DDE
Revision as of 13:46, 13 June 2023 by R4002 (Talk | contribs)
  • 35.0750 MHz / 39.4750 MHz - Channel 13
  • 35.0875 MHz / 39.4875 MHz - Channel 14
  • 35.1000 MHz / 39.5000 MHz - Channel 15
  • 35.1125 MHz / 39.5125 MHz
  • 35.1250 MHz / 39.5250 MHz
  • 35.1375 MHz / 39.5375 MHz
  • 35.1500 MHz / 39.5500 MHz
  • 35.1625 MHz / 39.5625 MHz
  • 35.1750 MHz / 39.5750 MHz
  • 35.1875 MHz / 39.5875 MHz
  • 35.2000 MHz / 39.6000 MHz
  • 35.2125 MHz / 39.6125 MHz
  • 35.2250 MHz / 39.6250 MHz
  • 35.2375 MHz / 39.6375 MHz
  • 35.2500 MHz / 39.6500 MHz
  • 35.2625 MHz / 39.6625 MHz
