- 26.995 MHz - 26995 kHz - Brown or Channel 3A
- 27.045 MHz - 27045 kHz - Red or Channel 7A
- 27.095 MHz - 27095 kHz - Orange or Channel 11A
- 27.145 MHz - 27145 kHz - Yellow or Channel 15A
- 27.195 MHz - 27195 kHz - Green or Channel 19A
- 27.255 MHz - 27255 kHz - Blue (shared with CB channel 23)
- 72.01 MHz
- 72.03 MHz
- 72.05 MHz
- 72.07 MHz
- 72.09 MHz
- 72.11 MHz
- 72.13 MHz
- 72.15 MHz
- 72.17 MHz
- 72.19 MHz
- 72.21 MHz
- 72.23 MHz
- 72.25 MHz
- 72.27 MHz
- 72.29 MHz
- 72.31 MHz
- 72.33 MHz
- 72.35 MHz
- 72.37 MHz
- 72.39 MHz
- 72.41 MHz
- 72.43 MHz
- 72.45 MHz
- 72.47 MHz
- 72.49 MHz
- 72.51 MHz
- 72.53 MHz
- 72.55 MHz
- 72.57 MHz
- 72.59 MHz
- 72.61 MHz
- 72.63 MHz
- 72.65 MHz
- 72.67 MHz
- 72.69 MHz
- 72.71 MHz
- 75.41 MHz
- 75.43 MHz
- 75.45 MHz
- 75.47 MHz
- 75.49 MHz
- 75.51 MHz
- 75.53 MHz
- 75.55 MHz
- 75.57 MHz
- 75.59 MHz
- 75.61 MHz
- 75.63 MHz
- 75.65 MHz
- 75.67 MHz
- 75.69 MHz
- 75.71 MHz
- 75.73 MHz
- 75.75 MHz
- 75.77 MHz
- 75.79 MHz
- 75.81 MHz
- 75.83 MHz
- 75.85 MHz
- 75.87 MHz
- 75.89 MHz
- 75.91 MHz
- 75.93 MHz
- 75.95 MHz
- 75.97 MHz
- 75.99 MHz
- 34.950 MHz - Channel 55
- 34.960 MHz - Channel 56
- 34.970 MHz - Channel 57
- 34.980 MHz - Channel 58
- 34.990 MHz - Channel 59
- 35.000 MHz - Channel 60
- 35.010 MHz - Channel 61
- 35.020 MHz - Channel 62
- 35.030 MHz - Channel 63
- 35.040 MHz - Channel 64
- 35.050 MHz - Channel 65
- 35.060 MHz - Channel 66
- 35.070 MHz - Channel 67
- 35.080 MHz - Channel 68
- 35.090 MHz - Channel 69
- 35.100 MHz - Channel 70
- 35.110 MHz - Channel 71
- 35.120 MHz - Channel 72
- 35.130 MHz - Channel 73
- 35.140 MHz - Channel 74
- 35.150 MHz - Channel 75
- 35.160 MHz - Channel 76
- 35.170 MHz - Channel 77
- 35.180 MHz - Channel 78
- 35.190 MHz - Channel 79
- 35.200 MHz - Channel 80
- 35.210 MHz - Channel 81
- 35.220 MHz - Channel 82
- 35.230 MHz - Channel 83
- 35.240 MHz - Channel 84
- 35.250 MHz - Channel 85
- 35.260 MHz - Channel 86
- 35.270 MHz - Channel 87
- 35.280 MHz - Channel 88
- 35.290 MHz - Channel 89
- 35.300 MHz - Channel 90
- 40.665 MHz - Channel 665
- 40.675 MHz - Channel 675
- 40.685 MHz - Channel 685
- 40.695 MHz - Channel 695
- 40.705 MHz - Channel 705
- 40.715 MHz - Channel 715
- 40.725 MHz - Channel 715
- 40.735 MHz - Channel 735
- 40.745 MHz - Channel 745
- 40.755 MHz - Channel 755
- 40.785 MHz - Channel 785
- 40.795 MHz - Channel 795
- 40.805 MHz - Channel 805
- 40.815 MHz - Channel 815
- 40.825 MHz - Channel 825
- 40.835 MHz - Channel 835
- 40.845 MHz - Channel 845
- 40.855 MHz - Channel 855
- 40.865 MHz - Channel 865
- 40.875 MHz - Channel 875
