Dead Hand System
Revision as of 15:44, 11 February 2019 by The Wrigley Guerrilla (Talk | contribs)
220px-DUGA_Radar_Array_near_Chernobyl%2C_Ukraine_2014.jpg (Duga-1 Radar Array, near Chernobyl, Ukraine. Theorized by some to be a Dead Hand System)
File:UVB-76-detail.jpg (UVB-76 Military Communications/Numbers Station, in Povarovo, Russia. Theorized to be a Dead Hand System)
System concept
Working principles
Upon activation and determination of the happening of a nuclear war, the system sends out a 15P011 command missile with a special 15B99 warhead which passes commands to open all silos and all command centers of the RVSN with appropriate receivers in flight. The command missile system is similar with the US Emergency Rocket Communications System.
Components
Commanding rocket:
Motivation
Operation
Accounts differ as to the degree of automation of Dead Hand. In a 1993 issue of The New York Times:[18]
The dead-hand system he [Dr. Blair] describes today takes this defensive trend to its logical, if chilling, conclusion. The automated system in theory would allow Moscow to respond to a Western attack even if top military commanders had been killed and the capital incinerated.
The communication missile would work similarly to the US Emergency Rocket Communications System (ERCS).
And they [the Soviets] thought that they could help those leaders by creating an alternative system so that the leader could just press a button that would say: I delegate this to somebody else. I don't know if there are missiles coming or not. Somebody else decide.
Now, the Soviets had once thought about creating a fully automatic system. Sort of a machine, a doomsday machine, that would launch without any human action at all. When they drew that blueprint up and looked at it, they thought, you know, this is absolutely crazy.
Current use
Sources
All sources courtesy of Wikipedia
