Signal Identification
Still under construction, call this a late Beta version, almost ready for prime time
Why is this Guide here?
Today's online receiver nodes (from services like Globaltuners, SDR-Radio.com, and WebSDR.org) mean that more people than ever potentially have access to monitor the HF spectrum. Often people with no prior exposure to HF radio or shortwave listening first gravitate to these kinds of services, as they take no investment in equipment to start using. They then face a sometimes steep learning curve of "what am I hearing, and what are these things on the radio".
If you look at the tables of the guide you will see it is divided into three types of signals, "Non DATA Signals", "DATA Signals", and "Unidentified Signals". Each section can be further broken down into sub categories.
Non DATA Signals:
DATA Signals:
Unidentified Signals:
Unidentified Signals are signals that have not yet been identified. As they are reported or added they will be assigned an "HFU UNID" sequential 3 digit number. This number means nothing, and is just a way to track information and discussions about that signal on the HFUnderground HF Mystery Signals board.
These UNID signals may appear in more than one segment of the guide, they will be in the Unidentified Signals segment, but may also be shown under their modulation types. For example, an Unknown signal that is obviously an FSK signal may be in both the Unidentified Signals area, and the FSK area, but in both cases they will carry the same UNID number.
Basic information shown for all Entries
Mode
Frequency Range (kHz)
Bandwidth (kHz)
Shift (kHz)
Number of Tones
Key Features
Sources
Recording
Spectrum Image
"Spectrum Image" is a 200 pixel wide expandable thumbnail image of the signal, often either the spectrum or a waterfall / histogram of some kind. Typically the full size version of this images is at least 640 x 480.
The Signals
Non DATA Signals
Communications Modes
Mode | Frequency Range (kHz) | Bandwidth (kHz) | Shift (Hz) | Number of Tones | Key Features | Sources | Recording | Spectrum Image |
AM | All Frequencies in the HF Range | Typically 2.6 to 10.0 kHz, can be wider or narrower | Not Applicable | Not Applicable | Carrier present in center of signal, audio typically mirrored left and right of the carrier | World wide | AM recording link here | ![]() |
CW
(Morse Code) | All Frequencies in the HF Range | Very narrow, potentially less than 50 Hz | Not Applicable | Not Applicable | Line or broken line on the waterfall, no sidebands, may show wider "key clicks" at the start and stop of each dot and dash | World wide | CW recording link here | ![]() |
LSB | All Frequencies in the HF Range | Typically 2.4 to 3.0 kHz, can be wider or narrower | Not Applicable | Not Applicable | No carrier present in Spectrum, audio typically bunched to towards the right (low audio frequency) | World wide | LSB recording link here | ![]() |
USB | All Frequencies in the HF Range | Typically 2.4 to 3.0 kHz, can be wider or narrower | Not Applicable | Not Applicable | No carrier present in Spectrum, audio typically bunched to towards the left (low audio frequency) | World wide | USB recording link here | ![]() |
Non Communications Modes
16 x 64 Sounder (nickname, official name or designation not known) | Below 4000 to above 30000 observed | 2.5 kHz | Not Applicable | Not Applicable | FMCW transmission, changes sweep rates in 16 steps, resulting in 16 different sounds per transmission, a pilot tone may precede each rate change but is not always present | Unknown | Media:16x64_sounder.mp3
16 x 64 sounder recording | ![]() |
29B6 radar "Kontainer" | 6000 to at least 32000 | 4 to 28 kHz observed, unknown limits, width depending on specific operating conditions | Not Applicable | Not Applicable | FMOP transmission, presenting a wide signal equal to the swept (chirped) width, sweep rate creates a pulsed sound affect, easily confused with British PLUTO radar | Kovylkino, Mordovia, Russia | Media:29B6.mp3
29B6 recording, first portion wide audio, second narrow, as would be heard on many receivers | ![]() |
CODAR (Coastal Ocean Dynamics Applications Radar), a specialized radar used to study ocena currents and waves | 4000 to 27000 | 16 to 240 kHz, depending on band, higher frequencies mean wider swept widths | Not Applicable | Not Applicable | FMOP or FMICW transmission, presenting a wide signal equal to the swept (chirped) width, sweep rate can create "swooshing" sounds on radio, pulsed transmission can give the sound a rough quality | World wide, hundreds of locations around the World | Media:CODAR.mp3
