HF pagers
Revision as of 12:51, 20 October 2021 by R4002 (Talk | contribs)
See also the Remote Control FCC Part 95 Class C Page - Remote Control Radio Service (RCRS), FCC Rules Part 95, Personal Radio Services, Subpart C—Radio Control Radio Service 95.701-95.899, previously 95.201-95.225
Frequency List
Note: This list is a dynamic list and will never be complete. Many of these systems - especially the paging systems and telemetry or data link systems, act as de facto 11 meter beacons and de facto high frequency beacons
Frequency Remarks
26.100 MHz Hospital pagers - Europe FM mode
26.145 MHz Marine Instruments Radio Buoys
26.150 MHz Marine Instruments Radio Buoys
26.150 MHz Hospital pagers (Holland) FM mode - confirmed active October 2021
26.155 MHz Marine Instruments Radio Buoys
26.160 MHz Marine Instruments Radio Buoys
26.165 MHz Marine Instruments Radio Buoys
26.170 MHz Marine Instruments Radio Buoys
26.175 MHz Marine Instruments Radio Buoys
26.250 MHz UK Paging on-site pager - confirmed active October 2021
26.300 MHz Hospital pagers (Holland) FM mode - confirmed active July 2020
26.350 MHz Hospital pagers (Holland) FM mode - confirmed active July 2020
26.400 MHz Hospital pagers (Holland) FM mode - confirmed active July 2020
26.450 MHz Hospital pagers (Holland) FM mode - confirmed active July 2020
26.500 MHz Paging, heard in Europe, noted use in Holland - FM mode - confirmed active July 2020
26.555 MHz POCSAG pager - Europe
26.650 MHz Hospital pagers - Europe - confirmed active August 2021
26.695 MHz Offset frequency for 26.700 MHz, heard in Western Europe and UK - confirmed active August 2021
26.700 MHz European on-site paging systems - confirmed active August 2021
26.750 MHz Hospital pagers Europe - POCSAG - confirmed active October 2021
26.835 MHz UK Paging on-site Radio Paging Hire frequency - maximum ERP 2 watts 26.8350 MHz
26.850 MHz Hospital pagers - Europe FM mode - FSK - confirmed active October 2021
26.855 MHz Hospital pagers - Europe FM mode - FSK - confirmed active October 2021
26.885 MHz POCSAG pager - Europe
26.920 MHz UK Paging on-site Radio Paging Hire frequency - maximum ERP 2 watts 26.9200 MHz
26.935 MHz Data link or telemetry system, unknown origin or source, possibly Middle East - FM mode
26.935 MHz POCSAG pager - Europe
26.940 MHz POCSAG pager (other modes heard) - heard daily in Russia - Russian 26 MHz paging system
26.945 MHz Russia - State Committee for Radio Frequencies (Protocol No. 170 of 12/30/88) - 2 watt alarm data links - FSK
26.950 MHz Local pager, heard in mainland Europe, transmits "idle" signal even when no pages are being sent - off the air?
26.950 MHz Hospital pagers on-site paging systems Europe - confirmed active October 2021
26.950 MHz POCSAG pager (other modes heard) - heard daily in Russia - Russian 26 MHz paging system
26.955 MHz Paging heard on several Russian SDRs, possible alternate to 26.945 MHz, 26.95 MHz and 26.96 MHz frequencies?
26.960 MHz Russia - State Committee for Radio Frequencies (Protocol No. 170 of 12/30/88) - 2 watt alarm data links - FSK
26.995 MHz Remote Control Technology Long Range Wireless Switch System LRWSS model # 01217 4 watt PTDFM FSK (FM) 27MHz transmitter
26.995 MHz Remote Control Technology Medium Range Wireless Switch System MRWSS model # 01214 2 watt FSK (FM) 27MHz transmitter
27.000 MHz Russian data link or telemetry system, 10-12 kHz, MFSK
27.007 MHz POCSAG paging signal, heard in Finland (unknown source), possibly offset 27.005 MHz or 27.0075 MHz
27.070 MHz POGSAG Pager FM - Russian origin - 27 MHz Russian paging system frequency
27.090 MHz European standardized Eurobalise train telemetry system 27,090-27,100 MHz (27,095 MHz center frequency, system 27.09 MHz-27.1 MHz)
27.095 MHz European standardized Eurobalise train telemetry system 27,095 MHz +/- 500 kHz 26.695 MHz - 27.595 MHz
27.100 MHz European standardized Eurobalise train telemetry system 27,090-27,100 MHz (27,095 MHz center frequency, system 27.09 MHz-27.1 MHz)
27.145 MHz THOR GUARD Voice of Thor - VOT - 27.255 MHz one-to-many alarm control system (strobe or siren) - 44 output version
27.195 MHz Remote Control Technology Short Range Wireless Switch System SRWSS model # 01215 1 watt PTDFM FSK (FM) 27MHz transmitter
27.233 MHz POCSAG Paging signals, narrowband (center frequency 27.233, tune 27.230 MHz USB)
27.255 MHz Radio Control RC Service Part 95 25 watt power limit, 8.5 kHz bandwidth limit in USA
27.255 MHz Multiple-site FSK 27 MHz data link system noted near Highland Falls, NY USA, nearly constant FSK data bursts - off the air?
27.255 MHz Multiple-site FSK 27 MHz data link system noted near Rockport, Maine - FSK data bursts identical to those seen on Highland Falls NY SDR
27.255 MHz Data link system located in rural Virginia, roughly 20 miles north of Richmond, VA (data bursts on 27.255 MHz)
27.255 MHz RadioShack 7 watt FSK paging transmitter on-site system model PG-99 17-6020 - 100 unique receiver (pager) IDs supported
27.255 MHz RadioShack 4 watt FSK paging transmitter on-site system model 17-6023 - 1000 unique receiver (pager) IDs supported
27.255 MHz Linear Controls XT-1 1-channel fixed telemetry/control system transmitter, 10 watt FSK, 6 kHz bandwidth 6K00F1D 6K00F2D
27.255 MHz Linear Controls XT-4 4-channel fixed telemetry/control system transmitter, 10 watt FSK, 6 kHz bandwidth 6K00F1D 6K00F2D
27.255 MHz Linear Controls XT-1H 1-channel portable telemetry/control system transmitter, 2 watt FSK, 6 kHz bandwidth 6K00F1D 6K00F2D
27.255 MHz Linear Controls XT-2H 2-channel portable telemetry/control system transmitter, 2 watt FSK, 6 kHz bandwidth 6K00F1D 6K00F2D
27.255 MHz THOR GUARD Voice of Thor - VOT - 27.255 MHz one-to-many alarm control system (strobe or siren) - 12w output version
27.450 MHz Paging, heard in several parts of Europe, sometimes an unmodulated FM carrier transmitted - 27.45 MHz
27.450 MHz Alarm system datalinks - UK - 500mW power limit (considered a SRD or RC device)
27.510 MHz Paging, voice and data - possibly offset 27.5125 MHz or 27.513 MHz
27.650 MHz Data link/Carrier signal, FM/FSK, possible military, Norfolk, VA - confirmed active again March 2019
Keywords:
