HF pagers
Frequency List
Note: This list is a dynamic list and will never be complete.
| Frequency | Remarks |
| 26.150 MHz | Hospital pagers (Holland) FM mode - confirmed active June 2020 |
| 26.160 MHz | Marine Instruments Radio Buoys |
| 26.165 MHz | Marine Instruments Radio Buoys |
| 26.170 MHz | Marine Instruments Radio Buoys |
| 26.175 MHz | Marine Instruments Radio Buoys |
| 26.250 MHz | Hospital pagers (Holland) FM mode - confirmed active July 2020 |
| 26.300 MHz | Hospital pagers (Holland) FM mode - confirmed active July 2020 |
| 26.350 MHz | Hospital pagers (Holland) FM mode - confirmed active July 2020 |
| 26.400 MHz | Hospital pagers (Holland) FM mode - confirmed active July 2020 |
| 26.450 MHz | Hospital pagers (Holland) FM mode - confirmed active July 2020 |
| 26.500 MHz | Paging, heard in Europe, noted use in Holland - FM mode - confirmed active July 2020 |
| 26.545 MHz | Channel 3A 26.995 MHz "down one band" |
| 26.595 MHz | Channel 7A 27.045 MHz "down one band" |
| 26.645 MHz | Channel 11A 27.095 MHz "down one band" |
| 26.695 MHz | Channel 15A 27.145 MHz "down one band" |
| 26.745 MHz | Channel 19A 27.195 MHz "down one band" |
| 26.805 MHz | Channel 23 27.255 MHz "down one band" |
| 26.950 MHz | Local pager, heard in mainland Europe, transmits "idle" signal even when no pages are being sent - off the air? |
| 26.995 MHz | Remote Control Technology Long Range Wireless Switch System LRWSS model # 01217 4-watt FSK (FM) 27MHz transmitter |
| 27.070 MHz | POGSAG Pager FM - Russian origin - Russia paging frequency |
| 27.255 MHz | Radio Control RC Service Part 95 25 watt power limit, 8.5 kHz bandwidth limit in USA |
| 27.255 MHz | Data link system located in rural Virginia, roughly 20 miles north of Richmond, VA (data bursts on 27.255 MHz) |
| 27.255 MHz | Linear Controls XT-1 "Xtended Range Wireless" telemetry/control system, 10 watts FSK mode |
| 27.445 MHz | Channel 3A 26.995 MHz "up one band" |
| 27.495 MHz | Channel 7A 27.045 MHz "up one band" |
| 27.510 MHz | Paging, voice and data - possibly offset 27.5125 MHz |
| 27.545 MHz | Channel 11A 27.095 MHz "up one band" |
| 27.595 MHz | Channel 15A 27.145 MHz "up one band" |
| 27.645 MHz | Channel 19A 27.195 MHz "up one band" |
| 27.705 MHz | Channel 23 27.255 MHz "up one band" |
Keywords:
