SHARES
SHARES Frequency List SHARES Frequencies List SHARES HF-SSB Frequencies Emergency Management HF Frequency List
SHARES is a multi-agency system that used frequencies assigned to several different agencies and organizations. It conducts weekly radio check nets every Wednesday at 1600 UTC on 6765 USB, 6845 USB and 6910 USB (and likely other frequencies at other times).
Since these frequencies are of interest to utility monitors and are often heard, I wanted to compile a list of frequencies in use:
All frequencies are "dial frequencies" in USB mode, transmissions made in USB voice and MT63 digital mode. There are apparently other 5 MHz band frequencies in use, including ones that match up with 60 meter amateur band channels. Frequencies with associated notes are frequencies noted in use by myself (confirmed usage and remarks). Note that SHARES does use ALE technology. Most frequencies are in the fixed/mobile bands.
National Communications System (NCS) Shared Resources (SHARES) High Frequency Radio Program - As an additional means of HF communications, Federal agencies may use the Shared Resources (SHARES) HF Radio Program as a means of passing message traffic when their own networks are not available.
- 4458 kHz USB - SHARES Region 4 SHARES Northeast Region Hurricane Net heard here
- 4490 kHz USB - MARS frequency
- 4618 kHz USB
- 4636 kHz USB - Civil Air Patrol CAP HF Frequency (primary user)
- 5063.5 kHz USB
- 5429 kHz USB
- 5711 kHz USB
- 5760 kHz USB
- 6765 kHz USB - SHARES North Primary
- 6800 kHz USB
- 6845 kHz USB - SHARES Northeast SHARES Region 4
- 6910 kHz USB - SHARES Central SHARES Region 6
- 6912 kHz USB - SHARES Central alternate frequency (primary 6910 USB)
- 6915 kHz USB - SHARES Central alternate frequency (primary 6910 USB)
- 7391 kHz USB
- 7403.5 kHz USB
- 7615 kHz USB - Civil Air Patrol / CAP use as well
- 7642 kHz USB
- 7792 kHz USB
- 7791 kHz USB
- 7991 kHz USB
- 9057 kHz USB
- 9064 kHz USB
- 9106 kHz USB
- 11108 kHz USB
- 11217 kHz USB
- 13242 kHz USB
- 13426.5 kHz USB
- 14396.5 kHz USB - Daytime FEMA use, SHARES admin net
- 14928.5 kHz USB
- 15094 kHz USB
- 17458 kHz USB
- 17487 kHz USB
- 20107 kHz USB
- 25354 kHz USB - Civil Air Patrol / CAP use
- 26617 kHz USB - Civil Air Patrol / CAP use
- 26620 kHz USB - Civil Air Patrol / CAP use - old CAP local "talkaround" frequency 26.620 MHz AM
- 26812 kHz USB - often local use only
- 27546 kHz USB - often local use only - CAP frequency as well
- 29894 kHz USB - often local use only
