As with the 72 MHz and 75 MHz RC frequencies, 26/27 MHz RC transmitters are limited to 8 kHz bandwidth. Emissions include 8K00F1D, 8K00F2D, 8K00A1D, 8K00A2D, 7K50F1D, 7K50F2D, 7K50A1D, 6K00F1D, 6K00F2D, 6K00A1D, 6K00A2D, or similar emissions. Like AM CB radio voice, standard specified emissions may range from 5.5 kHz to 7.5 kHz to the 8.0 kHz limit. There are numerous bandwidth and modulation combinations in use. Standard 26/27 MHz (26-28 MHz in the FCC rules) AM voice transceivers use 8K00A3E, 6K00A3E (standard AM voice) 5K75A3E, 5K80A3E or similar emissions.
49 MHz RC Frequencies
RC transmitters generally use generally use 49.830 MHz or 49.860 MHz as 49 MHz "RC channel 1". Children's RC toys are often offered in two versions, a "49 MHz" version and a "27 MHz" version, without any channel numbers indicated. The 27 MHz version generally will operate on 27.145 MHz. These devices are usually operating under Part 15, not Part 95 (with some rare exceptions for the 26 / 27 MHz gear. Part 15 power limit is 10,000 microvolts per meter at 3 meters (10,000 microvolts/meter at 3m).
49.6 MHz - 50 MHz (49.600 MHz - 49.975 MHz, 49.995 MHz) band (47 CFR 15.235 subband 49.820 MHz - 49.900 MHz) shared with military users and other Part 15 devices, including baby monitors, wireless microphones, 49 MHz walkie-talkies, intercom systems and first-generation cordless phones.
For a more in-depth discussion of other 49 MHz band devices, see the 49 MHz Part 15 page - Operation within the band 49.82 MHz - 49.90 MHz.
- 49.830 MHz - Channel 1/Channel A - Secondary 49 MHz RC frequency
- 49.860 MHz - Channel 3/Channel C - Primary 49 MHz RC frequency
Many devices using the 49 MHz band use non-standard frequencies or channels (for various reasons). See the Part 15 link above for more information.
The following channels are allocated to remote controlled aircraft, 750 mW 0.75 watt max transmitter power. From 72.400 MHz to 72.600 MHz, band is shared with operational fixed, business data link, telemetry and point-to-point links within the Business Radio Service
- 72.010 MHz
- 72.030 MHz
- 72.050 MHz
- 72.070 MHz
- 72.090 MHz
- 72.110 MHz
- 72.130 MHz
- 72.150 MHz
- 72.170 MHz
- 72.190 MHz
- 72.210 MHz
- 72.230 MHz
- 72.250 MHz
- 72.270 MHz
- 72.290 MHz
- 72.310 MHz
- 72.330 MHz
- 72.350 MHz
- 72.370 MHz
- 72.390 MHz
- 72.410 MHz
- 72.430 MHz
- 72.450 MHz
- 72.470 MHz
- 72.490 MHz
- 72.510 MHz
- 72.530 MHz
- 72.550 MHz
- 72.570 MHz
- 72.590 MHz
- 72.610 MHz
- 72.630 MHz
- 72.650 MHz
- 72.670 MHz
- 72.690 MHz
- 72.710 MHz
- 72.730 MHz
- 72.750 MHz
- 72.770 MHz
- 72.790 MHz
- 72.810 MHz
- 72.830 MHz
- 72.850 MHz
- 72.870 MHz
- 72.890 MHz
- 72.910 MHz
- 72.930 MHz
- 72.950 MHz
- 72.970 MHz
- 72.990 MHz
- 75.410 MHz
- 75.430 MHz
- 75.450 MHz
- 75.470 MHz
- 75.490 MHz
- 75.510 MHz
- 75.530 MHz
- 75.550 MHz
- 75.570 MHz
- 75.590 MHz
- 75.610 MHz
- 75.630 MHz
- 75.650 MHz
- 75.670 MHz
- 75.690 MHz
- 75.710 MHz
- 75.730 MHz
- 75.750 MHz
- 75.770 MHz
- 75.790 MHz
- 75.810 MHz
- 75.830 MHz
- 75.850 MHz
- 75.870 MHz
- 75.890 MHz
- 75.910 MHz
- 75.930 MHz
- 75.950 MHz
- 75.970 MHz
- 75.990 MHz
Maximum output power 100mW or 0.1 watts - for general use (aircraft, ground vehicles, boats, etc). 10 kHz channel spacing, maximum 10 kHz bandwidth, AM or FM. With the exception of 26.995 MHz, 27.045 MHz, 27.095 MHz, 27.145 MHz and 27.195 MHz, these channels are shared with the CB radio service and the Community Audio Distribution Service (CADS) in the UK.
