Part 15 Beacons
Overview
There are three below-30 MHz bands available to hobbyists for Part 15 transmitters:
- 160 - 190 kHz
 - 13553 - 13567 kHz (often referred to as 13560 kHz, 13.56 MHz or 22 meters, shared with ISM)
 - 26960 - 27280 kHz (11 meters, shared with CB, RC, data links/telemetry and ISM from 26957 - 27283 kHz)
160-190 kHz Part 15 Beacons
- 167.180 LC Sacramento CA
 - 181.818 JH Florence SC
 - 182.448 R Keeler CA
 - 183.500 WD2XFJ Burbank CA
 - 185.100 22A Baraga MI
 - 185.185 SIW Oswego IL
 - 185.290 KT Oswego KS
 - 185.297 TAG Raymond ME
 - 185.299 SIW Oswego IL
 - 185.303 SJ East Haven CT
 - 185.650 WE2XEB Penn Yan NY
 - 186.204 MLS Massilon OH
 - 187.015 J La Crescenta CA
 - 187.507 WI Aiken SC
 - 188.830 EAR Saltford, ON
13560 kHz Part 15 Beacons
13553 kHz - 13567 kHz
- 13554.000 AZ Oro Valley AZ
 - 13555.414 TAG Holden MA
 - 13555.420 JIM Dallas TX
 - 13555.430 SIW Elgin IL
 - 13555.440 SIW Elgin IL
 - 13555.450 MP London ON
 - 13555.462 EH East Haven CT
 - 13555.472 7P Ajo AZ
 - 13555.500 NC Stanfield NC
 - 13555.528 EDJ Monroe GA
 - 13555.920 WV Richwood, WV
 - 13555.98 TSN
 - 13556.20 NOM NOM (not 24/7)
 - 13556.600 OH Findlay OH
 - 13557.50 PBJ Tracey City TN
 - 13557.800 PLM [UNKNOWN]
 - 13558.2 PVC
 - 13558.510 AJO Ajo AZ
 - 13558.98 NHVT
 - 13561.100 17331PA Hanover, PA
 - 13562.080 NDB
 - 13562.35 IPA Sandwich,MA
 - 13562.950 SZX Macomb IL
 - 13563.000 RR
 - 13563.55 PCO Colorado
 - 13564.280 T Sun City CA
 - 13561.55 WMD (not 24/7)
 - 13562.80 GNK Madison WI
 - 13564.20 KEPR Everton,AR
 - 13564.72 ABBY
 - 13564.82 DYG San Tan Valley AZ
 - 13564.965 RF Grid EM96 NC
 - 13565.04 K6FRC Patterson CA
 - 13565.69 MR.X Parts Unknown
 - 13566.07 KAH
 - 13566.20 AMA Hamilton ON
 - 13566.22 WAS North Carolina
 - 13566.40 RVA Richmond, VA
 - 13566.50 ODX
26960 - 27280 kHz Part 15 Beacons
No Part 15 compliant 27MHz beacons reported.
See the 11 meter / 27 MHz CB beacons page, HF beacons and the Part 95 Subpart C 27MHz RC - the 26-28 MHz RCRS remote control pages for additional information on beacons in this band. Numerous Part 15 devices, Part 95 systems and on-site pager systems, wide-area paging and data link networks operating in this band may act as de facto beacons.
22 meter band beacon kit
FCC Regulations
160 - 190 kHz
13560 kHz
26960 - 27280 kHz
- Radio beacons - general topic
 - Radio propagation beacons
 - LowFER
 - HiFER
 - High Frequency Beacon
 - Part 15 Beacons
 - Letter beacon
 - Fishnet beacon
