HF pagers
Frequency List
| Frequency | Remarks |
| 26.200 MHz | UK Paging on-site pager |
| 26.500 MHz | Paging, heard in Europe, noted use in Holland |
| 26.815 MHz | UK Paging on-site pager |
| 26.955 MHz | Fixed allocation - often used for point-to-point links outside USA |
| 27.075 MHz | UK data frequency, UK low-power R/C "Orange" telemetry (100 mw limit) |
| 27.255 MHz | Linear Controls "Xtended Range Wireless" telemetry/control system, 10 watts FSK mode |
| 27.255 MHz | RadioShack 7-watt FSK paging system on-site paging system frequency (legal under Part 95 of FCC rules) |
| 27.510 MHz | Paging, German allocation pager 27 MHz |
| 27.650 MHz | Data link (US East Coast based), possibly US military |
| 27.905 MHz | R/C and data link systems, local paging - Czech Republic - 1 watt power limit max 8.5 kHz bandwidth |
| 27.915 MHz | R/C and data link systems, local paging - Czech Republic - 1 watt power limit max 8.5 kHz bandwidth |
| 27.975 MHz | R/C and data link systems - Czech Republic - 100mw power limit 8.5 kHz bandwidth limit |
| 27.985 MHz | R/C and data link systems - Czech Republic - 100mw power limit 8.5 kHz bandwidth limit |
| 27.995 MHz | R/C and data link systems - Czech Republic - 100mw power limit 8.5 kHz bandwidth limit |
Keywords:
26 MHz pager 27MHz paging 27.255 MHz data link 27 MHz data transmitter 27007 kHz 27255 kHz FCC Part 15 Part 95 POCSAG 26.995MHz 27.045MHz 27.095MHz 27.145MHz 27.195MHz 27.225MHz 27.235MHz 27.245MHz 27.255MHz 27.270MHz 27.12 MHz ISM 27MHz band paging Long Range Systems 467.750 MHz RCRS Remote Control Radio Service 25 watt 27.255 data 27MHz data link 100mw low power data link IOT low frequency 900 MHz 151.820 MHz 151.880 MHz 151.940 MHz 154.570 MHz 154.600 MHz MURS data datalink 154MHz 151MHz license free long range 10 watt FSK signal Linear Systems WAVE lightning detector remote monitoring link 27MHz CB radio frequency list HFUnderground Community Audio Distribution Service CADS Wireless Public Address System WPAS 27.995 MHz 26.000 MHz 26MHz paging pager EU harmonized radio bands allocation 27.5 MHz 27500 kHz