- 40.885 MHz - Channel 885
- 40.895 MHz - Channel 895
- 40.905 MHz - Channel 905
- 40.915 MHz - Channel 915
- 40.925 MHz - Channel 925
- 40.935 MHz - Channel 935
- 40.945 MHz - Channel 945
- 40.955 MHz - Channel 955
- 40.965 MHz - Channel 965
- 40.975 MHz - Channel 975
- 40.985 MHz - Channel 985
- 40.995 MHz - Channel 995
- 27.095 MHz - 27095 kHz - European CEPT designator A3 - European standardized use for the Eurobalise railroad/train transponder system
- 34.995 M
- 35.000 MHz - RC Channel 500
- 35.010 MHz - RC Channel 501
- 35.020 MHz - RC Channel 502
- 35.030 MHz - RC Channel 503
- 35.040 MHz - RC Channel 504
- 35.050 MHz - RC Channel 505
- 35.060 MHz - RC Channel 506
- 35.070 MHz - RC Channel 507
- 35.080 MHz - RC Channel 508
- 35.090 MHz - RC Channel 509
- 35.100 MHz - RC Channel 510
- 35.110 MHz - RC Channel 511
- 35.120 MHz - RC Channel 512
- 35.130 MHz - RC Channel 513
- 35.140 MHz - RC Channel 514
- 35.150 MHz - RC Channel 515
- 35.160 MHz - RC Channel 516
- 35.170 MHz - RC Channel 517
- 35.180 MHz - RC Channel 518
- 35.190 MHz - RC Channel 519
- 35.200 MHz - RC Channel 520
- 35.210 MHz - RC Channel 521
- 35.220 MHz - RC Channel 522
- 35.230 MHz - RC Channel 523
- 35.240 MHz - RC Channel 524
- 35.250 MHz - RC Channel 525
- 35.260 MHz - RC Channel 526
- 35.270 MHz - RC Channel 527
- 35.280 MHz - RC Channel 528
- 35.290 MHz - RC Channel 529
- 35.300 MHz - RC Channel 530
- 36.250 MHz - RC Channel 625
- 36.260 MHz - RC Channel 626
- 36.270 MHz - RC Channel 627
- 36.280 MHz - RC Channel 628
- 36.290 MHz - RC Channel 629
- 36.300 MHz - RC Channel 630
- 36.310 MHz - RC Channel 631
- 36.320 MHz - RC Channel 632
- 36.330 MHz - RC Channel 633
- 36.340 MHz - RC Channel 634
- 36.350 MHz - RC Channel 635
- 36.360 MHz - RC Channel 636
- 36.370 MHz - RC Channel 637
- 36.380 MHz - RC Channel 638
- 36.390 MHz - RC Channel 639
- 36.400 MHz - RC Channel 640
- 36.410 MHz - RC Channel 641
- 36.420 MHz - RC Channel 642
- 36.430 MHz - RC Channel 643
- 36.440 MHz - RC Channel 644
- 36.450 MHz - RC Channel 645
- 36.460 MHz - RC Channel 646
- 36.470 MHz - RC Channel 647
- 36.480 MHz - RC Channel 648
- 36.490 MHz - RC Channel 649
- 36.500 MHz - RC Channel 650
- 36.510 MHz - RC Channel 651
- 36.520 MHz - RC Channel 652
- 36.530 MHz - RC Channel 653
- 36.540 MHz - RC Channel 654
- 36.550 MHz - RC Channel 655
- 36.560 MHz - RC Channel 656
- 36.570 MHz - RC Channel 657
- 36.580 MHz - RC Channel 658
- 36.590 MHz - RC Channel 659
- 40.510 MHz - RC Channel 451
- 40.530 MHz - RC Channel 453
- 40.550 MHz - RC Channel 455
