HF marine
Fisheries, fishing boats, and other commercial marine users will often use frequencies in the aeronautical or aircraft bands (including the 6525 kHz to 6685 kHz R and 6685 kHz to 6765 kHz OR or military aircraft 6 MHz subbands 6525 kHz to 6765 kHz), other HF aircraft bands, fixed/mobile bands (including 43 meters - 6765-7000 kHz) clear frequencies in the shortwave broadcast bands or even amateur frequencies for "out of band" communications to reduce the chance of radio interception by their competition. Out of band frequencies are also used in other ITU regions for marine fax transmissions.
See also: VHF marine band
Band | Frequency Range |
405-525 kHz | MF band, used in some areas for NAVTEX on 490 kHz and/or 518 kHz. 500 kHz (600 meters) was the original CW Morse code calling frequency |
1600-2000 kHz | MF band, used in Europe and elsewhere (also used heavily for fishnet beacons) - overlaps with 1800-2000 kHz 160 meter amateur band |
2000-2300 kHz | MF 2 MHz marine band - USB voice calling/distress 2182 kHz, DSC calling/distress 2187.5 kHz - USCG no longer monitors 2182 kHz USB |
2450-2850 kHz | MF 2 MHz marine band |
4000-4063 kHz | 4 MHz fixed/mobile band, shared with marine for simplex purposes |
4063-4438 kHz | HF 4 MHz marine band - USB voice calling/distress 4125 kHz, DSC calling/distress 4207.5 kHz |
6200-6525 kHz | HF 6 MHz marine band - USB voice calling/distress 6215 kHz, DSC calling/distress 6312 kHz |
8000-8195 kHz | 8 MHz fixed/mobile band, shared with marine for simplex purposes |
8195-8815 kHz | HF 8 MHz marine band - USB voice calling/distress 8291 kHz, DSC calling/distress 8414.5 kHz |
12330-13200 kHz | HF 12 MHz marine band - USB voice calling/distress 12290 kHz, DSC calling/distress 12577 kHz |
16460-17360 kHz | HF 16 MHz/17 MHz marine band - USB voice calling/distress 16420 kHz, DSC calling/distress 16804.5 kHz |
22000-22855 kHz | HF 22 MHz marine band |
25070-25121 kHz | HF 25 MHz marine band |
26145-26175 kHz | HF 26 MHz marine band |
26175-28000 kHz | Various CB-like marine allocations found in this region (maybe HF-marine radios stop at 27500 kHz or 27.5 MHz) |
