It is important to note that many lower-cost children's grade RC toys actually fall under Part 15 operation within the 26.98 MHz to 27.28 MHz band (not to be confused with the 26.957 MHz to 27.283 MHz ISM band), but still use the same 27 MHz RC channel plan. 26.98 MHz-27.28 MHz, 26.96 MHz-27.28 MHz, operation within the band 26.98 MHz - 27.28 MHz, etc. etc. While many of these Part 15 devices use the standard 27 MHz RC frequencies, numerous 27 MHz RC devices do not. FCC approval documentation for RC devices operating under 15C show use of offset frequencies including 27.12 MHz, 27.14 MHz, 27.141 MHz, 27.1447 MHz, 27.15 MHz, etc. Toy grade devices tend to use 27.145 MHz -/+ 5 kHz or so. Higher quality devices allow the user to select the channel / frequency used, often by swapping crystals.
- RC channel frequency: 26.995 MHz; center frequency between 26.9923 MHz - 26.9977 MHz
- RC channel frequency: 27.045 MHz; center frequency between 27.0423 MHz - 27.0477 MHz
- RC channel frequency: 27.095 MHz; center frequency between 27.0923 MHz - 27.0977 MHz
- RC channel frequency: 27.145 MHz; center frequency between 27.1423 MHz - 27.1477 MHz
- RC channel frequency: 27.195 MHz; center frequency between 27.1923 MHz - 27.1977 MHz
- RC channel frequency: 27.255 MHz; center frequency between 27.2523 MHz - 27.2577 MHz
- RC channel frequency: 26.995 MHz; center frequency between 26.9936 MHz - 26.9964 MHz
- RC channel frequency: 27.045 MHz; center frequency between 27.0436 MHz - 27.0464 MHz
- RC channel frequency: 27.095 MHz; center frequency between 27.0936 MHz - 27.0964 MHz
- RC channel frequency: 27.145 MHz; center frequency between 27.1436 MHz - 27.1464 MHz
- RC channel frequency: 27.195 MHz; center frequency between 27.1936 MHz - 27.1964 MHz
- RC channel frequency: 27.255 MHz; center frequency between 27.2536 MHz - 27.2564 MHz
In other words, a legal 11m beacon system could be set up to transmit 2.5 watts or less with the center frequency on 26.997 MHz, 27.097 MHz, 27.143 MHz, 27.044 MHz, 27.2567 MHz and it would be within the FCC rules (as long as it is being used to switch a remote device on or off).
The higher power systems (for example, on-site paging systems operating on 26.995 MHz or 27.255 MHz, must adhere to the tighter frequency stability standard. Many of these systems are still in operation on 27.255 MHz and secondhand paging systems can be purchased for under $50 in many cases. Attaching a RadioShack 17-6020 - RadioShack PG-99 or 17-6023 paging transmitter to a base station CB antenna could provide wide-area coverage quite easily.
49 MHz RC Frequencies
The following channels are allocated to remote controlled aircraft, 750 mW 0.75 watt max transmitter power. From 72.4 MHz to 72.6 MHz, band is shared with operational fixed, business data link, telemetry and point-to-point links within the Business Radio Service.
- 72.010 MHz
- 72.030 MHz
- 72.050 MHz
- 72.070 MHz
- 72.090 MHz
- 72.110 MHz
- 72.130 MHz
- 72.150 MHz
- 72.170 MHz
- 72.190 MHz
- 72.210 MHz
- 72.230 MHz
- 72.250 MHz
- 72.270 MHz
- 72.290 MHz
- 72.310 MHz
- 72.330 MHz
- 72.350 MHz
- 72.370 MHz
- 72.390 MHz
- 72.410 MHz
- 72.430 MHz
- 72.450 MHz
- 72.470 MHz
- 72.490 MHz
- 72.510 MHz
- 72.530 MHz
- 72.550 MHz
- 72.570 MHz
- 72.590 MHz
- 72.610 MHz
- 72.630 MHz
- 72.650 MHz
- 72.670 MHz
- 72.690 MHz
- 72.710 MHz
- 72.730 MHz
- 72.750 MHz
- 72.770 MHz
- 72.790 MHz
- 72.810 MHz
- 72.830 MHz
- 72.850 MHz
- 72.870 MHz
- 72.890 MHz
- 72.910 MHz
- 72.930 MHz
- 72.950 MHz
- 72.970 MHz
- 72.990 MHz
- 75.410 MHz
- 75.430 MHz
- 75.450 MHz
- 75.470 MHz
- 75.490 MHz
- 75.510 MHz
- 75.530 MHz
- 75.550 MHz
- 75.570 MHz
- 75.590 MHz
- 75.610 MHz
- 75.630 MHz
- 75.650 MHz
- 75.670 MHz
- 75.690 MHz
- 75.710 MHz
- 75.730 MHz
- 75.750 MHz
- 75.770 MHz
- 75.790 MHz
- 75.810 MHz
- 75.830 MHz
- 75.850 MHz
- 75.870 MHz
- 75.890 MHz
- 75.910 MHz
- 75.930 MHz
- 75.950 MHz
- 75.970 MHz
- 75.990 MHz
Canada
49 MHz band
Maximum power 100mw on 49 MHz in Canada for RC purposes. No official channel numbering or designation. The 49.82 MHz - 49.90 MHz band appears to have the same power limits as the Part 15 band in the United States. Conflicting reports on exact power limits for R/C use in Canada. RC reference material does indicate 100mw or 0.1 watt power limit. Use of 49 MHz band is not recommended for aero models (aircraft models) or any sort of long-range model control, due to the proliferation of low-power low-quality RC toys and other unlicensed devices using the same 49 MHz band. Although this may not be as big of an issue as it was 10 or 20 years ago...the 4 watt limit on 27 MHz RC and the higher power available on 72 MHz/75 MHz still don't make 49 MHz very attractive.
- 72.010 MHz - Channel 11
- 72.030 MHz - Channel 12
- 72.050 MHz - Channel 13
- 72.070 MHz - Channel 14
- 72.090 MHz - Channel 15
- 72.110 MHz - Channel 16
- 72.130 MHz - Channel 17
- 72.150 MHz - Channel 18
- 72.170 MHz - Channel 19
- 72.190 MHz - Channel 20
- 72.210 MHz - Channel 21
- 72.230 MHz - Channel 22
- 72.250 MHz - Channel 23
- 72.270 MHz - Channel 24
- 72.290 MHz - Channel 25
- 72.310 MHz - Channel 26
- 72.330 MHz - Channel 27
- 72.350 MHz - Channel 28
- 72.370 MHz - Channel 29
- 72.390 MHz - Channel 30
- 72.410 MHz - Channel 31
- 72.430 MHz - Channel 32
- 72.450 MHz - Channel 33
- 72.470 MHz - Channel 34
- 72.490 MHz - Channel 35
- 72.510 MHz - Channel 36
- 72.530 MHz - Channel 37
- 72.550 MHz - Channel 38
- 72.570 MHz - Channel 39
- 72.590 MHz - Channel 40
- 72.610 MHz - Channel 41
- 72.630 MHz - Channel 42
- 72.650 MHz - Channel 43
- 72.670 MHz - Channel 44
- 72.690 MHz - Channel 45
- 72.710 MHz - Channel 46
- 72.730 MHz - Channel 47
- 72.750 MHz - Channel 48
- 72.770 MHz - Channel 49
- 72.790 MHz - Channel 50
- 72.810 MHz - Channel 51
- 72.830 MHz - Channel 52
- 72.850 MHz - Channel 53
- 72.870 MHz - Channel 54
- 72.890 MHz - Channel 55
- 72.910 MHz - Channel 56
- 72.930 MHz - Channel 57
- 72.950 MHz - Channel 58
- 72.970 MHz - Channel 59
- 72.990 MHz - Channel 60
- 75.410 MHz - Channel 61
- 75.430 MHz - Channel 62
- 75.450 MHz - Channel 63
- 75.470 MHz - Channel 64
- 75.490 MHz - Channel 65
- 75.510 MHz - Channel 66
- 75.530 MHz - Channel 67
- 75.550 MHz - Channel 68
- 75.570 MHz - Channel 69
- 75.590 MHz - Channel 70
- 75.610 MHz - Channel 71
- 75.630 MHz - Channel 72
- 75.650 MHz - Channel 73
- 75.670 MHz - Channel 74
- 75.690 MHz - Channel 75
- 75.710 MHz - Channel 76
- 75.730 MHz - Channel 77
- 75.750 MHz - Channel 78
- 75.770 MHz - Channel 79
- 75.790 MHz - Channel 80
- 75.810 MHz - Channel 81
- 75.830 MHz - Channel 82
- 75.850 MHz - Channel 83
- 75.870 MHz - Channel 84
- 75.890 MHz - Channel 85
- 75.910 MHz - Channel 86
- 75.930 MHz - Channel 87
- 75.950 MHz - Channel 88
- 75.970 MHz - Channel 89
- 75.990 MHz - Channel 90
Maximum output power 100mW or 0.1 watt - for R/C aircraft use only 10 kHz channels, 10 kHz maximum bandwidth. Portion of this band is shared with Short Range Devices (SRD) allocation 34.995 MHz to 35.225 MHz (see section below on European standardization).
