HF pagers
26.995, 27.045, 27.095, 27.145 and 27.195 MHz are all RC exclusive frequencies and voice transmissions are not allowed. However, these frequencies are often used as a "secret channel" or "A channel" by CBers and freeband operators. 27.255 MHz is CB channel 23 and data transmissions must co-exist with voice traffic on the same frequency. This likely explains the 25 watt power limit on 27.255 compared to the 4 watt power limit on the original 5 R/C channels. The original five can trace their roots back to the origins of the CB radio service - when the band was first allocated as 26.96 MHz to 27.23 MHz the FCC included five model control/data channels 35 kHz from the band edges with 50 kHz spacing between each RC channel. 27.255 was added later as a shared channel with CB channel 23.
There is also extensive Part 15 usage of these frequencies for low-power R/C model control. Higher power levels are used by professional grade systems. Most higher-end remote control/radio control devices use the 72 MHz and 75 MHz frequencies (where 0.75 watts is the maximum power output) or the unlicensed 2.4 GHz band. However, there remains considerable use of 26-27 MHz for data link, remote sensor monitoring and other similar purposes due to the high power available for unlicensed users and excellent propagation characteristics for point-to-point data networks.
| Frequency | Remarks |
| 26.200 MHz | UK Paging on-site pager |
| 26.500 MHz | Paging, heard in Europe, noted use in Holland |
| 26.815 MHz | UK Paging on-site pager |
| 27.075 MHz | UK data frequency, UK low-power R/C "Orange" telemetry (100 mw limit) |
| 27.255 MHz | Linear Controls "Xtended Range Wireless" telemetry/control system, 10 watts FSK mode |
| 27.255 MHz | RadioShack 7-watt FSK paging system on-site paging system frequency (legal under Part 95 of FCC rules) |
| 27.510 MHz | Paging, German allocation pager 27 MHz |
| 27.650 MHz | Data link (US East Coast based), possibly US military |
Keywords:
26 MHz pager 27MHz paging 27.255 MHz data link 27 MHz data transmitter 27007 kHz 27255 kHz FCC Part 15 Part 95 POCSAG 26.995MHz 27.045MHz 27.095MHz 27.145MHz 27.195MHz 27.225MHz 27.235MHz 27.245MHz 27.255MHz 27.270MHz 27.12 MHz ISM 27MHz band paging Long Range Systems 467.750 MHz
