Cordless telephone
Revision as of 13:16, 26 April 2021 by R4002 (Talk | contribs)
placeholder for additional info later
Frequencies
The "49 MHz" cordless phones were rapidly adopted by consumers, resulting in heavy frequency congestion. The 49.830-49.890 MHz frequencies were and still are heavily used by other devices including baby monitors in continuous transmit mode. 15 frequencies were added bringing the total number of channels to 25. 43.71 MHz to 44.49 MHz (43.72 MHz to 44.48 MHz), 46.60 MHz to 46.98 MHz (46.61 MHz to 46.97 MHz), 48.75 MHz to 49.51 MHz (48.76 MHz to 49.50 MHz and 49.66 MHz to 50.0 MHz (49.67 MHz to 49.9 MHz). Note that the frequencies overlap with the VHF low band business radio band, the military bands, the 49 MHz RC 49 MHz remote control device frequencies and 49 MHz short range devices (walkie-talkies, baby monitors, etc.) The original 10 channel cordless phones used the 46.6 MHz - 47.0 MHz and 49.6 MHz to 50.0 MHz ranges only (46.610 MHz - 46.970 MHz and 46.670 MHz - 49.990 MHz).
The FCC quickly moved to authorize additional frequency space for cordless phones. With the 900 MHz ISM band 902-928 MHz becoming available next. 900 MHz cordless phones are still used today. Analog FM, digital voice and various frequency hopping spread-spectrum or FHSS cordless phones became available for the 900MHz band. If FHSS technology is used, base stations may transmit up to 1 watt ERP. This increase in transmitter power combined with the interference rejection capabilities of spread spectrum gave the higher-end 900 MHz cordless phones significant range. Unlike the older-generation models, 900 MHz cordless telephones never had a standardized channel plan or base and handset frequency pair or channel plan. This meant that manufacturers simply created their own, with widely differing channel steps, number of channels and other options. Even cheap analog FM 900 MHz cordless phones usually featured automatic channel selection. In other words, if the first channel pair was busy the system simply switched to the next clear channel. This same technology was (and is) included in digital voice cordless telephones operating in the 900 MHz band, the 2.4 GHz band and the 5.8 GHz band as well as those using modern DECT technology.
The 2.4 GHz band became available shortly after 900 MHz and originally provided excellent results. However, the proliferation of devices operating in the 2.4 GHz band now means that 2.4GHz cordless phones often suffer from (or cause) interference and/or have reduced range compared to the other bands. The 5.8 GHz allocation was opened up to alleviate the congestion on 2.4 GHz. Many 5.8 GHz band cordless phones are sold today. Some "5.8 GHz" phones are actually cross-band and use 5.8 GHz for handset to base but use 900 MHz or 2.4 GHz for base-to-handset.
47.4 MHz to 47.550 MHz (47.45 MHz to 47.55 MHz)
CT0 - UK Specification CT0 Extended - Long Range 100mW power output
CT0 - UK Specification CT0 - Current Allocation - 10mW power output, FM mode. 31.025 MHz - 31.225 MHz and 39.925 MHz - 40.125 MHz.
Cordless telephony Equipment operating in the Frequency Range 864.1- 868.1 MHz (CT2) 2-level frequency shift keying. 10mW transmit power limit. 40 channels at 100 kHz channel spacing. Base frequencies 864.1 MHz to 868.1 MHz. Handset frequencies 864.1 MHz - 868.1 MHz. The UK is assigning other services to the 864-868 MHz band but CT2 equipment remains legal to use.
DECT 1880-1900 MHz - <250mW handset and base stations 1880-1900 MHz on the standard GMSK modulation type using TDMA. CEPT DECT standard.
Spain
CT1
  • Base Frequency: 31.025 MHz - Handset Frequency: 39.925 MHz - Channel 1
  • Base Frequency: 31.050 MHz - Handset Frequency: 39.950 MHz - Channel 2
  • Base Frequency: 31.075 MHz - Handset Frequency: 39.975 MHz - Channel 3
  • Base Frequency: 31.100 MHz - Handset Frequency: 40.000 MHz - Channel 4
  • Base Frequency: 31.300 MHz - Handset Frequency: 40.200 MHz - Channel 11
  • Base Frequency: 31.325 MHz - Handset Frequency: 40.225 MHz - Channel 12