- 34.950 MHz - Channel 55
- 34.960 MHz - Channel 56
- 34.970 MHz - Channel 57
- 34.980 MHz - Channel 58
- 34.990 MHz - Channel 59
- 35.000 MHz - Channel 60
- 35.010 MHz - Channel 61
- 35.020 MHz - Channel 62
- 35.030 MHz - Channel 63
- 35.040 MHz - Channel 64
- 35.050 MHz - Channel 65
- 35.060 MHz - Channel 66
- 35.070 MHz - Channel 67
- 35.080 MHz - Channel 68
- 35.090 MHz - Channel 69
- 35.100 MHz - Channel 70
- 35.110 MHz - Channel 71
- 35.120 MHz - Channel 72
- 35.130 MHz - Channel 73
- 35.140 MHz - Channel 74
- 35.150 MHz - Channel 75
- 35.160 MHz - Channel 76
- 35.170 MHz - Channel 77
- 35.180 MHz - Channel 78
- 35.190 MHz - Channel 79
- 35.200 MHz - Channel 80
- 35.210 MHz - Channel 81
- 35.220 MHz - Channel 82
- 35.230 MHz - Channel 83
- 35.240 MHz - Channel 84
- 35.250 MHz - Channel 85
- 35.260 MHz - Channel 86
- 35.270 MHz - Channel 87
- 35.280 MHz - Channel 88
- 35.290 MHz - Channel 89
- 35.300 MHz - Channel 90
- 40.665 MHz - Channel 665
- 40.675 MHz - Channel 675
- 40.685 MHz - Channel 685
- 40.695 MHz - Channel 695
- 40.705 MHz - Channel 705
- 40.715 MHz - Channel 715
- 40.725 MHz - Channel 715
- 40.735 MHz - Channel 735
- 40.745 MHz - Channel 745
- 40.755 MHz - Channel 755
- 40.785 MHz - Channel 785
- 40.795 MHz - Channel 795
- 40.805 MHz - Channel 805
- 40.815 MHz - Channel 815
- 40.825 MHz - Channel 825
- 40.835 MHz - Channel 835
- 40.845 MHz - Channel 845
- 40.855 MHz - Channel 855
- 40.865 MHz - Channel 865
- 40.875 MHz - Channel 875
- 40.885 MHz - Channel 885
- 40.895 MHz - Channel 895
- 40.905 MHz - Channel 905
- 40.915 MHz - Channel 915
- 40.925 MHz - Channel 925
- 40.935 MHz - Channel 935
- 40.945 MHz - Channel 945
- 40.955 MHz - Channel 955
- 40.965 MHz - Channel 965
- 40.975 MHz - Channel 975
- 40.985 MHz - Channel 985
- 40.995 MHz - Channel 995
The 26/27 MHz, 34/35 MHz and 40 MHz RC frequencies/bands are designated under the "Short Range Device" (SRD) legislation/standardization. The 49 MHz SRD band is also used for RC purposes, often with equipment designed for the American market.
- 34.995 MHz to 35.225 MHz - European standardized aero models only (flying models, aircraft models only) CEPT 35 MHz band, 5/10 kHz spacing, generally starting at 35.000 MHz going up to 35.220 MHz in 10 kHz steps. Some countries have additional allocations above and below the EU standardized band.
