Cordless telephone
Revision as of 13:19, 14 February 2024 by R4002 (Talk | contribs)
Cordless phone. See also: DECT.
Frequencies
Early systems used these frequencies (most of which are now allocated as part of the AM mediumwave broadcast band, the long range marine mobile / maritime mobile radio service and the fixed/mobile services) for the base units: 1.665, 1.690, 1.695, 1.710, 1.725, 1.730, 1.750, 1.755, 1.770 MHz.
1665 kHz, 1690 kHz, 1710 kHz, 1725 kHz, 1730 kHz, 1750 kHz, 1755 kHz, 1770 kHz
Both base and handset (portable unit) used frequency modulation (FM).
The so-called "49 MHz" cordless phones were rapidly adopted by consumers, resulting in heavy frequency congestion. The 49.830-49.890 MHz frequencies were and still are heavily used by other devices including baby monitors in continuous transmit mode. 15 frequencies were added bringing the total number of channels to 25. 43.71 MHz to 44.49 MHz (43.72 MHz to 44.48 MHz), 46.60 MHz to 46.98 MHz (46.61 MHz to 46.97 MHz), 48.75 MHz to 49.51 MHz (48.76 MHz to 49.50 MHz and 49.66 MHz to 50.0 MHz (49.67 MHz to 49.9 MHz). Note that the frequencies overlap with the VHF low band business radio band, the military bands, the 49 MHz RC 49 MHz remote control device frequencies and 49 MHz short range devices (walkie-talkies, baby monitors, etc.) The original 10 channel cordless phones used the 46.6 MHz - 47.0 MHz and 49.6 MHz to 50.0 MHz ranges only (46.610 MHz - 46.970 MHz and 46.670 MHz - 49.990 MHz).
900 MHz Cordless Phones
The FCC quickly moved to authorize additional frequency space for cordless phones. With the 900 MHz ISM band 902-928 MHz becoming available next. 900 MHz cordless phones are still used today. Multiple duplex pair analog narrow FM, digital voice and various frequency hopping spread-spectrum or FHSS cordless phones became available for the 900MHz band. If FHSS technology is used, base stations may transmit up to 1 watt ERP. This increase in transmitter power combined with the interference rejection capabilities of spread spectrum gave the higher-end 900 MHz cordless phones significant range. Unlike the older-generation models, 900 MHz cordless telephones never had a standardized channel plan or base and handset frequency pair or channel plan. This meant that manufacturers simply created their own, with widely differing channel steps, number of channels and other options. Even cheap analog FM 900 MHz cordless phones usually featured automatic channel selection. In other words, if the first channel pair was busy the system simply switched to the next clear channel. This same technology was (and is) included in digital voice cordless telephones operating in the 900 MHz band, the 2.4 GHz band and the 5.8 GHz band as well as those using modern DECT technology.
Analog 900 MHz cordless phones usually feature the same automatic channel (base frequency and handset frequency pair) selection that the previous VHF low band 25-channel analog cordless phones offered. Available channels varied from 10 analog pairs to 25-30 or 50 or more.
Base and handset frequency split varied from 10 MHz to 20 MHz to 25 MHz. Frequency spacing for regular analog FM cordless phone systems varies/varied from 10 kHz, 12.5 kHz, 15 kHz to 25 kHz, 30 kHz or 50 kHz.
  • Base Frequency 902.125 MHz - Handset Frequency 926.125 MHz - Channel 1
  • Base Frequency 902.175 MHz - Handset Frequency 926.175 MHz - Channel 2
2.4 GHz Cordless Phones and 5.8 GHz Cordless Phones
The 2.4 GHz band (2400 MHz - 2483.5 MHz) became available shortly after 900 MHz and originally provided excellent results. However, the proliferation of devices operating in the 2.4 GHz band now means that 2.4GHz cordless phones often suffer from (or cause) interference and/or have reduced range compared to the other bands. The 5.8 GHz allocation (5725 MHz - 5875 MHz or 5.725 GHz - 5.875 GHz) was opened up to alleviate the congestion on 2.4 GHz. Many 5.8 GHz band cordless phones are sold today. Some "5.8 GHz" phones are actually cross-band and use 5.8 GHz for handset to base but use 900 MHz or 2.4 GHz for base-to-handset.
DECT 6.0 - DECT Cordless Phones
CT0 - UK Specification CT0 - Current Allocation - 10mW power output, FM mode. 31 MHz cordless phone UK. 31.025 MHz - 31.225 MHz and 39.925 MHz - 40.125 MHz. 8.9 MHz duplex offset (handset transmit frequency +8.9 MHz above base transmit frequency). 25 kHz channel spacing, 12.5 kHz offset frequencies.
DECT 1.8 GHz/1.9 GHz 1880-1900 MHz - <250mW handset and base stations 1880-1900 MHz on the standard GMSK modulation type using TDMA. CEPT DECT standard.
Spain
Variants of this channel plan are or were used in many other European countries.
The EU is currently in the process of reorganizing the 31.025 MHz - 31.325 MHz band.
Authorization to use cordless phones in the 31 MHz and 39 MHz/40 MHz band will expire and be withdrawn effective December 31st, 2023.
France CT0
  • Bade: 26.4625 MHz - Handset: 41.4625 MHz - Channel 13
Republic of Vanuatu CT1 CT2 DECT
DECT is approved for the frequency band 1880 MHz - 1900 MHz or 1.88 GHz - 1.9 GHz. The Personal Handy Phone System (PHS) is approved for operating in the overlapping frequency band 1895 MHz - 1920 MHz or 1.895 GHz - 1.920 GHz.
