HF marine
See also: VHF marine band
Band | Frequency Range |
405-525 kHz | MF band, used in some areas for NAVTEX on 490 kHz and/or 518 kHz. 500 kHz or 500 kc (600 meters) was the original CW Morse code calling frequency |
1600-2000 kHz | MF band, used in Europe and elsewhere (also used heavily for fishnet beacons) - overlaps with 1800-2000 kHz 160 meter amateur band |
2000-2300 kHz | MF 2 MHz marine band - USB voice calling/distress 2182 kHz, DSC calling/distress 2187.5 kHz - USCG no longer monitors 2182 kHz USB |
2450-2850 kHz | MF 2 MHz marine band, USB voice and FSK modes, some AM voice heard here in Russia, Eastern Europe and Asia (older-generation trawler radios 2-3 MHz) |
4000-4063 kHz | 4 MHz fixed/mobile band, shared with marine for simplex purposes, can be paired cross-band with 8 MHz |
4063-4438 kHz | HF 4 MHz marine band - USB voice calling/distress 4125 kHz, DSC calling/distress 4207.5 kHz |
6200-6525 kHz | HF 6 MHz marine band - USB voice calling/distress 6215 kHz, DSC calling/distress 6312 kHz |
8000-8195 kHz | 8 MHz fixed/mobile band, shared with marine for simplex purposes, can be paired cross-band with 4 MHz |
8195-8815 kHz | HF 8 MHz marine band - USB voice calling/distress 8291 kHz, DSC calling/distress 8414.5 kHz |
12330-13200 kHz | HF 12 MHz marine band - USB voice calling/distress 12290 kHz, DSC calling/distress 12577 kHz |
16460-17360 kHz | HF 16 MHz/17 MHz marine band - USB voice calling/distress 16420 kHz, DSC calling/distress 16804.5 kHz |
18780-18900 kHz | HF 18 MHz marine band |
19680-19800 kHz | HF 19 MHz marine band |
22000-22855 kHz | HF 22 MHz marine band |
25070-25121 kHz | HF 25 MHz marine band |
26145-26175 kHz | HF 26 MHz marine band |
26175-30000 kHz | Various CB-like marine allocations found in this region (many SSB marine radios stop at 27500 kHz or 27.5 MHz) |
- 2003.0 kHz
- 2065.0 kHz
- 2079.0 kHz
- 2082.5 kHz
- 2086.0 kHz
- 2093.0 kHz
- 2096.5 kHz
- 2142.0 kHz
- 2203.0 kHz
- 2214.0 kHz
- 2635.0 kHz
- 2638.0 kHz
- 2738.0 kHz
- 2782.0 kHz
- 2830.0 kHz
- 4146.0 kHz
- 4149.0 kHz
- 4417.0 kHz
- 6224.0 kHz
- 6227.0 kHz
- 6230.0 kHz
- 6516.0 kHz
- 8294.0 kHz
- 8297.0 kHz
- 12353.0 kHz
- 12356.0 kHz
- 12359.0 kHz
- 12362.0 kHz
- 12365.0 kHz
- 16528.0 kHz
- 16531.0 kHz
- 16534.0 kHz
- 16537.0 kHz
- 16540.0 kHz
- 16543.0 kHz
- 16546.0 kHz
- 18825.0 kHz
- 18828.0 kHz
- 18831.0 kHz
- 18834.0 kHz
- 18837.0 kHz
- 18840.0 kHz
- 18843.0 kHz
- 22159.0 kHz
- 22162.0 kHz
- 22165.0 kHz
- 22168.0 kHz
- 22171.0 kHz
- 22174.0 kHz
- 22177.0 kHz
- 25100.0 kHz
- 25103.0 kHz
- 25106.0 kHz
- 25109.0 kHz
- 25112.0 kHz
- 25115.0 kHz
- 25118.0 kHz
ITU Channel | Ship Transmit / Coast Receive | Coast Transmit / Ship Receive |