Czech Republic
- 35.000 MHz - C1
- 35.010 MHz - C2
- 35.020 MHz - C3
- 35.030 MHz - C4
- 35.040 MHz - C5
- 35.050 MHz - C6
- 35.060 MHz - C7
- 35.070 MHz - C8
- 35.080 MHz - C9
- 35.090 MHz - C10
- 35.100 MHz - C11
- 35.110 MHz - C12
- 35.120 MHz - C13
- 35.130 MHz - C14
- 35.140 MHz - C15
- 35.150 MHz - C16
- 35.160 MHz - C17
- 35.170 MHz - C18
- 35.180 MHz - C19
- 35.190 MHz - C20
- 35.200 MHz - C21
- 35.210 MHz - C22
- 35.220 MHz - C23
- 35.820 MHz - D1
- 35.830 MHz - D2
- 35.840 MHz - D3
- 35.850 MHz - D4
- 35.860 MHz - D5
- 35.870 MHz - D6
- 35.880 MHz - D7
- 35.890 MHz - D8
- 35.900 MHz - D9
- 35.910 MHz - D10
France
- 26.815 MHz - 26815 kHz
- 26.825 MHz - 26825 kHz
- 26.835 MHz - 26835 kHz
- 26.845 MHz - 26845 kHz
- 26.855 MHz - 26855 kHz
- 26.865 MHz - 26865 kHz
- 26.875 MHz - 26875 kHz
- 26.885 MHz - 26885 kHz
- 26.895 MHz - 26895 kHz
- 26.905 MHz - 26905 kHz
- 26.915 MHz - 26915 kHz
- 35.000 MHz
- 35.010 MHz
- 35.020 MHz
- 35.030 MHz
- 35.040 MHz
- 35.050 MHz
40 MHz / 41 MHz FM
- 72 MHz AM or FM
- 27.005 MHz - 27005 kHz
- 27.015 MHz - 27015 kHz
- 27.035 MHz - 27035 kHz
- 27.055 MHz - 27055 kHz
- 27.065 MHz - 27065 kHz
- 27.085 MHz - 27085 kHz
- 27.105 MHz - 27105 kHz
- 27.115 MHz - 27115 kHz
- 27.135 MHz - 27135 kHz
- 35.010 MHz
- 35.020 MHz
- 35.030 MHz
- 35.040 MHz
- 35.050 MHz
- 35.060 MHz
- 35.070 MHz
- 35.080 MHz
- 35.090 MHz
- 35.100 MHz
- 35.110 MHz
- 35.120 MHz
- 35.130 MHz
- 35.140 MHz
- 35.150 MHz
- 35.160 MHz
- 35.170 MHz
- 35.180 MHz
- 35.190 MHz
- 35.200 MHz
- 35.820 MHz
- 35.830 MHz
- 35.840 MHz
- 35.850 MHz
- 35.860 MHz
- 35.870 MHz
- 35.880 MHz
- 35.890 MHz
- 35.900 MHz
- 35.910 MHz
- 40.665 MHz
- 40.675 MHz
- 40.685 MHz
- 40.695 MHz
Sweden
- 35.000 MHz - RC Channel 60
- 35.010 MHz - RC Channel 61
- 35.020 MHz - RC Channel 62
- 35.030 MHz - RC Channel 63
- 35.040 MHz - RC Channel 64
- 35.050 MHz - RC Channel 65
- 35.060 MHz - RC Channel 66
- 35.070 MHz - RC Channel 67
- 35.080 MHz - RC Channel 68
- 35.090 MHz - RC Channel 69
- 35.100 MHz - RC Channel 70
- 35.110 MHz - RC Channel 71
- 35.120 MHz - RC Channel 72
- 35.130 MHz - RC Channel 73
- 35.140 MHz - RC Channel 74
- 35.150 MHz - RC Channel 75
- 35.160 MHz - RC Channel 76
- 35.170 MHz - RC Channel 77
- 35.180 MHz - RC Channel 78
- 35.190 MHz - RC Channel 79
- 35.200 MHz - RC Channel 80
- 35.210 MHz - RC Channel 81
- 35.220 MHz - RC Channel 82
- 35.230 MHz - RC Channel 83
- 35.240 MHz - RC Channel 84
- 35.250 MHz - RC Channel 85
- 35.260 MHz - RC Channel 86
- 35.270 MHz - RC Channel 87
- 40.665 MHz
- 40.675 MHz
- 40.685 MHz
- 40.695 MHz
- 40.705 MHz
- 40.715 MHz
- 40.725 MHz
- 40.735 MHz
- 40.745 MHz
- 40.755 MHz
- 40.765 MHz
- 40.775 MHz
- 40.785 MHz
- 40.795 MHz
27 MHz
