Revision as of 17:36, 21 December 2018 by R4002 (Talk | contribs)
The 26995-27255 frequencies may be used for data links, remote sensing and other niche purposes that the 72 MHz and 75 MHz frequencies may not be used for. See the HF pagers page for more information.
  • 27.255 MHz - 27255 kHz - Blue (shared with channel 23)
Many wireless mice and keyboards use 27.145 MHz. Low power remote control devices may fall under Part 15 rules instead of Part 95. 72-76 MHz band is shared with the mid-band VHF business radio band
The following channels are allocated to remote controlled aircraft, 750 mW max power:
  • 72.01
  • 72.03
  • 72.05
  • 72.07
  • 72.09
  • 72.11
  • 72.13
  • 72.15
  • 72.17
  • 72.19
  • 72.21
  • 72.23
  • 72.25
  • 72.27
  • 72.29
  • 72.31
  • 72.33
  • 72.35
  • 72.37
  • 72.39
  • 72.41
  • 72.43
  • 72.45
  • 72.47
  • 72.49
  • 72.51
  • 72.53
  • 72.55
  • 72.57
  • 72.59
  • 72.61
  • 72.63
  • 72.65
  • 72.67
  • 72.69
  • 72.71
The following channels are allocated to remote controlled boats, 750 mW max power:
  • 75.41
  • 75.43
  • 75.45
  • 75.47
  • 75.49
  • 75.51
  • 75.53
  • 75.55
  • 75.57
  • 75.59
  • 75.61
  • 75.63
  • 75.65
  • 75.67
  • 75.69
  • 75.71
  • 75.73
  • 75.75
  • 75.77
  • 75.79
  • 75.81
  • 75.83
  • 75.85
  • 75.87
  • 75.89
  • 75.91
  • 75.93
  • 75.95
  • 75.97
  • 75.99
  • 34.950 MHz - Channel 55
  • 34.960 MHz - Channel 56
  • 34.970 MHz - Channel 57
  • 34.980 MHz - Channel 58
  • 34.990 MHz - Channel 59
  • 35.000 MHz - Channel 60
  • 35.010 MHz - Channel 61
  • 35.020 MHz - Channel 62
  • 35.030 MHz - Channel 63
  • 35.040 MHz - Channel 64
  • 35.050 MHz - Channel 65
  • 35.060 MHz - Channel 66
  • 35.070 MHz - Channel 67
  • 35.080 MHz - Channel 68
  • 35.090 MHz - Channel 69
  • 35.100 MHz - Channel 70
  • 35.110 MHz - Channel 71
  • 35.120 MHz - Channel 72
  • 35.130 MHz - Channel 73
  • 35.140 MHz - Channel 74
  • 35.150 MHz - Channel 75
  • 35.160 MHz - Channel 76
  • 35.170 MHz - Channel 77
  • 35.180 MHz - Channel 78
  • 35.190 MHz - Channel 79
  • 35.200 MHz - Channel 80
  • 35.210 MHz - Channel 81
  • 35.220 MHz - Channel 82
  • 35.230 MHz - Channel 83
  • 35.240 MHz - Channel 84
  • 35.250 MHz - Channel 85
  • 35.260 MHz - Channel 86
  • 35.270 MHz - Channel 87
  • 35.280 MHz - Channel 88
  • 35.290 MHz - Channel 89
  • 35.300 MHz - Channel 90
Maximum output power 100mW or 0.1 watts. 10 kHz bandwidth - many EU/CEPT countries have additional allocations for R/C purposes, including 26/27 MHz and allocations in the 30 MHz, 31 MHz, 35 MHz, 36 MHz, 40 MHz and other bands into the VHF/UHF range.
  • 27.095 MHz - 27095 kHz - European CEPT designator A3
