HF marine
See also: VHF marine band
| Band | Frequency Range |
| 2450-2850 kHz | MF 2 MHz marine band, USB voice and FSK modes, some AM voice heard here in Russia, Eastern Europe and Asia (older-generation trawler radios 2-3 MHz) |
| 16460-17360 kHz | HF 16 MHz/17 MHz marine band - USB voice calling/distress 16420 kHz, DSC calling/distress 16804.5 kHz |
| 26175-30000 kHz | Various CB-like marine allocations found in this region (many SSB marine radios stop at 27500 kHz or 27.5 MHz) |
- 2003.0 kHz
- 2065.0 kHz
- 2079.0 kHz
- 2082.5 kHz
- 2086.0 kHz
- 2093.0 kHz
- 2096.5 kHz
- 2142.0 kHz
- 2203.0 kHz
- 2214.0 kHz
- 2635.0 kHz
- 2638.0 kHz
- 2738.0 kHz
- 2782.0 kHz
- 2830.0 kHz
- 4146.0 kHz
- 4149.0 kHz
- 4417.0 kHz
- 6224.0 kHz
- 6227.0 kHz
- 6230.0 kHz
- 6516.0 kHz
- 8294.0 kHz
- 8297.0 kHz
- 12353.0 kHz
- 12356.0 kHz
- 12359.0 kHz
- 12362.0 kHz
- 12365.0 kHz
- 16528.0 kHz
- 16531.0 kHz
- 16534.0 kHz
- 16537.0 kHz
- 16540.0 kHz
- 16543.0 kHz
- 16546.0 kHz
- 18825.0 kHz
- 18828.0 kHz
- 18831.0 kHz
- 18834.0 kHz
- 18837.0 kHz
- 18840.0 kHz
- 18843.0 kHz
- 22159.0 kHz
- 22162.0 kHz
- 22165.0 kHz
- 22168.0 kHz
- 22171.0 kHz
- 22174.0 kHz
- 22177.0 kHz
- 25100.0 kHz
- 25103.0 kHz
- 25106.0 kHz
- 25109.0 kHz
- 25112.0 kHz
- 25115.0 kHz
- 25118.0 kHz
| ITU Channel | Ship Transmit / Coast Receive | Coast Transmit / Ship Receive |
| 401 | 4065 kHz | 4357 kHz |
| 402 | 4068 kHz | 4360 kHz |
| 403 | 4065 kHz | 4357 kHz |
| 404 | 4065 kHz | 4357 kHz |
| 405 | 4065 kHz | 4357 kHz |
| 406 | 4065 kHz | 4357 kHz |
| 407 | 4065 kHz | 4357 kHz |
| 408 | 4065 kHz | 4357 kHz |
| 409 | 4065 kHz | 4357 kHz |
| 410 | 4065 kHz | 4357 kHz |
| 411 | 4065 kHz | 4357 kHz |
| 412 | 4065 kHz | 4357 kHz |
| 413 | 4065 kHz | 4357 kHz |
| 414 | 4065 kHz | 4357 kHz |
| 415 | 4065 kHz | 4357 kHz |
| 416 | 4065 kHz | 4357 kHz |
| 417 | 4065 kHz | 4357 kHz |
| 418 | 4065 kHz | 4357 kHz |
| 419 | 4065 kHz | 4357 kHz |
| 420 | 4065 kHz | 4357 kHz |
| 421 | 4065 kHz | 4357 kHz |
| 422 | 4065 kHz | 4357 kHz |
| 423 | 4065 kHz | 4357 kHz |
| 424 | 4065 kHz | 4357 kHz |
| 425 | 4065 kHz | 4357 kHz |
| 426 | 4065 kHz | 4357 kHz |
| 427 | 4065 kHz | 4357 kHz |
