HF marine
See also: VHF marine band
| Band | Frequency Range |
| 2450-2850 kHz | MF 2 MHz marine band |
| 16460-17360 kHz | HF 16 MHz/17 MHz marine band - USB voice calling/distress 16420 kHz, DSC calling/distress 16804.5 kHz |
| 26175-28000 kHz | Various CB-like marine allocations found in this region (many SSB marine radios stop at 27500 kHz or 27.5 MHz) |
See also:
- VHF marine band
- Maritime Fax Transmissions
