 34.970 MHz - Channel 57
- 34.980 MHz - Channel 58
- 34.990 MHz - Channel 59
- 35.000 MHz - Channel 60
- 35.010 MHz - Channel 61
- 35.020 MHz - Channel 62
- 35.030 MHz - Channel 63
- 35.040 MHz - Channel 64
- 35.050 MHz - Channel 65
- 35.060 MHz - Channel 66
- 35.070 MHz - Channel 67
- 35.080 MHz - Channel 68
- 35.090 MHz - Channel 69
- 35.100 MHz - Channel 70
- 35.110 MHz - Channel 71
- 35.120 MHz - Channel 72
- 35.130 MHz - Channel 73
- 35.140 MHz - Channel 74
- 35.150 MHz - Channel 75
- 35.160 MHz - Channel 76
- 35.170 MHz - Channel 77
- 35.180 MHz - Channel 78
- 35.190 MHz - Channel 79
- 35.200 MHz - Channel 80
- 35.210 MHz - Channel 81
- 35.220 MHz - Channel 82
- 35.230 MHz - Channel 83
- 35.240 MHz - Channel 84
- 35.250 MHz - Channel 85
- 35.260 MHz - Channel 86
- 35.270 MHz - Channel 87
- 35.280 MHz - Channel 88
- 35.290 MHz - Channel 89
- 35.300 MHz - Channel 90
- 40.665 MHz - Channel 665
- 40.675 MHz - Channel 675
- 40.685 MHz - Channel 685
- 40.695 MHz - Channel 695
- 40.705 MHz - Channel 705
- 40.715 MHz - Channel 715
- 40.725 MHz - Channel 715
- 40.735 MHz - Channel 735
- 40.745 MHz - Channel 745
- 40.755 MHz - Channel 755
- 40.785 MHz - Channel 785
- 40.795 MHz - Channel 795
- 40.805 MHz - Channel 805
- 40.815 MHz - Channel 815
- 40.825 MHz - Channel 825
- 40.835 MHz - Channel 835
- 40.845 MHz - Channel 845
- 40.855 MHz - Channel 855
- 40.865 MHz - Channel 865
- 40.875 MHz - Channel 875
- 40.885 MHz - Channel 885
- 40.895 MHz - Channel 895
- 40.905 MHz - Channel 905
- 40.915 MHz - Channel 915
- 40.925 MHz - Channel 925
- 40.935 MHz - Channel 935
- 40.945 MHz - Channel 945
- 40.955 MHz - Channel 955
- 40.965 MHz - Channel 965
- 40.975 MHz - Channel 975
- 40.985 MHz - Channel 985
- 40.995 MHz - Channel 995
Maximum output power 100mW or 0.1 watts. 10 kHz bandwidth - many EU/CEPT countries have additional allocations for R/C purposes, including 26/27 MHz and allocations in the 30 MHz, 31 MHz, 35 MHz, 36 MHz, 40 MHz and other bands into the VHF/UHF range.
- 27.095 MHz - 27095 kHz - European CEPT designator A3
