EDF and GDF
Revision as of 16:59, 13 June 2023 by R4002 (Talk | contribs)
French electric and gas utility radio network. PMR VHF mid band 66-88 MHz band.
See also: DDE VHF low band 35 MHz / 36 MHz and 39 MHz / 40 MHz.
Repeater outputs 72 MHz / 73 MHz Repeater inputs: 68 MHz / 69 MHz
Repeater offset -4.05 MHz. Mobiles transmit low side. 12.5 kHz channel spacing.
  • Channel 01 - 72.5250 MHz / 68.4750 MHz
  • Channel 02 - 72.5375 MHz / 68.4875 MHz
  • Channel 03 - 72.5500 MHz / 68.5000 MHz
  • Channel 04 - 72.5625 MHz / 68.5125 MHz
  • Channel 05 - 72.5750 MHz / 68.5250 MHz
  • Channel 06 - 72.5875 MHz / 68.5375 MHz
  • Channel 07 - 72.6000 MHz / 68.5500 MHz
  • Channel 08 - 72.6125 MHz / 68.5625 MHz
  • Channel 09 - 72.6250 MHz / 68.5750 MHz
  • Channel 10 - 72.6375 MHz / 68.5875 MHz
  • Channel 11 - 72.6500 MHz / 68.6000 MHz
  • Channel 12 - 72.6625 MHz / 68.6125 MHz
  • Channel 13 - 72.6750 MHz / 68.6250 MHz
  • Channel 14 - 72.6875 MHz / 68.6375 MHz
  • Channel 15 - 72.7000 MHz / 68.6500 MHz
  • Channel 16 - 72.7125 MHz / 68.6625 MHz
  • Channel 17 - 72.7250 MHz / 68.6750 MHz
  • Channel 18 - 72.7375 MHz / 68.6875 MHz
  • Channel 19 - 72.7500 MHz / 68.7000 MHz
  • Channel 20 - 72.7625 MHz / 68.7125 MHz
  • Channel 21 - 72.7750 MHz / 68.7250 MHz
  • Channel 22 - 72.7875 MHz / 68.7375 MHz
  • Channel 23 - 72.8000 MHz / 68.7500 MHz
  • Channel 24 - 72.8125 MHz / 68.7625 MHz
  • Channel 25 - 72.8250 MHz / 68.7750 MHz
  • Channel 26 - 72.8375 MHz / 68.7875 MHz
  • Channel 27 - 72.8500 MHz / 68.8000 MHz
  • Channel 28 - 72.8625 MHz / 68.8125 MHz
  • Channel 29 - 72.8750 MHz / 68.8250 MHz
  • Channel 30 - 72.8875 MHz / 68.8375 MHz
  • Channel 31 - 72.9000 MHz / 68.8500 MHz
  • Channel 32 - 72.9125 MHz / 68.8625 MHz
  • Channel 33 - 72.9250 MHz / 68.8750 MHz
  • Channel 34 - 72.9375 MHz / 68.8875 MHz
  • Channel 35 - 72.9500 MHz / 68.9000 MHz
  • Channel 36 - 72.9625 MHz / 68.9125 MHz
  • Channel 37 - 72.9750 MHz / 68.9250 MHz
  • Channel 38 - 72.9875 MHz / 68.9375 MHz
  • Channel 39 - 73.0000 MHz / 68.9500 MHz
  • Channel 40 - 73.0125 MHz / 68.9625 MHz
  • Channel 41 - 73.0250 MHz / 68.9750 MHz
  • Channel 42 - 73.0375 MHz / 68.9875 MHz
  • Channel 43 - 73.0500 MHz / 69.0000 MHz
  • Channel 44 - 73.0625 MHz / 69.0125 MHz
  • Channel 45 - 73.0750 MHz / 69.0250 MHz
  • Channel 46 - 73.0875 MHz / 69.0375 MHz
  • Channel 47 - 73.1000 MHz / 69.0500 MHz
  • Channel 48 - 73.1125 MHz / 69.0625 MHz
See also:
