HF pagers
Frequency List
Frequency | Remarks |
26.200 MHz | UK Paging on-site pager |
26.200 MHz | Italy Paging on-site pager (European standard frequency, AM and FM allowed) |
26.220 MHz | UK Paging on-site pager (offset frequency) |
26.225 MHz | Begin European standardized 26 MHz paging band (to 26.935 MHz) with some exceptions |
26.225 MHz | UK Paging on-site pager (offset frequency) |
26.237 MHz | UK Paging on-site, non-hospital use (offset frequency, 26.2375 MHz, 26.238 MHz) |
26.250 MHz | UK Paging on-site pager |
26.300 MHz | UK Paging on-site pager |
26.350 MHz | UK Paging on-site pager |
26.350 MHz | Italy Paging on-site pager (European standard frequency, AM and FM allowed) |
26.410 MHz | UK Paging on-site, non-hospital use |
26.435 MHz | UK Paging on-site, non-hospital use (offset frequency, 26.436 MHz) |
26.437 MHz | UK Paging on-site, non-hospital use (offset frequency, 26.4375 MHz, 26.438 MHz) |
26.460 MHz | UK Paging on-site, non-hospital use (offset frequency) |
26.462 MHz | UK Paging on-site, non-hospital use (offset frequency, 26.4625 MHz, 26.463 MHz) |
26.500 MHz | Paging, heard in Europe, noted use in Holland |
26.545 MHz | UK Paging on-site, non-hospital use |
26.580 MHz | UK Paging on-site, non-hospital use |
26.590 MHz | UK Paging on-site, non-hospital use (offset frequency, 26.5875 MHz, 26.588 MHz) |
26.600 MHz | Paging, heard in Europe, allocated in Holland (see 26.5 MHz above) |
26.605 MHz | Pager, unknown origin, heard on European SDRs during band openings, possible offset for 26.6 MHz |
26.615 MHz | UK Paging on-site, non-hospital use, heard on European SDRs during band openings |
26.635 MHz | Unknown origin pager, logged August 2017 sending POCSAG on UK remote SDR |
26.670 MHz | UK Paging on-site, non-hospital use |
26.675 MHz | Designated FM (ROS, PSK31, etc) data channel in Germany [German CB channel 52] |
26.685 MHz | Designated FM (ROS, PSK31, etc) data channel in Germany [German CB channel 53] |
26.695 MHz | Offset frequency for 26.700 MHz, heard in Western Europe and UK |
26.700 MHz | European on-site paging systems, pager transmitter center frequency (see 26.695 MHz and 26.705 MHz) |
26.705 MHz | Offset frequency for 26.700 MHz, heard in Western Europe and UK |
26.715 MHz | UK Paging on-site pager |
26.725 MHz | UK Paging on-site pager |
26.735 MHz | Pager, unknown origin, possibly Eastern Europe and/or Russia |
26.745 MHz | UK Paging on-site pager |
26.750 MHz | UK Paging on-site pager |
26.755 MHz | UK Paging on-site pager, monitored in Finland and elsewhere in Europe |
26.785 MHz | UK Paging on-site pager |
26.815 MHz | UK Paging on-site pager |
26.815 MHz | France - low power RC radio control data frequency |
26.825 MHz | France - low power RC radio control data frequency |
26.835 MHz | POCSAG pager - unknown origin pager (heard sporadically in UK, heard often in Russia) |
26.835 MHz | France - low power RC radio control data frequency |
26.845 MHz | France - low power RC radio control data frequency |
26.855 MHz | France - low power RC radio control data frequency |
26.865 MHz | UK Paging on-site pager |
26.865 MHz | France - low power RC radio control data frequency |
26.875 MHz | France - low power RC radio control data frequency |
26.885 MHz | France - low power RC radio control data frequency |
26.890 MHz | POCSAG pager logged in Europe during band openings, unknown origin |