401 | 4065 kHz | 4357 kHz |
402 | 4068 kHz | 4360 kHz |
403 | 4065 kHz | 4357 kHz |
404 | 4065 kHz | 4357 kHz |
405 | 4065 kHz | 4357 kHz |
406 | 4065 kHz | 4357 kHz |
407 | 4065 kHz | 4357 kHz |
408 | 4065 kHz | 4357 kHz |
409 | 4065 kHz | 4357 kHz |
410 | 4065 kHz | 4357 kHz |
411 | 4065 kHz | 4357 kHz |
412 | 4065 kHz | 4357 kHz |
413 | 4065 kHz | 4357 kHz |
414 | 4065 kHz | 4357 kHz |
415 | 4065 kHz | 4357 kHz |
416 | 4065 kHz | 4357 kHz |
417 | 4065 kHz | 4357 kHz |
418 | 4065 kHz | 4357 kHz |
419 | 4065 kHz | 4357 kHz |
420 | 4065 kHz | 4357 kHz |
421 | 4065 kHz | 4357 kHz |
422 | 4065 kHz | 4357 kHz |
423 | 4065 kHz | 4357 kHz |
424 | 4065 kHz | 4357 kHz |
425 | 4065 kHz | 4357 kHz |
426 | 4065 kHz | 4357 kHz |
427 | 4065 kHz | 4357 kHz |
428 | 4065 kHz | 4357 kHz |
429 | 4065 kHz | 4357 kHz |
601 | 6200 kHz | 6501 kHz |
602 | 6203 kHz | 6504 kHz |
603 | 6206 kHz | 6507 kHz |
604 | 6209 kHz | 6510 kHz |
605 | 6212 kHz | 6513 kHz |
606 | 6215 kHz | 6516 kHz |
607 | 6218 kHz | 6519 kHz |
608 | 6221 kHz | 6522 kHz |
801 | 4065 kHz | 4357 kHz |
802 | 4068 kHz | 4360 kHz |
803 | 4065 kHz | 4357 kHz |
804 | 4065 kHz | 4357 kHz |
805 | 4065 kHz | 4357 kHz |
806 | 4065 kHz | 4357 kHz |
807 | 4065 kHz | 4357 kHz |
808 | 4065 kHz | 4357 kHz |
809 | 4065 kHz | 4357 kHz |
810 | 4065 kHz | 4357 kHz |
811 | 4065 kHz | 4357 kHz |
812 | 4065 kHz | 4357 kHz |
813 | 4065 kHz | 4357 kHz |
814 | 4065 kHz | 4357 kHz |
815 | 4065 kHz | 4357 kHz |
816 | 4065 kHz | 4357 kHz |
817 | 4065 kHz | 4357 kHz |
818 | 4065 kHz | 4357 kHz |
819 | 4065 kHz | 4357 kHz |
820 | 4065 kHz | 4357 kHz |
821 | 4065 kHz | 4357 kHz |
822 | 4065 kHz | 4357 kHz |
823 | 4065 kHz | 4357 kHz |
824 | 4065 kHz | 4357 kHz |
825 | 4065 kHz | 4357 kHz |
826 | 4065 kHz | 4357 kHz |
827 | 4065 kHz | 4357 kHz |
828 | 4065 kHz | 4357 kHz |
829 | 4065 kHz | 4357 kHz |
830 | 4065 kHz | 4357 kHz |
831 | 4065 kHz | 4357 kHz |
832 | 4065 kHz | 4357 kHz |
833 | 4065 kHz | 4357 kHz |
1201 | 4065 kHz | 4357 kHz |
1202 | 4068 kHz | 4360 kHz |
1203 | 4065 kHz | 4357 kHz |
1204 | 4065 kHz | 4357 kHz |
1205 | 4065 kHz | 4357 kHz |
1206 | 4065 kHz | 4357 kHz |
1207 | 4065 kHz | 4357 kHz |
1208 | 4065 kHz | 4357 kHz |
1209 | 4065 kHz | 4357 kHz |
1210 | 4065 kHz | 4357 kHz |
1211 | 4065 kHz | 4357 kHz |
1212 | 4065 kHz | 4357 kHz |
1213 | 4065 kHz | 4357 kHz |
1214 | 4065 kHz | 4357 kHz |
1215 | 4065 kHz | 4357 kHz |
1216 | 4065 kHz | 4357 kHz |
1217 | 4065 kHz | 4357 kHz |
1218 | 4065 kHz | 4357 kHz |
1219 | 4065 kHz | 4357 kHz |
1220 | 4065 kHz | 4357 kHz |
1221 | 4065 kHz | 4357 kHz |
1222 | 4065 kHz | 4357 kHz |
1223 | 4065 kHz | 4357 kHz |
1224 | 4065 kHz | 4357 kHz |
