HF marine
Revision as of 13:17, 6 March 2019 by R4002 (Talk | contribs)
See also: VHF marine band
Band Frequency Range
2450-2850 kHz MF 2 MHz marine band, USB voice and FSK modes, some AM voice heard here in Russia, Eastern Europe and Asia (older-generation trawler radios)
16460-17360 kHz HF 16 MHz/17 MHz marine band - USB voice calling/distress 16420 kHz, DSC calling/distress 16804.5 kHz
25070-25121 kHz HF 25 MHz marine band
26145-26175 kHz HF 26 MHz marine band
26175-28000 kHz Various CB-like marine allocations found in this region (many SSB marine radios stop at 27500 kHz or 27.5 MHz)
SEA 209 2/4/6/8 MHz MF-SSB/HF-SSB marine transceiver - note the band switch + channel selector + clarifier or clarify (fine tune) control (labelled as CLARITY on this radio) combination with frequency display, similar to how export CB radios operate
See also:
