245 MHz VHF CB
Thailand and Bangladesh only. VHF 245MHz VHF 245 MHz CB license free two-way radio service. Handheld walkie talkie radios and mobile vehicle car radios are very popular and sold by all major land mobile radio manufacturers and vendors, professional two-way radio brands including Icom, Motorola, Baofeng, TYT, Hytera, Tait, AnyTone, Kenwood, Alinco, Yaesu and Vertex Standard as well as numerous re-brands. Both 80 and 160 channel versions must have red cases.
In 2020 the regulations were updated and the band was expanded from 80 channels to 160 channels - band limit expanded 1 MHz from 245.9875 MHz to 246.9875 MHz. 80 channel equipment remains legal but 160 channel equipment is being aggressively marketed and sold by Alinco, Spender and other major radio communications equipment companies. Radios must continue to have a red case. Many radios are sold for the 222-225 MHz amateur band but are easily modified to cover 220-260 MHz or 220-270 MHz.
Also known as "245 VHF" "245 CB" "CB 245" or other similar names. 245 MHz VHF band, FM voice. Favorable propagation characteristics, comparable to the 1.25 meter ham radio band at 220 MHz / 222 MHz - 225 MHz. Radios must have red cases per Thai law.
Technical Specifications
160 channels, straight channel numbering sequence. 245-246.9875 MHz, 245.0000 MHz to 246.9875 MHz. CTCSS, DCS and other selective calling or squelch systems are legal and heavily used. Narrow band FM mode. 11K3F3E / 11K2F3E / 11K0F3E emission and other slightly more narrow bandwidth FM emissions such as 9K10F3E, 8K50F3E, 6K00F3E etc.
12.5 kHz channel steps. 10 watt RF output power limit. No limit on antenna gain. Mobile antennas and base station fixed station antennas are widely used.
High gain mobile antennas are very popular, similar to the 477 MHz UHF CB services in Australia, New Zealand, etc.
Heavily used by taxi companies, ride share drivers, delivery services, hobbyists, security companies, bars, restaurants, general business users, trucking companies, etc. Mobile radios and handheld radios are very popular. Estimates of users above one million, especially in larger urban areas. According to reports, 27 MHz HF CB and 78 MHz VHF CB are niche services and 245 MHz VHF CB is by far the most commonly used personal radio service in Thailand and neighboring areas.
Thailand apparently has 26-27 MHz CB - popular with fishing fleets, freebanders, ham operators and DXers, a mid-band VHF 78 MHz band service from 78.0000 MHz to 78.9875 MHz (12.5 kHz steps, 10 watt power limit and radios must be yellow) as well.
The 245 MHz - 247 MHz band is also allowed in Bangladesh, with the same band plan, power limits and other technical specifications.
245 MHz VHF CB Channel Frequencies 80 Channel and 160 Channel
| Channel | Frequency |
| Channel 1 | 245.0000 MHz |
| Channel 2 | 245.0125 MHz |
| Channel 3 | 245.0250 MHz |
| Channel 4 | 245.0375 MHz |
| Channel 5 | 245.0500 MHz |
| Channel 6 | 245.0625 MHz |
| Channel 7 | 245.0750 MHz |
| Channel 8 | 245.0875 MHz |
| Channel 9 | 245.1000 MHz |
| Channel 10 | 245.1125 MHz |
| Channel 11 | 245.1250 MHz |
| Channel 12 | 245.1375 MHz |
| Channel 13 | 245.1500 MHz |
| Channel 14 | 245.1625 MHz |
| Channel 15 | 245.1750 MHz |
| Channel 16 | 245.1875 MHz |
| Channel 17 | 245.2000 MHz |
| Channel 18 | 245.2125 MHz |
| Channel 19 | 245.2250 MHz |
| Channel 20 | 245.2375 MHz |
| Channel 21 | 245.2500 MHz |
| Channel 22 | 245.2625 MHz |
| Channel 23 | 245.2750 MHz |
| Channel 24 | 245.2875 MHz |
| Channel 25 | 245.3000 MHz |
| Channel 26 | 245.3125 MHz |
| Channel 27 | 245.3250 MHz |
| Channel 28 | 245.3375 MHz |
| Channel 29 | 245.3500 MHz |
| Channel 30 | 245.3625 MHz |
| Channel 31 | 245.3750 MHz |
| Channel 32 | 245.3875 MHz |
| Channel 33 | 245.4000 MHz |
| Channel 34 | 245.4125 MHz |
| Channel 35 | 245.4250 MHz |
