KiwiSDR
Revision as of 17:43, 3 November 2018 by ChrisSmolinski (Talk | contribs)
Overview
Placeholder page
KiwiSDRs run by HFU Members
- Westminster, MD USA http://sdr.hfunderpants.com:8073
KiwiSDRs Tips
Set Static IP Address
GPS Antenna
The antenna that comes with the KiwiSDR works, but can be marginal, especially when used indoors. I bought this antenna from Amazon, and it seems to work better. I also found that it helps tremendously to have the antenna sitting on a metal ground plane. A simple small aluminum baking sheet works great. I carefully adjusted the location of the antenna on the sheet, as well as the location of both (they are sitting on a shelf) for maximum signal(s) from the GPS satellites.