26.895 MHz | France - low power RC radio control data frequency |
26.900 MHz | POCSAG pager - unknown origin (heard daily in UK, very strong signals) |
26.905 MHz | France - low power RC radio control data frequency |
26.915 MHz | France - low power RC radio control data frequency |
26.915 MHz | Designated FM (ROS, PSK31, etc) data channel in Germany [German CB channel 76] |
26.925 MHz | Designated FM (ROS, PSK31, etc) data channel in Germany [German CB channel 77] |
26.925 MHz | Data link system, heard in UK during band opening to Eastern Europe, CIS and/or Russia |
26.935 MHz | End European harmonized 26MHz pager band (26.225-26.935 MHz with some exceptions) |
26.945 MHz | POCSAG pager (other modes heard) - heard daily in Russia - Russian 26 MHz paging system |
26.950 MHz | Local pager, heard in mainland Europe, transmits "idle" signal even when no pages are being sent |
26.950 MHz | Fixed allocation - often used for point-to-point links outside USA |
26.955 MHz | Paging heard on several Russian SDRs, possible alternate to 26.945 MHz and 26.95 MHz frequencies? |
26.955 MHz | European standardized R/C and telemetry |
26.955 MHz | Fixed allocation - often used for point-to-point links outside USA (26950 kHz 26960 kHz allocation "international fixed") |
26.957 MHz | BEGIN ISM ISM ALLOCATION 26957-27283 kHz [center frequency 27120 +/- 163 kHz] |
26.960 MHz | Local pager, heard in mainland Europe, POCSAG paging 26MHz |
26.960 MHz | European standardized R/C and telemetry |
26.965 MHz | On-site local paging 5 watt ERP (Finland) |
26.975 MHz | UK data frequency, UK low-power R/C "Black" telemetry (100 mw limit) |
26.978 MHz | New Zealand channel RP1A on-site paging POCSAG |
26.995 MHz | Data link, paging systems and pagers, worldwide - also used for R/C purposes "Channel 3A" |
26.995 MHz | Radio Control RC Service Part 95 4 watt power limit in USA |
26.995 MHz | Linear Controls "Xtended Range Wireless" telemetry/control system, 4 watts FSK mode (Canada version) |
26.995 MHz | Migro Wireless Industrial wireless monitoring and control systems 27MHz - 4 watt FM FSK data link networks |
26.995 MHz | Australian 27 MHz R/C Channel 1 |
26.995 MHz | UK data frequency, UK low-power R/C "Brown" telemetry (100 mw limit) |
26.995 MHz | European standardized Short-Range Device (SRD) 100mw (10 kHz bandwidth or less) (26.990 MHz - 27.000 MHz) "A1" |
27.003 MHz | New Zealand channel RP2A on-site paging POCSAG |
27.007 MHz | POCSAG paging signal, heard in Finland (unknown source) |
27.015 MHz | Noted use for low-power on site paging in Ireland |
27.020 MHz | New Zealand R/C Channel 102 (100mw maximum power) |
27.025 MHz | UK data frequency, UK low-power R/C "Brown-Red" telemetry (100 mw limit) |
27.028 MHz | New Zealand channel RP3A on-site paging POCSAG |
27.045 MHz | Data link, paging systems and pagers, worldwide - also used for R/C purposes "Channel 7A" |
27.045 MHz | Radio Control RC Service Part 95 4 watt power limit in USA |
27.045 MHz | Australian 27 MHz R/C Channel 2 |
27.045 MHz | UK data frequency, UK low-power R/C "Red" telemetry (100 mw limit) |
27.045 MHz | European standardized Short-Range Device (SRD) 100mw (10 kHz bandwidth or less) (27.040 MHz - 27.050 MHz) "A2" |
27.053 MHz | New Zealand channel RP4A on-site paging POCSAG |
27.070 MHz | New Zealand R/C Channel 107 (100mw maximum power) |
