Revision as of 12:42, 11 May 2020 by R4002 (Talk | contribs)
26 MHz 27 MHz church radio parish radio - Wireless Public Address Service UK Ireland Northern Ireland
[1]
[2]
Three "bands" in (legal) use, the regular CB band 26.965-27.405 MHz, the UK FM "27/81" band 27.60125-27.99125 MHz and the "UW band" 27.605-27.995 MHz. Church services have been heard outside these band limits, often in the 27.405 MHz to 27.600 MHz portion and below 26.965 MHz (CB channel 1). Some churches use modified "export radios" which, instead of observing the UK FM offset, transmit on the "zeros" instead (i.e., operating on 27.800 MHz instead of 27.80125 MHz). Since the difference between UK FM offset and the zero offset is only 1.25 kHz and FM is used, this usually makes very little to no difference to the (local) receivers the church transmission is meant for. Examples include 27.729 MHz or 27.730 MHz instead of the 27.73125 MHz center frequency. 27.980 MHz AM is included in logs, even though the UK FM band prohibits use of AM mode, this would indicate use of "export" specification radios or multi-country radios set for "RU" or "Russia" mode.
CADS operates on the 80 UK CB channels (standard CB channels 1-40 and UK FM CB channels 1-40) so 26965-27405 and 27601.25-27991.25 FM mode only. UK law defines the 27/81 UK FM CB band as 27.59625 MHz to 27.99625 MHz (5 kHz down from UK CB channel 1 and 5 kHz up from UK CB channel 40, effectively 27.600 MHz to 28.000 MHz). The mid band CEPT/EU band is defined as 26.960 MHz to 27.410 MHz. Ireland's WPAS service operates on two sets of 40 interleaved channels for a total of 80 channels. Although not technically authorized in Ireland, Churches often use the standard 40 "mid band CB" or "CEPT CB" channels as well. Ireland allows use of AM and FM on all 80 channels as part of the WPAS system, while FM is the only mode allowed in the UK. When added to the 40 mid band CB channels 26.965 to 27.405 a total of 120 channels becomes available.
Frequencies
CB Channel Frequency
Mid Band CB UK, Europe, Ireland (used unofficially in Ireland) Defined under UK and Irish law as "26.96 MHz to 27.41 MHz"
Channel 01 26.965 MHz
Channel 02 26.975 MHz
Channel 03 26.985 MHz
Channel 04 27.005 MHz
Channel 05 27.015 MHz
Channel 06 27.025 MHz
Channel 07 27.035 MHz
Channel 08 27.055 MHz
Channel 09 27.065 MHz
Channel 10 27.075 MHz
Channel 11 27.085 MHz
Channel 12 27.105 MHz
Channel 13 27.115 MHz
Channel 14 27.125 MHz
Channel 15 27.135 MHz
Channel 16 27.155 MHz
Channel 17 27.165 MHz
Channel 18 27.185 MHz
Channel 19 27.185 MHz
Channel 20 27.205 MHz
Channel 21 27.215 MHz
Channel 22 27.225 MHz
Channel 23 27.255 MHz
Channel 24 27.235 MHz
Channel 25 27.245 MHz
Channel 26 27.265 MHz
Channel 27 27.275 MHz
Channel 28 27.285 MHz
Channel 29 27.295 MHz
Channel 30 27.305 MHz
Channel 31 27.315 MHz
Channel 32 27.325 MHz
Channel 33 27.335 MHz
Channel 34 27.345 MHz
Channel 35 27.355 MHz
Channel 36 27.365 MHz
Channel 37 27.375 MHz
Channel 38 27.385 MHz
Channel 39 27.395 MHz
Channel 40 27.405 MHz
Irish legislation specifically indicates 10 kHz channel bandwidth +/- 5 kHz from center frequency, so 27.605 MHz covers 27.600 MHz - 27.610 MHz, 27.60125 MHz covers 27.59625 MHz to 27.60625 MHz, 27.995 MHz covers 27.990 MHz - 28.000 MHz, 27.99125 MHz covers 27.98625 MHz - 27.99625 MHz. However, ComReg rules state the frequency spectrum for WPAS is 27.6 MHz to 27.99 MHz, leaving out the 27.99 MHz to 28.0 MHz spectrum..