- 34.950 MHz - Channel 55
- 34.960 MHz - Channel 56
- 34.970 MHz - Channel 57
- 34.980 MHz - Channel 58
- 34.990 MHz - Channel 59
- 35.000 MHz - Channel 60
- 35.010 MHz - Channel 61
- 35.020 MHz - Channel 62
- 35.030 MHz - Channel 63
- 35.040 MHz - Channel 64
- 35.050 MHz - Channel 65
- 35.060 MHz - Channel 66
- 35.070 MHz - Channel 67
- 35.080 MHz - Channel 68
- 35.090 MHz - Channel 69
- 35.100 MHz - Channel 70
- 35.110 MHz - Channel 71
- 35.120 MHz - Channel 72
- 35.130 MHz - Channel 73
- 35.140 MHz - Channel 74
- 35.150 MHz - Channel 75
- 35.160 MHz - Channel 76
- 35.170 MHz - Channel 77
- 35.180 MHz - Channel 78
- 35.190 MHz - Channel 79
- 35.200 MHz - Channel 80
- 35.210 MHz - Channel 81
- 35.220 MHz - Channel 82
- 35.230 MHz - Channel 83
- 35.240 MHz - Channel 84
- 35.250 MHz - Channel 85
- 35.260 MHz - Channel 86
- 35.270 MHz - Channel 87
- 35.280 MHz - Channel 88
- 35.290 MHz - Channel 89
- 35.300 MHz - Channel 90
Maximum output power 100mW or 0.1 watt - - R/C surface vehicles only (cars, boats, etc). 40.660 MHz to 40.700 MHz (40.680 MHz center frequency) shared with ISM and other short range devices (SRDs). Like RC frequencies around the 26-28 MHz band (27.12 MHz), the 40.68 MHz center frequency is shared with ISM devices and services. Allocated at the same time as the 35 MHz RC band in response to CB radio interference becoming increasingly problematic.
- 40.665 MHz - Channel 665
- 40.675 MHz - Channel 675
- 40.685 MHz - Channel 685
- 40.695 MHz - Channel 695
- 40.705 MHz - Channel 705
- 40.715 MHz - Channel 715
- 40.725 MHz - Channel 715
- 40.735 MHz - Channel 735
- 40.745 MHz - Channel 745
- 40.755 MHz - Channel 755
- 40.785 MHz - Channel 785
- 40.795 MHz - Channel 795
- 40.805 MHz - Channel 805
- 40.815 MHz - Channel 815
- 40.825 MHz - Channel 825
- 40.835 MHz - Channel 835
- 40.845 MHz - Channel 845
- 40.855 MHz - Channel 855
- 40.865 MHz - Channel 865
- 40.875 MHz - Channel 875
- 40.885 MHz - Channel 885
- 40.895 MHz - Channel 895
- 40.905 MHz - Channel 905
- 40.915 MHz - Channel 915
- 40.925 MHz - Channel 925
- 40.935 MHz - Channel 935
- 40.945 MHz - Channel 945
- 40.955 MHz - Channel 955
- 40.965 MHz - Channel 965
- 40.975 MHz - Channel 975
- 40.985 MHz - Channel 985
- 40.995 MHz - Channel 995
459 MHz Band - UHF
- 458.525 MHz - Channel 1
- 458.550 MHz - Channel 2
- 458.575 MHz - Channel 3
- 458.600 MHz - Channel 4
- 458.625 MHz - Channel 5
- 458.650 MHz - Channel 6
- 458.675 MHz - Channel 7
- 458.700 MHz - Channel 8
- 458.725 MHz - Channel 9
- 458.750 MHz - Channel 10
- 458.775 MHz - Channel 11
- 458.800 MHz - Channel 12
- 458.825 MHz - Channel 13
- 458.850 MHz - Channel 14
- 458.875 MHz - Channel 15
- 458.900 MHz - Channel 16
- 458.925 MHz - Channel 17
- 458.950 MHz - Channel 18
- 458.975 MHz - Channel 19
