Dead Hand System
Revision as of 15:38, 11 February 2019 by The Wrigley Guerrilla (Talk | contribs)
Dead Hand (Russian: Система «Периметр», Systema "Perimetr", lit. "Perimeter" System, with the GRAU Index 15E601, Cyrillic: 15Э601),[1] also known as Perimeter,[2] is a Cold War-era automatic nuclear weapons-control system used by the Soviet Union.[3] General speculation from insiders alleges that the system remains in use in the post-Soviet Russian Federation as well.[4][5] An example of fail-deadly and mutual assured destruction deterrence, it can automatically trigger the launch of the Russian intercontinental ballistic missiles (ICBMs) by sending a pre-entered highest-authority order from the General Staff of the Armed Forces, Strategic Missile Force Management to command posts and individual silos if a nuclear strike is detected by seismic, light, radioactivity, and overpressure sensors even with the commanding elements fully destroyed. By most accounts, it is normally switched off and is supposed to be activated during dangerous crises only; however, it is said to remain fully functional and able to serve its purpose whenever it may be needed.[6] A similar system existed in the U.S. known as the AN/DRC-8 Emergency Rocket Communications System (ERCS).
System concept
"Perimeter" appeared as an alternative system for all units armed with nuclear weapons. It was meant to be a backup communication system, in case the key components of the "Kazbek" command system and the link to the Strategic Missile Forces are destroyed by a first-strike in accordance with the concept developed in the US called "Limited nuclear war".[7]
In order to ensure its functionality the system was originally designed as fully automatic, and with the ability[8] to decide on the adequate retaliatory strike on its own with no (or minimal) human involvement in the event of an all-out attack.
Working principles
Upon activation and determination of the happening of a nuclear war, the system sends out a 15P011 command missile with a special 15B99 warhead which passes commands to open all silos and all command centers of the RVSN with appropriate receivers in flight. The command missile system is similar with the US Emergency Rocket Communications System.
Components
Commanding rocket:
It was designed to lie semi-dormant until switched on by a high official in a crisis. Then it would begin monitoring a network of seismic, radiation, and air pressure sensors for signs of nuclear explosions. Before launching any retaliatory strike, the system had to check off four if/then propositions: If it was turned on, then it would try to determine that a nuclear weapon had hit Soviet soil. If it seemed that one had, the system would check to see if any communication links to the war room of the Soviet General Staff remained. If they did, and if some amount of time—likely ranging from 15 minutes to an hour—passed without further indications of attack, the machine would assume officials were still living who could order the counterattack and shut down. But if the line to the General Staff went dead, then Perimeter would infer that apocalypse had arrived. It would immediately transfer launch authority to whoever was manning the system at that moment deep inside a protected bunker—bypassing layers and layers of normal command authority.[9]
Motivation
The purpose of the Dead Hand system, as described in the book of the same name,[10][11] was to maintain a second-strike capability, by ensuring that the destruction of the Soviet leadership would not have prevented the Soviet military from releasing its weapons.[3]
The Soviet Union took steps to ensure that nuclear retaliation, and hence deterrence, remained possible even if its leadership were to be destroyed in a surprise attack.[3] In contrast, Thompson argues that Perimeter's function was to limit acts of misjudgment by political or military leadership in the tight decision-making window between SLBM/cruise missile launches and impact.[12] He quotes Zheleznyakov on the purpose of Perimeter being "to cool down all these hotheads and extremists. No matter what was going to happen, there still would be revenge."[12]
Operation
In 1967, the Soviet Union first attempted to create a system, called "Signal", which they could use to create 30 premade orders from their headquarters to the missile units.[3] Although the system still was not completely automatic, their intent was no different.
In the early 1990s, several former high-ranking members of the Soviet military and the Central Committee of the Communist Party, in a series of interviews to the American defense contractor BDM, admitted the existence of the Dead Hand, making somewhat contradictory statements concerning its deployment.[13]
Colonel General Varfolomey Korobushin, former Deputy Chief of Staff of Strategic Rocket Forces, in 1992 said that the Russians had a system, to be activated only during a crisis, that would automatically launch all missiles, triggered by a combination of light, radioactivity and overpressure, even if every nuclear-command center and all leadership were destroyed.[14]
Colonel General Andrian Danilevich, Assistant for Doctrine and Strategy to the Chief of the General Staff from 1984 to 1990, stated in 1992 that the Dead Hand had been contemplated, but that the Soviets considered automatic-trigger systems too dangerous. Furthermore, such systems became unnecessary with the advent of efficient early-warning systems and increased missile readiness, so the idea had been rejected.[15]
In 1993, Vitaly Katayev, Senior Advisor to the Chairman of the Defense Industry Department of the Central Committee of the Communist Party in 1967–85, responsible for strategic arms and defense policy, arms control negotiations and military doctrine, confirmed that the Dead Hand had been "definitely operational" by the early 1980s. According to Katayev, it was not completely automatic but was intended to be activated manually during a threatening crisis. It was to be triggered by numerous sensors sensitive to light, seismic shock, radiation or atmospheric density.[16]
Although both Katayev and Korobushin claimed that the mechanism had already been deployed, Viktor Surikov, Deputy Director of the Central Scientific Research Institute for General Machine Building (TsNIIMash) in 1976–92, confirmed in 1993 that the Soviets had designed the automatic launch system with seismic, light and radiation sensors, but said that the design had been ultimately rejected by Marshal Sergey Akhromeyev on advice of Korobushin and never materialized.[17]
Accounts differ as to the degree of automation of Dead Hand. In a 1993 issue of The New York Times:[18]
The dead-hand system he [Dr. Blair] describes today takes this defensive trend to its logical, if chilling, conclusion. The automated system in theory would allow Moscow to respond to a Western attack even if top military commanders had been killed and the capital incinerated.
Flying high over missile fields and other military sites, these rockets in turn would broadcast attack orders to missiles, bombers and, via radio relays, submarines at sea. Contrary to some Western beliefs, Dr. Blair says, many of Russia's nuclear-armed missiles in underground silos and on mobile launchers can be fired automatically.[18]
The communication missile would work similarly to the US Emergency Rocket Communications System (ERCS).
However, more recent sources indicate the system was semi-automatic. In a 2007 article, Ron Rosenbaum quotes Blair as saying that Dead Hand is "designed to ensure semi-automatic retaliation to a decapitating strike."[19] Rosenbaum writes, "Of course, there's a world of difference between a 'semi-automatic' doomsday device and the totally automatic—beyond human control—doomsday device."
And they [the Soviets] thought that they could help those leaders by creating an alternative system so that the leader could just press a button that would say: I delegate this to somebody else. I don't know if there are missiles coming or not. Somebody else decide.
Now, the Soviets had once thought about creating a fully automatic system. Sort of a machine, a doomsday machine, that would launch without any human action at all. When they drew that blueprint up and looked at it, they thought, you know, this is absolutely crazy.[20]
Current use
In 2011, the commander of the Russian Strategic Missile Forces, Sergey Karakaev [ru], in an interview with Komsomolskaya Pravda, confirmed the operational state of the Perimeter assessment and communication system.[21]
In 2018, Colonel General Viktor Yesin [ru], the former chief of Russia's Main Staff of the Strategic Missile Forces, stated that the Perimeter system might become ineffective in the wake of the United States' withdrawal from the Intermediate-Range Nuclear Forces Treaty.[22]
