DDE
Revision as of 13:26, 13 June 2023 by R4002 (Talk | contribs)
12.5 kHz spacing, NFM 11K0F3E 11K0F1D 11K0F2D emissions. Voice and data. CTCSS (PL) tone squelch and in-band audio-frequency multi-tone selective calling in extensive use.
ePMR LMR PMR PLMR land mobile radio system. The VHF low band spectrum is used by numerous other services in France and elsewhere in Europe and other areas.
35 MHz / 36 MHz repeater output (mobile RX) 39 MHz / 40 MHz repeater input (mobile TX)