- 459.000 MHz - Channel 20
- 459.025 MHz - Channel 21
- 459.050 MHz - Channel 22
- 459.075 MHz - Channel 23
- 459.100 MHz - Channel 24
- 459.125 MHz - Channel 25
- 459.150 MHz - Channel 26
- 459.175 MHz - Channel 27
- 459.200 MHz - Channel 28
- 459.225 MHz - Channel 29
- 459.250 MHz - Channel 30
- 459.275 MHz - Channel 31
- 459.300 MHz - Channel 32
- 459.325 MHz - Channel 33
- 459.350 MHz - Channel 34
- 459.375 MHz - Channel 35
- 459.400 MHz - Channel 36
- 459.425 MHz - Channel 37
- 459.450 MHz - Channel 38
- 459.475 MHz - Channel 39
*CEPT ETSI SRD Bands It should be noted that not all EC / EU countries permit operation on all bands, additional country-specific restrictions as well as additional country-specific frequencies and bands (and European standardized RC channels) exist. See ETSI EN 300.220 and others for band-specific restrictions on power output, duty cycle, transmission length, listen-before-transmit, adaptive power control, adaptive frequency control and specific channels. No transmission length limit on the 26995, 27045, 27095, 27145 and 27195 channels when used for model control.
- 26.957 MHz to 27.283 MHz
- 26.995 MHz - 100mW ERP
- 27.045 MHz - 100mW ERP
- 27.095 MHz - 100mW ERP
- 27.145 MHz - 100mW ERP
- 27.195 MHz - 100mW ERP
- 40.660 MHz to 40.700 MHz
- 138.200 MHz to 138.450 MHz
- 169.400 MHz to 169.8125 MHz
- 433.040 MHz to 434.790 MHz
- 863 MHz to 876 MHz
- 915 MHz to 921 MHz
- 34.995 MHz to 35.225 MHz - European standardized aero models only (flying models, aircraft models only) CEPT 35 MHz band, 5/10 kHz spacing, generally starting at 35.000 MHz going up to 35.220 MHz in 10 kHz steps. Some countries have additional allocations above and below the EU standardized band. ITU “worldwide” standardization for SRDs - Short Range Devices - on the 40.66 MHz - 40.70 MHz band exists, but with a power limit of 10mW ERP. Several countries permit 100mW on the 35 MHz RC channels and/or the 40 MHz RC channels.
Czech Republic
- 34.050 MHz
- 34.075 MHz
- 34.150 MHz
- 34.175 MHz
- 35.000 MHz - C1
- 35.010 MHz - C2
- 35.020 MHz - C3
- 35.030 MHz - C4
- 35.040 MHz - C5
- 35.050 MHz - C6
- 35.060 MHz - C7
- 35.070 MHz - C8
- 35.080 MHz - C9
- 35.090 MHz - C10
- 35.100 MHz - C11
- 35.110 MHz - C12
- 35.120 MHz - C13
- 35.130 MHz - C14
- 35.140 MHz - C15
- 35.150 MHz - C16
- 35.160 MHz - C17
- 35.170 MHz - C18
- 35.180 MHz - C19
- 35.190 MHz - C20
- 35.200 MHz - C21
- 35.210 MHz - C22
- 35.220 MHz - C23
- 35.820 MHz - D1
- 35.830 MHz - D2
- 35.840 MHz - D3
- 35.850 MHz - D4
- 35.860 MHz - D5
- 35.870 MHz - D6
- 35.880 MHz - D7
- 35.890 MHz - D8
- 35.900 MHz - D9
- 35.910 MHz - D10
40 MHz FM - 1 watt ERP maximum power FSK (all models), 40.725 MHz - 40.985 MHz (40.720 MHz - 40.990 MHz)
France
- 26.815 MHz - 26815 kHz
- 26.825 MHz - 26825 kHz
