DDE
- 35 MHz / 36 MHz repeater output (mobile RX)
- 39 MHz / 40 MHz repeater input (mobile TX)
- 36.1625 MHz / 40.5625 MHz - Channel 00
- 36.1750 MHz / 40.5750 MHz - Channel 01
- 36.1875 MHz / 40.5875 MHz - Channel 02
- 36.2000 MHz / 40.6000 MHz - Channel 03
- 36.2125 MHz / 40.6125 MHz - Channel 04
- 36.2250 MHz / 40.6250 MHz - Channel 05
- 36.2375 MHz / 40.6375 MHz - Channel 06
- 35.0000 MHz / 39.4000 MHz - Channel 07
- 35.0125 MHz / 39.4125 MHz - Channel 08
- 35.0250 MHz / 39.4250 MHz - Channel 09
- 35.0375 MHz / 39.4375 MHz - Channel 10
- 35.0500 MHz / 39.4500 MHz - Channel 11
- 35.0625 MHz / 39.4625 MHz - Channel 12
- 35.0750 MHz / 39.4750 MHz - Channel 13
- 35.0875 MHz / 39.4875 MHz - Channel 14
- 35.1000 MHz / 39.5000 MHz - Channel 15
- 35.1125 MHz / 39.5125 MHz - Channel 16
- 35.1250 MHz / 39.5250 MHz - Channel 17
- 35.1375 MHz / 39.5375 MHz - Channel 18
- 35.1500 MHz / 39.5500 MHz - Channel 19
- 35.1625 MHz / 39.5625 MHz - Channel 20
- 35.1750 MHz / 39.5750 MHz - Channel 21
- 35.1875 MHz / 39.5875 MHz - Channel 22
- 35.2000 MHz / 39.6000 MHz - Channel 23
- 35.2125 MHz / 39.6125 MHz - Channel 24
- 35.2250 MHz / 39.6250 MHz - Channel 25
- 35.2375 MHz / 39.6375 MHz - Channel 26
- 35.2500 MHz / 39.6500 MHz - Channel 27
- 35.2625 MHz / 39.6625 MHz - Channel 28
- 35.2750 MHz / 39.6750 MHz - Channel 29
- 35.2875 MHz / 39.6875 MHz - Channel 30
- 35.3000 MHz / 39.7000 MHz - Channel 31
- 35.5000 MHz / 39.9000 MHz - Channel 32
- 35.5500 MHz / 39.9500 MHz - Channel 33
- 35.6000 MHz / 40.0000 MHz - Channel 34
- 35.6500 MHz / 40.0500 MHz - Channel 35
- 35.7750 MHz / 40.1750 MHz - Channel 36
- 35.8000 MHz / 40.2000 MHz - Channel 37
- 35.8500 MHz / 40.2500 MHz - Channel 38
- 35.9500 MHz / 40.3500 MHz - Channel 39
- 35.9875 MHz / 40.3875 MHz - Channel 40
- 36.0000 MHz / 40.4000 MHz - Channel 41
- 36.0500 MHz / 40.4500 MHz - Channel 42
- 36.1000 MHz / 40.5000 MHz - Channel 43
- 36.1500 MHz / 40.5500 MHz - Channel 44
- 35.5125 MHz / 39.9125 MHz - Channel 45
- 35.5250 MHz / 39.9250 MHz - Channel 46
- 35.5375 MHz / 39.9375 MHz - Channel 47
- 35.5625 MHz / 39.9625 MHz - Channel 48
- 35.5750 MHz / 39.9750 MHz - Channel 49
- 35.5875 MHz / 39.9875 MHz - Channel 50
- 35.6125 MHz / 40.0125 MHz - Channel 51
- 35.6250 MHz / 40.0250 MHz - Channel 52
- 35.6375 MHz / 40.0375 MHz - Channel 53
- 35.6625 MHz / 40.0625 MHz - Channel 54
- 35.6750 MHz / 40.0750 MHz - Channel 55
- 35.6875 MHz / 40.0875 MHz - Channel 56
- 35.7000 MHz / 40.1000 MHz - Channel 57
- 35.7125 MHz / 40.1125 MHz - Channel 58
- 35.7250 MHz / 40.1250 MHz - Channel 59
- 35.7375 MHz / 40.1375 MHz - Channel 60
