LowFER
Revision as of 05:52, 25 July 2011 by Strange Attractor (Talk | contribs)
(diff) โ† Older revision | Latest revision (diff) | Newer revision โ†’ (diff)
A LowFER is a low frequency radio beacon (or occasionally other type of station), run by a hobbyist under FCC Part 15 rules.
FCC rules
ยง 15.217 Operation in the band 160โ€“190 kHz.
(c) All emissions below 160 kHz or above 190 kHz shall be attenuated at least 20 dB below the level of the unmodulated carrier. Determination of compliance with the 20 dB attenuation specification may be based on measurements at the intentional radiator's antenna output terminal unless the intentional radiator uses a permanently attached antenna, in which case compliance shall be demonstrated by measuring the radiated emissions.