27.075 MHz | On-site local paging 5 watt ERP (Finland) |
27.075 MHz | UK data frequency, UK low-power R/C "Red-Orange" telemetry (100 mw limit) |
27.078 MHz | New Zealand channel RP5A on-site paging POCSAG |
27.090 MHz | Russian pagers, heard on Russian and Eastern European SDRs |
27.095 MHz | Data link, paging systems and pagers, worldwide - also used for R/C purposes "Channel 11A" |
27.095 MHz | Radio Control RC Service Part 95 4 watt power limit in USA |
27.095 MHz | Australian 27 MHz R/C Channel 3 |
27.095 MHz | UK data frequency, UK low-power R/C "Orange" telemetry (100 mw limit) |
27.095 MHz | European standardized Short-Range Device (SRD) 100mw (10 kHz bandwidth or less) (27.090 MHz - 27.100 MHz) "A3" |
27.095 MHz | European standardized Eurobalise train telemetry system (27.090 MHz - 27.100 MHz) |
27.103 MHz | New Zealand channel RP6A on-site paging POCSAG |
27.120 MHz | ISM center frequency 27.120 MHz +/- 163 kHz, often used for Part 15 devices (26.957 to 27.283 MHz) |
27.120 MHz | Part 15 Beacon frequency (second harmonic of 22 meters 13.56 MHz x2 - 27.12 MHz) |
27.120 MHz | New Zealand R/C Channel 112 (100mw maximum power) |
27.125 MHz | UK data frequency, UK low-power R/C "Orange-Yellow" telemetry (100 mw limit) |
27.125 MHz | Part 15 Beacon frequency (second harmonic 13 MHz ISM band 27.106 MHz - 27.134 MHz / 27106 kHz - 27134 kHz) |
27.137 MHz | New Zealand channel RP7A on-site paging POCSAG (offset frequency, 27.1375 MHz, 27.138 MHz) |
27.140 MHz | Russian pagers, heard on Russian and Eastern European SDRs |
27.145 MHz | Data link, paging systems and pagers, worldwide - also used for R/C purposes "Channel 15A" |
27.145 MHz | Radio Control RC Service Part 95 4 watt power limit in USA |
27.145 MHz | Australian 27 MHz R/C Channel 4 |
27.145 MHz | UK data frequency, UK low-power R/C "Yellow" telemetry (100 mw limit) |
27.145 MHz | European standardized Short-Range Device (SRD) 100mw (10 kHz bandwidth or less) (27.140 MHz - 27.150 MHz) "A4" |
27.162 MHz | New Zealand channel RP8A on-site paging POCSAG (offset frequency, 27.1625 MHz, 27.163 MHz) |
27.170 MHz | New Zealand R/C Channel 117 (100mw maximum power) |
27.175 MHz | UK data frequency, UK low-power R/C "Yellow-Green" telemetry (100 mw limit) |
27.187 MHz | New Zealand channel RP9A on-site paging POCSAG (offset frequency, 27.1875 MHz, 27.188 MHz) |
27.190 MHz | Paging, possibly on-site, heard on French and German SDRs |
27.195 MHz | Data link, paging systems and pagers, worldwide - also used for R/C purposes "Channel 19A" |
27.195 MHz | Radio Control RC Service Part 95 4 watt power limit in USA |
27.195 MHz | Australian 27 MHz R/C Channel 6 |
27.195 MHz | UK data frequency, UK low-power R/C "Green" telemetry (100 mw limit) |
27.195 MHz | European standardized Short-Range Device (SRD) 100mw (10 kHz bandwidth or less) (27.190 MHz - 27.200 MHz) "A5" |
27.212 MHz | New Zealand channel RP10A on-site paging POCSAG (offset frequency, 27.2125 MHz, 27.213 MHz) |
27.220 MHz | New Zealand R/C Channel 122 (100mw maximum power) |
27.225 MHz | UK data frequency, UK low-power "Green-Blue" R/C telemetry (100 mw limit) |
27.230 MHz | European standardized R/C and telemetry |
27.235 MHz | Digital modes (ROS, PSK31, etc) and paging found here - Europe |
27.237 MHz | New Zealand channel RP11A on-site paging POCSAG (offset frequency, 27.2375 MHz, 27.238 MHz) |
