HF pagers
In the United States, Part 95 of the FCC rules allow use of the six 26 MHz/27 MHz RC frequencies for high power control, supervision, data link and "attention getting" devices. Mean (average) power limit is 4 watts on 26.995 MHz, 27.045 MHz, 27.095 MHz, 27.145 MHz, 27.195 MHz and 25 watts on 27.255 MHz. The majority of high power systems use 27.255 MHz - however some do transmit 4 watts on 26.995 MHz. There is also extensive Part 15 usage of these frequencies for low-power R/C model control. Higher power levels are used by professional grade systems. Most higher-end remote control/radio control devices use the 72 MHz/75 MHz frequencies (there 0.75 watts is the maximum power output) or the unlicensed 2.4 GHz band. However, there remains considerable use of 26-27 MHz for data link, remote sensor monitoring and other similar purposes due to the high power available for unlicensed users and excellent propagation characteristics for point-to-point data networks.
| Frequency | Remarks |
| 26.200 MHz | UK Paging on-site pager |
| 26.500 MHz | Paging, heard in Europe, noted use in Holland |
| 26.815 MHz | UK Paging on-site pager |
| 27.075 MHz | UK data frequency, UK low-power R/C "Orange" telemetry (100 mw limit) |
| 27.255 MHz | Linear Controls "Xtended Range Wireless" telemetry/control system, 10 watts FSK mode |
| 27.255 MHz | RadioShack 7-watt FSK paging system on-site paging system frequency (legal under Part 95 of FCC rules) |
| 27.510 MHz | Paging, German allocation pager 27 MHz |
| 27.650 MHz | Data link (US East Coast based), possibly US military |
Keywords:
26 MHz pager 27MHz paging 27.255 MHz data link 27 MHz data transmitter 27007 kHz 27255 kHz FCC Part 15 Part 95 POCSAG 26.995MHz 27.045MHz 27.095MHz 27.145MHz 27.195MHz 27.225MHz 27.235MHz 27.245MHz 27.255MHz 27.270MHz 27.12 MHz ISM 27MHz band paging Long Range Systems 467.750 MHz
