Part 15 Beacons
Contents[hide] |
Overview
- 160 - 190 kHz
- 13553 - 13567 kHz (often referred to as 13560 kHz, 13.56 MHz or 22 meters, shared with ISM)
- 26960 - 27280 kHz (11 meters, shared with CB, RC, data links/telemetry and ISM from 26957 - 27283 kHz)
160-190 kHz Part 15 Beacons
- 167.180 LC Sacramento CA
- 181.818 JH Florence SC
- 182.448 R Keeler CA
- 183.500 WD2XFJ Burbank CA
- 185.100 22A Baraga MI
- 185.185 SIW Oswego IL
- 185.290 KT Oswego KS
- 185.297 TAG Raymond ME
- 185.299 SIW Oswego IL
- 185.303 SJ East Haven CT
- 185.650 WE2XEB Penn Yan NY
- 186.204 MLS Massilon OH
- 187.015 J La Crescenta CA
- 187.507 WI Aiken SC
- 188.830 EAR Saltford, ON
13560 kHz Part 15 Beacons
- 13554.000 AZ Oro Valley AZ
- 13555.414 TAG Holden MA
- 13555.420 JIM Dallas TX
- 13555.430 SIW Elgin IL
- 13555.440 SIW Elgin IL
- 13555.450 MP London ON
- 13555.462 EH East Haven CT
- 13555.472 7P Ajo AZ
- 13555.500 NC Stanfield NC
- 13555.528 EDJ Monroe GA
- 13555.920 WV Richwood, WV
- 13555.98 TSN
- 13556.200 HHH CT/MA Border (testing, may not be 24/7)
- 13556.600 OH Findlay OH
- 13557.50 PBJ Tracey City TN
- 13557.800 PLM [UNKNOWN]
- 13558.2 PVC
- 13558.510 AJO Ajo AZ
- 13561.100 17331PA Hanover, PA
- 13562.080 NDB
- 13562.950 SZX Macomb IL
- 13563.000 RR
- 13563.55 PCO Colorado
- 13564.280 T Sun City CA
- 13562.80 GNK Madison WI
- 13564.20 RF Grid EM96 NC
- 13565.04 K6FRC Patterson CA
- 13566.20 AMA Hamilton ON
Pending beacons:
- Freq TBD VVV CT/MA Border (Vertical dipole, solar powered)
- Freq TBD WOO Worcester, MA (Solar powered)
None reported
22 meter band beacon kit
FCC Regulations
160 - 190 kHz
13560 kHz
26960 - 27280 kHz
