Pirate Beacons
Revision as of 22:56, 3 May 2009 by Tube Shortwave (Talk | contribs)
A high frequency (HF) unlicensed beacon that does not follow government regulations for operation (such as Part 15), and are technically illegal.
There are many of these beacons, quite a few are run as propagation experiments. Due to their nature, the exact location of these stations is generally not known, although many are believed to operate from remote locations in the deserts of the southwest United States, like California's Mojave. Likewise, these stations tend to suddenly appear and disappear from the air. Most run with very low power levels of just fractions of a watt, and are often solar powered, so they can be hidden in open areas. Some are switched via a photocell, so they only operate at night to take advantage of nighttime HF propagation characteristics, running off of a battery that is charged during the daytime by a solar panel.
3450 OK OK
4011.8 FL Dasher
4062 C Very drifty, but slow drift, logged form 4052 to 4063. Its morse is not timed correcctly, it is probably sending a C with a short first dah (longer than dit, shorter than dah), but it could be an ER with a long dit, or a TR with a short dah. 24/7 Location: SW, probably CA
4078 W 300-400 mW Inverted L night time only Location: Colorado
4094.8 Dasher Sputnick - 60 dash/min, night only Location: West Virginia
4096 6 dots 1 Dash
4102.3 W... The WIND BEACON - sends 'W' ident and series of dits - each dit correlating to a turn of its anenometer, so if it is windy in the s.e. California desert, it sends lots of dits; and no wind, no dits.
4194 MX Xtal controlled milliwatt beacon operated occasionally in europe. Sometimes sends straight carrier instead of ID.
4608 MXC Xtal controlled milliwatt beacon operated occasionally in europe. Sometimes sends straight carrier instead of ID. Sister beacon to MX.
5484 SD San Diego, CA
5499.13 WA Dasher
8003 Dasher Solar/battery dipole 24/7 Location: Colorado "Pike JR" 84 dashes/min
8211.7 OR
10236.7 FL Dasher
External Links