CODAR recording, first 40 seconds in USB, next 40 in AM, last 40 in LSB | ![]() |
PLUTO radar (possible offical name, PLUTO II, suggested by online documents) | 8000 to 38000 | 3 to 40 kHz, depending on specific operating conditions | Not Applicable | Not Applicable | FMCW transmission, presenting a wide signal equal to the swept (chirped) width, sweep rate creates a pulsed sound affect, easily confused with Russian 29B6 radar | British Sovereing base of Akrotiri, Island of Cyprus | Media:PLUTO_50Hz.mp3
Media:PLUTO_25Hz.mp3 PLUTO recording link here | ![]() |
DATA Signals
FSK Modes
CIS 36-50, BEE, T-600 | All Frequencies in the HF Range | 0.085 to 0.500 kHz (85 to 500 Hz depending on mode) | 85, 125, 250, or 500, only one shift used at a time | 2 | Appears as two lines on waterfall, seperated by the shift, normally encrypted, at idle presents 36 Bd | Used primarily by Russian Navy, a mode of the T-600 modem | Media:CIS_36_50.mp3
CIS 36-50 recording | 200px |
CIS 50-50, BEE, T-600 | All Frequencies in the HF Range | 0.200 to 0.250 kHz (200 or 250 Hz depending on mode) | 200 or 250 Hz, only one shift used at a time | 2 | Appears as two lines on waterfall, seperated by the shift, normally encrypted, at idle presents 50 Bd | Used primarily by Russian Navy, a mode of the T-600 modem | Media:CIS_50_50.mp3
CIS 50-50 recording | ![]() |
STANAG 4481 FSK | All Frequencies in the HF Range | 0.85 kHz (850 Hz) | 850 Hz | 2 | Appears as two lines on waterfall, seperated by the shift, normally encrypted | Used by NATO forces world wide | Media:S4481_FSK.mp3
4481 FSK recording | ![]() |
MFSK Modes
MIL STD 181-141A ALE | All Frequencies in the HF Range | 1.75 kHz (1750 Hz) | 250 Hz | 8 | Appears as eight broken lines on waterfall, seperated by the shift, normally encrypted, rhythmic sound | Used world wide | Media:ALE_SND.mp3
MIL STD 188-141A sounding recording | ![]() |
JT-65 JT65 | All ham bands | 0.175 kHz (175 Hz) | ~2.65 Hz | 65 | Appears as stepped lines on the waterfall, has a musical sound to it, can be confused by new listeners for a polytone numbers station like XPA | Used world wide | Media:JT65.mp3
JT65 recording | ![]() |
PSK Modes
(Chinese) CHN 4+4 | All Frequencies in the HF Range | 2.9 kHz | 300 Hz, with 450 Hz gap | 8 | Appears as 8 PSK tones on the waterfall, noticeable 450 Hz gap between tones 4 and 5 | Used by Chinese military | Media:CHN4_4.mp3
CHN 4+4 recording | ![]() |
CIS12, Fire, MS5, AT3004D, AT3104D | All Frequencies in the HF Range | 3.3 kHz | 200 Hz (12 tone) or 120 Hz (20 tone) | 12 or 20 | Appears as 12 or 20 PSK tones on the waterfall, with 3300 Hz Doppler (pilot) tone | Used primarily by Russian military | Media:CIS12.mp3
CIS12 recording | ![]() |
PSK31 | Mostly in the ham radio bands | Used world wide | Media:psk31_recording.mp3 |
SELCAL Modes
Image Modes
Slow Scan TV SSTV | Mostly in the ham radio bands | 1100-2300 Hz | Distinctive burst of VIS code bits at the beginning, then a rhythmic sound as the scan lines of video are sent | Used world wide | Media:Robot36C.WAV | ![]() | ||
Weather Fascimile Fax | All Frequencies in the HF Range | 1500-2300 Hz | Rhythmic sound as the scan lines of video are sent twice a second | Used world wide | Media:Fax_signal.mp3 | ![]() | ||
Hellschreiber Hellschreiber | Mostly in the ham radio bands | Scratchy sound as the pixels of each character are sent | Used world wide |
HFU UNID001
Sweepers | All Frequencies in the HF Range, but primarily noticed above 10000 kHz | Sub 2 kHz to over 200 kHz | Not Applicable | Not Applicable | Various shapes, but typically presents as a sweeping, unstable, signal on a waterfall | Unknown, a strong theory is these are related to industrial processes, possibly RF Welding | Media:UNID001_Sweepers.mp3
Sweeper recording, multple examples | ![]() |
HFU UNID002
Pips | All Frequencies in the HF Range | Typically very narrow, as CW, but occasionally with light 3 kHz modulation | Not Applicable | Not Applicable | Appears as a periodic dit or dash on a waterfall with fixed spacing between Pips, typical lengths are 0.063 to 1.5 sec, spacing has ranged from 3.0 to 27 seconds | Unknown | Media:UNID002_Pips.mp3
Pips recording, multiple examples | ![]() |
