High Frequency Beacon
Revision as of 13:14, 7 July 2009 by ChrisSmolinski (Talk | contribs)
3450 OK OK
4011.8 FL Dasher
4062 C Very drifty, but slow drift, logged form 4052 to 4063. Its morse is not timed correcctly, it is probably sending a C with a short first dah (longer than dit, shorter than dah), but it could be an ER with a long dit, or a TR with a short dah. 24/7 Location: SW, probably CA
4078.14 WW 300-400 mW Inverted L night time only Location: Colorado
4094.8 Dasher Sputnick - 60 dash/min, night only Location: West Virginia
4096 6 dots 1 Dash
4102.3 W... The WIND BEACON - sends 'W' ident and series of dits - each dit correlating to a turn of its anenometer, so if it is windy in the s.e. California desert, it sends lots of dits; and no wind, no dits.
4194 MX Xtal controlled milliwatt beacon operated occasionally in europe. Sometimes sends straight carrier instead of ID.
4608 MXC Xtal controlled milliwatt beacon operated occasionally in europe. Sometimes sends straight carrier instead of ID. Sister beacon to MX.
5484 SD San Diego, CA
5499.13 WA Dasher
7998 UFO CW Tone Modulated
8003 Dasher Solar/battery dipole 24/7 Location: Colorado "Pike JR" 84 dashes/min
8211.7 OR
8261 F 250mW into a 1/2 wave inverted vee, 1400-0500, location: Western Canada
10236.7 FL Dasher
External Links