- 26.835 MHz - 26835 kHz
- 26.845 MHz - 26845 kHz
- 26.855 MHz - 26855 kHz
- 26.865 MHz - 26865 kHz
- 26.875 MHz - 26875 kHz
- 26.885 MHz - 26885 kHz
- 26.895 MHz - 26895 kHz
- 26.905 MHz - 26905 kHz
- 26.915 MHz - 26915 kHz
- 35.000 MHz
- 35.010 MHz
- 35.020 MHz
- 35.030 MHz
- 35.040 MHz
- 35.050 MHz
40 MHz / 41 MHz FM
- 72 MHz AM or FM
- 35.010 MHz
- 35.020 MHz
- 35.030 MHz
- 35.040 MHz
- 35.050 MHz
- 35.060 MHz
- 35.070 MHz
- 35.080 MHz
- 35.090 MHz
- 35.100 MHz
- 35.110 MHz
- 35.120 MHz
- 35.130 MHz
- 35.140 MHz
- 35.150 MHz
- 35.160 MHz
- 35.170 MHz
- 35.180 MHz
- 35.190 MHz
- 35.200 MHz
- 35.820 MHz
- 35.830 MHz
- 35.840 MHz
- 35.850 MHz
- 35.860 MHz
- 35.870 MHz
- 35.880 MHz
- 35.890 MHz
- 35.900 MHz
- 35.910 MHz
- 40.665 MHz
- 40.675 MHz
- 40.685 MHz
- 40.695 MHz
Italy
- 27.045 MHz
- 27.095 MHz
- 27.145 MHz
- 27.195 MHz
- 27.235 MHz
- 27.255 MHz
- 27.275 MHz
40 MHz band
- 40.665 MHz
- 40.675 MHz
- 40.685 MHz
- 40.695 MHz
- 40.705 MHz
- 40.715 MHz
- 40.725 MHz
- 40.735 MHz
- 40.745 MHz
- 40.755 MHz
- 40.765 MHz
- 40.775 MHz
- 40.785 MHz
- 40.795 MHz
- 40.805 MHz
- 40.815 MHz
- 40.825 MHz
- 40.835 MHz
- 40.845 MHz
- 40.855 MHz
- 40.865 MHz
- 40.875 MHz
Sweden
- 35.000 MHz - RC Channel 60
- 35.010 MHz - RC Channel 61
- 35.020 MHz - RC Channel 62
- 35.030 MHz - RC Channel 63
- 35.040 MHz - RC Channel 64
- 35.050 MHz - RC Channel 65
- 35.060 MHz - RC Channel 66
- 35.070 MHz - RC Channel 67
- 35.080 MHz - RC Channel 68
- 35.090 MHz - RC Channel 69
- 35.100 MHz - RC Channel 70
- 35.110 MHz - RC Channel 71
- 35.120 MHz - RC Channel 72
- 35.130 MHz - RC Channel 73
- 35.140 MHz - RC Channel 74
- 35.150 MHz - RC Channel 75
- 35.160 MHz - RC Channel 76
- 35.170 MHz - RC Channel 77
- 35.180 MHz - RC Channel 78
- 35.190 MHz - RC Channel 79
- 35.200 MHz - RC Channel 80
- 35.210 MHz - RC Channel 81
- 35.220 MHz - RC Channel 82
- 35.230 MHz - RC Channel 83
- 35.240 MHz - RC Channel 84
- 35.250 MHz - RC Channel 85
- 35.260 MHz - RC Channel 86
- 35.270 MHz - RC Channel 87
- 40.665 MHz
- 40.675 MHz
- 40.685 MHz
- 40.695 MHz
- 40.705 MHz
- 40.715 MHz
- 40.725 MHz
- 40.735 MHz
- 40.745 MHz
- 40.755 MHz
- 40.765 MHz
- 40.775 MHz
- 40.785 MHz
- 40.795 MHz
Denmark
- Frequencies
- 138.650 MHz - 500mW ERP
- Bands
Russia
27 MHz
- 40.610 MHz - General RC use
- 40.630 MHz - General RC use
- 40.650 MHz - General RC use
- 40.670 MHz - General RC use
- 40.680 MHz - General RC use and wireless microphones
- 40.690 MHz - General RC use
- 40.710 MHz - General RC use
- 40.730 MHz - General RC use
- 40.750 MHz - General RC use
- 40.770 MHz - Aircraft only
- 40.790 MHz - Aircraft only
- 40.810 MHz - Aircraft only
- 40.830 MHz - Aircraft only
- 40.850 MHz - Aircraft only
- 72.130 MHz - Aircraft only
- 72.150 MHz - Aircraft only
- 72.170 MHz - Aircraft only