| Channel 36 | 245.4375 MHz |
| Channel 37 | 245.4500 MHz |
| Channel 38 | 245.4625 MHz |
| Channel 39 | 245.4750 MHz |
| Channel 40 | 245.4875 MHz |
| Channel 41 | 245.5000 MHz |
| Channel 42 | 245.5125 MHz |
| Channel 43 | 245.5250 MHz |
| Channel 44 | 245.5375 MHz |
| Channel 45 | 245.5500 MHz |
| Channel 46 | 245.5625 MHz |
| Channel 47 | 245.5750 MHz |
| Channel 48 | 245.5875 MHz |
| Channel 49 | 245.6000 MHz |
| Channel 50 | 245.6125 MHz |
| Channel 51 | 245.6250 MHz |
| Channel 52 | 245.6375 MHz |
| Channel 53 | 245.6500 MHz |
| Channel 54 | 245.6625 MHz |
| Channel 55 | 245.6750 MHz |
| Channel 56 | 245.6875 MHz |
| Channel 57 | 245.7000 MHz |
| Channel 58 | 245.7125 MHz |
| Channel 59 | 245.7250 MHz |
| Channel 60 | 245.7375 MHz |
| Channel 61 | 245.7500 MHz |
| Channel 62 | 245.7625 MHz |
| Channel 63 | 245.7750 MHz |
| Channel 64 | 245.7875 MHz |
| Channel 65 | 245.8000 MHz |
| Channel 66 | 245.8125 MHz |
| Channel 67 | 245.8250 MHz |
| Channel 68 | 245.8375 MHz |
| Channel 69 | 245.8500 MHz |
| Channel 70 | 245.8625 MHz |
| Channel 71 | 245.8750 MHz |
| Channel 72 | 245.8875 MHz |
| Channel 73 | 245.9000 MHz |
| Channel 74 | 245.9125 MHz |
| Channel 75 | 245.9250 MHz |
| Channel 76 | 245.9375 MHz |
| Channel 77 | 245.9500 MHz |
| Channel 78 | 245.9625 MHz |
| Channel 79 | 245.9750 MHz |
| Channel 80 | 245.9875 MHz |
| Channel 81 | 246.0000 MHz |
| Channel 82 | 246.0125 MHz |
| Channel 83 | 246.0250 MHz |
| Channel 84 | 246.0375 MHz |
| Channel 85 | 246.0500 MHz |
| Channel 86 | 246.0625 MHz |
| Channel 87 | 246.0750 MHz |
| Channel 88 | 246.0875 MHz |
| Channel 89 | 246.1000 MHz |
| Channel 90 | 246.1125 MHz |
| Channel 91 | 246.1250 MHz |
| Channel 92 | 246.1375 MHz |
| Channel 93 | 245.1500 MHz |
| Channel 94 | 246.1625 MHz |
| Channel 95 | 246.1750 MHz |
| Channel 96 | 246.1875 MHz |
| Channel 97 | 246.2000 MHz |
| Channel 98 | 246.2125 MHz |
| Channel 99 | 246.2250 MHz |
| Channel 100 | 246.2375 MHz |
| Channel 101 | 246.2500 MHz |
| Channel 102 | 246.2625 MHz |
| Channel 103 | 246.2750 MHz |
| Channel 104 | 246.2875 MHz |
| Channel 105 | 246.3000 MHz |
| Channel 106 | 246.3125 MHz |
| Channel 107 | 246.3250 MHz |
| Channel 108 | 246.3375 MHz |
| Channel 109 | 246.3500 MHz |
| Channel 110 | 246.3625 MHz |
| Channel 112 | 246.3750 MHz |
| Channel 112 | 246.3875 MHz |
| Channel 113 | 246.4000 MHz |
| Channel 114 | 246.4125 MHz |
| Channel 115 | 246.4250 MHz |
| Channel 116 | 246.4375 MHz |
| Channel 117 | 246.4500 MHz |
| Channel 118 | 246.4625 MHz |
| Channel 119 | 246.4750 MHz |
| Channel 120 | 246.4875 MHz |
| Channel 121 | 246.5000 MHz |
| Channel 122 | 246.5125 MHz |
| Channel 123 | 246.5250 MHz |
| Channel 124 | 246.5375 MHz |
| Channel 125 | 246.5500 MHz |
| Channel 126 | 246.5625 MHz |
| Channel 127 | 246.5750 MHz |
| Channel 128 | 246.5875 MHz |
| Channel 129 | 246.6000 MHz |
| Channel 130 | 246.6125 MHz |
| Channel 131 | 246.6250 MHz |
| Channel 132 | 246.6375 MHz |
| Channel 133 | 246.6500 MHz |
| Channel 134 | 246.6625 MHz |
| Channel 135 | 246.6750 MHz |
| Channel 136 | 246.6875 MHz |
| Channel 137 | 246.7000 MHz |
| Channel 138 | 246.7125 MHz |
| Channel 139 | 246.7250 MHz |
| Channel 140 | 246.7375 MHz |
| Channel 141 | 246.7500 MHz |
| Channel 142 | 246.7625 MHz |
| Channel 143 | 246.7750 MHz |
| Channel 144 | 246.7875 MHz |
| Channel 145 | 246.8000 MHz |
| Channel 146 | 246.8125 MHz |
| Channel 147 | 246.8250 MHz |
| Channel 148 | 246.8375 MHz |
| Channel 149 | 246.8500 MHz |
| Channel 150 | 246.8625 MHz |
| Channel 151 | 246.8750 MHz |
| Channel 152 | 246.8875 MHz |
| Channel 153 | 246.9000 MHz |
| Channel 154 | 246.9125 MHz |
| Channel 155 | 246.9250 MHz |
| Channel 156 | 246.9375 MHz |
| Channel 157 | 246.9500 MHz |
| Channel 158 | 246.9625 MHz |
| Channel 159 | 246.9750 MHz |
| Channel 160 | 246.9875 MHz |