- 40.570 MHz - RC Channel 457
- 40.590 MHz - RC Channel 459
- 40.610 MHz - RC Channel 461
- 40.630 MHz - RC Channel 463
- 40.650 MHz - RC Channel 465
- 40.670 MHz - RC Channel 467
- 40.690 MHz - RC Channel 469
- 40.710 MHz - RC Channel 471
- 40.730 MHz - RC Channel 473
- 40.750 MHz - RC Channel 475
- 40.790 MHz - RC Channel 479
- 40.810 MHz - RC Channel 481
- 40.830 MHz - RC Channel 483
- 40.850 MHz - RC Channel 485
- 40.870 MHz - RC Channel 487
- 40.890 MHz - RC Channel 489
- 40.910 MHz - RC Channel 491
- 40.930 MHz - RC Channel 493
- 72.010 MHz - RC Channel 701
- 72.030 MHz - RC Channel 703
- 72.050 MHz - RC Channel 705
- 72.070 MHz - RC Channel 707
- 72.090 MHz - RC Channel 709
- 72.110 MHz - RC Channel 711
- 72.130 MHz - RC Channel 713
- 72.150 MHz - RC Channel 715
- 72.170 MHz - RC Channel 717
- 72.190 MHz - RC Channel 719
- 72.210 MHz - RC Channel 721
- 72.230 MHz - RC Channel 723
- 72.250 MHz - RC Channel 725
- 72.270 MHz - RC Channel 727
- 72.290 MHz - RC Channel 729
- 72.310 MHz - RC Channel 731
- 72.330 MHz - RC Channel 733
- 72.350 MHz - RC Channel 735
- 72.370 MHz - RC Channel 737
- 72.390 MHz - RC Channel 739
- 72.410 MHz - RC Channel 741
- 72.430 MHz - RC Channel 743
- 72.450 MHz - RC Channel 745
- 72.470 MHz - RC Channel 747
- 72.490 MHz - RC Channel 749
- 72.510 MHz - RC Channel 751
- 72.530 MHz - RC Channel 753
- 72.550 MHz - RC Channel 755
- 72.570 MHz - RC Channel 757
- 72.590 MHz - RC Channel 759
- 72.610 MHz - RC Channel 761
- 72.630 MHz - RC Channel 763
- 72.650 MHz - RC Channel 765
- 72.670 MHz - RC Channel 767
- 72.690 MHz - RC Channel 769
- 72.710 MHz - RC Channel 771
- 72.730 MHz - RC Channel 773
- 72.750 MHz - RC Channel 775
- 72.770 MHz - RC Channel 777
- 72.790 MHz - RC Channel 779
- 36.010 MHz - RC Channel 601
- 36.020 MHz - RC Channel 602
- 36.030 MHz - RC Channel 603
- 36.040 MHz - RC Channel 604
- 36.050 MHz - RC Channel 605
- 36.060 MHz - RC Channel 606
- 36.070 MHz - RC Channel 607
- 36.080 MHz - RC Channel 608
- 36.090 MHz - RC Channel 609
- 36.100 MHz - RC Channel 610
- 36.110 MHz - RC Channel 611
- 36.120 MHz - RC Channel 612
- 36.130 MHz - RC Channel 613
- 36.140 MHz - RC Channel 614
- 36.150 MHz - RC Channel 615
- 36.160 MHz - RC Channel 616
- 36.170 MHz - RC Channel 617
- 36.180 MHz - RC Channel 618
- 36.190 MHz - RC Channel 619
- 36.200 MHz - RC Channel 620
- 36.210 MHz - RC Channel 621
- 36.220 MHz - RC Channel 622
- 36.230 MHz - RC Channel 623
- 36.240 MHz - RC Channel 624
- 40.665 MHz - RC Channel 50
- 40.675 MHz - RC Channel 51
- 40.685 MHz - RC Channel 52
- 40.695 MHz - RC Channel 53