- 72.190 MHz - Aircraft only
- 72.210 MHz - Aircraft only
- 72.790 MHz - Aircraft only
- 72.810 MHz - Aircraft only
- 72.830 MHz - Aircraft only
- 72.850 MHz - Aircraft only
- 72.870 MHz - Aircraft only
- 73.220 MHz - General RC use
- 73.230 MHz - General RC use
- 73.240 MHz - General RC use
- 73.250 MHz - General RC use
- 73.260 MHz - General RC use
- 73.270 MHz - General RC use
- 73.280 MHz - General RC use
- 73.290 MHz - General RC use
- 73.300 MHz - General RC use
- 73.310 MHz - General RC use
- 73.320 MHz - General RC use
People's Republic of China
- 40.610 MHz
- 40.630 MHz
- 40.650 MHz
- 40.670 MHz
- 40.690 MHz
- 40.710 MHz
- 40.730 MHz
- 40.750 MHz
- 40.770 MHz
- 40.790 MHz
- 40.810 MHz
- 40.830 MHz
- 40.850 MHz
- 72.130 MHz
- 72.150 MHz
- 72.170 MHz
- 72.190 MHz
- 72.210 MHz
- 72.790 MHz
- 72.810 MHz
- 72.830 MHz
- 72.850 MHz
- 72.870 MHz
India
"New" channel plan:
Old channel plan:
- 35.000 MHz - RC Channel 500
- 35.010 MHz - RC Channel 501
- 35.020 MHz - RC Channel 502
- 35.030 MHz - RC Channel 503
- 35.040 MHz - RC Channel 504
- 35.050 MHz - RC Channel 505
- 35.060 MHz - RC Channel 506
- 35.070 MHz - RC Channel 507
- 35.080 MHz - RC Channel 508
- 35.090 MHz - RC Channel 509
- 35.100 MHz - RC Channel 510
- 35.110 MHz - RC Channel 511
- 35.120 MHz - RC Channel 512
- 35.130 MHz - RC Channel 513
- 35.140 MHz - RC Channel 514
- 35.150 MHz - RC Channel 515
- 35.160 MHz - RC Channel 516
- 35.170 MHz - RC Channel 517
- 35.180 MHz - RC Channel 518
- 35.190 MHz - RC Channel 519
- 35.200 MHz - RC Channel 520
- 35.210 MHz - RC Channel 521
- 35.220 MHz - RC Channel 522
- 35.230 MHz - RC Channel 523
- 35.240 MHz - RC Channel 524
- 35.250 MHz - RC Channel 525
- 35.260 MHz - RC Channel 526
- 35.270 MHz - RC Channel 527
- 35.280 MHz - RC Channel 528
- 35.290 MHz - RC Channel 529
- 35.300 MHz - RC Channel 530
- 36.250 MHz - RC Channel 625
- 36.260 MHz - RC Channel 626
- 36.270 MHz - RC Channel 627
- 36.280 MHz - RC Channel 628
- 36.290 MHz - RC Channel 629
- 36.300 MHz - RC Channel 630
- 36.310 MHz - RC Channel 631
- 36.320 MHz - RC Channel 632
- 36.330 MHz - RC Channel 633
- 36.340 MHz - RC Channel 634
- 36.350 MHz - RC Channel 635
- 36.360 MHz - RC Channel 636
- 36.370 MHz - RC Channel 637
- 36.380 MHz - RC Channel 638
- 36.390 MHz - RC Channel 639
- 36.400 MHz - RC Channel 640
- 36.410 MHz - RC Channel 641
- 36.420 MHz - RC Channel 642
- 36.430 MHz - RC Channel 643
- 36.440 MHz - RC Channel 644
- 36.450 MHz - RC Channel 645
- 36.460 MHz - RC Channel 646
- 36.470 MHz - RC Channel 647
- 36.480 MHz - RC Channel 648
- 36.490 MHz - RC Channel 649
- 36.500 MHz - RC Channel 650
- 36.510 MHz - RC Channel 651
- 36.520 MHz - RC Channel 652
- 36.530 MHz - RC Channel 653
- 36.540 MHz - RC Channel 654
- 36.550 MHz - RC Channel 655