  • 26.960 MHz - begin CB band / CADS band
  • 26.965 MHz - CB01
  • 26.975 MHz - CB02
  • 26.985 MHz - CB03
  • 27.005 MHz - CB04
  • 27.015 MHz - CB05
  • 27.025 MHz - CB06
  • 27.035 MHz - CB07
  • 27.055 MHz - CB08
  • 27.065 MHz - CB09
  • 27.075 MHz - CB10
  • 27.085 MHz - CB11
  • 27.105 MHz - CB12
  • 27.115 MHz - CB13
  • 27.125 MHz - CB14
  • 27.135 MHz - CB15
  • 27.155 MHz - CB16
  • 27.165 MHz - CB17
  • 27.175 MHz - CB18
  • 27.185 MHz - CB19
  • 27.205 MHz - CB20
  • 27.215 MHz - CB21
  • 27.225 MHz - CB22
  • 27.235 MHz - CB24
  • 27.245 MHz - CB25
  • 27.255 MHz - CB23
  • 27.265 MHz - CB25
  • 27.275 MHz - CB27
  • 27.285 MHz - CB28
  • 27.355 MHz - CB35
  • 27.365 MHz - CB36
  • 27.375 MHz - CB37
  • 27.385 MHz - CB38
  • 27.395 MHz - CB39
  • 27.405 MHz - CB40
  • 27.410 MHz - end CB band / CADS band
  • 27.59625 MHz - begin 27/81 UK FM CB band per Ofcom frequency allocation
  • 27.600 MHz - begin WPAS allocation per ComReg frequency allocation
  • 27.60125 MHz - LW01
  • 27.605 MHz - UW01
  • 27.61125 MHz - LW02
  • 27.615 MHz - UW02
  • 27.62125 MHz - LW03
  • 27.625 MHz - UW03
  • 27.63125 MHz - LW04
  • 27.635 MHz - UW04
  • 27.64125 MHz - LW05
  • 27.645 MHz - UW05
  • 27.65125 MHz - LW06
  • 27.655 MHz - UW06
  • 27.66125 MHz - LW07
  • 27.665 MHz - UW07
  • 27.67125 MHz - LW08
  • 27.675 MHz - UW08
  • 27.68125 MHz - LW09
  • 27.685 MHz - UW09
  • 27.69125 MHz - LW10
  • 27.695 MHz - UW10
  • 27.70125 MHz - LW11
  • 27.705 MHz - UW11
  • 27.71125 MHz - LW12
  • 27.715 MHz - UW12
  • 27.72125 MHz - LW13
  • 27.725 MHz - UW13
  • 27.73125 MHz - LW14
  • 27.735 MHz - UW14
  • 27.74125 MHz - LW15
  • 27.745 MHz - UW15
  • 27.75125 MHz - LW16
  • 27.755 MHz - UW16
  • 27.76125 MHz - LW17
  • 27.765 MHz - UW17
  • 27.77125 MHz - LW18
  • 27.775 MHz - UW18
  • 27.78125 MHz - LW19
  • 27.785 MHz - UW19
  • 27.79125 MHz - LW20
  • 27.795 MHz - UW20
  • 27.80125 MHz - LW21
  • 27.805 MHz - UW21
  • 27.81125 MHz - LW22
  • 27.815 MHz - UW22
  • 27.82125 MHz - LW23
  • 27.825 MHz - UW23
  • 27.83125 MHz - LW24
  • 27.835 MHz - UW24
  • 27.84125 MHz - LW25
  • 27.845 MHz - UW25
  • 27.85125 MHz - LW26
  • 27.855 MHz - UW26
  • 27.86125 MHz - LW27
  • 27.865 MHz - UW27
  • 27.87125 MHz - LW28
  • 27.875 MHz - UW28
  • 27.88125 MHz - LW29
  • 27.885 MHz - UW29
  • 27.89125 MHz - LW30
  • 27.895 MHz - UW30
  • 27.90125 MHz - LW31
  • 27.905 MHz - UW31
  • 27.91125 MHz - LW32
  • 27.915 MHz - UW32
  • 27.92125 MHz - LW33
  • 27.925 MHz - UW33
  • 27.93125 MHz - LW34
  • 27.935 MHz - UW34
  • 27.94125 MHz - LW35
  • 27.945 MHz - UW35
  • 27.95125 MHz - LW35
  • 27.955 MHz - UW36
  • 27.96125 MHz - LW37
  • 27.965 MHz - UW37
  • 27.97125 MHz - LW38
  • 27.975 MHz - UW38
  • 27.98125 MHz - LW39
  • 27.985 MHz - UW39
  • 27.990 MHz - end WPAS allocation per ComReg rules
  • 27.99125 MHz - LW40
  • 27.995 MHz - UW40
  • 27.99625 MHz - end 27/81 UK FM CB band
  • 28.000 MHz - end WPAS / CADS and start of 10m amateur radio band
  • EN 300 1134 (Radio equipment intended for the transmission of data (and/or speech) using constant or non-constant envelope modulation and having an antenna connector)
  • EN 300 1354 (Angle modulated CB radio equipment CEPT PR 27 Radio Equipment
  • EN 300 4334 (Double Side Band (DSB) and /or Single Side Band SSB amplitude
modulated CB radio equipment)
26.965 MHz to 27.405 MHz amplitude modulated, angle modulated voice sound broadcasting phase modulation or frequency modulation A3E and G3E or F3E26.96 MHz to 27.41 MHz band with the exception of 26.995 MHz 27.045 MHz 27.095 MHz, 27.145 MHz, 27.195 MHz. 27500 kHz 27.5 MHz to 27.6 MHz 27.6 MHz to 27.995 MHz 27.60125 MHz to 27.99125 MHz 27.59625 MHz 27.99625 MHz 27.605 MHz 27.995 MHz
  • The following maximum effective Radiated Power (ERP) limits will apply to WPAS systems.
  • Base Station equipment using Amplitude Modulation (AM): 1 watt (0dBW)
  • Base Station equipment using Frequency Modulation (FM): 4 watts (6dBW)
  • Antennas must be non directional and antenna gain must not exceed 3dBd
  • Antenna polarisation must be vertical
  • Antenna height must not exceed 10 metres above local ground level