| 428 | 4065 kHz | 4357 kHz |
| 429 | 4065 kHz | 4357 kHz |
| 601 | 6200 kHz | 6501 kHz |
| 602 | 6203 kHz | 6504 kHz |
| 603 | 6206 kHz | 6507 kHz |
| 604 | 6209 kHz | 6510 kHz |
| 605 | 6212 kHz | 6513 kHz |
| 606 | 6215 kHz | 6516 kHz |
| 607 | 6218 kHz | 6519 kHz |
| 608 | 6221 kHz | 6522 kHz |
| 801 | 4065 kHz | 4357 kHz |
| 802 | 4068 kHz | 4360 kHz |
| 803 | 4065 kHz | 4357 kHz |
| 804 | 4065 kHz | 4357 kHz |
| 805 | 4065 kHz | 4357 kHz |
| 806 | 4065 kHz | 4357 kHz |
| 807 | 4065 kHz | 4357 kHz |
| 808 | 4065 kHz | 4357 kHz |
| 809 | 4065 kHz | 4357 kHz |
| 810 | 4065 kHz | 4357 kHz |
| 811 | 4065 kHz | 4357 kHz |
| 812 | 4065 kHz | 4357 kHz |
| 813 | 4065 kHz | 4357 kHz |
| 814 | 4065 kHz | 4357 kHz |
| 815 | 4065 kHz | 4357 kHz |
| 816 | 4065 kHz | 4357 kHz |
| 817 | 4065 kHz | 4357 kHz |
| 818 | 4065 kHz | 4357 kHz |
| 819 | 4065 kHz | 4357 kHz |
| 820 | 4065 kHz | 4357 kHz |
| 821 | 4065 kHz | 4357 kHz |
| 822 | 4065 kHz | 4357 kHz |
| 823 | 4065 kHz | 4357 kHz |
| 824 | 4065 kHz | 4357 kHz |
| 825 | 4065 kHz | 4357 kHz |
| 826 | 4065 kHz | 4357 kHz |
| 827 | 4065 kHz | 4357 kHz |
| 828 | 4065 kHz | 4357 kHz |
| 829 | 4065 kHz | 4357 kHz |
| 830 | 4065 kHz | 4357 kHz |
| 831 | 4065 kHz | 4357 kHz |
| 832 | 4065 kHz | 4357 kHz |
| 833 | 4065 kHz | 4357 kHz |
| 1201 | 4065 kHz | 4357 kHz |
| 1202 | 4068 kHz | 4360 kHz |
| 1203 | 4065 kHz | 4357 kHz |
| 1204 | 4065 kHz | 4357 kHz |
| 1205 | 4065 kHz | 4357 kHz |
| 1206 | 4065 kHz | 4357 kHz |
| 1207 | 4065 kHz | 4357 kHz |
| 1208 | 4065 kHz | 4357 kHz |
| 1209 | 4065 kHz | 4357 kHz |
| 1210 | 4065 kHz | 4357 kHz |
| 1211 | 4065 kHz | 4357 kHz |
| 1212 | 4065 kHz | 4357 kHz |
| 1213 | 4065 kHz | 4357 kHz |
| 1214 | 4065 kHz | 4357 kHz |
| 1215 | 4065 kHz | 4357 kHz |
| 1216 | 4065 kHz | 4357 kHz |
| 1217 | 4065 kHz | 4357 kHz |
| 1218 | 4065 kHz | 4357 kHz |
| 1219 | 4065 kHz | 4357 kHz |
| 1220 | 4065 kHz | 4357 kHz |
| 1221 | 4065 kHz | 4357 kHz |
| 1222 | 4065 kHz | 4357 kHz |
| 1223 | 4065 kHz | 4357 kHz |
| 1224 | 4065 kHz | 4357 kHz |
| 1225 | 4065 kHz | 4357 kHz |
| 1226 | 4065 kHz | 4357 kHz |
| 1227 | 4065 kHz | 4357 kHz |
| 1228 | 4065 kHz | 4357 kHz |