- 36.560 MHz - RC Channel 656
- 36.570 MHz - RC Channel 657
- 36.580 MHz - RC Channel 658
- 36.590 MHz - RC Channel 659
- 40.510 MHz - RC Channel 451
- 40.530 MHz - RC Channel 453
- 40.550 MHz - RC Channel 455
- 40.570 MHz - RC Channel 457
- 40.590 MHz - RC Channel 459
- 40.610 MHz - RC Channel 461
- 40.630 MHz - RC Channel 463
- 40.650 MHz - RC Channel 465
- 40.670 MHz - RC Channel 467
- 40.690 MHz - RC Channel 469
- 40.710 MHz - RC Channel 471
- 40.730 MHz - RC Channel 473
- 40.750 MHz - RC Channel 475
- 40.790 MHz - RC Channel 479
- 40.810 MHz - RC Channel 481
- 40.830 MHz - RC Channel 483
- 40.850 MHz - RC Channel 485
- 40.870 MHz - RC Channel 487
- 40.890 MHz - RC Channel 489
- 40.910 MHz - RC Channel 491
- 40.930 MHz - RC Channel 493
- 72.010 MHz - RC Channel 701
- 72.030 MHz - RC Channel 703
- 72.050 MHz - RC Channel 705
- 72.070 MHz - RC Channel 707
- 72.090 MHz - RC Channel 709
- 72.110 MHz - RC Channel 711
- 72.130 MHz - RC Channel 713
- 72.150 MHz - RC Channel 715
- 72.170 MHz - RC Channel 717
- 72.190 MHz - RC Channel 719
- 72.210 MHz - RC Channel 721
- 72.230 MHz - RC Channel 723
- 72.250 MHz - RC Channel 725
- 72.270 MHz - RC Channel 727
- 72.290 MHz - RC Channel 729
- 72.310 MHz - RC Channel 731
- 72.330 MHz - RC Channel 733
- 72.350 MHz - RC Channel 735
- 72.370 MHz - RC Channel 737
- 72.390 MHz - RC Channel 739
- 72.410 MHz - RC Channel 741
- 72.430 MHz - RC Channel 743
- 72.450 MHz - RC Channel 745
- 72.470 MHz - RC Channel 747
- 72.490 MHz - RC Channel 749
- 72.510 MHz - RC Channel 751
- 72.530 MHz - RC Channel 753
- 72.550 MHz - RC Channel 755
- 72.570 MHz - RC Channel 757
- 72.590 MHz - RC Channel 759
- 72.610 MHz - RC Channel 761
- 72.630 MHz - RC Channel 763
- 72.650 MHz - RC Channel 765
- 72.670 MHz - RC Channel 767
- 72.690 MHz - RC Channel 769
- 72.710 MHz - RC Channel 771
- 72.730 MHz - RC Channel 773
- 72.750 MHz - RC Channel 775
- 72.770 MHz - RC Channel 777
- 72.790 MHz - RC Channel 779
- 36.010 MHz - RC Channel 601
- 36.020 MHz - RC Channel 602
- 36.030 MHz - RC Channel 603
- 36.040 MHz - RC Channel 604
- 36.050 MHz - RC Channel 605
- 36.060 MHz - RC Channel 606
- 36.070 MHz - RC Channel 607
- 36.080 MHz - RC Channel 608
- 36.090 MHz - RC Channel 609
- 36.100 MHz - RC Channel 610
- 36.110 MHz - RC Channel 611
- 36.120 MHz - RC Channel 612
- 36.130 MHz - RC Channel 613
- 36.140 MHz - RC Channel 614
- 36.150 MHz - RC Channel 615
- 36.160 MHz - RC Channel 616
- 36.170 MHz - RC Channel 617
- 36.180 MHz - RC Channel 618
- 36.190 MHz - RC Channel 619
- 36.200 MHz - RC Channel 620
- 36.210 MHz - RC Channel 621
- 36.220 MHz - RC Channel 622
- 36.230 MHz - RC Channel 623
- 36.240 MHz - RC Channel 624
- 40.665 MHz - RC Channel 50
- 40.675 MHz - RC Channel 51
- 40.685 MHz - RC Channel 52
- 40.695 MHz - RC Channel 53
