Signal Identification
Why is this Guide here?
With the advent and proliferation of SDRs to the hobby of shortwave listening, and the often associated wideband waterfall / spectrum displays, hobbyist are now more likely to notice short duration, transient, signals. Signals are now visually presented that in the past would not have been noticed at all unless the listener just happened to be tuned to the right random frequency when the short duration signal occurred. This has had the affect of raising the probability of reception of any given signal type, regardless of duration. Further, these waterfalls and spectrum images can be used to ID specific modes of operation, as different techniques often have very different visual signatures.
Today's online receiver nodes (from services like Globaltuner.com, SDR-Radio.com, and websdr.org) mean that more people than ever potentially have access to monitor the HF spectrum. Often people with no prior exposure to HF radio or shortwave listening first gravitate to these kinds of services, as they take no investment in equipment to start using.
Go to the HFUnderground HF Mystery Signal board and follow the guidelines presented there for posting. Assuming the signal is IDed there, and it is not already on the list here, it will likely be added to this list.
If you look at each segment of the guide you will see it is divided into two types of signals, "Non DATA Signals" and "DATA Signals". Each section is further broken down into sub categories.
All entries on this page contain the same basic data, if applicable.
"Spectrum Image" is a 200 pixel wide expandable thumbnail image of the signal, typically either the spectrum or a waterfall / histogram of some kind. Typically the full size version of this images is at least 640 x 480.
Non DATA Signals
Communications Modes
Mode | Frequency Range (kHz) | Bandwidth (kHz) | Shift (Hz) | Number of Tones | Key Features | Sources | Recording | Spectrum Image |
AM | All Frequencies in the HF Range | Typically 2.6 to 10.0 kHz, can be wider or narrower | Not Applicable | Not Applicable | Carrier present in center of signal, audio typically mirrored left and right of the carrier | World wide | AM recording link here | ![]() |
CW
(Morse Code) | All Frequencies in the HF Range | Very narrow, potentially less than 50 Hz | Not Applicable | Not Applicable | Line or broken line on the waterfall, no sidebands, may show wider "key clicks" at the start and stop of each dot and dash | World wide | CW recording link here | ![]() |
LSB | All Frequencies in the HF Range | Typically 2.4 to 3.0 kHz, can be wider or narrower | Not Applicable | Not Applicable | No carrier present in Spectrum, audio typically bunched to towards the right (low audio frequency) | World wide | LSB recording link here | ![]() |
USB | All Frequencies in the HF Range | Typically 2.4 to 3.0 kHz, can be wider or narrower | Not Applicable | Not Applicable | No carrier present in Spectrum, audio typically bunched to towards the left (low audio frequency) | World wide | USB recording link here | ![]() |
Non Communications Modes
16 x 64 Sounder (nickname, official name or designation not known) | Below 4000 to above 30000 observed | 2.5 kHz | Not Applicable | Not Applicable | FMCW transmission, changes sweep rates in 16 steps, resulting in 16 different sounds per transmission, a pilot tone may precede each rate change but is not always present | Unknown | Media:16x64_sounder.mp3
16 x 64 sounder recording | ![]() |
PLUTO radar (possible offical name, PLUTO II, suggested by open source documents) | 8000 to 38000 | 3 to 40 kHz, depending on specific operating conditions | Not Applicable | Not Applicable | FMCW transmission, presenting a wide signal equal to the swept (chirped) width, sweep rate creates a pulsed sound affect | British Sovereing base of Akrotiri, Island of Cyprus | PLUTO recording link here | ![]() |
Need to put some kind of break here, a line or something, to sep out the Non DATA from DATA
Probably need to put a desription of what is meant by DATA Signals in this area.
DATA Signals
FSK Modes
MFSK Modes
PSK Modes
SELCAL Modes
Image Modes