- 40.770 MHz - Aircraft only
- 40.790 MHz - Aircraft only
- 40.810 MHz - Aircraft only
- 40.830 MHz - Aircraft only
- 40.850 MHz - Aircraft only
- 72.130 MHz - Aircraft only
- 72.150 MHz - Aircraft only
- 72.170 MHz - Aircraft only
- 72.190 MHz - Aircraft only
- 72.210 MHz - Aircraft only
- 72.790 MHz - Aircraft only
- 72.810 MHz - Aircraft only
- 72.830 MHz - Aircraft only
- 72.850 MHz - Aircraft only
- 72.870 MHz - Aircraft only
People's Republic of China
- 40.610 MHz
- 40.630 MHz
- 40.650 MHz
- 40.670 MHz
- 40.690 MHz
- 40.710 MHz
- 40.730 MHz
- 40.750 MHz
- 40.770 MHz
- 40.790 MHz
- 40.810 MHz
- 40.830 MHz
- 40.850 MHz
- 72.130 MHz
- 72.150 MHz
- 72.170 MHz
- 72.190 MHz
- 72.210 MHz
- 72.790 MHz
- 72.810 MHz
- 72.830 MHz
- 72.850 MHz
- 72.870 MHz
- 35.000 MHz - RC Channel 500
- 35.010 MHz - RC Channel 501
- 35.020 MHz - RC Channel 502
- 35.030 MHz - RC Channel 503
- 35.040 MHz - RC Channel 504
- 35.050 MHz - RC Channel 505
- 35.060 MHz - RC Channel 506
- 35.070 MHz - RC Channel 507
- 35.080 MHz - RC Channel 508
- 35.090 MHz - RC Channel 509
- 35.100 MHz - RC Channel 510
- 35.110 MHz - RC Channel 511
- 35.120 MHz - RC Channel 512
- 35.130 MHz - RC Channel 513
- 35.140 MHz - RC Channel 514
- 35.150 MHz - RC Channel 515
- 35.160 MHz - RC Channel 516
- 35.170 MHz - RC Channel 517
- 35.180 MHz - RC Channel 518
- 35.190 MHz - RC Channel 519
- 35.200 MHz - RC Channel 520
- 35.210 MHz - RC Channel 521
- 35.220 MHz - RC Channel 522
- 35.230 MHz - RC Channel 523
- 35.240 MHz - RC Channel 524
- 35.250 MHz - RC Channel 525
- 35.260 MHz - RC Channel 526
- 35.270 MHz - RC Channel 527
- 35.280 MHz - RC Channel 528
- 35.290 MHz - RC Channel 529
- 35.300 MHz - RC Channel 530
- 36.250 MHz - RC Channel 625
- 36.260 MHz - RC Channel 626
- 36.270 MHz - RC Channel 627
- 36.280 MHz - RC Channel 628
- 36.290 MHz - RC Channel 629
- 36.300 MHz - RC Channel 630
- 36.310 MHz - RC Channel 631
- 36.320 MHz - RC Channel 632
- 36.330 MHz - RC Channel 633
- 36.340 MHz - RC Channel 634
- 36.350 MHz - RC Channel 635
- 36.360 MHz - RC Channel 636
- 36.370 MHz - RC Channel 637
- 36.380 MHz - RC Channel 638
- 36.390 MHz - RC Channel 639
- 36.400 MHz - RC Channel 640
- 36.410 MHz - RC Channel 641
- 36.420 MHz - RC Channel 642
- 36.430 MHz - RC Channel 643
- 36.440 MHz - RC Channel 644
- 36.450 MHz - RC Channel 645
- 36.460 MHz - RC Channel 646
- 36.470 MHz - RC Channel 647
- 36.480 MHz - RC Channel 648
- 36.490 MHz - RC Channel 649
- 36.500 MHz - RC Channel 650
- 36.510 MHz - RC Channel 651
- 36.520 MHz - RC Channel 652
- 36.530 MHz - RC Channel 653
- 36.540 MHz - RC Channel 654
- 36.550 MHz - RC Channel 655
- 36.560 MHz - RC Channel 656
- 36.570 MHz - RC Channel 657
- 36.580 MHz - RC Channel 658
