Three "bands" in (legal) use, the regular CB band 26.965-27.405 MHz, the UK FM "27/81" band 27.60125-27.99125 MHz and the "UW band" 27.605-27.995 MHz. Church services have been heard outside these band limits, often in the 27.405 MHz to 27.600 MHz portion and below 26.965 MHz (CB channel 1). Some churches use modified "export radios" which, instead of observing the UK FM offset, transmit on the "zeros" instead (i.e., operating on 27.800 MHz instead of 27.80125 MHz). Since the difference between UK FM offset and the zero offset is only 1.25 kHz and FM is used, this usually makes very little to no difference to the (local) receivers the church transmission is meant for. Examples include 27.729 MHz or 27.730 MHz instead of the 27.73125 MHz center frequency. 27.980 MHz AM is included in logs, even though the UK FM band prohibits use of AM mode, this would indicate use of "export" specification radios or multi-country radios set for "RU" or "Russia" mode.
CADS operates on the 80 UK CB channels (standard CB channels 1-40 and UK FM CB channels 1-40) so 26965-27405 and 27601.25-27991.25 FM mode only. UK law defines the 27/81 UK FM CB band as 27.59625 MHz to 27.99625 MHz (5 kHz down from UK CB channel 1 and 5 kHz up from UK CB channel 40, effectively 27.600 MHz to 28.000 MHz). The mid band CEPT/EU band is defined as 26.960 MHz to 27.410 MHz. Ireland's WPAS service operates on two sets of 40 interleaved channels for a total of 80 channels. Although not technically authorized in Ireland, Churches often use the standard 40 "mid band CB" or "CEPT CB" channels as well. Ireland allows use of AM and FM on all 80 channels as part of the WPAS system, while FM is the only mode allowed in the UK. When added to the 40 mid band CB channels 26.965 to 27.405 a total of 120 channels becomes available.
In practice, several churches will share frequencies or use offset channels and/or channels in between the 26.965-27.405 MHz range and the 27.60125-27.99125 MHz / 27.605-27.995 MHz range. Narrow FM mode with 5 kHz deviation (wideband in land mobile two-way radio parlance) is the standard, with some variation in deviation depending on the manufacturer and model of the radio transmitter used and when the radio was manufactured. AM mode is the standard 8 kHz A3E emission 8K00A3E (AM-narrow), although the de facto CB bandwidth is 10 kHz for AM and FM modes.
Frequencies
| CB Channel | Frequency |
| Channel 01 | 26.965 MHz |
| Channel 02 | 26.975 MHz |
| Channel 03 | 26.985 MHz |
| Channel 04 | 27.005 MHz |
| Channel 05 | 27.015 MHz |
| Channel 06 | 27.025 MHz |
| Channel 07 | 27.035 MHz |
| Channel 08 | 27.055 MHz |
| Channel 09 | 27.065 MHz |
| Channel 10 | 27.075 MHz |
| Channel 11 | 27.085 MHz |
| Channel 12 | 27.105 MHz |
| Channel 13 | 27.115 MHz |
| Channel 14 | 27.125 MHz |
| Channel 15 | 27.135 MHz |
| Channel 16 | 27.155 MHz |
| Channel 17 | 27.165 MHz |
| Channel 18 | 27.185 MHz |
| Channel 19 | 27.185 MHz |
| Channel 20 | 27.205 MHz |
| Channel 21 | 27.215 MHz |
| Channel 22 | 27.225 MHz |
| Channel 23 | 27.255 MHz |
| Channel 24 | 27.235 MHz |
| Channel 25 | 27.245 MHz |
| Channel 26 | 27.265 MHz |
| Channel 27 | 27.275 MHz |
| Channel 28 | 27.285 MHz |
| Channel 29 | 27.295 MHz |
| Channel 30 | 27.305 MHz |
| Channel 31 | 27.315 MHz |
| Channel 32 | 27.325 MHz |
| Channel 33 | 27.335 MHz |
| Channel 34 | 27.345 MHz |
| Channel 35 | 27.355 MHz |
| Channel 36 | 27.365 MHz |
| Channel 37 | 27.375 MHz |
| Channel 38 | 27.385 MHz |
| Channel 39 | 27.395 MHz |
| Channel 40 | 27.405 MHz |
