HF pagers
| Frequency | Remarks |
| 26.200 MHz | UK Paging on-site pager |
| 26.500 MHz | Paging, heard in Europe, noted use in Holland |
| 26.590 MHz | UK Paging on-site, non-hospital use |
| 26.815 MHz | UK Paging on-site pager |
| 26.975 MHz | UK data frequency, UK low-power R/C telemetry (100 mw limit) |
| 27.075 MHz | UK data frequency, UK low-power R/C telemetry (100 mw limit) |
| 27.120 MHz | ISM center frequency 27120 kHz +/- 163 kHz, often used for Part 15 devices (26.957 to 27.283 MHz) |
| 27.137 MHz | New Zealand channel RP7A on-site paging POCSAG |
| 27.162 MHz | New Zealand channel RP8A on-site paging POCSAG |
| 27.187 MHz | New Zealand channel RP9A on-site paging POCSAG |
| 27.212 MHz | New Zealand channel RP10A on-site paging POCSAG |
| 27.225 MHz | UK data frequency, UK low-power R/C telemetry (100 mw limit) |
| 27.237 MHz | New Zealand channel RP11A on-site paging POCSAG |
| 27.245 MHz | UK data frequency, UK low-power R/C telemetry (100 mw limit) |
| 27.255 MHz | Linear Controls "Xtended Range Wireless" telemetry/control system, 10 watts FSK mode |
| 27.262 MHz | New Zealand channel RP12A on-site paging POCSAG |
| 27.275 MHz | UK data frequency, UK low-power R/C telemetry (100 mw limit) |
| 27.412 MHz | Republic of Korea / South Korea on-site paging frequency allocation (offset frequency) |
| 27.422 MHz | Republic of Korea / South Korea on-site paging frequency allocation (offset frequency) |
| 27.510 MHz | Paging, German allocation pager 27 MHz |
| 27.650 MHz | Data link (US East Coast based), possibly US military |
