Amphetamine Radio
Revision as of 03:50, 16 March 2017 by R4002 (Talk | contribs)
Amphetamine Radio is a pirate radio station that first appeared in the summer of 2015. It is normally heard on 6925 USB but has been heard on "offset" frequencies 6923 and 6924.7 in addition to 6930, 6950 and 6955 kHz. Amphetamine Radio has also experimented with lower frequencies, including 3375 kHz, 4050 kHz and several others. The primary 90 meter frequency for Amphetamine Radio is 3375 kHz. USB is normally used, however Amphetamine Radio has transmitted broadcasts in AM mode, referring to it as "Amphetamine Modulation".
Amphetamine Radio often transmits SSTV images throughout their broadcasts and appears to be one of the most prolific transmitters of SSTV. Some of their broadcasts consist entirely of SSTV images. SSTV is usually transmitted in Scottie 1 mode. In addition to voice IDs, MCW (modulated CW) IDs are usually transmitted, often either before or after SSTV frames are sent. Amphetamine Radio's SSTV content often consists of "pin-up" style erotica, drug-related content and politically-leaning images. Amphetamine Radio has also transmitted "SSTV requests" made by listeners. Amphetamine Radio often adds the tagline "Pin-Up Pirate Radio" or "High Speed Pirate Radio" to their identification and has claimed to be "the most tweaked out station on the 43 meter band".
Amphetamine Radio usually signs off with with the Star Spangled Banner followed by a 1000Hz tone burst.
According to Amphetamine Radio QSL cards and communications the operator has made with various listeners, the current AR transmitter is an Icom IC-707 with a random wire antenna with counterpoise in sloper configuration.
Amphetamine Radio SSTV 6925 kHz - 25 September 2015
Amphetamine Radio SSTV 3375 kHz - 16 March 2017
