Signal Identification
Crude mock-up of the start of a signal identification section of the wiki.
Guidelines, goals, structure, and how to use described here.
Non DATA Signals
Communications Modes
| Mode | Frequency Range (kHz) | Bandwidth (kHz) | Shift (Hz) | Number of Tones | Key Features | Sources | Recording | Spectrum Image |
| AM | All Frequencies in the HF Range | Typically 2.6 to 10.0 kHz, can be wider or narrower | Not Applicable | Not Applicable | Carrier present in center of signal, audio typically mirrored left and right of the carrier | World wide | AM recording link here | |
| CW
(Morse Code) | All Frequencies in the HF Range | Very narrow, potentially less than 50 Hz | Not Applicable | Not Applicable | Line or broken line on the waterfall, no sidebands, may show wider "key clicks" at the start and stop of each dot and dash | World wide | CW recording link here | |
| LSB | All Frequencies in the HF Range | Typically 2.4 to 3.0 kHz, can be wider or narrower | Not Applicable | Not Applicable | No carrier present in Spectrum, audio typically bunched to towards the right (low audio frequency) | World wide | LSB recording link here | |
| USB | All Frequencies in the HF Range | Typically 2.4 to 3.0 kHz, can be wider or narrower | Not Applicable | Not Applicable | No carrier present in Spectrum, audio typically bunched to towards the left (low audio frequency) | World wide | USB recording link here | |
Non Communications Modes
| 16 x 64 Sounder (nickname, official name or designation not known) | Below 4000 to above 30000 observed | 3 kHz | Not Applicable | Not Applicable | FMCW transmission, changes sweep rates in 16 steps, resulting in 16 different sounds per transmission, pilot tone precedes each rate change | Unknown | File:16x64 sounder.mp316 x 64 sounder recording link here | |
| PLUTO radar (possible offical name, PLUTO II, suggested by open source documents) | 8000 to 38000 | 3 to 40 kHz, depending on specific operating conditions | Not Applicable | Not Applicable | FMCW transmission, presenting a wide signal equal to the swept (chirped) width, sweep rate creates a pulsed sound affect | British Sovereing base of Akrotiri, Island of Cyprus | PLUTO recording link here | |
Need to put some kind of break here, a line or something, to sep out the Non DATA from DATA
Probably need to put a desription of what is meant by DATA Signals in this area.
DATA Signals
FSK Modes
MFSK Modes
PSK Modes
SELCAL Modes
Image Modes
