DDE
Revision as of 13:44, 13 June 2023 by R4002 (Talk | contribs)
  • 35.0750 MHz / 39.4750 MHz - Channel 13
  • 35.0875 MHz / 39.4875 MHz - Channel 14
  • 35.1000 MHz / 39.5000 MHz - Channel 15
  • 35.1125 MHz
  • 35.1250 MHz
  • 35.1375 MHz
  • 35.1500 MHz
  • 35.1625 MHz
  • 35.1750 MHz
  • 35.1875 MHz
  • 35.2000 MHz
  • 35.2125 MHz
  • 35.2250 MHz
  • 35.2375 MHz
  • 35.2500 MHz
  • 35.2625 MHz