- 36.590 MHz - RC Channel 659
- 40.510 MHz - RC Channel 451
- 40.530 MHz - RC Channel 453
- 40.550 MHz - RC Channel 455
- 40.570 MHz - RC Channel 457
- 40.590 MHz - RC Channel 459
- 40.610 MHz - RC Channel 461
- 40.630 MHz - RC Channel 463
- 40.650 MHz - RC Channel 465
- 40.670 MHz - RC Channel 467
- 40.690 MHz - RC Channel 469
- 40.710 MHz - RC Channel 471
- 40.730 MHz - RC Channel 473
- 40.750 MHz - RC Channel 475
- 40.790 MHz - RC Channel 479
- 40.810 MHz - RC Channel 481
- 40.830 MHz - RC Channel 483
- 40.850 MHz - RC Channel 485
- 40.870 MHz - RC Channel 487
- 40.890 MHz - RC Channel 489
- 40.910 MHz - RC Channel 491
- 40.930 MHz - RC Channel 493
- 72.010 MHz - RC Channel 701
- 72.030 MHz - RC Channel 703
- 72.050 MHz - RC Channel 705
- 72.070 MHz - RC Channel 707
- 72.090 MHz - RC Channel 709
- 72.110 MHz - RC Channel 711
- 72.130 MHz - RC Channel 713
- 72.150 MHz - RC Channel 715
- 72.170 MHz - RC Channel 717
- 72.190 MHz - RC Channel 719
- 72.210 MHz - RC Channel 721
- 72.230 MHz - RC Channel 723
- 72.250 MHz - RC Channel 725
- 72.270 MHz - RC Channel 727
- 72.290 MHz - RC Channel 729
- 72.310 MHz - RC Channel 731
- 72.330 MHz - RC Channel 733
- 72.350 MHz - RC Channel 735
- 72.370 MHz - RC Channel 737
- 72.390 MHz - RC Channel 739
- 72.410 MHz - RC Channel 741
- 72.430 MHz - RC Channel 743
- 72.450 MHz - RC Channel 745
- 72.470 MHz - RC Channel 747
- 72.490 MHz - RC Channel 749
- 72.510 MHz - RC Channel 751
- 72.530 MHz - RC Channel 753
- 72.550 MHz - RC Channel 755
- 72.570 MHz - RC Channel 757
- 72.590 MHz - RC Channel 759
- 72.610 MHz - RC Channel 761
- 72.630 MHz - RC Channel 763
- 72.650 MHz - RC Channel 765
- 72.670 MHz - RC Channel 767
- 72.690 MHz - RC Channel 769
- 72.710 MHz - RC Channel 771
- 72.730 MHz - RC Channel 773
- 72.750 MHz - RC Channel 775
- 72.770 MHz - RC Channel 777
- 72.790 MHz - RC Channel 779
- 36.010 MHz - RC Channel 601
- 36.020 MHz - RC Channel 602
- 36.030 MHz - RC Channel 603
- 36.040 MHz - RC Channel 604
- 36.050 MHz - RC Channel 605
- 36.060 MHz - RC Channel 606
- 36.070 MHz - RC Channel 607
- 36.080 MHz - RC Channel 608
- 36.090 MHz - RC Channel 609
- 36.100 MHz - RC Channel 610
- 36.110 MHz - RC Channel 611
- 36.120 MHz - RC Channel 612
- 36.130 MHz - RC Channel 613
- 36.140 MHz - RC Channel 614
- 36.150 MHz - RC Channel 615
- 36.160 MHz - RC Channel 616
- 36.170 MHz - RC Channel 617
- 36.180 MHz - RC Channel 618
- 36.190 MHz - RC Channel 619
- 36.200 MHz - RC Channel 620
- 36.210 MHz - RC Channel 621
- 36.220 MHz - RC Channel 622
- 36.230 MHz - RC Channel 623
- 36.240 MHz - RC Channel 624
- 40.665 MHz - RC Channel 50
- 40.675 MHz - RC Channel 51
- 40.685 MHz - RC Channel 52
- 40.695 MHz - RC Channel 53