  • CT1 Cordless Telephones
Multiple frequency bands.
1.7 MHz band and 30 MHz pairs / 39 MHz 40 MHz power limit is 160mw EIRP.
30.075 MHz - 30.775 MHz 39.775 MHz - 40.475 MHz
30 MHz band 72 MHz bands frequency pairs (channels) are limited to 1 watt power 0dBW (base station) and 0.5 watt or 500mw power -3dBW (handset).
30 MHz base / 39-40 MHz handset channel plan:
  • Base: 30.075 MHz - Handset: 39.775 MHz - Channel 1
  • Base: 30.100 MHz - Handset: 39.800 MHz - Channel 2
  • Base: 30.125 MHz - Handset: 39.825 MHz - Channel 3
  • Base: 30.150 MHz - Handset: 39.850 MHz - Channel 4
  • Base: 30.175 MHz - Handset: 39.875 MHz - Channel 5
  • Base: 30.200 MHz - Handset: 39.900 MHz - Channel 6
  • Base: 30.225 MHz - Handset: 39.925 MHz - Channel 7
  • Base: 30.250 MHz - Handset: 39.950 MHz - Channel 8
  • Base: 30.275 MHz - Handset: 39.975 MHz - Channel 9
  • Base: 30.300 MHz - Handset: 40.000 MHz - Channel 10
  • Base: 30.325 MHz - Handset: 40.025 MHz - Channel 11
  • Base: 30.350 MHz - Handset: 40.050 MHz - Channel 12
  • Base: 30.375 MHz - Handset: 40.075 MHz - Channel 13
  • Base: 30.400 MHz - Handset: 40.100 MHz - Channel 14
  • Base: 30.425 MHz - Handset: 40.125 MHz - Channel 15
  • Base: 30.450 MHz - Handset: 40.150 MHz - Channel 16
  • Base: 30.475 MHz - Handset: 40.175 MHz - Channel 17
  • Base: 30.500 MHz - Handset: 40.200 MHz - Channel 18
  • Base: 30.525 MHz - Handset: 40.225 MHz - Channel 19
  • Base: 30.550 MHz - Handset: 40.250 MHz - Channel 20
  • Base: 30.575 MHz - Handset: 40.275 MHz - Channel 21
  • Base: 30.600 MHz - Handset: 40.300 MHz - Channel 22
  • Base: 30.625 MHz - Handset: 40.325 MHz - Channel 23
  • Base: 30.650 MHz - Handset: 40.350 MHz - Channel 24
  • Base: 30.675 MHz - Handset: 40.375 MHz - Channel 25
  • Base: 30.700 MHz - Handset: 40.400 MHz - Channel 26
  • Base: 30.725 MHz - Handset: 40.425 MHz - Channel 27
  • Base: 30.750 MHz - Handset: 40.450 MHz - Channel 28
  • Base: 30.775 MHz - Handset: 40.475 MHz - Channel 29
  • Base: 1.725 MHz 1725 kHz - Handset: 40.025 MHz - Channel 1
  • Base: 1.740 MHz 1740 kHz - Handset: 40.075 MHz - Channel 2
  • Base: 1.755 MHz 1755 kHz - Handset: 40.125 MHz - Channel 3
  • Base: 1.770 MHz 1770 kHz - Handset: 40.175 MHz - Channel 4
  • Base: 1.785 MHz 1785 kHz - Handset: 40.225 MHz - Channel 5
  • Base: 30.600 MHz - Handset: 72.800 MHz - Channel 22 Long Range Cordless Phone
  • Base: 30.625 MHz - Handset: 72.825 MHz - Channel 23 Long Range Cordless Phone
  • Base: 30.650 MHz - Handset: 72.850 MHz - Channel 24 Long Range Cordless Phone
  • Base: 30.675 MHz - Handset: 72.875 MHz - Channel 25 Long Range Cordless Phone
  • Base: 30.700 MHz - Handset: 72.900 MHz - Channel 26 Long Range Cordless Phone
  • Base: 30.725 MHz - Handset: 72.925 MHz - Channel 27 Long Range Cordless Phone
  • Base: 30.750 MHz - Handset: 72.950 MHz - Channel 28 Long Range Cordless Phone
  • Base: 30.775 MHz - Handset: 72.975 MHz - Channel 29 Long Range Cordless Phone
CT2 - similar to the 900 MHz band and the SRD860 band 864 MHz - 869 MHz band.
  • 864.150 MHz
  • 864.250 MHz
  • 864.350 MHz
  • 864.450 MHz
  • 864.550 MHz
  • 864.650 MHz
  • 864.750 MHz
  • 864.850 MHz
  • 864.950 MHz
  • 865.050 MHz
  • 865.150 MHz
  • 865.250 MHz
  • 865.350 MHz
  • 865.450 MHz
  • 865.550 MHz
  • 865.650 MHz
  • 865.750 MHz
  • 865.850 MHz
  • 865.950 MHz
  • 866.050 MHz
  • 866.150 MHz
  • 866.250 MHz
  • 866.350 MHz
  • 866.450 MHz
  • 866.550 MHz
  • 866.650 MHz
  • 866.750 MHz
  • 866.850 MHz
  • 866.950 MHz
  • 867.050 MHz
  • 867.150 MHz
  • 867.250 MHz
  • 867.350 MHz
  • 867.450 MHz
  • 867.550 MHz
  • 867.650 MHz
  • 867.750 MHz
  • 867.850 MHz
  • 867.950 MHz
  • 868.050 MHz