| 1229 | 4065 kHz | 4357 kHz |
| 1230 | 4065 kHz | 4357 kHz |
| 1231 | 4065 kHz | 4357 kHz |
| 1232 | 4065 kHz | 4357 kHz |
| 1233 | 4065 kHz | 4357 kHz |
| 1234 | 4065 kHz | 4357 kHz |
| 1235 | 4065 kHz | 4357 kHz |
| 1236 | 4065 kHz | 4357 kHz |
| 1237 | 4065 kHz | 4357 kHz |
| 1238 | 4065 kHz | 4357 kHz |
| 1239 | 4065 kHz | 4357 kHz |
| 1240 | 4065 kHz | 4357 kHz |
| 1241 | 4065 kHz | 4357 kHz |
| 1601 | 4065 kHz | 4357 kHz |
| 1602 | 4068 kHz | 4360 kHz |
| 1603 | 4065 kHz | 4357 kHz |
| 1604 | 4065 kHz | 4357 kHz |
| 1605 | 4065 kHz | 4357 kHz |
| 1606 | 4065 kHz | 4357 kHz |
| 1607 | 4065 kHz | 4357 kHz |
| 1608 | 4065 kHz | 4357 kHz |
| 1609 | 4065 kHz | 4357 kHz |
| 1610 | 4065 kHz | 4357 kHz |
| 1611 | 4065 kHz | 4357 kHz |
| 1612 | 4065 kHz | 4357 kHz |
| 1613 | 4065 kHz | 4357 kHz |
| 1614 | 4065 kHz | 4357 kHz |
| 1615 | 4065 kHz | 4357 kHz |
| 1616 | 4065 kHz | 4357 kHz |
| 1617 | 4065 kHz | 4357 kHz |
| 1618 | 4065 kHz | 4357 kHz |
| 1619 | 4065 kHz | 4357 kHz |
| 1620 | 4065 kHz | 4357 kHz |
| 1621 | 4065 kHz | 4357 kHz |
| 1622 | 4065 kHz | 4357 kHz |
| 1623 | 4065 kHz | 4357 kHz |
| 1624 | 4065 kHz | 4357 kHz |
| 1625 | 4065 kHz | 4357 kHz |
| 1626 | 4065 kHz | 4357 kHz |
| 1627 | 4065 kHz | 4357 kHz |
| 1628 | 4065 kHz | 4357 kHz |
| 1629 | 4065 kHz | 4357 kHz |
| 1630 | 4065 kHz | 4357 kHz |
| 1631 | 4065 kHz | 4357 kHz |
| 1632 | 4065 kHz | 4357 kHz |
| 1633 | 4065 kHz | 4357 kHz |
| 1634 | 4065 kHz | 4357 kHz |
| 1635 | 4065 kHz | 4357 kHz |
| 1636 | 4065 kHz | 4357 kHz |
| 1637 | 4065 kHz | 4357 kHz |
| 1639 | 4065 kHz | 4357 kHz |
| 1640 | 4065 kHz | 4357 kHz |
| 1641 | 4065 kHz | 4357 kHz |
| 1642 | 4065 kHz | 4357 kHz |
| 1643 | 4065 kHz | 4357 kHz |
| 1644 | 4065 kHz | 4357 kHz |
| 1645 | 4065 kHz | 4357 kHz |
| 1646 | 4065 kHz | 4357 kHz |
| 1647 | 4065 kHz | 4357 kHz |
| 1648 | 4065 kHz | 4357 kHz |
| 1649 | 4065 kHz | 4357 kHz |
| 1650 | 4065 kHz | 4357 kHz |
| 1651 | 4065 kHz | 4357 kHz |
| 1652 | 4065 kHz | 4357 kHz |
| 1653 | 4065 kHz | 4357 kHz |
| 1654 | 4065 kHz | 4357 kHz |
| 1655 | 4065 kHz | 4357 kHz |
| 1656 | 4065 kHz | 4357 kHz |
See also:
- VHF marine band
- Maritime Fax Transmissions
