DDE
Revision as of 13:28, 13 June 2023 by R4002 (Talk | contribs)
ePMR LMR PMR PLMR VHF low band land mobile radio system. The VHF low band spectrum is used by numerous other services in France and elsewhere in Europe and other areas.