- 35.7500 MHz / 40.1500 MHz - Channel 61
- 35.7625 MHz / 40.1625 MHz - Channel 62
- 35.7875 MHz / 40.1875 MHz - Channel 63
- 35.8125 MHz / 40.2125 MHz - Channel 64
- 35.8250 MHz / 40.2250 MHz - Channel 65
- 35.8375 MHz / 40.2375 MHz - Channel 66
- 35.8625 MHz / 40.2625 MHz - Channel 67
- 35.8750 MHz / 40.2750 MHz - Channel 68
- 35.8875 MHz / 40.2875 MHz - Channel 69
- 35.9000 MHz / 40.3000 MHz - Channel 70
- 35.9125 MHz / 40.3125 MHz - Channel 71
- 35.9250 MHz / 40.3250 MHz - Channel 72
- 35.9375 MHz / 40.3375 MHz - Channel 73
- 35.9625 MHz / 40.3625 MHz - Channel 74
- 35.9750 MHz / 40.3750 MHz - Channel 75
- 36.0125 MHz / 40.4125 MHz - Channel 76
- 36.0250 MHz / 40.4250 MHz - Channel 77
- 36.0375 MHz / 40.4375 MHz - Channel 78
- 36.0625 MHz / 40.4625 MHz - Channel 79
- 36.0750 MHz / 40.4750 MHz - Channel 80
- 36.0875 MHz / 40.4875 MHz - Channel 81
- 36.1125 MHz / 40.5125 MHz - Channel 82
- 36.1250 MHz / 40.5250 MHz - Channel 83
- 36.1375 MHz / 40.5375 MHz - Channel 84
- 35.3125 MHz / 39.7125 MHz - Channel 85
- 35.3250 MHz / 39.7250 MHz - Channel 86
- 35.3375 MHz / 39.7375 MHz - Channel 87
- 35.3500 MHz / 39.7500 MHz - Channel 88
- 35.3625 MHz / 39.7625 MHz - Channel 89
- 35.3750 MHz / 39.7750 MHz - Channel 90
- 35.3875 MHz / 39.7875 MHz - Channel 91
- 35.4000 MHz / 39.8000 MHz - Channel 92
- 35.4125 MHz / 39.8125 MHz - Channel 93
- 35.4250 MHz / 39.8250 MHz - Channel 94
- 35.4375 MHz / 39.8375 MHz - Channel 95
- 35.4500 MHz / 39.8500 MHz - Channel 96
- 35.4625 MHz / 39.8625 MHz - Channel 97
- 35.4750 MHz / 39.8750 MHz - Channel 98
- 35.4875 MHz / 39.8875 MHz - Channel 99
Additional French VHF low 30-50 MHz and VHF mid band 66-88 MHz PMR PLMR LMR spectrum allocations:
12.5 kHz spacing
- 30.8750 MHz - 32.1250 MHz - Simplex
- 32.6000 MHz - 33.0000 MHz - Simplex
- 34.8500 MHz - 34.9000 MHz - Simplex
- 34.9000 MHz - 36.2500 MHz - Repeater outputs (duplex) systems - including DDE PMR
- 36.2500 MHz - 36.6000 MHz - Simplex
- 36.8625 MHz - 39.1000 MHz - Simplex
- 39.3000 MHz - 40.6500 MHz - Repeater inputs (paired with 34.9 MHz - 36.25 MHz) - DDE PMR
- 68.4625 MHz - 69.2500 MHz - Repeater inputs (paired with 72.5125 MHz - 73.3 MHz) - EDF and GDF PMR
- 70.2500 MHz - 70.5250 MHz - Simplex
- 70.9750 MHz - 71.9500 MHz - Simplex
- 72.5125 MHz - 73.3000 MHz - Repeater outputs (duplex) systems - including EDF and GDF
- 75.2000 MHz - 75.3000 MHz - Simplex
- 75.3000 MHz - 77.4750 MHz - Repeater outputs (duplex - paired with 80.3 MHz - 82.475 MHz)
- 80.0000 MHz - 80.3000 MHz - Simplex
- 80.3000 MHz - 82.4750 MHz - Repeater inputs (paired with 75.3 MHz - 77.475 MHz)
