High Frequency Beacon
| Freq (kHz) | Station ID | Operation Notes | |
| 2097 | A | Arizona (15 watts) - 'A' ident or malfunctions as series of dits - 15 watts max., 24/7 (back on the air, recently reported on 6 April 2009) | |
| 3450 | OK | OK | |
| 4011.8 | FL | Dasher | |
| 4078 | W | 300-400 mW Inverted L night time only Location: Colorado | |
| 4077.27 | MO | Solar 200 mW 118ft end fed wire 24/7 Location: Oklahoma | |
| 4079 | TMPnnn | The TEMPERATURE BEACON - Temperature in deg. F. in s.w. Arizona - sends 'TMP' then 2 - 3 digit temp. in CW every 10 seconds. 1 watt | |
| 4089 | . | About 80 dits/minute, Death Valley N.P., 24/7, 500 mW to inv. vee. dipole | |
| 4094.2 | PA | Solar power 200 mW Dipole 24/7 Location: Arkansas | |
| 4094.8 | Dasher | Sputnick - 60 dash/min, night only Location: West Virginia | |
| 4096 | 6 dots 1 Dash | ||
| 4096.1 | Dasher | 4.5 sec long dashes (about 13 dashes per min.) Joshua Tree N.P.- big signal - north-facing dipole ('Coxie') 24/7 | |
| 4096.25 | Dasher | 1 sec dash (about 30 per min.) Joshua Tree N.P., 400 mW to inverted vee, 24/7 ('Hexie') | |
| 4096.6 | Dasher | 2 sec. dash (about 16 per minute) Mojave Nat. Preserve-400 mW to inverted vee, 24/7 ('Kelsie') | |
| 4097.2 | Dasher | 55 dashes per minute with chirp when sun is low; day-only, Inyo County, Calif. near DVNP at 5300 ft. elevation ('Inyo-whooper'), inv. vee., 0.5w | |
| 4102.3 | W... | The WIND BEACON - sends 'W' ident and series of dits - each dit correlating to a turn of its anenometer, so if it is windy in the s.e. California desert, it sends lots of dits; and no wind, no dits. | |
| 4194 | MX | Xtal controlled milliwatt beacon operated occasionally in europe. Sometimes sends straight carrier instead of ID. | |
| 4608 | MXC | Xtal controlled milliwatt beacon operated occasionally in europe. Sometimes sends straight carrier instead of ID. Sister beacon to MX. | |
| 5157.6 | Dasher | BLINKY 200 mW Dipole 24/7 Location: Florida | |
| 5499.13 | WA | Dasher | |
| 5678.4 | Dasher | PIKE solar/battery 100 mW Dipole 24/7 Location: Colorado "Honker" | |
| 6549.3 | FL | 300 mW Dipole 24/7 Location: Florida | |
| 6626.2 | S | About 60-200 dashes per min., Inyo COunty, Calif. near DVNP, sun-only, ~200 mW ('Rocky') | |
| 6626.4 | Dits | Fast 'drippy' sounding dits about 100/min., Mojave N.P., sun-only, 1.5 watts ('Rainy') | |
| 6700.4 | Dasher | About 62 dashes per min., 24/7, Joshua Tree N.P. (Hexy2k) | |
| 8001.5 | S | S.W. Arizona, sun-only, 1 watt. strong signal daytimes | |
| 8003 | Dasher | Solar/battery dipole 24/7 Location: Colorado "Pike JR" 84 dashes/min | |
| 8188.7 | W | Solar/battery 100 mW dipole daylight /7 Location: Colorado | |
| 8211.7 | OR | ||
| 10236.7 | FL | Dasher | |
| 11002.7 | CO | Solar battery 300 mW dipole 24/7 Location: Colorado |
External Links