1225 | 4065 kHz | 4357 kHz |
1226 | 4065 kHz | 4357 kHz |
1227 | 4065 kHz | 4357 kHz |
1228 | 4065 kHz | 4357 kHz |
1229 | 4065 kHz | 4357 kHz |
1230 | 4065 kHz | 4357 kHz |
1231 | 4065 kHz | 4357 kHz |
1232 | 4065 kHz | 4357 kHz |
1233 | 4065 kHz | 4357 kHz |
1234 | 4065 kHz | 4357 kHz |
1235 | 4065 kHz | 4357 kHz |
1236 | 4065 kHz | 4357 kHz |
1237 | 4065 kHz | 4357 kHz |
1238 | 4065 kHz | 4357 kHz |
1239 | 4065 kHz | 4357 kHz |
1240 | 4065 kHz | 4357 kHz |
1241 | 4065 kHz | 4357 kHz |
1601 | 4065 kHz | 4357 kHz |
1602 | 4068 kHz | 4360 kHz |
1603 | 4065 kHz | 4357 kHz |
1604 | 4065 kHz | 4357 kHz |
1605 | 4065 kHz | 4357 kHz |
1606 | 4065 kHz | 4357 kHz |
1607 | 4065 kHz | 4357 kHz |
1608 | 4065 kHz | 4357 kHz |
1609 | 4065 kHz | 4357 kHz |
1610 | 4065 kHz | 4357 kHz |
1611 | 4065 kHz | 4357 kHz |
1612 | 4065 kHz | 4357 kHz |
1613 | 4065 kHz | 4357 kHz |
1614 | 4065 kHz | 4357 kHz |
1615 | 4065 kHz | 4357 kHz |
1616 | 4065 kHz | 4357 kHz |
1617 | 4065 kHz | 4357 kHz |
1618 | 4065 kHz | 4357 kHz |
1619 | 4065 kHz | 4357 kHz |
1620 | 4065 kHz | 4357 kHz |
1621 | 4065 kHz | 4357 kHz |
1622 | 4065 kHz | 4357 kHz |
1623 | 4065 kHz | 4357 kHz |
1624 | 4065 kHz | 4357 kHz |
1625 | 4065 kHz | 4357 kHz |
1626 | 4065 kHz | 4357 kHz |
1627 | 4065 kHz | 4357 kHz |
1628 | 4065 kHz | 4357 kHz |
1629 | 4065 kHz | 4357 kHz |
1630 | 4065 kHz | 4357 kHz |
1631 | 4065 kHz | 4357 kHz |
1632 | 4065 kHz | 4357 kHz |
1633 | 4065 kHz | 4357 kHz |
1634 | 4065 kHz | 4357 kHz |
1635 | 4065 kHz | 4357 kHz |
1636 | 4065 kHz | 4357 kHz |
1637 | 4065 kHz | 4357 kHz |
1639 | 4065 kHz | 4357 kHz |
1640 | 4065 kHz | 4357 kHz |
1641 | 4065 kHz | 4357 kHz |
1642 | 4065 kHz | 4357 kHz |
1643 | 4065 kHz | 4357 kHz |
1644 | 4065 kHz | 4357 kHz |
1645 | 4065 kHz | 4357 kHz |
1646 | 4065 kHz | 4357 kHz |
1647 | 4065 kHz | 4357 kHz |
1648 | 4065 kHz | 4357 kHz |
1649 | 4065 kHz | 4357 kHz |
1650 | 4065 kHz | 4357 kHz |
1651 | 4065 kHz | 4357 kHz |
1652 | 4065 kHz | 4357 kHz |
1653 | 4065 kHz | 4357 kHz |
1654 | 4065 kHz | 4357 kHz |
1655 | 4065 kHz | 4357 kHz |
1656 | 4065 kHz | 4357 kHz |
- 18 MHz (18780 kHz - 18900 kHz) / 19 MHz marine band:
1801 | 18780 kHz | 19755 kHz |
1802 | 18783 kHz | 19758 kHz |
1803 | 18786 kHz | 19761 kHz |
1804 | 18789 kHz | 19764 kHz |
1805 | 18792 kHz | 19767 kHz |
1806 | 18795 kHz | 19770 kHz |
1807 | 18798 kHz | 19773 kHz |
1808 | 18801 kHz | 19776 kHz |
1809 | 18804 kHz | 19779 kHz |
1810 | 18807 kHz | 19782 kHz |
1811 | 18810 kHz | 19785 kHz |
1812 | 18813 kHz | 19788 kHz |
1813 | 18816 kHz | 19791 kHz |
1814 | 18819 kHz | 19794 kHz |
1815 | 18822 kHz | 19797 kHz |
See also:
- VHF marine band
- Maritime Fax Transmissions