27.240 MHz | European standardized R/C and telemetry |
27.245 MHz | Digital modes (ROS, PSK31, etc) and paging found here - Europe |
27.245 MHz | UK data frequency, UK low-power R/C "Blue" telemetry (100 mw limit) |
27.250 MHz | Noted use in Eastern Europe/Russia for POCSAG |
27.255 MHz | Data link, paging systems and pagers, worldwide - also used for R/C purposes - CB Channel 23 |
27.255 MHz | Paging USA, 25 watt power allowed in US for paging, telemetry, data link and R/C |
27.255 MHz | Radio Control RC Service Part 95 25 watt power limit in USA |
27.255 MHz | Linear Controls "Xtended Range Wireless" telemetry/control system, 10 watts FSK mode |
27.255 MHz | On-site local paging 5 watt ERP (Finland) |
27.255 MHz | Multiple-site FSK 27 MHz data link system noted near Poughquag, NY USA, 7.5-8 kHz bandwidth FSK bursts |
27.255 MHz | Multiple-site FSK 27 MHz data link system noted near Highland Falls, NY USA, nearly constant FSK data bursts |
27.255 MHz | Multiple-site FSK datalink system noted near CT/MA border, similar data bursts to systems in New York state |
27.255 MHz | RadioShack 7-watt FSK paging transmitter on-site system frequency (legal under Part 95 of FCC rules) |
27.255 MHz | WAVE Lightning Detection/Alert Remote Sirens - 10 watt data network connecting remote sites using FSK on 27.255 MHz |
27.255 MHz | Command Communications PS2000 PS2000AN PrivatePage on-site hospital paging system |
27.255 MHz | Devar, Inc PS1 PS1-B PR1 PR1-B Plug and Send telemetry systems 10 watts FSK (various versions on the market) |
27.255 MHz | POCSAG Paging System - unknown location last heard during 11 meter band opening in 2016 |
27.262 MHz | New Zealand channel RP12A on-site paging POCSAG (offset frequency, 27.2625 MHz, 27.263 MHz) |
27.270 MHz | Local pager, heard in mainland Europe, similar to systems operating on 27.300 MHz and 27.350 MHz |
27.275 MHz | UK data frequency, UK low-power R/C "White" or "Purple" telemetry (100 mw limit) |
27.280 MHz | New Zealand R/C Channel 128 (100mw maximum power) |
27.283 MHz | END ISM ALLOCATION 26957-27283 kHz [center frequency 27120 +/- 163 kHz] |
27.300 MHz | POCSAG Paging (heard daily in UK) |
27.350 MHz | POCSAG Paging (heard sporadically in UK - unknown origin) |
27.360 MHz | POCSAG Paging (heard sporadically in UK - unknown origin) |
27.400 MHz | On-site local paging 5 watt ERP (Finland) |
27.400 MHz | Republic of Korea / South Korea on-site paging frequency allocation |
27.410 MHz | Republic of Korea / South Korea on-site paging frequency allocation |
27.410 MHz | European standardized R/C and telemetry |
27.412 MHz | Republic of Korea / South Korea on-site paging frequency allocation (offset frequency 27.4125 MHz) |
27.415 MHz | European standardized R/C and telemetry |
27.415 MHz | Short-range audio links, including radio microphones (Czech Republic) |
27.422 MHz | Republic of Korea / South Korea on-site paging frequency allocation (offset frequency 27.4225 MHz) |
27.440 MHz | Republic of Korea / South Korea on-site paging frequency allocation |
27.450 MHz | Paging, heard in several parts of Europe |
27.465 MHz | Short-range audio links, including radio microphones (Czech Republic) |
27.510 MHz | Paging, German allocation pager 27 MHz |
27.515 MHz | Short-range audio links, including radio microphones (Czech Republic) |
27.545 MHz | R/C, data link and telemetry low power "RC channel 31" |
27.550 MHz | Paging, POCSAG, heard on European SDRs, unknown origin |
27.565 MHz | Short-range audio links, including radio microphones (Czech Republic) |
27.600 MHz | POCSAG Paging (heard daily in Netherlands) |
27.615 MHz | Short-range audio links, including radio microphones (Czech Republic) |
27.615 MHz | R/C, data link and telemetry low power "RC channel 32" |
27.635 MHz | R/C, data link and telemetry low power "RC channel 33" |
27.635 MHz | Digital modes (ROS, PSK31, etc) and paging found here - Europe |
27.650 MHz | POCSAG Paging (heard daily in Netherlands) |
27.650 MHz | Data link (US East Coast based), possibly US military |
27.665 MHz | Short-range audio links, including radio microphones (Czech Republic) |
27.675 MHz | R/C, data link and telemetry low power "RC channel 34" |
27.700 MHz | POCSAG Paging (heard daily in Netherlands) |
27.715 MHz | Short-range audio links, including radio microphones (Czech Republic) |
27.725 MHz | R/C, data link and telemetry low power "RC channel 35" |
27.750 MHz | POCSAG Paging (heard daily in Netherlands) |
27.765 MHz | Short-range audio links, including radio microphones (Czech Republic) |
27.775 MHz | R/C, data link and telemetry low power "RC channel 36" |
27.815 MHz | Short-range audio links, including radio microphones (Czech Republic) |
27.865 MHz | Short-range audio links, including radio microphones (Czech Republic) |
27.905 MHz | European standardized data link, telemetry and R/C - 1 watt power limit max 8.5 kHz bandwidth |
27.915 MHz | European standardized data link, telemetry and R/C - 1 watt power limit max 8.5 kHz bandwidth |
27.915 MHz | Short-range audio links, including radio microphones (Czech Republic) |
27.965 MHz | Short-range audio links, including radio microphones (Czech Republic) |
27.975 MHz | European standardized data link, telemetry and R/C - 100mw power limit 8.5 kHz bandwidth |
27.985 MHz | European standardized data link, telemetry and R/C - 100mw power limit 8.5 kHz bandwidth |
27.995 MHz | European standardized data link, telemetry and R/C - 100mw power limit 8.5 kHz bandwidth |
Keywords:
26 MHz pager 27MHz paging 27.255 MHz data link 27 MHz data transmitter 27007 kHz 27255 kHz FCC Part 15 Part 95 POCSAG 26.995MHz 27.045MHz 27.095MHz 27.145MHz 27.195MHz 27.225MHz 27.235MHz 27.245MHz 27.255MHz 27.270MHz 27.12 MHz ISM 27MHz band paging Long Range Systems 467.750 MHz RCRS Remote Control Radio Service 25 watt 27.255 data 27MHz data link 100mw low power data link IOT low frequency 900 MHz 151.820 MHz 151.880 MHz 151.940 MHz 154.570 MHz 154.600 MHz MURS data datalink 154MHz 151MHz license free long range 10 watt FSK signal Linear Systems WAVE lightning detector remote monitoring link 27MHz CB radio frequency list HFUnderground Community Audio Distribution Service CADS Wireless Public Address System WPAS 27.995 MHz 26.000 MHz 26MHz paging pager EU harmonized radio bands allocation 27.5 MHz 27500 kHz 27.905 MHz 10mw 1w 1 watt 27.915 MHz 27.965MHz 27.975 MHz 27.985 MHz 27.555 MHz international fixed service 26955 26.955 26,955 26,995 27,045 27,095 27,145 27,195, 27,225, 27,255 11_meter freeband 11 meter band 30 MHz band 29 MHz band 26 MHz band are 10 meter radios illegal freeband frequencies how do I use a CB radio police frequencies
